    5. Zugangsgeschützte API-Schnittstelle auslesen mit Blockly
      schnipsel71 @OliverIO last edited by schnipsel71
      @oliverio Ja, habe es schon gesehen und schon erfolgreich getestet:
      javascript.0	00:44:41.907	info	Start JavaScript script.js.common.HycubeOliverIO (Javascript/js)
      javascript.0	00:44:41.909	info	script.js.common.HycubeOliverIO: httpGet(config={"method":"get","url":"http://ip/auth/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"QmFzaWMgaHljdWJlOmh5Y3ViZQ=="}})
      javascript.0	00:44:41.910	info	script.js.common.HycubeOliverIO: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0	00:44:41.955	info	script.js.common.HycubeOliverIO: Token ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjEwMDA2ODEKfQo=
      javascript.0	00:44:41.956	info	script.js.common.HycubeOliverIO: httpGet(config={"method":"get","url":"http://ip/get_values/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjEwMDA2ODEKfQo="}})
      javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: 200
      javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: { "Battery_C": 52, "Battery_I": -13, "Battery_P": -615, "Battery_V": 49.5, "Grid_P": -5, "Grid_V": 226.26, "Grid_f": 50.005, "Home_P": 563, "Inv1_I": 2.5, "Inv1_P": 570, "Inv1_V": 227.4, "Meter2_P": 2, "solar1_I": 0, "solar1_p": 0, "solar1_v": 7.9, "solar2_I": 0, "solar2_p": 0, "solar2_v": 8.9, "solar_total_P": 0 }
      javascript.0	00:44:42.016	info	script.js.common.HycubeOliverIO: Object [AxiosHeaders] { 'access-control-allow-headers': 'Authorization', 'access-control-allow-origin': '*', connection: 'close', 'content-length': '393', 'content-type': 'application/json; charset=utf-8' }
      Jetzt muss ich die Werte nur noch in die Variablen kriegen...
      • OliverIO
        OliverIO @schnipsel71 last edited by
        @schnipsel71
        so das ist dann einfaches kopieren aus dem ursprungsskript.
        httpGet(
            'http://ip/auth/',
                headers: {
                    "Authorization": Buffer.from("Basic hycube:hycube").toString("base64"),
            (error, response) => {
                if (!error) {
                    let token = response.data;
                    console.log("Token "+ token);
                    httpGet(
                        'http://ip/get_values/',
                            headers: {
                                "Authorization": token
                            if (!error) {
                                console.log(response.statusCode);
                                console.log(response.data);
                                var result = JSON.parse(response.data);
                                var GridPower= (result["Grid_P"]);
                                var BatteryPower=result["Battery_P"];
                                var HausPower= result["Home_P"];
                                var solar= result["solar1_P"];
                                setState("HyWeb.Batterie", BatteryPower);
                                setState("HyWeb.Grid", GridPower);
                                setState("HyWeb.Hausverbrauch", HausPower);
                                setState("HyWeb.Solar", solar);
                            } else {
                                console.error(error);
                } else {
          @oliverio Klingt logisch. Ich habe es ausprobiert und es klappt!
          Vielen herzlichen Dank, OliverIO!
            TT-Tom @schnipsel71 last edited by
            @schnipsel71
            @OliverIO
            Schön das es jetzt funktioniert, das Login ist wirklich blöd gelöst.
              schnipsel71 @TT-Tom last edited by
              @tt-tom Dir natürlich auch herzlichen Dank!
              Heiko Glohr 1 Reply Last reply Reply Quote 0
              • Heiko Glohr
                Heiko Glohr @schnipsel71 last edited by
                @schnipsel71
                moin, ich habe auch eine Hycube Anlage und hatte ein fertiges Script. Das funktioniert leider seit nem Update nicht mehr.
                Nun habe ich das von dir gelesen und mich an die Arbeit gemacht.
                Irgendwie kommen aber keine Daten aus meiner Anlage raus.
                Ich pack das mal hier rein.
