    4. ssh Verbindung aufgebaut; Web-Oberfläche öffnet jedoch nicht
      Homoran Global Moderator Administrators @Berserker last edited by
      @berserker sagte in ssh Verbindung aufgebaut; Web-Oberfläche öffnet jedoch nicht:
      mit
      ...8081
      wäre der Admin.
      es kommt nichts.
      heisst genau was?
      schwarzer Bildschirm?
      bluescreen?
      Berserker 1 Reply Last reply Reply Quote 0
      • Berserker
        Berserker @Homoran last edited by
        @Thomas-Braun
        Hier einmal die Ausgabe:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: pi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.17-v7l+
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         16:50:39 up 51 min,  1 user,  load average: 0.76, 1.00, 0.77
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-07-19 16:50:39 CEST
                   Universal time: Fri 2024-07-19 14:50:39 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           3.8G        850M        2.4G         24M        539M        2.8G
        Swap:           99M          0B         99M
        Total:         3.9G        850M        2.5G
        Active iob-Instances: 	18
                 3827 M total memory
                  850 M used memory
                  305 M active memory
                  985 M inactive memory
                 2436 M free memory
                   72 M buffer memory
                  466 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 16:50:39 up 51 min,  1 user,  load average: 0.76, 1.00, 0.77
        Tasks: 147 total,   2 running, 145 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 38.6 us, 15.7 sy,  0.0 ni, 40.0 id,  0.0 wa,  0.0 hi,  5.7 si,  0.0 st
        MiB Mem :   3827.3 total,   2437.2 free,    850.5 used,    539.5 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2813.9 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  5.7G   23G  21% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     383M     0  383M   0% /run/user/1000
        [Fri Jul 19 15:58:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:9C:D8:DF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  115200 console=tty1 root=PARTUUID=39767051-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Jul 19 15:58:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Jul 19 15:59:01 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE     OPTIONS
        /                                     /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=1827468k,nr_inodes=97607,mode=755
        | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
        |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
        | `-/sys/kernel/config                configfs       configfs   rw,relatime
        |-/proc                               proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=391912k,mode=700,uid=1000,gid=1000
        `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        514M	/var/
        313M	/var/cache
        308M	/var/cache/apt
        249M	/var/cache/apt/archives
        98M	/var/lib
        Archived and active journals take up 24.0M in the file system.
        /opt/iobroker/backups:
        159M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G	/opt/iobroker/iobroker-data/
        560M	/opt/iobroker/iobroker-data/sonosCache
        213M	/opt/iobroker/iobroker-data/files
        151M	/opt/iobroker/iobroker-data/backup-objects
        138M	/opt/iobroker/iobroker-data/files/javascript.admin
        24M	/opt/iobroker/iobroker-data/objects.jsonl
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        15M	/opt/iobroker/iobroker-data/states.jsonl
        8.5M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        7.9M	/opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2215643-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.12.1
        /usr/bin/node 		v18.12.1
        /usr/bin/npm 		8.19.2
        /usr/bin/npx 		8.19.2
        /usr/bin/corepack 	0.14.2
        nodejs:
          Installed: 18.12.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
             18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
         *** 18.12.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.19
        admin: 		6.17.14
        javascript: 	8.3.1
        nodejs modules from github: 	1
        +-- iobroker.eufy-security@0.5.5 (git+ssh://git@github.com/bropat/ioBroker.eufy-security.git#0a15e1d125f4fd00144af66d57d8d738140ea619)
        Adapter State
        + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alarm.0                  : alarm                 : pi                                       - disabled
        + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
        + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
        + system.adapter.deconz.0                 : deconz                : pi                                       -  enabled, port: 80
        + system.adapter.discovery.0              : discovery             : pi                                       -  enabled
          system.adapter.eusec.0                  : eusec                 : pi                                       - disabled
        + system.adapter.history.0                : history               : pi                                       -  enabled
        + system.adapter.homee.0                  : homee                 : pi                                       -  enabled
        + system.adapter.hue.0                    : hue                   : pi                                       -  enabled, port: 443
        + system.adapter.hue.1                    : hue                   : pi                                       -  enabled, port: 443
        + system.adapter.info.0                   : info                  : pi                                       -  enabled
        + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
        + system.adapter.meross.0                 : meross                : pi                                       -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : pi                                       -  enabled
