    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Verbindung Tasmota (Sonoff) zu Node-Red
    • mickym
      OK - mal schauen. Warum das nicht geht ist mir im Moment schleierhaft.
      Zeig nochmal alle Nachrichten aus dem Debugfenster. Und nicht nur die 2 - wenn Du über das Webinterface schaltest
        Hajo 0 @mickym last edited by Homoran
        @mickym
        20.7.2024, 15:20:28node: debug 1esp/Badewanne/Temperatur : msg.payload : number
        23.88
        20.7.2024, 15:20:28node: debug 1esp/bme280/temperature : msg.payload : number
        23.93
        20.7.2024, 15:20:28node: debug 1esp/bme280/humidity : msg.payload : number
        41.69
        20.7.2024, 15:20:28node: debug 1esp/bme280/pressure : msg.payload : number
        987.6
        20.7.2024, 15:20:28node: debug 1esp/dht22/temperature : msg.payload : number
        20.9
        20.7.2024, 15:20:28node: debug 1esp/dht22/humidity : msg.payload : number
        55.7
        20.7.2024, 15:20:28node: debug 1esp/dht22/heatindex : msg.payload : number
        20.5
        20.7.2024, 15:20:28node: debug 1abstand/abstand : msg.payload : number
        45.32
        20.7.2024, 15:20:28node: debug 1temperatur/infrarot : msg.payload : number
        23.33
        20.7.2024, 15:20:28node: debug 1counter : msg.payload : number
        23.93
        41.69
        987.6
        20.7.2024, 15:20:28node: debug 1esp/ds18b20/temperature : msg.payload : number
        21.25
        20.9
        55.7
        20.5
        20.7.2024, 15:20:28node: debug 1esp/dht22/date : msg.payload : number
        21.87
        20.7.2024, 15:20:28node: debug 1esp/hcsr04/abstand : msg.payload : number
        0
        20.7.2024, 15:20:29node: debug 1esp/Badewanne/Temperatur : msg.payload : number
        23.88
        20.7.2024, 15:20:29node: debug 1esp/Badewanne/Abstand : msg.payload : number
        0
        20.7.2024, 15:20:29node: debug 1esp/distance : msg.payload : number
        19.21
        20.7.2024, 15:20:29node: debug 1esp/abstand : msg.payload : number
        19.3
        20.7.2024, 15:20:29node: debug 1abstand/abstand : msg.payload : number
        45.32
        20.7.2024, 15:20:29node: debug 1temperatur/infrarot : msg.payload : number
        23.33
        20.7.2024, 15:20:29node: debug 1temperatur/raum : msg.payload : number
        1037.55
        20.7.2024, 15:20:29node: debug 1test : msg.payload : string[6]
        "test 3"
        20.7.2024, 15:20:29node: debug 1led : msg.payload : boolean
        false
        20.7.2024, 15:28:00node: debug 1tasmota_340796/cmnd/power : msg.payload : string[2]
        "ON"
        20.7.2024, 15:28:01node: debug 1tasmota_340796/cmnd/power : msg.payload : string[3]
        "OFF"
        20.7.2024, 15:33:44node: debug 1esp/Badewanne/Temperatur : msg.payload : number
        23.88
        20.7.2024, 15:33:44node: debug 1esp/bme280/temperature : msg.payload : number
        23.93
        20.7.2024, 15:33:44node: debug 1esp/bme280/humidity : msg.payload : number
        41.69
        20.7.2024, 15:33:44node: debug 1esp/bme280/pressure : msg.payload : number
        987.6
        20.7.2024, 15:33:44node: debug 1esp/dht22/temperature : msg.payload : number
        20.9
        20.7.2024, 15:33:44node: debug 1esp/dht22/humidity : msg.payload : number
        55.7
        20.7.2024, 15:33:44node: debug 1esp/dht22/heatindex : msg.payload : number
        20.5
        20.7.2024, 15:33:44node: debug 1abstand/abstand : msg.payload : number
        45.32
        20.7.2024, 15:33:44node: debug 1temperatur/infrarot : msg.payload : number
        23.33
        20.7.2024, 15:33:44node: debug 1counter : msg.payload : number
        23.93
        41.69
        987.6
        20.7.2024, 15:33:44node: debug 1esp/ds18b20/temperature : msg.payload : number
        21.25
        20.9
        55.7
