    4. Beta Test js-controller Kiera (v6.0)
      Gui last edited by Gui
      Hi, beim aktuellen Update vom js-controller erhalte ich folgende Fehlermeldung:
      Update js-controller from @6.0.7 to @6.0.8
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.7.0
      Installing iobroker.js-controller@6.0.8... (System call)
      npm error code 6
      npm error path /opt/iobroker/node_modules/iobroker.js-controller
      npm error command failed
      npm error command sh -c node iobroker.js setup first
      npm error Uncaught Rejection: TypeError: callback is not a function
      npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
      npm error This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      npm error TypeError: callback is not a function
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-17T15_07_38_698Z-debug-0.log
      host.iob10 Cannot install iobroker.js-controller@6.0.8: 6
      • Adaptername: iobroker.js-controller
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: 6.0.8
      • js-controller Version: 6.0.7
      • Admin Version: 7.0.17
      • Hardwaresystem: lxc with PROXMOX on NUC
      • Arbeitsspeicher: 32GB
      • Festplattenart: SSD
      • Betriebssystem: Debian
      • Nodejs-Version: 20.15.1
      • NPM-Version: 10.7.0
      • Installationsart: Skript und Manuell
      • Image, Docker genutzt: Nein
      • Ort, Name der Imagedatei: ...
      Linux User bitte hier den Output von iob diag einfügen.
                              v.2024-05-22
       Static hostname: iob10
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.8-2-pve
          Architecture: x86-64
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                0
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:
      /usr/bin/nodejs         v20.15.1
      /usr/bin/node           v20.15.1
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.1
      Recommended versions are nodejs 20.15.1 and npm 10.7.0
      MEMORY:
      Mem:            3.2G        1.9G        310M        163K        1.1G        1.4G
      Swap:             0B          0B          0B
      Total:          3.2G        1.9G        310M
      Active iob-Instances:   37
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.7
                              admin                   7.0.17
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      + system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.1                  : admin                 : iob10                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                13975
      States:                 10431
      Size of iob-Database:
      5.8M    /opt/iobroker/iobroker-data/objects.json.bak
      1.4M    /opt/iobroker/iobroker-data/states.json.bak
      Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Gui last edited by
        @gui sagte in Fehler bei Update js-controller 6.0.7 auf 6.0.8:
        die Langfassung wäre hier jetzt sinnvoller.
        sonst noch mehr Beta-Versionen?
        wie durchgeführt?
        und aktuell ist ebenfalls relativ
        auch das ist Beta!
          @gui ich hab das mal zum Betatester Thread hinzugefügt
          • Feuersturm
            Feuersturm last edited by
            @foxriver76 js-controller 6.0.9 lies sich ohne Probleme auf meinen Testsystemen installieren und es gibt keine Auffälligkeiten
              Thomas Braun Most Active @Gui last edited by
              @gui
              Bitte NICHT als root im LXC herumturnen.
                Gui @Thomas Braun last edited by
                Hi @thomas-braun, ich werde das mal nicht weiter kommentieren, und nehme einfach an, dass es ein allgemeiner guter Ratschlag war.
                Ich habe es als erstes über die Weboberfläche gemacht, mit dem selben Ergebnis, und die läuft nicht unter root.
                  @gui
                  Im Container hampelt ein root herum:
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                0
                  Macht man NICHT. Ist kein Ratschlag, sondern allgemein übliches Verhalten aka 'best practise'.
                  Leg dir einen user dafür an, wenn es noch keinen geben sollte.
                    i@thomas-braun das war ich. Es gibt einen user für iobroker. Ich arbeite aber lieber als root, und ja ich weiß, das man das nicht macht ...
                    Zurück zum Problem. Hab mal die Harte Tour gemacht:
                    • js-controller Verzeichniss gelöscht
                    • js-controller neu installier "npm install iobroker.js-controller"
                    • npm rebuild
                    • iob upload
                    Bis jetzt sieht alles gut.
                    Aber bitte nicht nachmachen !!!!
                    Und bitte nicht schimpfen 😉
                    Thomas Braun G 2 Replies Last reply Reply Quote 0
                      @gui sagte in Beta Test js-controller Kiera (v6.0):
                      Harakiri?
                      Nein, man macht es NICHT.
                        Gui @Gui last edited by Gui
                        Hat nicht funktioniert. Nach ein paar Stunden waren plötzlich alle Instanzen down.
                        War ein Versuch auf die schnelle ...
                        ... und ja, ich gewöhne mir den root ab.
                          Du könntest ja auch mal ordentlich mit dem System umgehen...
                            @thomas-braun mach (versuch) ich doch.
                            Muss die Sache mal in ruhe angehen. Vielleicht noch als Ergänzung. Ich habe eine "Master-Slave" Installation, also 2 Instanzen mit Redis.
                            So richtig "Master-Slave" gibt es ja nicht mehr. Beim Master habe ich den Update noch nicht probiert.
                            Mal schauen ...
                            • Feuersturm
                              Feuersturm @Gui last edited by
                              @gui Aus dem ersten Beitrag
                              Achtung: MASTER/SLAVE-Systeme Reihenfolgen beachten!
                              Bei einem Multi-Host-System, welches auf js-controller 5.0.x läuft, ist es beim Update auf Version 6.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                              ? 1 Reply Last reply Reply Quote 1
                                A Former User @Feuersturm last edited by
                                @feuersturm
                                wie heisst es so schoen? kaum macht man's richtig... funktionierts... 😄
                                  Gui @Guest last edited by
                                  @ilovegym fast 😉
                                  @thomas-braun Danke für den Tipp.
                                  Master - ohne Probleme auf 6.0.9. Beim Slave dann gleicher Fehler.
                                  Da muss beim letzten Update irgendetwas kaputt gegangen sein.
                                    So, Backup eingespielt bei dem der Adapter noch 6.0.6 war, update auf 6.0.9 ohne Probleme.
                                    Muss also von 6.0.6 auf 6.0.7 was schief gelaufen sein.
                                    • Feuersturm
                                      @gui js-controller 6.0.7 war buggy und hat nicht funktioniert.
                                        Flugschüler @Feuersturm last edited by
                                        Seit dem update 6.0.9 und auch eine Version davor funktioniert bei mir beim Blockly request (deprecated) nicht mehr. Ich will damit den PC herunterfahren. Hat vorher funktioniert, jetzt nicht mehr. Ist das bei euch auch so?
                                        JB_Sullivan T UweRLP 3 Replies Last reply Reply Quote 0
                                        • JB_Sullivan
                                          JB_Sullivan @Flugschüler last edited by
                                          @flugschüler
                                          Sicher das es an der Host Version liegt? Welche Adapter Version vom JavaSkript Adapter hast du?
                                          In einem anderen Adapter Thread gibt es aktuell auch Probleme mit allem was größer als 8.7.1 ist. Könnte also auch am JS-Adapter liegen (für den Fall das du mehrere Sachen gleichzeitig geupdatet hast)
                                            Flugschüler @JB_Sullivan last edited by
                                            @jb_sullivan Ja stimmt. Ich glaub es liegt am Adapter. Wohin kann ich mich da wenden, hast du einen link?
                                            beta js-controller kiera test
                                            39
                                            331
                                            73492
