    4. iobroker cmd in Konsole geht nicht
      hukio @Thomas Braun last edited by
      pi@raspibull:~ $ sudo systemctl mask iobroker.service
      Created symlink /etc/systemd/system/iobroker.service → /dev/null.
      pi@raspibull:~ $ sudo systemctl unmask iobroker.service
      Removed /etc/systemd/system/iobroker.service.
        Thomas Braun Most Active @hukio last edited by
        @hukio
        Da frag ich mir nur... WARUM??
        Mit dpgk direkt hast du in der Regel nix am Hut.
        systemctl status iobroker.service
        sagt nun?
          pi@raspibull:~ $ systemctl status iobroker.service
          ● iobroker.service
               Loaded: masked (Reason: Unit iobroker.service is masked.)
               Active: inactive (dead)
          weil ich einen Fehler mit dpkg hatte.
            @hukio sagte in iobroker cmd in Konsole geht nicht:
            Und genau was wurde von dpkg bemängelt?
            sudo apt install --reinstall nodejs
            sudo reboot
              pi@raspibull:~ $ sudo apt install --reinstall nodejs
              Reading package lists... Done
              Building dependency tree... Done
              0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
              Need to get 0 B/28.9 MB of archives.
              After this operation, 0 B of additional disk space will be used.
              (Reading database ... 59474 files and directories currently installed.)
              Preparing to unpack .../nodejs_18.20.4-1nodesource1_arm64.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (18.20.4-1nodesource1) over (18.20.4-1nodesource1) ...
              Setting up nodejs (18.20.4-1nodesource1) ...
              Processing triggers for man-db (2.9.4-2) ...
              nach reboot iobroker startet nicht. cmd geht nicht
                Thomas Braun Most Active @hukio last edited by Thomas Braun
                @hukio
                sudo -u iobroker id
                Jag den Fixer mal über das System:
                curl -fsL https://iobroker.net/fix.sh | bash -
                  Das war es! cmd und iobroker laufen wieder.
                  pi@raspibull:~ $ sudo -u iobroker id
                  uid=1001(iobroker) gid=1001(iobroker) groups=1001(iobroker),5(tty),20(dialout),29(audio),44(video),46(plugdev),112(bluetooth),114(redis),997(gpio),998(i2c)
                  ● iobroker.service
                  pi@raspibull:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  Library version=2024-05-24
                      Welcome to the ioBroker installation fixer!
                      Script version: 2024-01-04
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                  Done.
                      Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                  Compressed 1 JSONL files. Done
                      Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  Vielen Dank für die Mühe. Ich frage immer zu spät, bzw. ich versuche es erst mal selbst. Habe aber nicht den background.
                  Nochmals Danke
                  HUK
                    @hukio
                    Dann bring die Kiste nun auf nodejs@20 und zeig dann nochmal die Langfassung von
                    iob nodejs-update 20
                    iob diag
                      Sorry, hab erst mal einen Kaffee zur Entspannung getrunken.
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                         Static hostname: raspibull
                               Icon name: computer
                        Operating System: Debian GNU/Linux 11 (bullseye)
                                  Kernel: Linux 6.1.21-v8+
                            Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       19:59:36 up  1:20,  3 users,  load average: 1.59, 1.72, 1.53
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Fri 2024-07-19 19:59:36 CEST
                                 Universal time: Fri 2024-07-19 17:59:36 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
                      *** Display-Server-Setup ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            3.8G        2.0G        535M        1.0M        1.2G        1.8G
                      Swap:           2.0G          0B        2.0G
                      Total:          5.8G        2.0G        2.6G
                      Active iob-Instances:   30
                               3793 M total memory
                               2037 M used memory
                               2141 M active memory
                                844 M inactive memory
                                535 M free memory
                                122 M buffer memory
                               1098 M swap cache
                               2027 M total swap
                                  0 M used swap
                               2027 M free swap
                      top - 19:59:36 up  1:20,  3 users,  load average: 1.59, 1.72, 1.53
                      Tasks: 196 total,   2 running, 194 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  8.1 us,  4.1 sy,  0.0 ni, 87.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3793.3 total,    535.2 free,   2037.4 used,   1220.7 buff/cache
                      MiB Swap:   2028.0 total,   2028.0 free,      0.0 used.   1797.4 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4       30G   20G  8.2G  71% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                      /dev/sda3      ext4      439G  3.9G  413G   1% /mnt/hukdata
                      /dev/sda1      vfat      256M   32M  225M  13% /boot
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Fri Jul 19 18:39:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:12:1E:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=4d904d30-02 rootfstype=ext4 fsck.repair=yes rootwait rootdelay=5
                      [Fri Jul 19 18:39:31 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Fri Jul 19 18:39:31 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Fri Jul 19 18:39:33 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      [Fri Jul 19 18:39:35 2024] EXT4-fs (sda3): mounted filesystem with ordered data mode. Quota mode: none.