        20.5
        20.7.2024, 15:33:45node: debug 1esp/dht22/date : msg.payload : number
        21.87
        20.7.2024, 15:33:45node: debug 1esp/hcsr04/abstand : msg.payload : number
        0
        20.7.2024, 15:33:45node: debug 1esp/Badewanne/Temperatur : msg.payload : number
        23.88
        20.7.2024, 15:33:45node: debug 1esp/Badewanne/Abstand : msg.payload : number
        0
        20.7.2024, 15:33:45node: debug 1esp/distance : msg.payload : number
        19.21
        20.7.2024, 15:33:45node: debug 1esp/abstand : msg.payload : number
        19.3
        20.7.2024, 15:33:45node: debug 1abstand/abstand : msg.payload : number
        45.32
        20.7.2024, 15:33:45node: debug 1temperatur/infrarot : msg.payload : number
        23.33
        20.7.2024, 15:33:45node: debug 1temperatur/raum : msg.payload : number
        1037.55
        20.7.2024, 15:33:45node: debug 1test : msg.payload : string[6]
        "test 3"
        20.7.2024, 15:33:45node: debug 1led : msg.payload : boolean
        false
        20.7.2024, 15:33:57node: debug 1tasmota_340796/cmnd/power : msg.payload : string[2]
        "ON"
        20.7.2024, 15:33:59node: debug 1tasmota_340796/cmnd/power : msg.payload : string[3]
        "OFF"
        • mickym
          mickym Most Active @Hajo 0 last edited by
          @hajo-0 sagte in Verbindung Tasmota (Sonoff) zu Node-Red:
          OK - wenn Du das nochmal überprüfst, dann sollte wenn Du das wegschickst, genau das gleiche über Deine mqtt-In Node wieder rein kommen, wie es auch beim manuellen Schalten kommt.
          Schau auch mal in die Konsole, ob da was ankommt, wenn Du über das Dashboard schaltest.
            @mickym Konsole war ein guter Tip. Das Problem liegt offenbar woanders:
            14:52:05.460 MQT: Verbindungsversuch…
            14:52:05.641 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.178.95:1883, rc 5. Wiederversuch in 10 s
            14:52:07.296 QPC: Reset
            14:52:16.807 MQT: Verbindungsversuch…
            14:52:16.878 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.178.95:1883, rc 5. Wiederversuch in 20 s
            14:52:37.788 MQT: Verbindungsversuch…
            14:52:37.859 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.178.95:1883, rc 5. Wiederversuch in 30 s
            • mickym
              mickym Most Active @Hajo 0 last edited by mickym
              @hajo-0 Hast Du denn die mqtt Konfigurationsnode richtige gesetzt. Mit UserID, Passwort, mqtt Protokoll 3.1.1. ? rc 5 bedeuted sonst meist Zugriff verweigert.
              Wenns gar nicht geht - du solltest halt auch keine Retain Nachrichten am Anfang schicken, dann stop mosquitto und fang nochmal mit einer jungfräulichen Datenbank an.
                Hajo 0 @mickym last edited by Hajo 0
                @mickym Wo stelle ich das ein? Hier?
                Mosquitto läuft ganz normal, alles funktioniert, nur eben Tasmota nicht.
                Pause. Muss grad weg. 🙂
                Ralla66 1 Reply Last reply Reply Quote 0
                • mickym
                  @hajo-0 Kann es sein, dass Du mit 2 Clients mit falschem Passwort zugreifst?. Gib Dein Passwort und Dein mqtt User ggf. nochmal ein.
                  Und dann überprüfe mal Dein mosquitto log.
                  cd /var/log/mosquitto$
                  sudo tail -n50 mosquitto.log
                  Eventuell ist diese tasmota Node auch noch ein vollständiger mqtt Broker - fällt mir ein. Lösch bitte diese Nodes (https://flows.nodered.org/node/node-red-contrib-sonoff-tasmota) komplett via Palettenmanager aus dem System.
                  • Ralla66
                    Ralla66 Most Active @Hajo 0 last edited by
                    @hajo-0
                    lass dies Sonderzeichen endlich alle weg,
                    Die haben bei Benutzer und Paßwort nix verloren.
