    4. Node-Red
    5. Function Node welche zwei Werte vergleicht
    • mickym
      mickym Most Active @1984chris last edited by
      @1984chris ok.
      • mickym
        @1984chris sagte in Function Node welche zwei Werte vergleicht:
        @mickym
        ich probier mal und dan zeig ichs dir...
        So berechne Du mal die Restminuten, die deine Pumpe noch laufen soll.
        Hier wird dann von Mitternacht die Restzeit abgerechnet, die die Pumpe dann noch für den Rest des Tages läuft.
        [{"id":"519e7da906393331","type":"inject","z":"517cd16e4d7e6ae4","name":"Restzeit","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"88","payloadType":"num","x":380,"y":4160,"wires":[["5c2762dfdf299aea"]]},{"id":"1e6ecc250f82fdce","type":"trigger","z":"517cd16e4d7e6ae4","name":"","op1":"true","op2":"false","op1type":"bool","op2type":"bool","duration":"1","extend":true,"overrideDelay":true,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":790,"y":4200,"wires":[["f6e82180b4e01d81"]]},{"id":"5c2762dfdf299aea","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"payload * 60000","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$moment().isAfter($moment().endOf('day').subtract($$.payload,'minute'))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":4200,"wires":[["1e6ecc250f82fdce"]]},{"id":"f6e82180b4e01d81","type":"debug","z":"517cd16e4d7e6ae4","name":"true/false schalten","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":990,"y":4200,"wires":[]}]
        1 1 Reply Last reply Reply Quote 0
        • 1
          1984chris @mickym last edited by
          @mickym
          Ich hätte jetzt schon angefangen würde wieder über den Shelly alle Minuten hochzählen lassen. Aber wie kann ich z.b jeden Tag um 18 Uhr abfragen ob die Pumpe 6 Stunden gelaufen ist wenn nicht erreicht soll diese laufen.
                  "id": "05cb99c34b0e088c",
                  "type": "switch",
                  "z": "b7365eb2cd9f043a",
                  "name": "Laufzeit",
                  "property": "payload.switch0.output",
                  "propertyType": "msg",
                  "rules": [
                          "t": "true"
                          "t": "false"
                  "checkall": "true",
                  "repair": false,
                  "outputs": 2,
                  "x": 1940,
                  "y": 760,
                  "wires": [
                          "299890253e280731"
                  "id": "c25482fa9bf763f0",
                  "type": "shelly-gen2",
                  "hostname": "192.168.1.110",
                  "description": "",
                  "mode": "polling",
                  "server": "",
                  "outputmode": "event",
                  "uploadretryinterval": 5000,
                  "pollinginterval": "5000",
                  "pollstatus": true,
                  "getstatusoncommand": true,
                  "devicetype": "Relay",
                  "outputs": 1,
                  "x": 1760,
                  "y": 760,
                  "wires": [
                          "05cb99c34b0e088c"
                  "id": "c5907383823c7ea9",
                  "type": "debug",
                  "name": "debug 16",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "complete": "false",
                  "statusVal": "",
                  "statusType": "auto",
                  "x": 2400,
                  "y": 760,
                  "wires": []
                  "id": "299890253e280731",
                  "type": "change",
                  "name": "Setze Laufzeit",
                  "rules": [
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "LaufzeitPoolpumpe",
                          "tot": "flow"
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "$exists(payload) ? payload : 0",
                          "tot": "jsonata"
                          "t": "set",
                          "p": "payload",
                          "pt": "msg",
                          "to": "payload + 1",
                          "tot": "jsonata"
                          "t": "set",
                          "p": "LaufzeitPoolpumpe",
                          "pt": "flow",
                          "to": "payload",
                          "tot": "msg"
                  "action": "",
                  "property": "",
                  "from": "",
                  "to": "",
                  "reg": false,
                  "x": 2140,
                  "y": 760,
                  "wires": [
                          "1a4d851ad146ec1b",
                          "c5907383823c7ea9"
                  "id": "3f5208fb9a554bb3",
                  "type": "inject",
                  "name": "Zeit",
                  "props": [
                          "p": "test",
                          "v": "1",
                          "vt": "num"
                  "repeat": "",
                  "crontab": "00 12 * * *",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "",
                  "x": 2430,
                  "y": 920,
                  "wires": [
                  "id": "1a4d851ad146ec1b",
                  "type": "switch",
                  "name": "",
                  "property": "payload",
                  "rules": [
                          "t": "gte",
                          "v": "20",
                          "vt": "str"
                          "t": "lte",
                          "v": "20",
                          "vt": "str"
                  "checkall": "true",
                  "repair": false,
                  "outputs": 2,
                  "x": 2430,
                  "y": 860,
                  "wires": [
          oder ist das der falsche Ansatz?
          • mickym
            Nein das passt schon - ich würde nur keinen extra Trigger mehr nehmen und anstatt der Laufzeit gleich die Restlaufzeit berechnen.