                      Show mounted filesystems:
                      TARGET                       SOURCE     FSTYPE     OPTIONS
                      /                            /dev/sda2  ext4       rw,noatime
                      |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                      |-/proc                      proc       proc       rw,relatime
                      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                      | `-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                      |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                      | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                      | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                      | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                      |-/mnt/hukdata               /dev/sda3  ext4       rw,noatime
                      `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      5.9G    /var/
                      3.1G    /var/log
                      3.0G    /var/log/journal/1ffd49df1b3a44ffb614b2c58029c285
                      660M    /var/cache
                      Archived and active journals take up 2.9G in the file system.
                      /opt/iobroker/backups:
                      7.2G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      871M    /opt/iobroker/iobroker-data/
                      356M    /opt/iobroker/iobroker-data/files
                      342M    /opt/iobroker/iobroker-data/history
                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                      129M    /opt/iobroker/iobroker-data/backup-objects
                      42M     /opt/iobroker/iobroker-data/objects.jsonl
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
                      HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                      /dev/ttyUSB0
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.15.1
                      /usr/bin/node           v20.15.1
                      /usr/bin/npm            10.7.0
                      /usr/bin/npx            10.7.0
                      /usr/bin/corepack       0.28.1
                      nodejs:
                        Installed: 20.15.1-1nodesource1
                        Candidate: 20.15.1-1nodesource1
                        Version table:
                       *** 20.15.1-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                              100 /var/lib/dpkg/status
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           12.22.12~dfsg-1~deb11u4 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: redis
                      Core adapters versions
                      js-controller:  5.0.19
                      admin:          6.17.14
                      javascript:     8.3.1
                      nodejs modules from github:     1
                      +-- iobroker.rtspstream@0.0.4 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#adff9611d3ab1871cd94d2e779b9fd4fcc937353)
                      Adapter State
                        system.adapter.adb.0                    : adb                   : raspibull                                - disabled
                      + system.adapter.admin.0                  : admin                 : raspibull                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : raspibull                                -  enabled
                      + system.adapter.backitup.0               : backitup              : raspibull                                -  enabled
                        system.adapter.broadlink2.0             : broadlink2            : raspibull                                - disabled
                      + system.adapter.daikin.0                 : daikin                : raspibull                                -  enabled
                      + system.adapter.daikin.1                 : daikin                : raspibull                                -  enabled
                        system.adapter.discovery.0              : discovery             : raspibull                                - disabled
                      + system.adapter.doorbird.0               : doorbird              : raspibull                                -  enabled
                      + system.adapter.email.0                  : email                 : raspibull                                -  enabled
                      + system.adapter.email.1                  : email                 : raspibull                                - disabled
                        system.adapter.flot.0                   : flot                  : raspibull                                - disabled
                      + system.adapter.fritzdect.0              : fritzdect             : raspibull                                -  enabled
                        system.adapter.fullybrowser.0           : fullybrowser          : raspibull                                - disabled
                      + system.adapter.history.0                : history               : raspibull                                -  enabled
                      + system.adapter.influxdb.0               : influxdb              : raspibull                                -  enabled, port: 8086
                      + system.adapter.iot.0                    : iot                   : raspibull                                -  enabled
                      + system.adapter.iqontrol.0               : iqontrol              : raspibull                                -  enabled
