    4. Node-Red
    5. Function Node welche zwei Werte vergleicht
    • 1
      1984chris @mickym last edited by
      @mickym
      könntest du mir ein BeispielFlow machen?
      • mickym
        mickym Most Active @1984chris last edited by
        @1984chris So ich habe noch den Haken bei der Filter Node rausgemacht. Der war fehlerhaft. Ansonsten hier nun der erweiterte Flow.
        Durch die Debug Nodes siehst Du nun immer die aktuelle Erzeugung und die Summe des Verbrauchs
        Hier der Import:
        [{"id":"a86c1f1e4b75e441","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"81","payloadType":"num","x":150,"y":3720,"wires":[["494bb9361ae7bea3"]]},{"id":"f18c81168d9f50a0","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2600","payloadType":"num","x":150,"y":3580,"wires":[["6fa8637750ac1054"]]},{"id":"a3d2d88cd6708218","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"79","payloadType":"num","x":150,"y":3760,"wires":[["494bb9361ae7bea3"]]},{"id":"f3d26ec9c8d67465","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2300","payloadType":"num","x":150,"y":3620,"wires":[["6fa8637750ac1054"]]},{"id":"84b2fa38187ff34f","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"AutoEin","payload":"AutoEin","payloadType":"str","x":140,"y":3480,"wires":[["5e6eefda3fb81cfd"]]},{"id":"eba9ab8e96ae87e8","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AutoAus","payloadType":"str","x":160,"y":3520,"wires":[["5e6eefda3fb81cfd"]]},{"id":"5e6eefda3fb81cfd","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"AutoEin","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":3500,"wires":[["043e832f297c9831"]]},{"id":"6fa8637750ac1054","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"Einspeisung","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":3600,"wires":[["043e832f297c9831","ed14cc2d24f3ff16"]]},{"id":"494bb9361ae7bea3","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"SOC","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":3700,"wires":[["043e832f297c9831"]]},{"id":"c9bdbf8b0e1b8b42","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"AutoEin\":$exists($flowContext(\"AutoEin\")),\t   \"Einspeisung\":$exists($flowContext(\"Einspeisung\")),\t   \"SOC\":$exists($flowContext(\"SOC\")),\t   \"Verbrauch\": $exists($flowContext(\"SOC\"))\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":3600,"wires":[["9367f9f7.8f5708","3a39b9030c5759fa"]]},{"id":"2975f91defeba563","type":"debug","z":"517cd16e4d7e6ae4","name":"Alle Parameter gesetzt?","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1410,"y":3540,"wires":[]},{"id":"9367f9f7.8f5708","type":"switch","z":"517cd16e4d7e6ae4","name":"AND?","property":"$reduce(payload.*,function($i, $j){$i and $j})","propertyType":"jsonata","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":1110,"y":3600,"wires":[["2975f91defeba563","c6ee18440c5ede12"]],"info":"# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n \"Office\": true,\n \"Bedroom\": true,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n \"Office\": true,\n \"Bedroom\": false,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": true,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": false,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."},{"id":"45a1bb09159cf684","type":"switch","z":"517cd16e4d7e6ae4","name":"SOC > 80%","property":"SOC","propertyType":"flow","rules":[{"t":"gt","v":"80","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1810,"y":3580,"wires":[["55afcaa9b715c923","e6bff6b181617360"],["a24a10d67adf7325"]]},{"id":"5192b4bc40dd7659","type":"switch","z":"517cd16e4d7e6ae4","name":"Überschuss > 2500W","property":"$flowContext(\"Einspeisung\") - $flowContext(\"Verbrauch\")\t\t","propertyType":"jsonata","rules":[{"t":"gt","v":"2500","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1540,"y":3580,"wires":[["45a1bb09159cf684"],["0f2c3c5c8743b77e"]]},{"id":"f558e9a1afff1836","type":"debug","z":"517cd16e4d7e6ae4","name":"Ergebnis","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":2820,"y":3560,"wires":[]},{"id":"c6ee18440c5ede12","type":"switch","z":"517cd16e4d7e6ae4","name":"Auto Ein/Aus","property":"AutoEin","propertyType":"flow","rules":[{"t":"cont","v":"AutoEin","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1330,"y":3600,"wires":[["5192b4bc40dd7659"],["473eacb13a6cb11c"]]},{"id":"5d671131260cc2d4","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Aus","rules":[{"t":"set","p":"payload","pt":"msg","to":"Pumpe