    4. Homekit Adapter lässt sich nicht installieren
      Maddog-1 last edited by
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: pIOBroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 10 (buster)
                  Kernel: Linux 6.8.8-3-pve
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) N5095 @ 2.00GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       13:20:54 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Fri 2024-07-19 13:20:54 UTC
                 Universal time: Fri 2024-07-19 13:20:54 UTC
                       RTC time: n/a
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      manuel
      HOME=/home/manuel
      GROUPS=manuel sudo
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:           4.1G        1.5G        1.7G        8.0M        902M        2.6G
      Swap:          4.1G          0B        4.1G
      Total:         8.2G        1.5G        5.8G
      Active iob-Instances:   26
               4096 M total memory
               1524 M used memory
               1419 M active memory
                813 M inactive memory
               1668 M free memory
                  0 M buffer memory
                902 M swap cache
               4096 M total swap
                  0 M used swap
               4096 M free swap
      top - 13:20:55 up  1:16,  1 user,  load average: 0.42, 0.57, 0.39
      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  3.1 us,  3.1 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,   1668.5 free,   1525.0 used,    902.5 buff/cache
      MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   2562.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       32G  5.1G   25G  18% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     7.8G  8.1M  7.7G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                SOURCE                           FSTYPE     OPTIONS
      /                                     /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,mode=755,uid=100000,gid=100000,inode64
      | `-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
      | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/.lxc/proc                    proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                     sys                              sysfs      rw,relatime
      | |-/dev/full                         udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/null                         udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/random                       udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/tty                          udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/urandom                      udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/zero                         udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8043388k,nr_inodes=2010847,mode=755,inode64
      | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                         devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                         devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      419M    /var/
      235M    /var/cache
      231M    /var/cache/apt
      181M    /var/lib
      169M    /var/cache/apt/archives
            Users in the 'systemd-journal' group can see all messages. Pass -q to
            turn off this notice.
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      705M    /opt/iobroker/iobroker-data/
      568M    /opt/iobroker/iobroker-data/files
      149M    /opt/iobroker/iobroker-data/files/vis-2
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
      24M     /opt/iobroker/iobroker-data/files/eventlist.admin/static/js/main.bf7d9efc.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22559e53cd9ded11af12dca5a7669f5d-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.15.1
      /usr/bin/node           v20.15.1
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.1
      nodejs:
        Installed: 20.15.1-1nodesource1
        Candidate: 20.15.1-1nodesource1
        Version table:
       *** 20.15.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u4 500
              500 http://security.debian.org buster/updates/main amd64 Packages
           10.24.0~dfsg-1~deb10u1 500
              500 http://ftp.debian.org/debian buster/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.17.14
      javascript:     8.3.1
      nodejs modules from github:     2
      +-- iobroker.gotify@0.2.0 (git+ssh://git@github.com/ThomasPohl/ioBroker.gotify.git#c20ff9a8867b6b452a30b947c005fd7b6f42b41d)
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : pIOBroker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : pIOBroker                                -  enabled
      + system.adapter.backitup.0               : backitup              : pIOBroker                                -  enabled
        system.adapter.daswetter.0              : daswetter             : pIOBroker                                -  enabled
        system.adapter.discovery.0              : discovery             : pIOBroker                                - disabled
        system.adapter.dwd.0                    : dwd                   : pIOBroker                                -  enabled
      + system.adapter.eventlist.0              : eventlist             : pIOBroker                                -  enabled
      + system.adapter.firetv.0                 : firetv                : pIOBroker                                -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : pIOBroker                                -  enabled
      + system.adapter.gotify.0                 : gotify                : pIOBroker                                -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : pIOBroker                                -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : pIOBroker                                -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : pIOBroker                                -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pIOBroker                                -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pIOBroker                                -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : pIOBroker                                - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pIOBroker                                - disabled
