    5. Zugangsgeschützte API-Schnittstelle auslesen mit Blockly
    • OliverIO
      OliverIO @OliverIO last edited by
      @oliverio sagte in Zugangsgeschützte API-Schnittstelle auslesen mit Blockly:
      ah sorry
      da hat sich beim copy paste noch was eingeschlichen
      ich hatte mittlerweile korrigiert
      https://forum.iobroker.net/topic/75532/zugangsgeschützte-api-schnittstelle-auslesen-mit-blockly/54?_=1720983979855
        schnipsel71 @OliverIO last edited by schnipsel71
        @oliverio Ja, habe es schon gesehen und schon erfolgreich getestet:
        javascript.0	00:44:41.907	info	Start JavaScript script.js.common.HycubeOliverIO (Javascript/js)
        javascript.0	00:44:41.909	info	script.js.common.HycubeOliverIO: httpGet(config={"method":"get","url":"http://ip/auth/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"QmFzaWMgaHljdWJlOmh5Y3ViZQ=="}})
        javascript.0	00:44:41.910	info	script.js.common.HycubeOliverIO: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        javascript.0	00:44:41.955	info	script.js.common.HycubeOliverIO: Token ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjEwMDA2ODEKfQo=
        javascript.0	00:44:41.956	info	script.js.common.HycubeOliverIO: httpGet(config={"method":"get","url":"http://ip/get_values/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjEwMDA2ODEKfQo="}})
        javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: 200
        javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: { "Battery_C": 52, "Battery_I": -13, "Battery_P": -615, "Battery_V": 49.5, "Grid_P": -5, "Grid_V": 226.26, "Grid_f": 50.005, "Home_P": 563, "Inv1_I": 2.5, "Inv1_P": 570, "Inv1_V": 227.4, "Meter2_P": 2, "solar1_I": 0, "solar1_p": 0, "solar1_v": 7.9, "solar2_I": 0, "solar2_p": 0, "solar2_v": 8.9, "solar_total_P": 0 }
        javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: Object [AxiosHeaders] { 'access-control-allow-headers': 'Authorization', 'access-control-allow-origin': '*', connection: 'close', 'content-length': '393', 'content-type': 'application/json; charset=utf-8' }
        Jetzt muss ich die Werte nur noch in die Variablen kriegen...
        • OliverIO
          OliverIO @schnipsel71 last edited by
          @schnipsel71
          so das ist dann einfaches kopieren aus dem ursprungsskript.
          httpGet(
              'http://ip/auth/',
                  headers: {
                      "Authorization": Buffer.from("Basic hycube:hycube").toString("base64"),
              (error, response) => {
                  if (!error) {
                      let token = response.data;
                      console.log("Token "+ token);
                      httpGet(
                          'http://ip/get_values/',
                              headers: {
                                  "Authorization": token
                              if (!error) {
                                  console.log(response.statusCode);
                                  console.log(response.data);
                                  var result = JSON.parse(response.data);
                                  var GridPower= (result["Grid_P"]);
                                  var BatteryPower=result["Battery_P"];
                                  var HausPower= result["Home_P"];
                                  var solar= result["solar1_P"];
                                  setState("HyWeb.Batterie", BatteryPower);
                                  setState("HyWeb.Grid", GridPower);
                                  setState("HyWeb.Hausverbrauch", HausPower);
                                  setState("HyWeb.Solar", solar);
                              } else {
                                  console.error(error);
                  } else {
            @oliverio Klingt logisch. Ich habe es ausprobiert und es klappt!
            Vielen herzlichen Dank, OliverIO!
              TT-Tom @schnipsel71 last edited by
              @schnipsel71
              @OliverIO
              Schön das es jetzt funktioniert, das Login ist wirklich blöd gelöst.
                schnipsel71 @TT-Tom last edited by
                @tt-tom Dir natürlich auch herzlichen Dank!
                Heiko Glohr 1 Reply Last reply Reply Quote 0
                • Heiko Glohr
                  Heiko Glohr @schnipsel71 last edited by
                  @schnipsel71
                  moin, ich habe auch eine Hycube Anlage und hatte ein fertiges Script. Das funktioniert leider seit nem Update nicht mehr.
                  Nun habe ich das von dir gelesen und mich an die Arbeit gemacht.
                  Irgendwie kommen aber keine Daten aus meiner Anlage raus.