Aus 0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2430,"y":3660,"wires":[["ddf39dae01705e59"]]},{"id":"856ab41216e0c0af","type":"delay","z":"517cd16e4d7e6ae4","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":2240,"y":3660,"wires":[["5d671131260cc2d4"]]},{"id":"55afcaa9b715c923","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Ein","rules":[{"t":"set","p":"payload","pt":"msg","to":"Pumpe Ein 1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2030,"y":3560,"wires":[["ddf39dae01705e59"]]},{"id":"e6bff6b181617360","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2040,"y":3600,"wires":[["856ab41216e0c0af"]]},{"id":"19225af3a1bf8b1a","type":"rbe","z":"517cd16e4d7e6ae4","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":2650,"y":3560,"wires":[["f558e9a1afff1836"]]},{"id":"9685a44b6acadc85","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 1","payload":"60","payloadType":"num","x":180,"y":3820,"wires":[["6236f30557c7e780"]]},{"id":"3a39b9030c5759fa","type":"debug","z":"517cd16e4d7e6ae4","name":"Alle Parameter","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1140,"y":3540,"wires":[]},{"id":"7971d5242a5ea489","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 2","payload":"100","payloadType":"num","x":170,"y":3900,"wires":[["6236f30557c7e780"]]},{"id":"7c3015bff0b30e2e","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 3","payload":"2300","payloadType":"num","x":170,"y":3980,"wires":[["6236f30557c7e780"]]},{"id":"a3f8d990d290d69d","type":"join","z":"517cd16e4d7e6ae4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":410,"y":3900,"wires":[["edaa035f0714e9aa"]]},{"id":"edaa035f0714e9aa","type":"change","z":"517cd16e4d7e6ae4","name":"Summe Verbrauch","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload.*)","tot":"jsonata"},{"t":"set","p":"Verbrauch","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":3900,"wires":[["cf8c319f66d88019","c9bdbf8b0e1b8b42"]]},{"id":"b29693a62628fd9f","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 1","payload":"0","payloadType":"num","x":180,"y":3860,"wires":[["6236f30557c7e780"]]},{"id":"f548db43288fcfb0","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 2","payload":"0","payloadType":"num","x":180,"y":3940,"wires":[["6236f30557c7e780"]]},{"id":"3c6178107678bdff","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 3","payload":"0","payloadType":"num","x":180,"y":4020,"wires":[["6236f30557c7e780"]]},{"id":"cf8c319f66d88019","type":"debug","z":"517cd16e4d7e6ae4","name":"Summe Verbrauch","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":3900,"wires":[]},{"id":"43328f2d1b31cb20","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"4500","payloadType":"num","x":150,"y":3660,"wires":[["6fa8637750ac1054"]]},{"id":"ed14cc2d24f3ff16","type":"debug","z":"517cd16e4d7e6ae4","name":"Einspeisung","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":3660,"wires":[]},{"id":"a24a10d67adf7325","type":"junction","z":"517cd16e4d7e6ae4","x":1960,"y":3660,"wires":[["856ab41216e0c0af"]]},{"id":"0f2c3c5c8743b77e","type":"junction","z":"517cd16e4d7e6ae4","x":1720,"y":3660,"wires":[["a24a10d67adf7325"]]},{"id":"473eacb13a6cb11c","type":"junction","z":"517cd16e4d7e6ae4","x":1440,"y":3660,"wires":[["0f2c3c5c8743b77e"]]},{"id":"ddf39dae01705e59","type":"junction","z":"517cd16e4d7e6ae4","x":2540,"y":3560,"wires":[["19225af3a1bf8b1a"]]},{"id":"6236f30557c7e780","type":"junction","z":"517cd16e4d7e6ae4","x":340,"y":3900,"wires":[["a3f8d990d290d69d"]]},{"id":"043e832f297c9831","type":"junction","z":"517cd16e4d7e6ae4","x":560,"y":3600,"wires":[["c9bdbf8b0e1b8b42"]]}]
        1 1 Reply Last reply Reply Quote 0
        • 1
          @mickym
          Vielen Danke, werde es später probieren.
          Muss jetzt leider weg.
          Melde mich später wieder.
          LG Christoph
          • 1
            1984chris @1984chris last edited by
            @1984chris
            bin gerade am testen will damit einen shelly ein oder Ausschalten wenn die Filter Node am Ende ist funktioniert das nicht. Wenn ich Schgalter aus mit 1 ON und Schalter aus mit 0 Off verbinde funktioniert es. Es werden dann halt wenn sekündlich Werte geschickt werden z.b für Ein diese immer weitergeleitet an den Shelly wie kann ich das unterbinden?
