    4. iCal Apple Kalender verknüpfen
      Homoran Global Moderator Administrators @wendy2702 last edited by
      @wendy2702 sagte in iCal Apple Kalender verknüpfen:
      am Handy leider nicht.
      kein Wunder bei einer schwarzen 4k Briefmarke
      @MarcIO
      siehe https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge/1
      • haus-automatisierung
        haus-automatisierung Developer Most Active @MarcIO last edited by
        @marcio Der iCal-Adapter kann kein CalDAV.
        M MartinP 2 Replies Last reply Reply Quote 0
          MarcIO last edited by MarcIO
          Danke für den Hinweis 😄
          2024-07-22 14:20:07.951	info	Terminated (NO_ERROR): Without reason
          2024-07-22 14:20:07.950	debug	Plugin sentry destroyed
          2024-07-22 14:20:02.943	info	All calenders could not be processed, Do not clean up events
          2024-07-22 14:20:02.942	warn	Error reading "http://p102-caldav.icloud.com/published/2/Mjxxx6dA": Cannot read URL: "http://p102-caldav.icloud.com/published/2/MjkxODAxxxDcLvG_Iu6dA"
          2024-07-22 14:20:02.941	warn	Error reading from URL "http://p102-caldav.icloud.com/published/2/Mjkxxxx6dA"
          2024-07-22 14:20:02.716	debug	reading calendar from URL: http://p102-caldav.icloud.com/published/2/MjkxODAzxxxvG_Iu6dA, color: #000000
          2024-07-22 14:20:02.570	info	starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.ical, node: v20.15.1, js-controller: 5.0.19
          2024-07-22 14:20:02.004	debug	Plugin sentry Initialize Plugin (enabled=true)
          2024-07-22 14:20:01.964	debug	States connected to redis: 127.0.0.1:9000
          2024-07-22 14:20:01.905	debug	States create User PubSub Client
          2024-07-22 14:20:01.903	debug	States create System PubSub Client
          2024-07-22 14:20:01.890	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          2024-07-22 14:20:01.858	debug	Objects connected to redis: 127.0.0.1:9001
          2024-07-22 14:20:01.848	debug	Objects client initialize lua scripts
          2024-07-22 14:20:01.810	debug	Objects create User PubSub Client
          2024-07-22 14:20:01.808	debug	Objects create System PubSub Client
          2024-07-22 14:20:01.805	debug	Objects client ready ... initialize now
          2024-07-22 14:20:01.758	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          2024-07-22 14:15:07.926	info	Terminated (NO_ERROR): Without reason
          2024-07-22 14:15:07.925	debug	Plugin sentry destroyed
          2024-07-22 14:15:02.918	info	All calenders could not be processed, Do not clean up events
          2024-07-22 14:15:02.917	warn	Error reading "http://p102-caldav.icloud.com/published/2/MxxxxLvG_Iu6dA": Cannot read URL: "http://p102-caldav.icloud.com/published/2/MjkxODAzNTI2MjkxODAzNYvJNo8h8kCm2kxUdK1-Az79RwSwuRaI3xxxE4gs6c3hDcLvG_Iu6dA"
          2024-07-22 14:15:02.916	warn	Error reading from URL "http://p102-caldav.icloud.com/published/2/Mjkxxxxxs6c3hDcLvG_Iu6dA"
          @JohGre
          Jap, hatte leider auch nicht funktioniert
          wendy2702 DJMarc75 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @MarcIO last edited by
            @marcio siehe Beitrag von @haus-automatisierung
              MarcIO @haus-automatisierung last edited by MarcIO
              Also hier die Anleitung (https://www.iobroker.net/docu/index-298.htm?page_id=154&lang=de), der ich nachgegangen bin.
              Gibt es dennoch eine andere Möglichkeit einen Apple Kalender zu integrieren?