      + system.adapter.javascript.0             : javascript            : pIOBroker                                -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : pIOBroker                                -  enabled
      + system.adapter.node-red.0               : node-red              : pIOBroker                                -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.pi-hole.0                : pi-hole               : pIOBroker                                -  enabled
      + system.adapter.ping.0                   : ping                  : pIOBroker                                -  enabled
      + system.adapter.proxmox.0                : proxmox               : pIOBroker                                -  enabled, port: 8006
      + system.adapter.signal-cmb.0             : signal-cmb            : pIOBroker                                -  enabled
      + system.adapter.synology.0               : synology              : pIOBroker                                -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : pIOBroker                                -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : pIOBroker                                -  enabled
      + system.adapter.telegram.0               : telegram              : pIOBroker                                -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : pIOBroker                                - disabled
      + system.adapter.trashschedule.0          : trashschedule         : pIOBroker                                -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : pIOBroker                                -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pIOBroker                                - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : pIOBroker                                -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : pIOBroker                                -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : pIOBroker                                - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : pIOBroker                                - disabled
        system.adapter.vis-weather.0            : vis-weather           : pIOBroker                                - disabled
        system.adapter.vis.0                    : vis                   : pIOBroker                                -  enabled
      + system.adapter.web.0                    : web                   : pIOBroker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : pIOBroker                                -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
      Objects and States
      Objects:        8340
      States:         7148
      Hit:1 http://security.debian.org buster/updates InRelease
      Hit:2 http://ftp.debian.org/debian buster InRelease
      Hit:3 http://ftp.debian.org/debian buster-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      105        351606     93/systemd-resolved
      tcp        0      0 192.168.1.126:2010      0.0.0.0:*               LISTEN      1000       398547     5104/io.hm-rpc.1
      tcp        0      0 192.168.1.126:2001      0.0.0.0:*               LISTEN      1000       398483     5089/io.hm-rpc.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          351918     279/master
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       396467     4898/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       394973     4898/iobroker.js-co
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      105        351600     93/systemd-resolved
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          345978     1/init
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       396717     4973/node-red
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       396593     4916/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       401823     5307/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          351919     279/master
      tcp6       0      0 :::5355                 :::*                    LISTEN      105        351603     93/systemd-resolved
      tcp6       0      0 :::22                   :::*                    LISTEN      0          350584     1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          345980     1/init
      tcp6       0      0 :::80                   :::*                    LISTEN      1000       396720     4973/node-red
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           105        351599     93/systemd-resolved
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           105        351605     93/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          345979     1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       396721     4973/node-red
      udp6       0      0 :::5355                 :::*                                105        351602     93/systemd-resolved
      udp6       0      0 :::111                  :::*                                0          345981     1/init
      2024-07-19 13:13:05.365  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:05;CALL;1;11;913872;6929;SIP1;
      2024-07-19 13:13:09.324  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:13:09;CONNECT;1;11;6929;
      2024-07-19 13:15:00.021  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8529
      2024-07-19 13:15:01.020  - info: dwd.0 (8529) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
      2024-07-19 13:15:02.450  - info: dwd.0 (8529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-07-19 13:15:02.964  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-19 13:15:04.067  - info: host.pIOBroker instance system.adapter.daswetter.0 started with pid 8547
      2024-07-19 13:15:04.888  - info: daswetter.0 (8547) starting. Version 3.1.15 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.15.1, js-controller: 5.0.19
      2024-07-19 13:15:07.049  - info: daswetter.0 (8547) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2024-07-19 13:15:07.556  - info: daswetter.0 (8547) cleaned everything up...