                    "id": "be0d20ba8c83cf52",
                    "type": "inject",
                    "z": "b7365eb2cd9f043a",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "Verbraucher 1",
                    "payload": "0",
                    "payloadType": "num",
                    "x": 140,
                    "y": 540,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "69beb01e48cbb490",
                    "type": "join",
                    "name": "",
                    "mode": "custom",
                    "build": "object",
                    "property": "payload",
                    "propertyType": "msg",
                    "key": "topic",
                    "joiner": "\\n",
                    "joinerType": "str",
                    "accumulate": true,
                    "timeout": "",
                    "count": "1",
                    "reduceRight": false,
                    "reduceExp": "",
                    "reduceInit": "",
                    "reduceInitType": "",
                    "reduceFixup": "",
                    "x": 790,
                    "y": 540,
                    "wires": [
                            "423fc589613bb585"
                    "id": "e27beb8583aa4ba3",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "payload": "60",
                    "x": 140,
                    "y": 500,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "a2acd308ce3c999b",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "Verbraucher 3",
                    "payload": "2300",
                    "x": 130,
                    "y": 660,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "0c034a90eacd5fc4",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "Verbraucher 2",
                    "payload": "100",
                    "x": 130,
                    "y": 580,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "89f4ac760b787b09",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "payload": "0",
                    "x": 140,
                    "y": 620,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "eb464f1d17573074",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "payload": "0",
                    "x": 140,
                    "y": 700,
                    "wires": [
                            "69beb01e48cbb490"
                    "id": "423fc589613bb585",
                    "type": "change",
                    "name": "Summe Verbrauch",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "$sum(payload.*)",
                            "tot": "jsonata"
                            "t": "set",
                            "p": "Verbrauch",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 970,
                    "y": 540,
                    "wires": [
                            "a846941657aec3a0",
                            "ae6c196add3ae406"
                    "id": "a846941657aec3a0",
                    "type": "debug",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "complete": "payload",
                    "targetType": "msg",
                    "statusVal": "",
                    "statusType": "auto",
                    "x": 1210,
                    "y": 540,
                    "wires": []
                    "id": "ae6c196add3ae406",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "{\t \"AutoEin\":$exists($flowContext(\"AutoEin\")),\t \"Einspeisung\":$exists($flowContext(\"Einspeisung\")),\t \"SOC\":$exists($flowContext(\"SOC\")),\t \"Verbrauch\": $exists($flowContext(\"Verbrauch\"))\t}",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 1310,
                    "y": 240,
                    "wires": [
                            "c682c690f3686aba",
                            "8a0e4f6d9aadf84a"
                    "id": "ad44ce022520acb9",
                    "type": "junction",
                    "x": 940,
                    "y": 240,
                    "wires": [
                            "ae6c196add3ae406"
                    "id": "c682c690f3686aba",
                    "type": "switch",
                    "name": "AND?",
                    "property": "$reduce(payload.*,function($i, $j){$i and $j})",
                    "propertyType": "jsonata",
                    "rules": [
                            "t": "true"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 1,
                    "x": 1490,
                    "y": 240,
                    "wires": [
                            "296fc791b35c3cf0",
                            "611f290ee889a6c9"
                    "info": "# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n \"Office\": true,\n \"Bedroom\": true,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n \"Office\": true,\n \"Bedroom\": false,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": true,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": false,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."
                    "id": "8a0e4f6d9aadf84a",
                    "type": "debug",
                    "name": "Alle Parameter",
                    "active": false,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1520,
                    "y": 180,
                    "wires": []
                    "id": "075995c61d50b0fc",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "AutoEin",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 750,
                    "y": 120,
                    "wires": [
                            "ad44ce022520acb9"
                    "id": "81cca1013046684b",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "Einspeisung",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 740,
                    "y": 240,
                    "wires": [
                            "ad44ce022520acb9",
                            "86c5f5293c29797f"
                    "id": "723be488aa772937",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "SOC",
                            "pt": "flow",
                            "to": "payload",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 740,
                    "y": 340,
                    "wires": [
                            "ad44ce022520acb9"
                    "id": "296fc791b35c3cf0",
                    "type": "debug",