                  Ich pack das mal hier rein.
                  httpGet(
                      'http://10.10.1.139/auth/',
                          headers: {
                          if (!error) {
                              httpGet(
                                  'http://10.10.1.139/get_values/',
                                      headers: {
                                      if (!error) {
                                      } else {
                          } else {
                  Im Debugfenster kommt
                  javascript.0	14:06:19.611	info	Stopping script script.js.ioBroker.Energie.Hycube.hycube
                  javascript.0	14:06:19.711	info	Start JavaScript script.js.ioBroker.Energie.Hycube.hycube (Javascript/js)
                  javascript.0	14:06:19.724	info	script.js.ioBroker.Energie.Hycube.hycube: httpGet(config={"method":"get","url":"http://10.10.1.139/auth/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"QmFzaWMgaHljdWJlOmh5Y3ViZQ=="}})
                  javascript.0	14:06:19.727	info	script.js.ioBroker.Energie.Hycube.hycube: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  javascript.0	14:06:19.772	info	script.js.ioBroker.Energie.Hycube.hycube: Token ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjE1NjcxNzkKfQo=
                  javascript.0	14:06:19.772	info	script.js.ioBroker.Energie.Hycube.hycube: httpGet(config={"method":"get","url":"http://10.10.1.139/get_values/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjE1NjcxNzkKfQo="}})
                  javascript.0	14:06:19.782	info	script.js.ioBroker.Energie.Hycube.hycube: 200
                  javascript.0	14:06:19.782	info	script.js.ioBroker.Energie.Hycube.hycube: { "Battery_C": 100, "Battery_I": -21.299999237060547, "Battery_P": -1116.8814148439415, "Battery_V": 52.43574905395508, "Grid_I_L1": -19.158, "Grid_I_L2": -18.836, "Grid_I_L3": -18.267, "Grid_P": -13177.5, "Grid_V_L1": 237.6, "Grid_V_L2": 238.1, "Grid_V_L3": 236.2, "Grid_f": 50, "Home_P": 883.8000000000002, "Inv1_I_L1": 9.6, "Inv1_I_L2": 9.7, "Inv1_I_L3": 9.5, "Inv1_P_L1": -2365, "Inv1_P_L2": -2370, "Inv1_P_L3": -2372, "Inv1_V_L1": 238, "Inv1_V_L2": 238.4, "Inv1_V_L3": 236.1, "Meter2_P": -7043.7, "Meter3_P": -7017.6, "Solar1_I": 7.3, "Solar1_P": 2563, "Solar1_V": 381.8, "Solar2_I": 7.7, "Solar2_V": 464, "solar2_P": 3284, "solar_total_P": 5847 }
                  javascript.0	14:06:19.783	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:32:25)
                  javascript.0	14:06:19.785	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:33:25)
                  javascript.0	14:06:19.788	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:34:25)
                  javascript.0	14:06:19.789	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:35:25)
                  Datenpunkte werden keine angelegt
                  Mich würde interessieren wo da der Fehler im System ist 😉
                  • OliverIO
                    OliverIO @Heiko Glohr last edited by OliverIO
                    @heiko-glohr
                    Du musst die datenpunkte selbst anlegen.
                    SetState legt sie nicht an.
                    Die Daten kommen an, man kann sie im log erkennen
                    Heiko Glohr 2 Replies Last reply Reply Quote 0
                    • Heiko Glohr
                      Heiko Glohr @OliverIO last edited by
                      @oliverio
                      Ah ok,
                      Dann versuche ich das mal
                      Zu lange her, dass ich das gemacht hatte 😉
                      • Heiko Glohr
                        @oliverio
                        Hallo Oliviero,
                        irgendwie klappts noch nicht wirklich.
                        Das Script liegt unter Scripte\ioBroker\Energy\Hycube.
                        Unter Objekte gibts oben den Ordner Userdata.
                        Es gibt aber auch einen Ordner Javascript.
                        Hab in verschiedenen Ordner einen state Number BatteryPower angelegt aber steht immer 0 in Orange
                        Wahrscheinlich falscher Order oder falsch angelegt
                        • OliverIO
                          @heiko-glohr
                          der usprüngliche anfrager hatte diese datenpunkte
                          ich glaube ich hatte mal darauf hingewiesen, das das so nicht zulässig ist (meines Wissens nach), es gab da aber keine antwort. keine Ahnung ob ihr da noch irgend etwas anderes verwendet.
                          Wenn du die Datenpunkte angelegt hast, dann kopiere den Datenpunktnamen und trage ihn im Skript ein.
