    4. iCal Apple Kalender verknüpfen
      Homoran Global Moderator Administrators @MarcIO last edited by Homoran
      @marcio is this posted in the English section intentionally?
      Did you read the docu?
        Oh, it was meant for the german community. But however we can continue here as well.
        Already did and followed all steps.
          @marcio moved!
          • wendy2702
            wendy2702 last edited by
            Die Instanz mal auf Debug stellen und dann das logfile posten bzw. Mal schauen was drin steht
              MarcIO @wendy2702 last edited by MarcIO
              @wendy2702
              Hoffentlich gut lesbar..
              wendy2702 haus-automatisierung 2 Replies Last reply Reply Quote 0
              • JohGre
                JohGre last edited by
                @marcio Hast du's schon mit https probiert
                • wendy2702
                  wendy2702 @MarcIO last edited by
                  @marcio am Handy leider nicht.
                  Bitte als Text in Code Tags </> posten
                    Homoran Global Moderator Administrators @wendy2702 last edited by
                    @wendy2702 sagte in iCal Apple Kalender verknüpfen:
                    kein Wunder bei einer schwarzen 4k Briefmarke
                    @MarcIO
                    siehe https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
                    • haus-automatisierung
                      haus-automatisierung Developer Most Active @MarcIO last edited by
                      @marcio Der iCal-Adapter kann kein CalDAV.
                      M MartinP 2 Replies Last reply Reply Quote 0
                        MarcIO last edited by MarcIO
                        Danke für den Hinweis 😄
                        2024-07-22 14:20:07.951	info	Terminated (NO_ERROR): Without reason
                        2024-07-22 14:20:07.950	debug	Plugin sentry destroyed
                        2024-07-22 14:20:02.943	info	All calenders could not be processed, Do not clean up events
                        2024-07-22 14:20:02.942	warn	Error reading "http://p102-caldav.icloud.com/published/2/Mjxxx6dA": Cannot read URL: "http://p102-caldav.icloud.com/published/2/MjkxODAxxxDcLvG_Iu6dA"
                        2024-07-22 14:20:02.941	warn	Error reading from URL "http://p102-caldav.icloud.com/published/2/Mjkxxxx6dA"
                        2024-07-22 14:20:02.716	debug	reading calendar from URL: http://p102-caldav.icloud.com/published/2/MjkxODAzxxxvG_Iu6dA, color: #000000
                        2024-07-22 14:20:02.570	info	starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.15.1, js-controller: 5.0.19
                        2024-07-22 14:20:02.004	debug	Plugin sentry Initialize Plugin (enabled=true)
                        2024-07-22 14:20:01.964	debug	States connected to redis: 127.0.0.1:9000
                        2024-07-22 14:20:01.905	debug	States create User PubSub Client
                        2024-07-22 14:20:01.903	debug	States create System PubSub Client
                        2024-07-22 14:20:01.890	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        2024-07-22 14:20:01.858	debug	Objects connected to redis: 127.0.0.1:9001
                        2024-07-22 14:20:01.848	debug	Objects client initialize lua scripts
                        2024-07-22 14:20:01.810	debug	Objects create User PubSub Client
                        2024-07-22 14:20:01.808	debug	Objects create System PubSub Client
                        2024-07-22 14:20:01.805	debug	Objects client ready ... initialize now
                        2024-07-22 14:20:01.758	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2024-07-22 14:15:07.926	info	Terminated (NO_ERROR): Without reason
                        2024-07-22 14:15:07.925	debug	Plugin sentry destroyed
                        2024-07-22 14:15:02.918	info	All calenders could not be processed, Do not clean up events
                        2024-07-22 14:15:02.917	warn	Error reading "http://p102-caldav.icloud.com/published/2/MxxxxLvG_Iu6dA": Cannot read URL: "http://p102-caldav.icloud.com/published/2/MjkxODAzNTI2MjkxODAzNYvJNo8h8kCm2kxUdK1-Az79RwSwuRaI3xxxE4gs6c3hDcLvG_Iu6dA"
                        2024-07-22 14:15:02.916	warn	Error reading from URL "http://p102-caldav.icloud.com/published/2/Mjkxxxxxs6c3hDcLvG_Iu6dA"
                        @JohGre
                        Jap, hatte leider auch nicht funktioniert
                        wendy2702 DJMarc75 2 Replies Last reply Reply Quote 0
                        • wendy2702
                          @marcio siehe Beitrag von @haus-automatisierung
                            MarcIO @haus-automatisierung last edited by MarcIO
                            Also hier die Anleitung (https://www.iobroker.net/docu/index-298.htm?page_id=154&lang=de), der ich nachgegangen bin.