                    "name": "Alle Parameter gesetzt?",
                    "active": false,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1790,
                    "y": 180,
                    "wires": []
                    "id": "611f290ee889a6c9",
                    "type": "switch",
                    "name": "Auto Ein/Aus",
                    "property": "AutoEin",
                    "propertyType": "flow",
                    "rules": [
                            "t": "cont",
                            "v": "AutoEin",
                            "vt": "str"
                            "t": "else"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 1710,
                    "y": 240,
                    "wires": [
                            "e917da2b3033e0ad"
                            "4064534edf8a91ba"
                    "id": "3527032527097f5a",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "AutoEin",
                    "payload": "AutoEin",
                    "payloadType": "str",
                    "x": 180,
                    "y": 40,
                    "wires": [
                            "075995c61d50b0fc"
                    "id": "aa347550f2f3195a",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "AutoAus",
                    "payload": "AutoAus",
                    "x": 220,
                    "y": 80,
                    "wires": [
                            "075995c61d50b0fc"
                    "id": "60b09aa662d21699",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "2600",
                    "x": 170,
                    "y": 240,
                    "wires": [
                            "81cca1013046684b"
                    "id": "de72bd27154966a3",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "2300",
                    "x": 170,
                    "y": 280,
                    "wires": [
                            "81cca1013046684b"
                    "id": "034ed6ed5c92fe19",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "4500",
                    "x": 170,
                    "y": 320,
                    "wires": [
                            "81cca1013046684b"
                    "id": "86c5f5293c29797f",
                    "type": "debug",
                    "name": "Einspeisung",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 990,
                    "y": 320,
                    "wires": []
                    "id": "a81140ec925e801f",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "81",
                    "x": 110,
                    "y": 380,
                    "wires": [
                            "723be488aa772937"
                    "id": "d71c87a4f57fa8a9",
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "79",
                    "x": 110,
                    "y": 420,
                    "wires": [
                            "723be488aa772937"
                    "id": "e917da2b3033e0ad",
                    "type": "switch",
                    "name": "Überschuss > 2500W",
                    "property": "$flowContext(\"Einspeisung\") - $flowContext(\"Verbrauch\")\t\t",
                    "rules": [
                            "t": "gt",
                            "v": "2500",
                            "vt": "num"
                            "t": "else"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 1920,
                    "y": 220,
                    "wires": [
                            "fa07332ccb7479f3"
                            "62b38ef63522d9ae"
                    "id": "4064534edf8a91ba",
                    "type": "junction",
                    "x": 1820,
                    "y": 300,
                    "wires": [
                            "62b38ef63522d9ae"
                    "id": "fa07332ccb7479f3",
                    "type": "switch",
                    "name": "SOC > 80%",
                    "property": "SOC",
                    "rules": [
                            "t": "gt",
                            "v": "80",
                            "vt": "num"
                            "t": "else"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 2190,
                    "y": 220,
                    "wires": [
                            "07419de8e60d43c6",
                            "4a3b1677942b79db"
                            "12d84d1a6640f144"
                    "id": "62b38ef63522d9ae",
                    "type": "junction",
                    "x": 2100,
                    "y": 300,
                    "wires": [
                            "12d84d1a6640f144"
                    "id": "07419de8e60d43c6",
                    "type": "change",
                    "name": "Schalter Ein",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "Pumpe Ein 1",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 2410,
                    "y": 200,
                    "wires": [
                            "aafdd4e5972e1401"
                    "id": "4a3b1677942b79db",
                    "type": "change",
                    "name": "",
                    "rules": [
                            "t": "set",
                            "p": "reset",
                            "pt": "msg",
                            "to": "true",
                            "tot": "bool"
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "1",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 2430,
                    "y": 240,
                    "wires": [
                            "f15fd06658be8b23",
                            "3c0a215e508cab6f"
                    "id": "12d84d1a6640f144",
                    "type": "junction",
                    "x": 2420,
                    "y": 320,
                    "wires": [
                            "3c0a215e508cab6f"
                    "id": "aafdd4e5972e1401",
                    "type": "rbe",
                    "name": "",
                    "func": "rbe",
                    "gap": "",
                    "start": "",
                    "inout": "out",
                    "septopics": false,
                    "topi": "topic",
                    "x": 3090,
                    "y": 220,
                    "wires": [
