    4. zigbee2mqtt-Instanz startet nicht
    • 1Topf
      1Topf @arteck last edited by
      @arteck sagte in zigbee2mqtt-Instanz startet nicht:
      @1topf na klar geht das nicht.. der Port darf nicht 2 mal belegt sein
      Ich hab die doch nicht gleichzeitig laufen! Entweder oder!
      1Topf 1 Reply Last reply Reply Quote 0
      • 1Topf
        1Topf @1Topf last edited by
        @1topf
        Während obiger Antwort lief gerade noch einmal eine komplette Neuinstallation mit neuestem Bookworm 12.2. + ioB + zigbee2mqtt. Den z2m-Adapter starten verursacht sofort ein
        host.iobroker
        	2023-11-20 18:11:03.010	info	instance system.adapter.zigbee2mqtt.0 terminated with code null ()
        host.iobroker
        	2023-11-20 18:11:03.008	warn	instance system.adapter.zigbee2mqtt.0 terminated due to SIGILL
        host.iobroker
        	2023-11-20 18:11:00.161	info	instance system.adapter.zigbee2mqtt.0 started with pid 10733
        host.iobroker
        	2023-11-20 18:10:59.995	info	"system.adapter.zigbee2mqtt.0" enabled
        Die Konsole zeigt für zigbee2mqtt:
        iobroker@iobroker:/opt/zigbee2mqtt$ npm start
        > zigbee2mqtt@1.33.2 start
        > node index.js
        Zigbee2MQTT:info  2023-11-20 18:12:49: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-11-20.18-12-48' filename: log.txt
        Zigbee2MQTT:info  2023-11-20 18:12:49: Starting Zigbee2MQTT version 1.33.2 (commit #311ea07)
        Zigbee2MQTT:info  2023-11-20 18:12:49: Starting zigbee-herdsman (0.21.0)
        Zigbee2MQTT:info  2023-11-20 18:12:50: zigbee-herdsman started (resumed)
        Zigbee2MQTT:info  2023-11-20 18:12:50: Coordinator firmware version: '{"meta":{"maintrel":2,"majorrel":2,"minorrel":7,"product":2,"revision":20211222,"transportrev":2},              "type":"zStack30x"}'
        Zigbee2MQTT:info  2023-11-20 18:12:50: Currently 0 devices are joined:
        Zigbee2MQTT:info  2023-11-20 18:12:50: Zigbee: disabling joining new devices.
        Zigbee2MQTT:info  2023-11-20 18:12:50: Connecting to MQTT server at mqtt://192.168.178.244:1886
        Zigbee2MQTT:error 2023-11-20 18:12:51: MQTT error: connect ECONNREFUSED 192.168.178.244:1886
        Zigbee2MQTT:error 2023-11-20 18:12:51: MQTT failed to connect, exiting...
        Zigbee2MQTT:info  2023-11-20 18:12:51: Stopping zigbee-herdsman...
        Zigbee2MQTT:error 2023-11-20 18:12:52: MQTT error: connect ECONNREFUSED 192.168.178.244:1886
        Zigbee2MQTT:error 2023-11-20 18:12:53: MQTT error: connect ECONNREFUSED 192.168.178.244:1886
        Zigbee2MQTT:error 2023-11-20 18:12:54: MQTT error: connect ECONNREFUSED 192.168.178.244:1886
        Zigbee2MQTT:error 2023-11-20 18:12:55: MQTT error: connect ECONNREFUSED 192.168.178.244:1886
        Zigbee2MQTT:info  2023-11-20 18:12:56: Stopped zigbee-herdsman
        Is ja auch klar, weil der Dummy-Server nicht startet, da der Adapter bzw. die Instanz wegen terminated due to SIGILL nicht startet.
        Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @1Topf last edited by
          @1topf sagte in zigbee2mqtt-Instanz startet nicht:
          Warum legt man dann da diese unglückliche Kombination
          iobroker@iobroker
          an? Sollte doch mittlerweile durchgedrungen sein, dass der User 'iobroker' für den Systemdienst vorgesehen ist und nicht anderweitig verwendet werden soll.
            crunchip Forum Testing Most Active @1Topf last edited by
            Mal auf debug stellen ob man mehr sieht
            • 1Topf
              1Topf @crunchip last edited by
              @crunchip
              Die Instanz müßte dafür vermutlich starten, oder?
              • Q
                quotschmacher last edited by
                na das ist ja lustig... habe vor kurzem meine instanz seit langem mal geupdatet und dann startete sie auch nicht mehr. jetzt aufgrund dessen hier auf 2.10.1 zurück und es läuft wieder. ich hatte relativ lange mit dem update gewartet, weil da eine meldung war, das man ein neues auth-token brauchen würde. sowas nutze ich aber eh nicht.
                arteck A 2 Replies Last reply Reply Quote 0
                  arteck Developer Most Active @quotschmacher last edited by
                  @quotschmacher sagte in zigbee2mqtt-Instanz startet nicht:
                  und wo ist das problem.. wenns man nicht nutzt... was soll den dann nicht gehen..
                  • Q
                    quotschmacher @arteck last edited by
                    @arteck ich schrieb ja nur, dass diese warnmeldung der grund war, warum ich längere zeit nicht geupdated hatte und dass das eine der änderungen von einer version die noch ging zu einer, bei der die instanz überhaupt nicht mehr startet war. irgendwas wurde ja an der websocket-kommunikation umgestellt. wobei das kein grund ist, nicht mehr zu starten. und mein log war halt auch leer -lediglich die SIGILL-meldung.
                      Areaman_51 @quotschmacher last edited by
                      @quotschmacher Hallo, ich wollte mal nachfragen, ob es dazu in der zwischenzeit eine andere Lösung gibt, als auf die Version 2.10.1. zurückzugehen. Da ich den gleichen Fehler bekomme, wenn ich auf die Aktuelle Version update.
                      • 1Topf
                        1Topf @Areaman_51 last edited by
                        @areaman_51 Kann ich dir nicht sagen. Ich habe damals "einfach" mal einen anderen Rechner benutzt, und auf dem lief die identische Installation problemlos und alles hat auf Anhieb funktioniert. Der läuft immer noch, momentan mit v2.13.6.
                        1318