                      + system.adapter.javascript.0             : javascript            : raspibull                                -  enabled
                      + system.adapter.lgtv.0                   : lgtv                  : raspibull                                -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : raspibull                                -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.netatmo.0                : netatmo               : raspibull                                -  enabled
                      + system.adapter.nuki-extended.0          : nuki-extended         : raspibull                                -  enabled
                      + system.adapter.onkyo.0                  : onkyo                 : raspibull                                -  enabled
                        system.adapter.onvif.0                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                        system.adapter.onvif.1                  : onvif                 : raspibull                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                        system.adapter.ping.0                   : ping                  : raspibull                                - disabled
                        system.adapter.robonect.0               : robonect              : raspibull                                - disabled
                      + system.adapter.scenes.0                 : scenes                : raspibull                                -  enabled
                      + system.adapter.shelly.0                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : raspibull                                -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.signal-cmb.0             : signal-cmb            : raspibull                                -  enabled
                      + system.adapter.simple-api.0             : simple-api            : raspibull                                -  enabled, port: 8087, bind: 192.168.178.78, run as: admin
                      + system.adapter.socketio.0               : socketio              : raspibull                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : raspibull                                -  enabled, port: 1889, bind: 0.0.0.0
                        system.adapter.telegram.0               : telegram              : raspibull                                - disabled, port: 8443, bind: 0.0.0.0
                        system.adapter.text2command.0           : text2command          : raspibull                                - disabled
                      + system.adapter.tr-064.0                 : tr-064                : raspibull                                -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspibull                                - disabled
                      + system.adapter.web.0                    : web                   : raspibull                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : raspibull                                -  enabled, port: /dev/ttyUSB0
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "adb"          : 0.0.7    , installed 0.0.7
                      Adapter    "admin"        : 6.17.14  , installed 6.17.14
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                      Adapter    "doorbird"     : 1.6.0    , installed 1.6.0
                      Adapter    "email"        : 1.3.1    , installed 1.3.1
                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                      Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                      Adapter    "robonect"     : 1.3.6    , installed 1.3.6
                      Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                      Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "ws"           : 2.6.1    , installed 2.6.1
                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                      Objects and States
                      Objects:        11797
                      States:         8235
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:6 https://repos.influxdata.com/debian stable InRelease
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13736      778/influxd
                      tcp        0      0 192.168.178.78:8087     0.0.0.0:*               LISTEN      1001       65522      7315/io.simple-api.
                      tcp        0      0 192.168.178.78:8100     0.0.0.0:*               LISTEN      1001       66435      7184/io.doorbird.0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14502      555/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       79079      9094/adb
                      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       68076      7113/io.sonoff.0
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       67385      7177/io.shelly.1
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66341      7080/io.mqtt.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65132      6872/iobroker.js-co
                      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        12228      538/redis-server 12
                      tcp6       0      0 :::3000                 :::*                    LISTEN      111        13919      1039/grafana
                      tcp6       0      0 :::51989                :::*                    LISTEN      1001       65452      7094/io.nuki-extend
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14513      555/sshd: /usr/sbin
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        1980       778/influxd