              JohGre 1 Reply Last reply Reply Quote 0
              • JohGre
                JohGre @MarcIO last edited by
                @marcio Hast du jetzt schon https versucht. Habe selber zwei AppleCaleder eingebunden
                • MartinP
                  MartinP @haus-automatisierung last edited by MartinP
                  @haus-automatisierung said in iCal Apple Kalender verknüpfen:
                  Ich habe den iCal-Adapter an meine heimische Radicale - Instanz gehängt ...
                  Die Leute von radicale schreiben...
                  Free and Open-Source CalDAV and CardDAV Server
                  https://radicale.org/v3.html
                  Funktioniert ...
                  Ich glaube eher, dass die "intern gehosteten" Apple Kalender ein anderes Format haben ...
                  Radicale aufzusetzen und dann im iPhone Kalender einen Radicale Kalender zu nutzen ist aber auch nicht so ganz ohne ... Apple verlangt seit iOS 13 ssl und Schlüssellängen von mindestens 2048 ...
                  https://forum.emclient.com/t/what-is-the-caldav-url-for-an-icloud-account/78102/6
                  mich würde wirklich wundern, wenn eine http:// icloud - URL noch funktioniert ...
                    MarcIO @JohGre last edited by
                    @johgre
                    Ja hab ich probiert, hat leider nicht funktioniert.
                    Hast du in deiner URL auch dieses "caldav"?
                    https://p102-caldav.icloud.com/pxxxxxxxxx
                    @MartinP eben den Adapter Webcal entdeckt. Verspricht Erfolg mit caldav, scheint erstmal einfacher zu sein, sonst gebe ich mal deinen Vorschlag eine Chance. Danke dir!
                    • MartinP
                      MartinP last edited by MartinP
                      @marcio Ich würde noch versuchen, die URL in den Grafiken und den Listings zu anonymisieren.... die URL funktioniert im Browser und gibt eine *.ics Datei aus, die man herunterladen kann ....
                      Darf denn Dein iobroker ins Internet?
                      ist die Adresse denn erreichbar?
                      Was sagt denn ein wget aus der Linux-Maschine des iobroker auf die URL
                      wget http://p102-caldav.icloud.com/published/2/Mj.............................."
                      • DJMarc75
                        DJMarc75 @MarcIO last edited by
                        @marcio wie @MartinP schon schrieb
                        DRINGEND persönliche Daten aus Deinen Beiträgen entfernen ( oder @homoran kann das machen ?!)
                        • JohGre
                          @marcio Ja. Der Kalender ist freigegeben?
                            @martinp Oh f**k, danke für die Erinnerung, Anonymisierung done!
                            Internet sollte im Normalfall funktionieren, den Code kann ich allerdings morgen erst wieder probieren.
                            @JohGre Ja ist freigegeben. Der Link funktioniert manuell, allerdings kommt eben in IOB nichts an. An der Konfiguration kann da nichts liegen, oder?
                            MartinP JohGre 2 Replies Last reply Reply Quote 0
                            • MartinP
                              MartinP @MarcIO last edited by
                              @marcio Ich habe zwei Ideen
                              1. dass irgendein Muster in dem INHALT der ICS-Datei den ical-Adapter zum straucheln bringt ....
                              2. der User-Agent, der vom ICAL-Adapter der Apple-Cloud gemeldet wird, diese renitent werden lässt...
                              (1) könnte man testen, indem man die ics-Datei herunterlädt, und den ical Adapter die Datei einlesen lässt ...
                              (2) im ICAL-Adapter kann man den User-Agenten irgendwie konfigurieren ...
                              • JohGre
                                @marcio Hab nichts besonderes eingestellt.
                                  Homoran Global Moderator Administrators @DJMarc75 last edited by Homoran
                                  @djmarc75 sagte in iCal Apple Kalender verknüpfen:
                                  nee 🤧
                                  • MartinP
                                    @homoran Gute Besserung...
                                    M 1 Reply Last reply Reply Quote 2
                                      MarcIO @MartinP last edited by
                                      @martinp also deine Vermutung lag richtig, der IOB kommt leider nicht ins Internet.
                                      Die Datei habe ich erstmal lokal abgelegt und kann per IP zugreifen.
                                      1929