                            "0858f158df46bb51",
                            "92a59b4ca2939e92",
                            "abb927025f221499"
                    "id": "f15fd06658be8b23",
                    "type": "delay",
                    "name": "",
                    "pauseType": "delay",
                    "timeout": "5",
                    "timeoutUnits": "seconds",
                    "rate": "1",
                    "nbRateUnits": "1",
                    "rateUnits": "second",
                    "randomFirst": "1",
                    "randomLast": "5",
                    "randomUnits": "seconds",
                    "drop": false,
                    "allowrate": false,
                    "outputs": 1,
                    "x": 2720,
                    "y": 300,
                    "wires": [
                            "5c2873c0b8c42da6"
                    "id": "3c0a215e508cab6f",
                    "type": "rbe",
                    "name": "",
                    "func": "rbe",
                    "gap": "",
                    "start": "",
                    "inout": "out",
                    "septopics": false,
                    "topi": "topic",
                    "x": 2510,
                    "y": 320,
                    "wires": [
                            "f15fd06658be8b23"
                    "id": "5c2873c0b8c42da6",
                    "type": "change",
                    "name": "Schalter Aus",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "Pumpe Aus 0",
                            "tot": "str"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 2890,
                    "y": 300,
                    "wires": [
                            "aafdd4e5972e1401"
                    "id": "0858f158df46bb51",
                    "type": "debug",
                    "name": "Ergebnis",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 3240,
                    "y": 160,
                    "wires": []
                    "id": "92a59b4ca2939e92",
                    "type": "function",
                    "name": "1 On",
                    "func": "msg.payload = {\n    method: \"Switch.Set\",\n    parameters : {\n        id : 0,\n        on: true,\n        \n    }\n};\nreturn msg;",
                    "outputs": 1,
                    "timeout": "",
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 3290,
                    "y": 240,
                    "wires": [
                            "55a334f62dd97366"
                    "id": "abb927025f221499",
                    "type": "function",
                    "name": "0 off",
                    "func": "msg.payload = {\n    method: \"Switch.Set\",\n    parameters : {\n        id : 0,\n        on : false,\n    }\n};\nreturn msg;",
                    "outputs": 1,
                    "timeout": "",
                    "noerr": 0,
                    "initialize": "",
                    "finalize": "",
                    "libs": [],
                    "x": 3290,
                    "y": 340,
                    "wires": [
                            "55a334f62dd97366"
                    "id": "55a334f62dd97366",
                    "type": "shelly-gen2",
                    "hostname": "192.168.1.110",
                    "description": "",
                    "mode": "polling",
                    "server": "",
                    "outputmode": "event",
                    "uploadretryinterval": 5000,
                    "pollinginterval": 5000,
                    "pollstatus": false,
                    "getstatusoncommand": true,
                    "devicetype": "Relay",
                    "outputs": 1,
                    "x": 3620,
                    "y": 280,
                    "wires": [
            • mickym
              mickym Most Active @1984chris last edited by mickym
              @1984chris
              Dann mach halt nicht das mit Pumpe ein 0 - das hast Du doch eingeführt, sondern setze die Schalter auf on, off oder true, false.
              Im Übrigen muss man auch nicht über RPC schalten und function Nodes braucht man dafür auch nicht.
              In der Regel mache ich alles über mqtt.
              Wenn Du mqtt nutzt kannst Du auch Gen2 Geräte direkt über einen command topic schalten.
              https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Switch#mqtt-control
              Und falls Du Objekte versenden willst, geht das auch mit JSONATA einfacher als mit function Nodes.
              Sowas ist Käse - damit schaltest Du gleichzeitig ein und aus. Du musst das doch vorher festlegen.
              Wenn dann schaltest Du true/false vorher - also werde ich jetzt mal Schalter ein auf true setzen und Schalter aus auf false.
              für Schalter aus entsprechend.
              Wenn Du das RPC verwenden willst und nicht das Command über mqtt, dann erstellt man mit einer Change Node das Objekt und die payload, die aus dem filter kommt ist nur true oder false.
              Also ab Schalter ein/aus die Nodes durch diese ersetzen - die function Nodes sparst Du Dir und nutzt JSONATA mit einer Change Node.
              [{"id":"07419de8e60d43c6","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Ein","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2890,"y":4440,"wires":[["aafdd4e5972e1401"]]},{"id":"aafdd4e5972e1401","type":"rbe","z":"517cd16e4d7e6ae4","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":3090,"y":4460,"wires":[["fe12d75c77ea96a9"]]},{"id":"5c2873c0b8c42da6","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Aus","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2890,"y":4540,"wires":[["aafdd4e5972e1401"]]},{"id":"0858f158df46bb51","type":"debug","z":"517cd16e4d7e6ae4","name":"Ergebnis","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3480,"y":4420,"wires":[]},{"id":"fe12d75c77ea96a9","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"method\": \"Switch.Set\",\t   \"parameters\" : {\t       \"id\" : 0,\t       \"on\": payload       \t   }\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":3290,"y":4460,"wires":[["0858f158df46bb51"]]}]
              Was das dahinten sein soll, verstehe ich nicht
              Ich würde es wieder wegschmeissen und meinen ursprünglichen Flow nehmen.