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       67467      7339/io.socketio.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       67486      7363/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       65204      6894/io.admin.0
                      tcp6       0      0 ::1:6379                :::*                    LISTEN      110        12229      538/redis-server 12
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14420      430/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       67442      7112/io.shelly.0
                      udp        0      0 0.0.0.0:46765           0.0.0.0:*                           1001       88232      7095/io.onkyo.0
                      udp        0   1536 0.0.0.0:59344           0.0.0.0:*                           1001       88278      7095/io.onkyo.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13663      774/dhcpcd
                      udp        0      0 0.0.0.0:45133           0.0.0.0:*                           108        14422      430/avahi-daemon: r
                      udp6       0      0 :::54489                :::*                                108        14423      430/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        14421      430/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          13675      774/dhcpcd
                      2024-07-19 19:51:34.258  - info: shelly.0 (7112) [CoAP] Device 192.168.178.51 (shellyswitch / shellyswitch-135140 / SHSW-21#135140#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:35.002  - info: shelly.0 (7112) [CoAP] Device 192.168.178.49 (shellyswitch / shellyswitch-134FB4 / SHSW-21#134FB4#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:35.066  - info: shelly.0 (7112) [CoAP] Device 192.168.178.79 (shelly1 / shelly1-500291F06303 / SHSW-1#500291F06303#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:36.289  - info: shelly.0 (7112) [CoAP] Device 192.168.178.33 (shellyswitch / shellyswitch-135173 / SHSW-21#135173#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:36.384  - info: shelly.0 (7112) [CoAP] Device 192.168.178.57 (shellyswitch25 / shellyswitch25-BA7AC4 / SHSW-25#BA7AC4#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:36.843  - info: shelly.0 (7112) [CoAP] Device 192.168.178.95 (shellyswitch25 / shellyswitch25-E098068D2599 / SHSW-25#E098068D2599#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:37.382  - info: shelly.0 (7112) [CoAP] Device 192.168.178.81 (shelly1 / shelly1-F4CFA2764699 / SHSW-1#F4CFA2764699#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:37.396  - info: shelly.0 (7112) [CoAP] Device 192.168.178.55 (shelly1 / shelly1-0597BD / SHSW-1#0597BD#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:38.189  - info: shelly.0 (7112) [CoAP] Device 192.168.178.54 (shelly1 / shelly1-1D92AF / SHSW-1#1D92AF#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:38.696  - info: shelly.0 (7112) [CoAP] Device 192.168.178.65 (shellyswitch25 / shellyswitch25-76C387 / SHSW-25#76C387#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:39.970  - info: shelly.0 (7112) [CoAP] Device 192.168.178.58 (shellyswitch25 / shellyswitch25-BA76C8 / SHSW-25#BA76C8#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:40.553  - info: shelly.0 (7112) [CoAP] Device 192.168.178.92 (shelly1 / shelly1-3083988C032A / SHSW-1#3083988C032A#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:40.557  - info: shelly.0 (7112) [CoAP] Device 192.168.178.77 (shelly1 / shelly1-1D92AC / SHSW-1#1D92AC#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:41.461  - info: shelly.0 (7112) [CoAP] Device 192.168.178.40 (shelly1 / shelly1-1D92BD / SHSW-1#1D92BD#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:41.997  - info: shelly.0 (7112) [CoAP] Device 192.168.178.66 (shellyswitch25 / shellyswitch25-76CFA7 / SHSW-25#76CFA7#1) connected! Polltime set to 20 sec.
                      2024-07-19 19:51:42.712  - info: sonoff.0 (7113) Client [Stromzähler] connected with secret 1721411502684_8632
                      2024-07-19 19:51:51.981  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplus1pm-fcb467279060" connected!
                      2024-07-19 19:51:53.267  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplusplugs-d4d4daebcba4" connected!
                      2024-07-19 19:52:01.783  - info: shelly.1 (7177) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-fcb467279060 / shellyplus1pm#fcb467279060#1) (false)
                      2024-07-19 19:52:03.250  - info: shelly.1 (7177) [MQTT] Client Close:  (shellyplusplugs / shellyplusplugs-d4d4daebcba4 / shellyplusplugs#d4d4daebcba4#1) (false)
                      2024-07-19 19:52:04.869  - error: shelly.1 (7177) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-fcb467279060"
                      2024-07-19 19:52:05.237  - error: shelly.1 (7177) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4daebcba4"
                      2024-07-19 19:52:55.695  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplus1pm-fcb467279060" connected!
                      2024-07-19 19:52:58.529  - info: shelly.1 (7177) [MQTT] Device with client id "shellyplusplugs-d4d4daebcba4" connected!
                      2024-07-19 19:59:47.641  - info: influxdb.0 (6951) Store 19 buffered influxDB history points
                      Nochmals Danke!
                        USB-Devices by-id:
                        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
                        HINT:
                        /dev/ttyUSB0
                        Das würde ich noch umstellen.
                        Alles andere schaut soweit gut aus.
                        854