                httpGet(
                    'http://10.10.1.139/auth/',
                        headers: {
                        if (!error) {
                            httpGet(
                                'http://10.10.1.139/get_values/',
                                    headers: {
                                    if (!error) {
                                    } else {
                        } else {
                Im Debugfenster kommt
                javascript.0	14:06:19.611	info	Stopping script script.js.ioBroker.Energie.Hycube.hycube
                javascript.0	14:06:19.711	info	Start JavaScript script.js.ioBroker.Energie.Hycube.hycube (Javascript/js)
                javascript.0	14:06:19.724	info	script.js.ioBroker.Energie.Hycube.hycube: httpGet(config={"method":"get","url":"http://10.10.1.139/auth/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"QmFzaWMgaHljdWJlOmh5Y3ViZQ=="}})
                javascript.0	14:06:19.727	info	script.js.ioBroker.Energie.Hycube.hycube: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                javascript.0	14:06:19.772	info	script.js.ioBroker.Energie.Hycube.hycube: Token ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjE1NjcxNzkKfQo=
                javascript.0	14:06:19.772	info	script.js.ioBroker.Energie.Hycube.hycube: httpGet(config={"method":"get","url":"http://10.10.1.139/get_values/","responseType":"text","responseEncoding":"utf8","timeout":2000,"headers":{"User-Agent":"Mozilla/5.0 (X11; Linux i686; rv:109.0) Gecko/20100101 Firefox/121.0","Authorization":"ewogICAgIlBlcm1pc3Npb24iOiAzLAogICAgImV4cCI6IDE3MjE1NjcxNzkKfQo="}})
                javascript.0	14:06:19.782	info	script.js.ioBroker.Energie.Hycube.hycube: 200
                javascript.0	14:06:19.782	info	script.js.ioBroker.Energie.Hycube.hycube: { "Battery_C": 100, "Battery_I": -21.299999237060547, "Battery_P": -1116.8814148439415, "Battery_V": 52.43574905395508, "Grid_I_L1": -19.158, "Grid_I_L2": -18.836, "Grid_I_L3": -18.267, "Grid_P": -13177.5, "Grid_V_L1": 237.6, "Grid_V_L2": 238.1, "Grid_V_L3": 236.2, "Grid_f": 50, "Home_P": 883.8000000000002, "Inv1_I_L1": 9.6, "Inv1_I_L2": 9.7, "Inv1_I_L3": 9.5, "Inv1_P_L1": -2365, "Inv1_P_L2": -2370, "Inv1_P_L3": -2372, "Inv1_V_L1": 238, "Inv1_V_L2": 238.4, "Inv1_V_L3": 236.1, "Meter2_P": -7043.7, "Meter3_P": -7017.6, "Solar1_I": 7.3, "Solar1_P": 2563, "Solar1_V": 381.8, "Solar2_I": 7.7, "Solar2_V": 464, "solar2_P": 3284, "solar_total_P": 5847 }
                javascript.0	14:06:19.783	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:32:25)
                javascript.0	14:06:19.785	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:33:25)
                javascript.0	14:06:19.788	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:34:25)
                javascript.0	14:06:19.789	warn	at Object.<anonymous> (script.js.ioBroker.Energie.Hycube.hycube:35:25)
                Datenpunkte werden keine angelegt
                Mich würde interessieren wo da der Fehler im System ist 😉
                • OliverIO
                  OliverIO @Heiko Glohr last edited by OliverIO
                  @heiko-glohr
                  Du musst die datenpunkte selbst anlegen.
                  SetState legt sie nicht an.
                  Die Daten kommen an, man kann sie im log erkennen
                  Heiko Glohr 2 Replies Last reply Reply Quote 0
                  • Heiko Glohr
                    Heiko Glohr @OliverIO last edited by
                    @oliverio
                    Ah ok,
                    Dann versuche ich das mal
                    Zu lange her, dass ich das gemacht hatte 😉
                    • Heiko Glohr
                      @oliverio
                      Hallo Oliviero,
                      irgendwie klappts noch nicht wirklich.
                      Das Script liegt unter Scripte\ioBroker\Energy\Hycube.
                      Unter Objekte gibts oben den Ordner Userdata.
                      Es gibt aber auch einen Ordner Javascript.
                      Hab in verschiedenen Ordner einen state Number BatteryPower angelegt aber steht immer 0 in Orange
                      Wahrscheinlich falscher Order oder falsch angelegt
                      • OliverIO
                        @heiko-glohr
                        der usprüngliche anfrager hatte diese datenpunkte
                        ich glaube ich hatte mal darauf hingewiesen, das das so nicht zulässig ist (meines Wissens nach), es gab da aber keine antwort. keine Ahnung ob ihr da noch irgend etwas anderes verwendet.
                        Wenn du die Datenpunkte angelegt hast, dann kopiere den Datenpunktnamen und trage ihn im Skript ein.
                        Also so das bspw anstatt HyWeb.batterie dort 0_userdata.Batterie dransteht.
                        • Heiko Glohr
                          @oliverio said in Zugangsgeschützte API-Schnittstelle auslesen mit Blockly:
                          GridPower
                          Hi, oki, Das habe ich verstanden und im alten Script war das auch mal so bei mir.