            Die Frage ist auch, willst du die Restlaufzeit immer um 18 Uhr beginnen lassen (im Sommer läuft sie ja vielleicht auch so) oder wie ich es berechnet habe. Die Restlaufzeit setzt Du um 0 Uhr zurück. Ich nehm mal Deinen Flow und leg die beiden mal zusammen.
            • 1
              @mickym
              mann könnte ja sagen wenn bis 21 Uhr nicht erreicht dann soll sie laufen oder?
              • mickym
                @1984chris Ich hätte jetzt einfach die Restlaufzeit von Mitternacht abgezogen. Das heißt sie beginnt irgendwann zwischen 18:00 und Mitternacht zu starten, je nachdem wieviel Restlaufzeit noch übrig ist.
                • mickym
                  mickym Most Active last edited by mickym
                  Hier mal der Flow auf Basis Deines Flows:
                  Der Unterschied zu Deiner Lösung ist, dass ich von der Mindestlaufzeit, also 360 Minuten die Laufzeit gleich runterzähle, um gleich die Restlaufzeit zu ermitteln.
                  PS:
                  Die trigger Node war falsch - hier nochmal der korrigierte Flow:
                  [{"id":"05cb99c34b0e088c","type":"switch","z":"517cd16e4d7e6ae4","name":"Laufzeit","property":"payload.switch0.output","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":440,"y":4340,"wires":[["299890253e280731"],["91dbdd3988b0aa05"]]},{"id":"c5907383823c7ea9","type":"debug","z":"517cd16e4d7e6ae4","name":"Restlaufzeit Poolpumpe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":4320,"wires":[]},{"id":"299890253e280731","type":"change","z":"517cd16e4d7e6ae4","name":"Setze Restlaufzeit","rules":[{"t":"set","p":"payload","pt":"msg","to":"RestlaufzeitPoolpumpe","tot":"flow"},{"t":"set","p":"payload","pt":"msg","to":"$exists(payload) ? payload : 360","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"payload - 1","tot":"jsonata"},{"t":"set","p":"RestlaufzeitPoolpumpe","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":4320,"wires":[["c5907383823c7ea9"]]},{"id":"3f5208fb9a554bb3","type":"inject","z":"517cd16e4d7e6ae4","name":"Setze Restlaufzeit","props":[{"p":"payload"}],"repeat":"","crontab":"00 00 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"360","payloadType":"num","x":230,"y":4480,"wires":[["ace95e0732cddec2"]]},{"id":"91dbdd3988b0aa05","type":"switch","z":"517cd16e4d7e6ae4","name":"RestlaufzeitPoolpumpe > 0","property":"RestlaufzeitPoolpumpe","propertyType":"flow","rules":[{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":680,"y":4380,"wires":[["a237f7ed1098d31d"]]},{"id":"a237f7ed1098d31d","type":"change","z":"517cd16e4d7e6ae4","name":"Hole Restlaufzeit","rules":[{"t":"set","p":"payload","pt":"msg","to":"RestlaufzeitPoolpumpe","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":4380,"wires":[["5c2762dfdf299aea"]]},{"id":"ace95e0732cddec2","type":"change","z":"517cd16e4d7e6ae4","name":"","rules":[{"t":"set","p":"RestlaufzeitPoolpumpe","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":4480,"wires":[[]]},{"id":"1e6ecc250f82fdce","type":"trigger","z":"517cd16e4d7e6ae4","name":"","op1":"true","op2":"false","op1type":"bool","op2type":"bool","duration":"1","extend":false,"overrideDelay":true,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1530,"y":4380,"wires":[["f6e82180b4e01d81"]]},{"id":"5c2762dfdf299aea","type":"change","z":"517cd16e4d7e6ae4","name":"Beginne Start Mitternacht - Restlaufzeit","rules":[{"t":"set","p":"delay","pt":"msg","to":"payload * 60000","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$moment().isAfter($moment().endOf('day').subtract($$.payload,'minute'))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":4380,"wires":[["1e6ecc250f82fdce","468333a84690b385"]]},{"id":"f6e82180b4e01d81","type":"debug","z":"517cd16e4d7e6ae4","name":"true/false schalten Pumpe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1770,"y":4380,"wires":[]},{"id":"0667a378e99ea44b","type":"inject","z":"517cd16e4d7e6ae4","name":"Pumpe läuft","props":[{"p":"payload.switch0.output","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":250,"y":4300,"wires":[["05cb99c34b0e088c"]]},{"id":"f4befc2343090b87","type":"inject","z":"517cd16e4d7e6ae4","name":"Pumpe läuft nicht","props":[{"p":"payload.switch0.output","v":"false","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":240,"y":4360,"wires":[["05cb99c34b0e088c"]]},{"id":"468333a84690b385","type":"debug","z":"517cd16e4d7e6ae4","name":"Trigger","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1500,"y":4440,"wires":[]}]
                  Ach und noch eine Korrektur.