          system.adapter.spotify-premium.0        : spotify-premium       : pi                                       - disabled
        + system.adapter.terminal.0               : terminal              : pi                                       -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : pi                                       -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alarm"        : 3.6.1    , installed 3.6.1
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "deconz"       : 1.4.1    , installed 1.4.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "eusec"        : 1.2.1    , installed 1.2.1
        Adapter    "homee"        : 1.2.0    , installed 1.2.0
        Adapter    "hue"          : 3.11.0   , installed 3.11.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Adapter    "link"         : 0.5.12   , installed 0.5.12
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mielecloudservice": 6.5.6, installed 6.5.6
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
        Adapter    "roborock"     : 0.6.4    , installed 0.6.4
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        Objects: 	7493
        States: 	6299
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://phoscon.de/apt/deconz buster InRelease
        Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        Pending Updates: 224
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:36217         0.0.0.0:*               LISTEN      1001       36548      6318/io.yahka.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       38023      5906/io.mqtt.0
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16184      376/deCONZ
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       35498      5339/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       35490      5339/iobroker.js-co
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       16182      376/deCONZ
        tcp        0      0 127.0.0.1:38897         0.0.0.0:*               LISTEN      1001       97836      6318/io.yahka.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14237      695/sshd
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       39202      6227/io.terminal.0
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       35933      5791/io.sonos.0
        tcp6       0      0 :::42703                :::*                    LISTEN      1001       37766      6318/io.yahka.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53810      11320/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39378      6266/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14239      695/sshd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14065      687/dhcpcd
        udp        0      0 0.0.0.0:55004           0.0.0.0:*                           108        16749      378/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16747      378/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       37106      5834/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16187      376/deCONZ
        udp6       0      0 :::35340                :::*                                108        16750      378/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14087      687/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        16748      378/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       37108      5834/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       37107      5834/io.deconz.0
        2024-07-19 16:10:01.231  - info: homee.0 (6113) initialize 1 homeegrams
        2024-07-19 16:13:00.842  - info: host.pi "system.adapter.admin.0" disabled
        2024-07-19 16:13:00.845  - info: host.pi stopInstance system.adapter.admin.0 (force=false, process=true)
        2024-07-19 16:13:00.852  - info: host.pi stopInstance system.adapter.admin.0 send kill signal
        2024-07-19 16:13:00.851  - info: admin.0 (5387) Got terminate signal TERMINATE_YOURSELF
        2024-07-19 16:13:00.858  - info: admin.0 (5387) terminating https server on port 8081
        2024-07-19 16:13:00.861  - info: admin.0 (5387) terminating
        2024-07-19 16:13:00.863  - info: admin.0 (5387) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-07-19 16:13:01.364  - info: admin.0 (5387) terminating
        2024-07-19 16:13:01.509  - info: host.pi instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-07-19 16:13:41.735  - info: host.pi "system.adapter.admin.0" enabled
        2024-07-19 16:13:41.883  - info: host.pi instance system.adapter.admin.0 started with pid 11320
        2024-07-19 16:13:45.639  - info: admin.0 (11320) starting. Version 6.17.14 in /opt/iobroker/node_modules/iobroker.admin, node: v18.12.1, js-controller: 5.0.19
        2024-07-19 16:13:45.720  - info: admin.0 (11320) requesting all objects
        2024-07-19 16:13:47.668  - info: admin.0 (11320) received all objects
        2024-07-19 16:13:48.019  - info: admin.0 (11320) Request actual repository...
        2024-07-19 16:13:48.167  - info: admin.0 (11320) Secure socket.io server listening on port 8081
        2024-07-19 16:13:48.189  - info: admin.0 (11320) https server listening on port 8081
        2024-07-19 16:13:48.190  - info: admin.0 (11320) Use link "https://127.0.0.1:8081" to configure.
        2024-07-19 16:13:48.645  - info: host.pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2024-07-19 16:13:51.158  - info: admin.0 (11320) Repository received successfully.
        2024-07-19 16:25:30.509  - info: hue.1 (5746) Started scene: Scene Gedimmt
        2024-07-19 16:42:01.370  - info: hue.1 (5746) Started scene: Scene Gedimmt
        2024-07-19 16:48:16.663  - info: hue.1 (5746) Started scene: Scene Gedimmt
        2024-07-19 16:50:02.060  - info: hue.1 (5746) Started scene: Scene Gedimmt
        Die Seite wird nicht gefunden, also er öffnet garnichts.
        Thomas Braun Homoran Ro75 6 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Berserker last edited by
          Zu ALT.