                          Ich hab das jetzt angepasst
                                                  setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", BatteryPower);
                                                  setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", GridPower);
                                                  setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", HausPower);
                                                  setState("0_userdata.0.Datenpunkte_ioBroker.Hycube", solar);
                          Dann lege ich in dem Hycube Ordner den Datenpunkt an aber selbes Ergebnis. 0
                          Die Orangenen Fehler von vorhin sind aber weg. Das würde bedeuten, dass er den Ordner findet
                          • Heiko Glohr
                            @oliverio
                            sorry war mein Fehler,
                            musste natürlich den Datenpunkt komplett im Script angeben.
                            Jetzt gehts
                            Vielen Dank und schönen Sonntag
                            • OliverIO
                              @heiko-glohr du schreibst die daten immer in den gleichen datenpunkt
                              das ist die bezeichnung des datenpunkts
                              das ist die variable in der die daten enthalten sind und in den datenpunkt geschrieben werden sollen
                              BatteryPower
                              • Heiko Glohr
                                @oliverio
                                ok,
                                Werte kommen jetzt an aber noch wirr
                                Battery hat grag 81% und Wert kommt mit -1167,00667812
                                • OliverIO
                                  @heiko-glohr
                                  das sind die werte, die oben auf der console ausgegeben worden sind
                                  von daher passt es vom wert, was da geliefert wird.
                                  die interpretation der werte kann ich nicht. ich habe das gerät nicht.
                                  aber evtl andere können da etwas dazu sagen.
                                  hast du da eine weboberfläche oder app des gerätes?
                                  der dokumentation nach
                                  file:///C:/Users/oweit/Downloads/API_Manual%20(3).pdf
                                  bedeuten die buchstaben das
                                  Unit of measurement
                                  Name Unit
                                  C Capacity percent
                                  P Power watt (W)
                                  U Voltage volt (V)
                                  I Current Ampere (A)
                                  f frequenz Hertz (Hz)
                                    "Battery_C": 100,
                                    "Grid_P": -13177.5,
                                    "Grid_V_L1": 237.6,
                                    "Grid_V_L2": 238.1,
                                    "Grid_V_L3": 236.2,
                                    "Grid_f": 50,
                                    "Inv1_I_L1": 9.6,
                                    "Inv1_I_L2": 9.7,
                                    "Inv1_I_L3": 9.5,
                                    "Inv1_P_L1": -2365,
                                    "Inv1_P_L2": -2370,
                                    "Inv1_P_L3": -2372,
                                    "Inv1_V_L1": 238,
                                    "Inv1_V_L2": 238.4,
                                    "Inv1_V_L3": 236.1,
                                    "Solar1_I": 7.3,
                                    "Solar1_P": 2563,
                                    "Solar1_V": 381.8,
                                    "Solar2_I": 7.7,
                                    "Solar2_V": 464,
                                    "solar2_P": 3284,
                                  • Heiko Glohr
                                    @oliverio
                                    ah ok,
                                    ich spiel einfach mal bissl rum.
                                    ISt ja schon mal gut wenn was zurückkommt.
                                    • Heiko Glohr
                                      @oliverio
                                      Nun passt alles soweit
                                      Werte sind richtig
                                      Solarerzeugung kommt auch richtig zurück wenn ich das Script starte
                                      Bleibt dann aber so stehen
                                      Wie erreiche ich dass die Werte immer aktuell sind 😬
                                      OliverIO S 2 Replies Last reply Reply Quote 0
                                      • OliverIO
                                        @heiko-glohr
                                        du machst um deinen vorhandenen code die schedule anweisung
                                        das müsste theoretisch alle 5 minuten dann ausführen.
                                        mehr details findest du hier
                                        https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#schedule
                                        ich arbeite damit allerdings nicht, daher nur theoretisch
                                        schedule("* */5 * * * *"),()=>{
                                        hier dein code
                                          schnipsel71 @Heiko Glohr last edited by
                                          @heiko-glohr Oder du verwendest den Befehl im Originalscript (siehe in einer meiner ersten Beiträge).
                                          • Heiko Glohr
                                            @schnipsel71
                                            so ähnlich hab ich es gemacht 😉
                                            Jetzt muss ich nur noch schauen wie das alles zusammenspielt.
                                            Ich hab Ost/West und nen SMA Wechselrichter und ich meine, dass ich beides auslesen muss um die korrekten Angaben zu bekommen.
                                            Die Zahlen nur aus der Hycube Anlage stimmen nicht mit dem was die App anzeigt.
                                            Da wäre die Gesamtproduktion grad mal die Hälfte.
                                            Wenn man bei denen nachfragt können die leider nicht viel beitragen.
                                            6696
