    4. mihome-vacuum Adapter Karten werden nichtmehr geladen.
      Rushmed Most Active @Thomas Braun last edited by
      @thomas-braun Nein, was muss ich tun?
        Thomas Braun Most Active @Rushmed last edited by
        @rushmed
        Erstmal anschauen:
        cd /opt/iobroker/ && npm ls canvas
          @thomas-braun sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
          pi@Smartazamba:~ $ cd /opt/iobroker/ && npm ls canvas
          iobroker.inst@3.0.0 /opt/iobroker
          └─┬ iobroker.mihome-vacuum@4.2.0
            └── canvas@2.11.2
            @rushmed sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
            Versuch mal den Adapter drüberzuinstallieren.
            iob upgrade iobroker.mihome-vacuum@4.2.0 --debug
            • haselchen
              haselchen Most Active @Rushmed last edited by
              @rushmed
              Wenn du den Adapter startest, dann sollten canvas Warnungen kommen im Log und auch die Anweisung/Anleitung, was zu tun ist.
                Rushmed Most Active @haselchen last edited by Rushmed
                @haselchen Oha, da steh was:
                mihome-vacuum.0
                2024-07-18 22:59:44.831	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                Wie installier' ich die noch gleich? Auf der Adapterseite konnte ichs nichmehr finden.
                Edit: Hab was gefunden:
                https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum?tab=readme-ov-file#error-at-installation
                das probier' ich.
                  Rushmed Most Active @Rushmed last edited by Rushmed
                  @rushmed
                  pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
                  pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas
                  npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                  npm warn deprecated har-validator@5.1.5: this library is no longer supported
                  npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                  npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                  npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                  npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
                  npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm warn deprecated @humanwhocodes/config-array@0.11.14: Use @eslint/config-array instead
                  npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                  npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                  npm warn deprecated gauge@3.0.2: This package is no longer supported.
                  npm warn deprecated sinon@15.2.0: 16.1.1
                  added 420 packages, and audited 421 packages in 4m
                  54 packages are looking for funding
                   run `npm fund` for details
                  2 moderate severity vulnerabilities
                  Some issues need review, and may require choosing
                  a different dependency.
                  Run `npm audit` for details.
                  pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ cd /opt/iobroker/ && npm ls canvas
                  ├── canvas@2.11.2 extraneous
                    └── canvas@2.11.2
                  Edit:
                  Keine Ahnung wie das in den Post kommt:
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                    Rushmed Most Active last edited by
                    Danke, die Karten sind wieder da.
                    Woher weiß ich wann canvas Zuwendung braucht bevor tagelang keine Karte aktualisiert wird.
                    Bzw. Wann wird dieser Eingriff notwendig?
                    haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                    • haselchen
                      @rushmed
                      Das Log bei Updates und Installationen verfolgen....
                        Z. B. wenn sich die Major nodejs-Version ändert. Dann müssen gewisse Adapater/Module gegen die neue Version gebaut werden. Geht i.d.R. automatisch beim ersten Start einer Instanz.
                          @haselchen Ich kann mit der Forenhilfe solche Sachen handhaben. Aber es ist echt immer schwierig den ioBroker als sorgenfreies Smarthome an andere zu vermitteln.
                          • haselchen
                            @rushmed
                            Ich weiss, was Du meinst.
                            Das System permanent zu pflegen ist schon ne Aufgabe.
                            Neben Familie, Arbeit und anderen Hobbys...
                            Damit es Spass macht, nicht unter Druck setzen, permanent nach Updates zu gucken.
                            Jeder setzt das System anders ein.
                            Ich möchte ein wenig Automation, aber es soll nicht mein Leben bestimmen.
                            Ich denke, ich habe einen guten Mittelweg gefunden.
                              @rushmed
                              cd /opt/iobroker && npm prune
                              Dann wirst du den extraneous noch los.
                                Rushmed Most Active @Thomas Braun last edited by Rushmed
                                pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/ && npm ls canvas
                                  └── canvas@2.11.2
                                Ich küsse deine Augen!
                                Edit: Auch wieder so eine Sache, ich kümmer mich um sowas aber die meisten wollen das es einfach funktioniert. Kann mann dan icht mit "wenn Major Update mache XXX" im Hintergrund gleich alles geradeziehen?
                                  Das machen die Adapter wie gesagt i. d. R. automatisch. Funktioniert aber nicht immer.
                                    @thomas-braun Bitte nicht falsch verstehen, das ist keineswegs persönliche Kritik.
                                      Jetzt werden die Karten wieder nicht mehr angelegt.
                                      Beim Adapterstart kommt wieder:
                                      mihome-vacuum.0
                                      2024-07-19 11:52:02.734	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                                      Wie kann das sein?
                                        @rushmed
                                        Das Paket canvas muss wohl im Pfad von mihome-vaccuum installiert werden.
                                          @thomas-braun Ich hatte gestern die Anleitung befolgt und danach ging es ja auch.
                                            @rushmed
                                            Dann mach es nochmal.
                                            Es darf aber am Ende kein 'canvas' in der obersten Ebene des npm tree liegen.
                                            R P 2 Replies Last reply Reply Quote 0
                                            karte karten map mihome vacuum
                                            2642