          Installier da KOMPLETT FRISCH NEU ein Raspberry OS 12 'Bookworm'.
            ist das eine Meldung?
            im Browser?
            wie genau?
              du hast einen Schaden im Dateisystem, besser: mindestens 8
              • Berserker
                Es bleibt quasi so im Browser hängen
                Ohne irgendeinen Output
                  Dein Dateisystem hatte Einschläge. Aber kein Problem, du musst es ja eh neuinstallieren, Backup rein und gut ist.
                  Dann wird auch das nodesource-Repository das richtige sein.
                  hust
                  • Ro75
                    Ro75 @Berserker last edited by
                    [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): 8 orphan inodes deleted [Fri Jul 19 15:58:58 2024] EXT4-fs (mmcblk0p2): recovery complete
                    Deine SD-Karte bzw. das Dateisystem hat einen Treffer. Neue Karte, neue installation Debian 12 (Bookworm), 64 BIT, Lite Version ohne Desktop.
                    Ro75.
                      ist das https? und port 8081?
                      ich sehe beides nicht
                      • Berserker
                        Ja
                        https://192.168.1.242:8081/?login&href=#tab-intro
                        @Thomas-Braun
                        Ohh man, das letzte Backup ist von April 😞
                        @Ro75
                        Ist eine neue SD zwangsweise nötig?
                        Homoran Ro75 Thomas Braun 3 Replies Last reply Reply Quote 0
                          lass den ganzen Zinnober nach dem Port mal weg
                          • Berserker
                            hatte ich auch schon ausprobiert, leider ohne erfolg
                              @berserker dann war es das wahrscheinlich erstmal.
                              willst du riskieten auf einem wurmstichigen Datenträger zu arbeiten?
                              • Ro75
                                In meinen Augen definiv. Kostet nicht die Welt. Nimm eine GRÖßERE. Damit die (Über)schreibrate pro Zelle kleiner ist. Ein Komplettbackup? aus April würde ich nicht einsetzen, da dort schon Fehler drin sein können.
                                Backup mittels Backitup hast du doch? Wenn ja, aktuelles zu Seite legen, notieren was alles jetzt drauf ist und NEU installieren. Alles andere ist nur Kosmetik und der Lack blättert dann gleich wieder ab - verlorene Zeit.
                                Ro75.
                                Berserker 1 Reply Last reply Reply Quote 1
                                  Man könnte noch Versuche etwas zu retten, indem man ggf. controller und admin neu installiert.
                                  ob es dann Sinn ergibt ein Backup zu fahren ist fraglich.
                                  ggf. ist es besser als gar nichts.
                                  • Berserker
                                    Berserker @Ro75 last edited by
                                    @ro75
                                    genau ich habe von Backitup ein Backup aus April
                                    Das kann ich aber ohne Probleme danach wieder rauf spielen ?
                                    @Homoran
                                    alles klar, dann ne neue
                                    Homoran Ro75 2 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @Berserker last edited by Homoran
                                      was für ein Backup?
                                      edit: backitup... gut!
                                      controller v5 ... gut
                                      admin v6 .... gut!
                                      müsste klappen
                                      @homoran sagte in ssh Verbindung aufgebaut; Web-Oberfläche öffnet jedoch nicht:
                                      das kann aber auch das Dateisystem noch weiter schädigen
                                      • Ro75
                                        wenn du bereits im April
                                        bei diesem Backup diese Version vom js-controller aktiv hattest und den nicht erst danach aktualisiert hast - wird es keine Probleme geben.
                                        Ro75.
                                          Alter Spruch: Kein Backup, kein Mitleid... Der Backitup-Adapter legt dir jede Nacht eins an. Musst du nur einstellen.
                                          • Berserker
                                            Berserker @Thomas Braun last edited by
                                            @thomas-braun Hatte ich eingestellt, nur schaltet der sich bei mir ab und zu ab
                                            Ich habe nun auf eine neue SD Karte eine neu Version aufgespielt und IOBroker neu installiert. Habe alle Adapter heruntergeladen und anschließend von Backitup das Backup gezogen. Nun wurde neugestartet und es ist wieder kein Zugriff auf die Web Oberfläche 😞
                                            Ich kann nicht einmal eine ssh Verbindung aufbauen (allerdings könnte das auch schon vor backitup der fall gewesen sein)
                                            Homoran Thomas Braun 4 Replies Last reply Reply Quote 0
                                            1364