                          Also so das bspw anstatt HyWeb.batterie dort 0_userdata.Batterie dransteht.
                          • Heiko Glohr
                            @oliverio said in Zugangsgeschützte API-Schnittstelle auslesen mit Blockly:
                            GridPower
                            Hi, oki, Das habe ich verstanden und im alten Script war das auch mal so bei mir.
                            Ich hab das jetzt angepasst
                                                    setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", BatteryPower);
                                                    setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", GridPower);
                                                    setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", HausPower);
                                                    setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", solar);
                            Dann lege ich in dem Hycube Ordner den Datenpunkt an aber selbes Ergebnis. 0
                            Die Orangenen Fehler von vorhin sind aber weg. Das würde bedeuten, dass er den Ordner findet
                            • Heiko Glohr
                              @oliverio
                              sorry war mein Fehler,
                              musste natürlich den Datenpunkt komplett im Script angeben.
                              Jetzt gehts
                              Vielen Dank und schönen Sonntag
                              • OliverIO
                                @heiko-glohr du schreibst die daten immer in den gleichen datenpunkt
                                das ist die bezeichnung des datenpunkts
                                das ist die variable in der die daten enthalten sind und in den datenpunkt geschrieben werden sollen
                                BatteryPower
                                • Heiko Glohr
                                  @oliverio
                                  ok,
                                  Werte kommen jetzt an aber noch wirr
                                  Battery hat grag 81% und Wert kommt mit -1167,00667812
                                  • OliverIO
                                    @heiko-glohr
                                    das sind die werte, die oben auf der console ausgegeben worden sind
                                    von daher passt es vom wert, was da geliefert wird.
                                    die interpretation der werte kann ich nicht. ich habe das gerät nicht.
                                    aber evtl andere können da etwas dazu sagen.
                                    hast du da eine weboberfläche oder app des gerätes?
                                    der dokumentation nach
                                    file:///C:/Users/oweit/Downloads/API_Manual%20(3).pdf
                                    bedeuten die buchstaben das
                                    Unit of measurement
                                    Name Unit
                                    C Capacity percent
                                    P Power watt (W)
                                    U Voltage volt (V)
                                    I Current Ampere (A)
                                    f frequenz Hertz (Hz)
                                      "Battery_C": 100,
                                      "Grid_P": -13177.5,
                                      "Grid_V_L1": 237.6,
                                      "Grid_V_L2": 238.1,
                                      "Grid_V_L3": 236.2,
                                      "Grid_f": 50,
                                      "Inv1_I_L1": 9.6,
                                      "Inv1_I_L2": 9.7,
                                      "Inv1_I_L3": 9.5,
                                      "Inv1_P_L1": -2365,
                                      "Inv1_P_L2": -2370,
                                      "Inv1_P_L3": -2372,
                                      "Inv1_V_L1": 238,
                                      "Inv1_V_L2": 238.4,
                                      "Inv1_V_L3": 236.1,
                                      "Solar1_I": 7.3,
                                      "Solar1_P": 2563,
                                      "Solar1_V": 381.8,
                                      "Solar2_I": 7.7,
                                      "Solar2_V": 464,
                                      "solar2_P": 3284,
                                    • Heiko Glohr
                                      @oliverio
                                      ah ok,
                                      ich spiel einfach mal bissl rum.
                                      ISt ja schon mal gut wenn was zurückkommt.
                                      • Heiko Glohr
                                        @oliverio
                                        Nun passt alles soweit
                                        Werte sind richtig
                                        Solarerzeugung kommt auch richtig zurück wenn ich das Script starte
                                        Bleibt dann aber so stehen
                                        Wie erreiche ich dass die Werte immer aktuell sind 😬
                                        OliverIO S 2 Replies Last reply Reply Quote 0
                                        • OliverIO
                                          @heiko-glohr
                                          du machst um deinen vorhandenen code die schedule anweisung
                                          das müsste theoretisch alle 5 minuten dann ausführen.
                                          mehr details findest du hier
                                          https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#schedule
                                          ich arbeite damit allerdings nicht, daher nur theoretisch
                                          schedule("* */5 * * * *"),()=>{
                                          hier dein code
                                            schnipsel71 @Heiko Glohr last edited by
                                            @heiko-glohr Oder du verwendest den Befehl im Originalscript (siehe in einer meiner ersten Beiträge).
                                            6696
