    4. mihome-vacuum Adapter Karten werden nichtmehr geladen.
      Rushmed Most Active @Rushmed last edited by Rushmed
      @rushmed
      pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
      pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
      npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated @humanwhocodes/config-array@0.11.14: Use @eslint/config-array instead
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
      npm warn deprecated gauge@3.0.2: This package is no longer supported.
      npm warn deprecated sinon@15.2.0: 16.1.1
      added 420 packages, and audited 421 packages in 4m
      54 packages are looking for funding
       run `npm fund` for details
      2 moderate severity vulnerabilities
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ cd /opt/iobroker/ && npm ls canvas
      iobroker.inst@3.0.0 /opt/iobroker
      ├── canvas@2.11.2 extraneous
      └─┬ iobroker.mihome-vacuum@4.2.0
        └── canvas@2.11.2
      Edit:
      Keine Ahnung wie das in den Post kommt:
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Rushmed Most Active last edited by
        Danke, die Karten sind wieder da.
        Woher weiß ich wann canvas Zuwendung braucht bevor tagelang keine Karte aktualisiert wird.
        Bzw. Wann wird dieser Eingriff notwendig?
        haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @Rushmed last edited by
          @rushmed
          Das Log bei Updates und Installationen verfolgen....
            Thomas Braun Most Active @Rushmed last edited by
            @rushmed sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
            Z. B. wenn sich die Major nodejs-Version ändert. Dann müssen gewisse Adapater/Module gegen die neue Version gebaut werden. Geht i.d.R. automatisch beim ersten Start einer Instanz.
              Rushmed Most Active @haselchen last edited by
              @haselchen Ich kann mit der Forenhilfe solche Sachen handhaben. Aber es ist echt immer schwierig den ioBroker als sorgenfreies Smarthome an andere zu vermitteln.
              • haselchen
                @rushmed
                Ich weiss, was Du meinst.
                Das System permanent zu pflegen ist schon ne Aufgabe.
                Neben Familie, Arbeit und anderen Hobbys...
                Damit es Spass macht, nicht unter Druck setzen, permanent nach Updates zu gucken.
                Jeder setzt das System anders ein.
                Ich möchte ein wenig Automation, aber es soll nicht mein Leben bestimmen.
                Ich denke, ich habe einen guten Mittelweg gefunden.
                  @rushmed
                  cd /opt/iobroker && npm prune
                  Dann wirst du den extraneous noch los.
                    Rushmed Most Active @Thomas Braun last edited by Rushmed
                    @thomas-braun sagte in mihome-vacuum Adapter Karten werden nichtmehr geladen.:
                    pi@Smartazamba:/opt/iobroker $ cd /opt/iobroker/ && npm ls canvas
                      └── canvas@2.11.2
                    Ich küsse deine Augen!
                    Edit: Auch wieder so eine Sache, ich kümmer mich um sowas aber die meisten wollen das es einfach funktioniert. Kann mann dan icht mit "wenn Major Update mache XXX" im Hintergrund gleich alles geradeziehen?
                      Das machen die Adapter wie gesagt i. d. R. automatisch. Funktioniert aber nicht immer.
                        @thomas-braun Bitte nicht falsch verstehen, das ist keineswegs persönliche Kritik.
                          Jetzt werden die Karten wieder nicht mehr angelegt.
                          Beim Adapterstart kommt wieder:
                          mihome-vacuum.0
                          2024-07-19 11:52:02.734	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                          Wie kann das sein?
                            @rushmed
                            Das Paket canvas muss wohl im Pfad von mihome-vaccuum installiert werden.
                              @thomas-braun Ich hatte gestern die Anleitung befolgt und danach ging es ja auch.
                                @rushmed
                                Dann mach es nochmal.
                                Es darf aber am Ende kein 'canvas' in der obersten Ebene des npm tree liegen.
                                R P 2 Replies Last reply Reply Quote 0
                                  Wie kann ich das prüfen?
                                    @rushmed
                                    Per
                                      pi@Smartazamba:~ $ cd /opt/iobroker/ && npm ls canvas
                                        └── canvas@2.11.2
                                      Hab jetzt noch nicht neu installiert aber die Ausgabe sieht doch gut aus, oder?
                                        @rushmed
                                        Ja, so soll das aussehen.
                                        Kann aber dennoch sein, das du das nochmal anlegen musst.
                                          Folgendes hab ich jetzt durchgeführt:
                                          • canvas nach Anleitung installiert, Adapter neu gestartet --> Kartenerstellung funktioniert.
                                          • cd /opt/iobroker && npm prune, Adapter neu gestartet --> Kartenerstellung funktioniert nicht.
                                          • cd /opt/iobroker && npm prune, Adapter neu gestartet --> Kartenerstellung funktioniert.
                                          • Adapter neu gestartet --> Kartenerstellung funktioniert nicht.
                                          Ich beobachte das jetzt mal weiter.
                                            Rushmed Most Active last edited by Rushmed
                                            Bei mir kommen weider seit vier Tagen keine Karten mehr über den Adapter. Weiß noch jemand Hilfe?
                                            Wie gesagt, Adapterstart bringt:
                                            mihome-vacuum.0
                                            2024-07-24 19:38:02.863	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum#error-at-installation
                                            Obwohl:
                                              └── canvas@2.11.2
                                            gut aussieht.
                                            Laut der Adapteranleitung soll Canvas hier liegen: /opt/iobroker/node_modules/iobroker.mihome-vacuum
                                            Die Installation funktioniert auch:
                                            pi@Smartazamba:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm ls canvas                                        iobroker.mihome-vacuum@4.2.0 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                                            └── canvas@2.11.2
                                            Edit:
                                            Jetz kommt die Warnmeldung beim Adapterstart wieder und:
                                            pi@Smartazamba:~ $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum && npm ls canvas
                                            └── (empty)
                                            Canvas ist in /opt/iobroker/node_modules/iobroker.mihome-vacuum scheinbar wieder verschwunden.
                                            Wie kann das sein? @mcm1957 und @dirkhe habt ihr noch ne Idee?
                                            karte karten map mihome vacuum
                                            2642