              Hier nochmal mein ursprünglicher Flow - da musst halt die Shelly Node wieder hinten dran hängen - oder Du nutzt halt mqtt und nicht diese Nodes. 😉
              [{"id":"a86c1f1e4b75e441","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"81","payloadType":"num","x":150,"y":3720,"wires":[["494bb9361ae7bea3"]]},{"id":"f18c81168d9f50a0","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2600","payloadType":"num","x":150,"y":3580,"wires":[["6fa8637750ac1054"]]},{"id":"a3d2d88cd6708218","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"79","payloadType":"num","x":150,"y":3760,"wires":[["494bb9361ae7bea3"]]},{"id":"f3d26ec9c8d67465","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2300","payloadType":"num","x":150,"y":3620,"wires":[["6fa8637750ac1054"]]},{"id":"84b2fa38187ff34f","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"AutoEin","payload":"AutoEin","payloadType":"str","x":140,"y":3480,"wires":[["5e6eefda3fb81cfd"]]},{"id":"eba9ab8e96ae87e8","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"AutoAus","payloadType":"str","x":160,"y":3520,"wires":[["5e6eefda3fb81cfd"]]},{"id":"5e6eefda3fb81cfd","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"AutoEin","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":3500,"wires":[["043e832f297c9831"]]},{"id":"6fa8637750ac1054","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"Einspeisung","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":3600,"wires":[["043e832f297c9831","ed14cc2d24f3ff16"]]},{"id":"494bb9361ae7bea3","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"SOC","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":3700,"wires":[["043e832f297c9831"]]},{"id":"c9bdbf8b0e1b8b42","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"AutoEin\":$exists($flowContext(\"AutoEin\")),\t   \"Einspeisung\":$exists($flowContext(\"Einspeisung\")),\t   \"SOC\":$exists($flowContext(\"SOC\")),\t   \"Verbrauch\": $exists($flowContext(\"SOC\"))\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":3600,"wires":[["9367f9f7.8f5708","3a39b9030c5759fa"]]},{"id":"2975f91defeba563","type":"debug","z":"517cd16e4d7e6ae4","name":"Alle Parameter gesetzt?","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1410,"y":3540,"wires":[]},{"id":"9367f9f7.8f5708","type":"switch","z":"517cd16e4d7e6ae4","name":"AND?","property":"$reduce(payload.*,function($i, $j){$i and $j})","propertyType":"jsonata","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":1110,"y":3600,"wires":[["2975f91defeba563","c6ee18440c5ede12"]],"info":"# All properties of an object must be true.\n\nAll properties of an object must be true.\n\n`{\n \"Office\": true,\n \"Bedroom\": true,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis true,\n\n`{\n \"Office\": true,\n \"Bedroom\": false,\n \"Living Room Balcony\": true,\n \"Living Room Right Window\": true,\n \"Living Room Left Window\": true\n}`\n\nis false.\n\n# Alle Eigenschaften eines Objektes müssen wahr sein\n\nAlle Eigenschaften eines Objektes müssen wahr sein.\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": true,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt true,\n\n`{\n \"Büro Balkon\": true,\n \"Schlafzimmer Balkon\": true,\n \"Wohnzimmer Balkon\": true,\n \"Wohnzimmer rechtes Fenster\": false,\n \"Wohnzimmer linkes Fenster\": true\n}`\n\nergibt false."},{"id":"45a1bb09159cf684","type":"switch","z":"517cd16e4d7e6ae4","name":"SOC > 80%","property":"SOC","propertyType":"flow","rules":[{"t":"gt","v":"80","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1810,"y":3580,"wires":[["55afcaa9b715c923","e6bff6b181617360"],["a24a10d67adf7325"]]},{"id":"5192b4bc40dd7659","type":"switch","z":"517cd16e4d7e6ae4","name":"Überschuss > 2500W","property":"$flowContext(\"Einspeisung\") - $flowContext(\"Verbrauch\")\t\t","propertyType":"jsonata","rules":[{"t":"gt","v":"2500","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1540,"y":3580,"wires":[["45a1bb09159cf684"],["0f2c3c5c8743b77e"]]},{"id":"c6ee18440c5ede12","type":"switch","z":"517cd16e4d7e6ae4","name":"Auto