                            Gibt es dennoch eine andere Möglichkeit einen Apple Kalender zu integrieren?
                            JohGre 1 Reply Last reply Reply Quote 0
                            • JohGre
                              JohGre @MarcIO last edited by
                              @marcio Hast du jetzt schon https versucht. Habe selber zwei AppleCaleder eingebunden
                              • MartinP
                                MartinP @haus-automatisierung last edited by MartinP
                                @haus-automatisierung said in iCal Apple Kalender verknüpfen:
                                Ich habe den iCal-Adapter an meine heimische Radicale - Instanz gehängt ...
                                Die Leute von radicale schreiben...
                                Free and Open-Source CalDAV and CardDAV Server
                                https://radicale.org/v3.html
                                Funktioniert ...
                                Ich glaube eher, dass die "intern gehosteten" Apple Kalender ein anderes Format haben ...
                                Radicale aufzusetzen und dann im iPhone Kalender einen Radicale Kalender zu nutzen ist aber auch nicht so ganz ohne ... Apple verlangt seit iOS 13 ssl und Schlüssellängen von mindestens 2048 ...
                                https://forum.emclient.com/t/what-is-the-caldav-url-for-an-icloud-account/78102/6
                                mich würde wirklich wundern, wenn eine http:// icloud - URL noch funktioniert ...
                                  MarcIO @JohGre last edited by
                                  @johgre
                                  Ja hab ich probiert, hat leider nicht funktioniert.
                                  Hast du in deiner URL auch dieses "caldav"?
                                  https://p102-caldav.icloud.com/pxxxxxxxxx
                                  @MartinP eben den Adapter Webcal entdeckt. Verspricht Erfolg mit caldav, scheint erstmal einfacher zu sein, sonst gebe ich mal deinen Vorschlag eine Chance. Danke dir!
                                  • MartinP
                                    MartinP last edited by MartinP
                                    @marcio Ich würde noch versuchen, die URL in den Grafiken und den Listings zu anonymisieren.... die URL funktioniert im Browser und gibt eine *.ics Datei aus, die man herunterladen kann ....
                                    Darf denn Dein iobroker ins Internet?
                                    ist die Adresse denn erreichbar?
                                    Was sagt denn ein wget aus der Linux-Maschine des iobroker auf die URL
                                    wget http://p102-caldav.icloud.com/published/2/Mj.............................."
                                    • DJMarc75
                                      DJMarc75 @MarcIO last edited by
                                      @marcio wie @MartinP schon schrieb
                                      DRINGEND persönliche Daten aus Deinen Beiträgen entfernen ( oder @homoran kann das machen ?!)
                                      • JohGre
                                        @marcio Ja. Der Kalender ist freigegeben?
                                          @martinp Oh f**k, danke für die Erinnerung, Anonymisierung done!
                                          Internet sollte im Normalfall funktionieren, den Code kann ich allerdings morgen erst wieder probieren.
                                          @JohGre Ja ist freigegeben. Der Link funktioniert manuell, allerdings kommt eben in IOB nichts an. An der Konfiguration kann da nichts liegen, oder?
                                          MartinP JohGre 2 Replies Last reply Reply Quote 0
                                          • MartinP
                                            MartinP @MarcIO last edited by
                                            @marcio Ich habe zwei Ideen
                                            1. dass irgendein Muster in dem INHALT der ICS-Datei den ical-Adapter zum straucheln bringt ....
                                            2. der User-Agent, der vom ICAL-Adapter der Apple-Cloud gemeldet wird, diese renitent werden lässt...
                                            (1) könnte man testen, indem man die ics-Datei herunterlädt, und den ical Adapter die Datei einlesen lässt ...
                                            (2) im ICAL-Adapter kann man den User-Agenten irgendwie konfigurieren ...
                                            1929