      2024-07-19 13:15:07.565  - info: host.pIOBroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-19 13:16:42.242  - info: fritzbox.0 (5059) data from 192.168.1.1: 19.07.24 15:16:42;DISCONNECT;1;213;
      2024-07-19 13:20:00.012  - info: host.pIOBroker instance system.adapter.dwd.0 started with pid 8675
      2024-07-19 13:20:00.885  - info: dwd.0 (8675) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.15.1, js-controller: 5.0.19
      2024-07-19 13:20:02.041  - info: dwd.0 (8675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-07-19 13:20:02.556  - info: host.pIOBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-07-19 13:20:04.027  - info: host.pIOBroker instance system.adapter.meteoalarm.0 started with pid 8693
      2024-07-19 13:20:05.927  - info: meteoalarm.0 (8693) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v20.15.1, js-controller: 5.0.19
      2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) 15.1: Updated Weather Alarms for Kreis Kronach -> 0 alarm(s) found
      2024-07-19 13:20:07.845  - info: meteoalarm.0 (8693) Terminated (ADAPTER_REQUESTED_TERMINATION): All data processed. Adapter stopped until next scheduled process.
      2024-07-19 13:20:08.376  - info: host.pIOBroker instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        Homoran Global Moderator Administrators @Maddog-1 last edited by Homoran
        @maddog-1 sagte in Homekit Adapter lässt sich nicht installieren:
        also doch.
        dann frag ich mich auch wo da nodejs v20 herkommt
        Pending Updates: 0
        aber nur, weil keine mehr angeboten werden
          Maddog-1 @Homoran last edited by
          hatte vorhin das iob Nodejs-Update gemacht, ich war der aus dem anderen Beitrag mit dem Problem das ich als Root user das Update nicht machen konnte
            @maddog-1 aber wie auch @Thomas-Braun schrieb sollte es für Buster gar nicht mehr gebaut werden.
              Thomas Braun Most Active @Maddog-1 last edited by Thomas Braun
              @maddog-1
              Deine Systemzeit ist falsch.
              Setz das auf die richtige Zeitzone.
              Der user 'manuel' fehlt in der Gruppe 'iobroker' (und ggfls. noch weiteren).
              Boot Target: graphical.target
              Sollte auf multi-user.target gesetzt werden.
              @Homoran
              Gut möglich, dass nur ein Raspberry 'Buster' davon betroffen ist. Die waren damals auch noch weiter von der Debian-Basis weg als heute.
              Aber nichts destotrotz ist Buster einfach 'end-of-life' und muss durch ein noch lebendes Release ersetzt werden.
                da bin ich überfragt, hatte nur den Befehl ausgeführt
                iob nodejs-update
                  Das geht im Moment noch, in einer kommenden Version wird das auf keinem Buster-basierendem System mehr möglich sein.
                    Maddog-1 @Thomas Braun last edited by
                    gibt es da noch einen anderen befehl für die Zeitzone?
                    dpkg-reconfigure tzdata
                    der den ich gerade über google gefunden habe funktioniert nicht
                    das mit dem user in den gruppen und multi user Target muss ich auch erstmal googeln, da hab ich keinen plan hab vorhin nur nach deinem anderen Beitrag den User angelegt
                      Maddog-1 @Maddog-1 last edited by
                      ok das mit der Zeitzone hat sich erledigt, hatte das Sudo vergessen, bin ja jetzt kein root mehr
                        @maddog-1
                        Zeitzone
                        sudo timedatectl set-timezone Europe/Berlin
                        Über tzdata geht's aber auch.
                        User Gruppen:
                        sudo usermod -aG adm,dialout,sudo,audio,video,plugdev,users,iobroker DEIN_USERNAME
                        exit
                        Boot Target:
                        sudo systemctl set-default multi-user.target
                          @thomas-braun said in Homekit Adapter lässt sich nicht installieren:
                          super, Dankeschön, hat alles funktioniert
                          zum thema Update,
                          kann man das 1 zu 1 von hier übernehmen
                          https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                          oder gibts ne andere vorgehensweise für nen Proxmox container
                          oder eben ganz neu aufsetzten
                            @maddog-1
                            Container sind Wegwerfartikel. Das ist wohl am einfachsten und schnellsten, da einen aktuellen Container drüberzustülpen als zwei Dist-Upgrades zu fahren, bis du dann auf Debian 12 Bookworm bist.
                              ok dann werde ich mich mal wenn ich frei hab dran setzen
                              Danke für die Hilfe
                              1250