Ein/Aus","property":"AutoEin","propertyType":"flow","rules":[{"t":"cont","v":"AutoEin","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1330,"y":3600,"wires":[["5192b4bc40dd7659"],["473eacb13a6cb11c"]]},{"id":"5d671131260cc2d4","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Aus","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2430,"y":3660,"wires":[["ddf39dae01705e59"]]},{"id":"856ab41216e0c0af","type":"delay","z":"517cd16e4d7e6ae4","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":2240,"y":3660,"wires":[["5d671131260cc2d4"]]},{"id":"55afcaa9b715c923","type":"change","z":"517cd16e4d7e6ae4","name":"Schalter Ein","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2430,"y":3560,"wires":[["ddf39dae01705e59"]]},{"id":"e6bff6b181617360","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":2040,"y":3600,"wires":[["856ab41216e0c0af"]]},{"id":"19225af3a1bf8b1a","type":"rbe","z":"517cd16e4d7e6ae4","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":2650,"y":3620,"wires":[["fe12d75c77ea96a9"]]},{"id":"9685a44b6acadc85","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 1","payload":"60","payloadType":"num","x":180,"y":3820,"wires":[["6236f30557c7e780"]]},{"id":"3a39b9030c5759fa","type":"debug","z":"517cd16e4d7e6ae4","name":"Alle Parameter","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1140,"y":3540,"wires":[]},{"id":"7971d5242a5ea489","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 2","payload":"100","payloadType":"num","x":170,"y":3900,"wires":[["6236f30557c7e780"]]},{"id":"7c3015bff0b30e2e","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 3","payload":"2300","payloadType":"num","x":170,"y":3980,"wires":[["6236f30557c7e780"]]},{"id":"a3f8d990d290d69d","type":"join","z":"517cd16e4d7e6ae4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":410,"y":3900,"wires":[["edaa035f0714e9aa"]]},{"id":"edaa035f0714e9aa","type":"change","z":"517cd16e4d7e6ae4","name":"Summe Verbrauch","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload.*)","tot":"jsonata"},{"t":"set","p":"Verbrauch","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":3900,"wires":[["cf8c319f66d88019","c9bdbf8b0e1b8b42"]]},{"id":"b29693a62628fd9f","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 1","payload":"0","payloadType":"num","x":180,"y":3860,"wires":[["6236f30557c7e780"]]},{"id":"f548db43288fcfb0","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 2","payload":"0","payloadType":"num","x":180,"y":3940,"wires":[["6236f30557c7e780"]]},{"id":"3c6178107678bdff","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Verbraucher 3","payload":"0","payloadType":"num","x":180,"y":4020,"wires":[["6236f30557c7e780"]]},{"id":"cf8c319f66d88019","type":"debug","z":"517cd16e4d7e6ae4","name":"Summe Verbrauch","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":3900,"wires":[]},{"id":"43328f2d1b31cb20","type":"inject","z":"517cd16e4d7e6ae4","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"4500","payloadType":"num","x":150,"y":3660,"wires":[["6fa8637750ac1054"]]},{"id":"ed14cc2d24f3ff16","type":"debug","z":"517cd16e4d7e6ae4","name":"Einspeisung","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":610,"y":3660,"wires":[]},{"id":"0858f158df46bb51","type":"debug","z":"517cd16e4d7e6ae4","name":"Ergebnis","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3020,"y":3580,"wires":[]},{"id":"fe12d75c77ea96a9","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"method\": \"Switch.Set\",\t   \"parameters\" : {\t       \"id\" : 0,\t       \"on\": payload       \t   }\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":2830,"y":3620,"wires":[["0858f158df46bb51"]]},{"id":"a24a10d67adf7325","type":"junction","z":"517cd16e4d7e6ae4","x":1960,"y":3660,"wires":[["856ab41216e0c0af"]]},{"id":"0f2c3c5c8743b77e","type":"junction","z":"517cd16e4d7e6ae4","x":1720,"y":3660,"wires":[["a24a10d67adf7325"]]},{"id":"473eacb13a6cb11c","type":"junction","z":"517cd16e4d7e6ae4","x":1440,"y":3660,"wires":[["0f2c3c5c8743b77e"]]},{"id":"ddf39dae01705e59","type":"junction","z":"517cd16e4d7e6ae4","x":2560,"y":3620,"wires":[["19225af3a1bf8b1a"]]},{"id":"6236f30557c7e780","type":"junction","z":"517cd16e4d7e6ae4","x":340,"y":3900,"wires":[["a3f8d990d290d69d"]]},{"id":"043e832f297c9831","type":"junction","z":"517cd16e4d7e6ae4","x":560,"y":3600,"wires":[["c9bdbf8b0e1b8b42"]]}]
              • 1
                @mickym
                das habe ich gemacht das die Verzögerung nicht bei jedem Wert (wenn <2500W,SOC<80% usw.)um eins raufgesetzt wird und mit einem >2500W, SOC>80% usw wird die Verzögerung wieder zurückgesetzt und der Filter bekommt auch eine Änderung, passt das nicht so? weil es funktioniert Eigentlich.