                      Hajo 0 @Ralla66 last edited by
                      @ralla66 Ok, gelobe Besserung. Funktioniert aber schon ewig ohne Probleme.
                        @mickym gelöscht. Logeintrag:
                        1721487645: New connection from 192.168.178.120:58585 on port 1883.
                        1721487645: Client <unknown> disconnected, not authorised.
                        1721487766: New connection from 192.168.178.120:56657 on port 1883.
                        1721487766: Client <unknown> disconnected, not authorised.
                        1721487887: New connection from 192.168.178.120:52932 on port 1883.
                        1721487887: Client <unknown> disconnected, not authorised.
                        1721488008: New connection from 192.168.178.120:55358 on port 1883.
                        1721488008: Client <unknown> disconnected, not authorised.
                        1721488129: New connection from 192.168.178.120:53846 on port 1883.
                        1721488129: Client <unknown> disconnected, not authorised.
                        1721488160: New connection from 192.168.178.95:42944 on port 1883.
                        1721488160: Client nodered_bb6e59c24d05513f disconnected.
                        1721488160: New client connected from 192.168.178.95:42944 as nodered_87f3f184b2
                        bd1b31 (p2, c1, k60, u'mqtt').
                        1721488166: New connection from 192.168.178.95:46878 on port 1883.
                        1721488166: New client connected from 192.168.178.95:46878 as nodered_5853fc39ae
                        3275c4 (p2, c1, k60, u'mqtt').
                        1721488166: Client nodered_87f3f184b2bd1b31 disconnected.
                        1721488250: New connection from 192.168.178.120:58688 on port 1883.
                        1721488250: Client <unknown> disconnected, not authorised.
                        1721488372: New connection from 192.168.178.120:54563 on port 1883.
                        1721488372: Client <unknown> disconnected, not authorised.
                        Ich muss mich mal für heute verabschieden. Meiner Frau gehts nicht gut, wir warten auf den Notarzt.
                        • mickym
                          Ok dann gute Besserung für Deine Frau. Und Dein Client mit der IP 120 ist auf jedenfall nicht OK. Also lösch die alten tasmota Nodes aus Deinem System komplett und gib ggf. die Daten neu auf dem Tasmota Gerät neu ein. NodeRed schnein OK zu sein.
                            @mickym Danke. Komme gerade aus dem Krankenhaus. Alles gut, muss aber noch bis Montag bleiben, MRT, CT, usw.
                            Habe die Konfiguration von Tasmota auf der S26 (IP 120) komplett zurückgesetzt und wieder ins WLAN aufgenommen. Tasmota Nodes waren schon gelöscht und deinstalliert. Node-Red habe ich restarted.
                            Bei den MQTT Einstellungen setze ich unter "Host" wieder die IP des Node-Red Raspis ein, 192.168.178.95:1883.
                            Aber was muss unter "Client", "Benutzer" und "Passwort" eingegeben werden? Sind das Default-Werte für Tasmota oder sind das die Zugangsdaten für Node-Red?
                            Was sollte ich noch irgendwo eingeben, ändern? Dieser Zugang zu Tasmota nervt echt, mit meinen D1minis hatte ich weniger Probleme... Aber ich finde die Steckdosen schön und preiswert.
                            Danke für Deine viele Hilfe. Morgen gehts weiter, jetzt gehe ich schlafen. Gute Nacht.
                            • mickym
                              Die Tasmotageräte kennen kein NodeRed sie verbinden sich nur mit Deinem mqtt-Broker.
                              Den Client lässt Du so oder gibst einen Namen ein, mit dem Du im mosquitto Log identifizierst, wenn sich das Gerät am mosquitto anmelden.
                              Benutzer und Passwort sind die Credentials im mosquitto, die Du ggf. definiert hast. (Also die gleiche Username und Passwort, die Du in den Konfigurationsnodes in NodeRed eingetragen hast. )
                              Also das Gerät meldet sich am mqtt Broker (=mosquitto) an und sonst nirgends.
                              Ja halt auf der Maschine auf der Mosquitto läuft (wie gesagt das hat alles mit NOde Red nichts zu tun, sondern mit mosquitto).
                              Merke:
                              Alle Geräte kommunizieren mit Mosquitto. Und Node-Red auch. Der MQTT Broker ist die Kommunikationsdrehscheibe, der alle Infos und Kommandos verteilt.