                  Das Rücksetzen der Restlaufzeit würde ich erst um 1:00 setzen, damit sich da nichts überschneidet. Ach und noch ein Switch vergessen. Sorry. 😞
                  Hier nur auf die payload=true abprüfen:
                  also diese switch Node noch vor die trigger Node setzen:
                  [{"id":"93c5f7c44538e1d7","type":"switch","z":"517cd16e4d7e6ae4","name":"Mitternacht - Restlaufzeit","property":"payload","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":1550,"y":4380,"wires":[["1e6ecc250f82fdce"]]}]
                  • 1
                    @mickym
                    und am Ende wo die true/false debug Node ist kopiere ich diese
                            "id": "cb3e837f22606744",
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload ? \"Pumpe ein 1\" : \"Pumpe aus 0\"",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 3190,
                            "y": 180,
                            "wires": [
                                    "6368866539be04ce"
                            "id": "6368866539be04ce",
                            "type": "debug",
                            "name": "Ergebnis für Homeserver",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "payload",
                            "targetType": "msg",
                            "statusVal": "",
                            "x": 3570,
                            "y": 20,
                            "wires": []
                    • mickym
        [        {        "id": "cb3e837f22606744",        "type": "change",        "z": "b7365eb2cd9f043a",        "name": "",        "rules": [        {        "t": "set",        "p": "payload",        "pt": "msg",        "to": "payload ? \"Pumpe ein 1\" : \"Pumpe aus 0\"",        "tot": "jsonata"        }        ],        "action": "",        "property": "",        "from": "",        "to": "",        "reg": false,        "x": 3190,        "y": 180,        "wires": [        [        "6368866539be04ce"        ]        ]        },        {        "id": "6368866539be04ce",        "type": "debug",        "z": "b7365eb2cd9f043a",        "name": "Ergebnis für Homeserver",        "active": true,        "tosidebar": true,        "console": false,        "tostatus": false,        "complete": "payload",        "targetType": "msg",        "statusVal": "",        "statusType": "auto",        "x": 3570,        "y": 20,        "wires": []        }        ]
                      Na ich weiß nicht ob du den Homeserver brauchst, ich dachte Du schaltest die Pumpe wieder über Deinen Shelly. Aber musst Du wissen.
                      • 1
                        @mickym
                        die poolpumpe ist an einem EIB Schaltaktor angeschlossen diesen ich über den Homeserver steuen kann.
                        • 1
                          1984chris @1984chris last edited by
                          @1984chris
                          über den shelly ist nur die Zeiterfassung, da ist ja die Wärmepumpe angeschlossen.
                          • mickym
                            @1984chris
                            Na aber Du willst doch die Laufzeit Deiner Poolpumpe ermitteln und nicht der Wärmepumpe
                            • 1
                              @mickym
                              der Shelly schließt einen potialfreien Kontakt in der Wärmepumpe und ist parallel zum Aktor der Poolpumpe, damit sollte das passen oder?
                              • mickym
                                @mickym
                                Ja wenn das so ist und die Wärmepumpe immer synchron zur Poolpumpe läuft, dann ist das OK.
                                Wenn Du im Übrigen die Restlaufzeit nicht minus Mitternacht, sondern früher zum Beispiel 23:00 Uhr - Restlaufzeit laufen lassen willst, dann änderst Du die Change Node wie folgt:
                                • 1
                                  @mickym
                                  heißt bei 2 Stunden Restlaufzeit würde die Pumpe um 21:00 einschalten?
                                  • mickym
                                    mickym Most Active @1984chris last edited by mickym
                                    @1984chris JA.
                                    Bei der Variante um Mitteernacht um 22 uhr. Das kannst Du wählen wie Du willst. Ich habs halt möglichst spät genommen, weil im Sommer um 18 Uhr ja ggf. noch genügend Strom erzeugt wird, dass die Pumpe sowieso läuft. Du kannst natürlich auch grundsätzlich die Restlaufzeit ab 18 Uhr laufen lassen. Dann musst Du halt direkt ab der Shelly Node parallel laufen.
                                    • 1
                                      @mickym
                                      heißt wenn ich zum testen einmal nur 3 Stunden am Tag den shelly einschalte dann ausschalte, müsste die Poolpumpe um 20:00 Einschalten bei Restlaufzeit -23:00 (bei 6 stündiger Laufzeit).
                                      • mickym
                                        @mickym
                                        Ja wenn du die Variante 23:00 Uhr - Restlaufzeit verwendest
                                        • 1
                                          @mickym
                                          Werde das Morgen mal testen und berichten.
                                          • mickym
                                            @1984chris Ja Du kannst es so anpassen wie Du willst. Du kannst Dir auf der Systemkonsole ja auch die Nachrichten ausgeben lassen. Wenn Du eine Konsole in deinem Docker hast - dann müsstest Du ja sehen, dass nodered als Service gestartet ist. Ich kenn mich da mit Docker zuwenig aus.
                                            33201