                • mickym
                  @1984chris Selbst wenn die Verzögerungen um 8 raufgesetz werden, und einmal ein Pumpe ein kommt, wird nicht um 1 runtergesetzt, sondern die Delay Node wird komplett zurückgesetzt. Ein reset setzt immer sofort auf 0.
                  Der Filter braucht man nur zum Schluss. Wenn Du 8 mal off/false ankommt, kommt das nur einmal durch - dafür ist der Filter ja da und den braucht man nur zum Schluss. Wie gesagt - ich habe nun Schalter ein und aus auf true und false gesetzt.
                  1 2 Replies Last reply Reply Quote 0
                  • 1
                    @mickym
                    ich bekomme halt sekündlich werte das spielt dann keine Rolle?
                    • mickym
                      @1984chris sagte in Function Node welche zwei Werte vergleicht:
                      @mickym
                      Na das wird durch den Filter blockiert - somit bekommt Dein Shelly nicht dauernd Kommandos. Du siehst doch an der debug Node Ergebnis, dass nur beim Wechsel von aus/ein ein Kommando durchkommt.
                      • 1
                        @mickym
                        Das beim Schalter ein Setze String Pumpe ein 1 habe ich gehabt weil ich ein UDP Telegramm mit diesen Inhalt versende und das im Homserver die Pumpe aktiviert.Wie kan ich das jetzt lösen?
                        • 1
                          @mickym
                          Ich meinte nur das der Zähler bei der Verzögerung (blaue Ziffer) immer höher wird.
                          • mickym
                            @mickym
                            Also Du schaltest sowohl einen Shelly - als auch irgendwas im Homeserver.
                            • 1
                              @mickym
                              ja.
                              • mickym
                                @mickym
                                Ja aber das stört ja nicht. In der Regel baut man halt keine zeitliche Verzögerungen ein, sondern nimmt ein Hysterese um unnötiges Schalten zu verhindern.
                                • 1
                                  @mickym
                                  ok dachte nur.
                                  Dann lösch ich das wieder raus.
                                  • 1
                                    @mickym
                                    Ich erkläre dir mein Vorhaben,
                                    Habe einen Homserver mit einer Zeitschaltuhr wo die Poolpumpe jeden tag 3 mal je 2 Stunden eingeschaltet wird (dafür brauche ich die UDP Telegramme) das ich diese Zeitschaltuhr ausschalte und die Poolpumpe direkt einschalte bei PV Überschuss und die Wärmepumpe.Ich hoffe hab das halbwegs erklärt.
                                    • mickym
                                      @mickym
                                      ja.
                                      Dann bereitest Du die payload je nachdem ob true oder false einmal für den Shelly und einmal für den Homeserver auf. Wird ja dann gleichzeitig gesendet.
                                      [{"id":"0858f158df46bb51","type":"debug","z":"517cd16e4d7e6ae4","name":"Ergebnis für Shelly","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3070,"y":3680,"wires":[]},{"id":"fe12d75c77ea96a9","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t   \"method\": \"Switch.Set\",\t   \"parameters\" : {\t       \"id\" : 0,\t       \"on\": payload       \t   }\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":2830,"y":3660,"wires":[["0858f158df46bb51"]]},{"id":"b1dfdd79c609cc2a","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload ? \"Pumpe ein 1\" : \"Pumpe aus 0\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":2830,"y":3580,"wires":[["f128f99f6a4ec367"]]},{"id":"f128f99f6a4ec367","type":"debug","z":"517cd16e4d7e6ae4","name":"Ergebnis für Homeserver","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":3090,"y":3560,"wires":[]}]
                                      Nochmal zur Hysterese. In der Regel macht man sowas halt nicht zeitorientiert, sondern nimmt einen Puffer.
                                      Lassen wir mal den SOC bei 80 - aber bei dem Überschuss nehme ich keine feste Grenze von 2500,
                                      sondern ich sage ab 2500 schalte Wärmepumpe ein, schalte sie aber erst aus, wenn der Überschuss unter 2300 sinkt. In dem Puffer passiert gar nichts. Also man nimmt gewisse Pufferbereiche um kurzfristige Schwankungen auszugleichen und keinen zeitlichen Puffer.
                                      • mickym
                                        @mickym
                                        Ich hab dir oben true/false einmal für den Shelly und gleichzeitig für den Homeserver aufbereitet.
                                        • mickym
                                          @mickym
                                          ok dachte nur.
                                          Was Du machen kannst, wenn Du die Anzahl Nachrichten vermindern willst, dann kannst Du auch eine delay Node nehmen und die Nachrichtenrate begrenzen.
                                          • 1
                                            @mickym
                                            das ist ja die Verzögerung oder?
                                            33158