                              Sowohl NodeRed als auch Dein Gerät(Tasmota Steckdose) sind MQTT Clients.
                              Wenn Du über NodeRed Kommandos sendest, publishest Du Kommandos, die das Tasmota Gerät abonniert (subscribed hat) - also alles topics unter cmnd.
                              Das Tasmota Gerät wiederum published Information unter stat und tele, die Du mit NodeRed abonnieren (subscriben kannst).
                              Das ist wichtig zu verstehen. Wir werden ggf. Deine Struktur noch nachträglich optimieren. Aber erst mal versuchen wir es nur quick & dirty - machen es dann aber gleich schön, damit Du später auch schön weiter machen kannst.
                              H Ralla66 2 Replies Last reply Reply Quote 0
                                @mickym Guten Morgen und danke für deine Super Erklärungen. Ich habe da wohl völlig auf dem Schlauch gestanden. Die Installation ist schon eine Weile her...
                                Username/PW ist jetzt klar, ist auch in jedem Sketch für die D1 eingetragen. ABER: das PW ist kurz, 4 Zeichen. Tasmota verweigert dies, verlangt mindestens 5 Zeichen. Wenn ich das am Mosquitto ändere, muss ich alle Sketche neu machen, alle Geräte aufmachen, neu programmieren. Gibt es eine Möglichkeit, Tasmota auch zu einem kürzeren PW zu überreden?
                                  Hajo 0 @Hajo 0 last edited by
                                  @hajo-0 Sorry, erst denken, dann schreiben.... Ich habe jetzt einen weiteren User im Mosquitto PW-File eingetragen, restarted. Tasmota hat das jetzt akzeptiert.
                                    Hajo 0 @Hajo 0 last edited by Hajo 0
                                    @hajo-0 Sieht jetzt alles vernünftig aus, aber klappt noch nicht.
                                    2024-07-21 07_53_22-pi@raspi5_ ~.jpg 2024-07-21 07_53_48-Node-RED _ 192.168.178.95 – Mozilla Firefox.jpg 2024-07-21 07_54_18-Tasmota - Konsole – Mozilla Firefox.jpg
                                    Muss wieder los, sorry... melde mich später.
                                    • Ralla66
                                      Ralla66 Most Active @mickym last edited by
                                      @mickym sagte in Verbindung Tasmota (Sonoff) zu Node-Red:
                                      Mosquitto
                                      habe ich ja nicht, aber können 2 Mosquitto Mqtt Broker auf dem gleichen Gerät ( IP ) mit dem gleichen
                                      Port (1883 ) und anderem Paßwort laufen ?
                                      Vermutlich Nein, womit sein altes Paßwort der alten Geräte ja weg wäre.
                                        @ralla66 Doch, geht. Es läuft 1 Mosquitto, der hat einen Passwortfile und dort stehen zwei (oder auch ganz viele) User mit Passwort drin.
                                          Es funktioniert! Es waren so viele Kleinigkeiten von falschen Zugangsdaten, Vergessenes bei Mosquitto/Node-Red, usw.
                                          Vielen vielen Dank für die Geduld mit mir. Das sind jetzt die aktuellen Einstellungen von Tasmota und Node-Red.
                                          2024-07-21 14_18_43-Tasmota - MQTT-Einstellungen – Mozilla Firefox.jpg2024-07-21 14_19_52-Node-RED _ 192.168.178.95 – Mozilla Firefox.jpg 2024-07-21 14_20_08-Node-RED _ 192.168.178.95 – Mozilla Firefox.jpg
                                          Ich kapiere nicht, warum dann überall auf die Tasmota-Node hingewiesen wird, die ja nun absolut nichts kann.
                                          @mickym Hast Du noch Tips zum "schön" machen für die jetzt mit Sicherheit folgenden weiteren Steckdosen?
                                          Auf jeden Fall erstmal herzlichen Dank!!
                                          Ralla66 mickym 2 Replies Last reply Reply Quote 0
                                          • Ralla66
                                            je nach Anforderung halt, läuft aber genauso.
                                            Für ein simples Ein / Aus reicht das ja.
                                            Letzt endlich ist das ja nur eine 0 oder 1 in den Datenpunkt schreiben.
                                            Wege gibt es da viele, Tasmota, IoBroker, Mqtt Node ...............................................
                                            2900
