    3. Cloud Dienste
    4. Alexa Sprachausgabe funktioniert nicht mehr
      postworld @Thomas Braun last edited by postworld
      @thomas-braun said in Alexa Sprachausgabe funktioniert nicht mehr:
      Die Langfassung von iob diag ist wesentlich gesprächiger...
      Kommt sofort 😉
      Langfassung iob diag:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: pibroker
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       15:29:59 up 43 min,  2 users,  load average: 0.42, 0.13, 0.06
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-07-25 15:29:59 CEST
                 Universal time: Thu 2024-07-25 13:29:59 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        165M        3.6G        1.2M        231M        3.8G
      Swap:           209M          0B        209M
      Total:          4.2G        165M        3.9G
      Active iob-Instances:   1
               3792 M total memory
                157 M used memory
                170 M active memory
                 62 M inactive memory
               3479 M free memory
                 23 M buffer memory
                197 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 15:30:00 up 43 min,  2 users,  load average: 0.42, 0.13, 0.06
      Tasks: 164 total,   1 running, 163 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,   3477.7 free,    159.4 used,    221.5 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   3632.7 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       15G  3.0G   11G  23% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Thu Jul 25 14:46:11 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6B:62:3A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7f3d05a8-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Thu Jul 25 14:46:14 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
      [Thu Jul 25 14:46:16 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE      OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime,commit=600
      |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=412
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671308k,nr_inodes=417827,mode=755
      | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
      | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      632M    /var/
      206M    /var/cache
      200M    /var/cache/apt
      162M    /var/lib
      134M    /var/lib/apt
      Archived and active journals take up 64.0M in the file system.
      /opt/iobroker/backups:
      6.2M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      20M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.8M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MYZ-if03
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MYZ-if00
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AL02VDM7-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.17.14
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : pibroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.backitup.0               : backitup              : pibroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : pibroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.17.14  , installed 6.17.14
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Objects and States
      Objects:        143
      States:         76
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          962        702/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          964        702/sshd: /usr/sbin
      udp        0      0 0.0.0.0:47857           0.0.0.0:*                           104        4081       559/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4079       559/avahi-daemon: r
      udp6       0      0 fe80::66aa:ee16:868:546 :::*                                0          1021       644/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        4080       559/avahi-daemon: r
      udp6       0      0 :::48673                :::*                                104        4082       559/avahi-daemon: r
      2024-07-25 15:28:36.430  - info: backitup.0 (800) cleaned everything up...
      2024-07-25 15:28:36.430  - info: admin.0 (784) terminating https server on port 8081
      2024-07-25 15:28:36.433  - info: host.pibroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2024-07-25 15:28:36.435  - info: host.pibroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2024-07-25 15:28:36.437  - info: host.pibroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2024-07-25 15:28:36.446  - info: admin.0 (784) Got terminate signal TERMINATE_YOURSELF
      2024-07-25 15:28:36.447  - info: backitup.0 (800) Got terminate signal TERMINATE_YOURSELF
      2024-07-25 15:28:36.449  - info: discovery.0 (831) Got terminate signal TERMINATE_YOURSELF
      2024-07-25 15:28:36.453  - info: backitup.0 (800) terminating
      2024-07-25 15:28:36.453  - info: host.pibroker stopInstance system.adapter.admin.0 send kill signal
      2024-07-25 15:28:36.454  - info: admin.0 (784) terminating
      2024-07-25 15:28:36.456  - info: discovery.0 (831) terminating
      2024-07-25 15:28:36.457  - info: backitup.0 (800) Terminated (NO_ERROR): Without reason
      2024-07-25 15:28:36.458  - info: admin.0 (784) Terminated (NO_ERROR): Without reason
      2024-07-25 15:28:36.460  - info: discovery.0 (831) Terminated (NO_ERROR): Without reason
      2024-07-25 15:28:36.496  - info: host.pibroker stopInstance system.adapter.backitup.0 send kill signal
      2024-07-25 15:28:36.496  - info: host.pibroker stopInstance system.adapter.discovery.0 send kill signal
      2024-07-25 15:28:36.935  - info: discovery.0 (831) terminating
      2024-07-25 15:28:36.941  - info: backitup.0 (800) terminating
      2024-07-25 15:28:36.945  - info: admin.0 (784) terminating
      2024-07-25 15:28:37.126  - info: host.pibroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-07-25 15:28:37.166  - info: host.pibroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-07-25 15:28:37.172  - info: host.pibroker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
      2024-07-25 15:28:37.173  - info: host.pibroker All instances are stopped.
      2024-07-25 15:28:37.274  - info: host.pibroker terminated
        Thomas Braun Most Active @postworld last edited by
        @postworld sagte in Alexa Sprachausgabe funktioniert nicht mehr:
        iob start
        iob start admin
        und
        systemctl status iobroker.service
        sagt dazu?
          habe das so eingegeben, keine Änderung. Komme nicht in den IoBroker.
          bei dem letzten Befehl kommt viel heraus, das ist ein Block davon:
          ...skipping...
          ● iobroker.service - ioBroker Server
          Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
          Active: active (running) since Thu 2024-07-25 16:32:28 CEST; 37min ago
          Docs: http://iobroker.net
          Main PID: 700 (iobroker.js-con)
          Tasks: 44 (limit: 3917)
          CPU: 31.034s
          CGroup: /system.slice/iobroker.service
          ├─700 iobroker.js-controller
          ├─743 io.admin.0
          ├─805 io.backitup.0
          └─813 io.discovery.0
          Jul 25 16:32:28 pibroker systemd[1]: Started iobroker.service - ioBroker Server.
          Jul 25 16:32:35 pibroker bash[700]: host.pibroker check instance "system.adapter.admin.0" for host "pibroker"
          Jul 25 16:32:35 pibroker bash[700]: host.pibroker check instance "system.adapter.backitup.0" for host "pibroker"
          Jul 25 16:32:35 pibroker bash[700]: host.pibroker check instance "system.adapter.discovery.0" for host "pibroker"
          Jul 25 16:53:55 pibroker bash[700]: Cannot get NPM version: timeout
            Das ist ja auch nur der Staus des Services, keine Änderung. Ausgabe davon komplett hier rein.
              Ich hatte mich da verschaut, es ist doch überschaubar.
              Ergebnis:
              pi@pibroker:~ $ iob start
              pi@pibroker:~ $ iob start admin
              pi@pibroker:~ $ systemctl status iobroker.service
              Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
              Active: active (running) since Thu 2024-07-25 17:52:01 CEST; 34min ago
              Main PID: 718 (iobroker.js-con)
              CPU: 32.665s
              ├─718 iobroker.js-controller
              ├─847 io.admin.0
              ├─862 io.backitup.0
              └─873 io.discovery.0
              Jul 25 17:52:01 pibroker systemd[1]: Started iobroker.service - ioBroker Server.
              Jul 25 17:52:08 pibroker bash[718]: host.pibroker check instance "system.adapte>
              Jul 25 17:52:11 pibroker bash[718]: ================================== > LOG RE>
              lines 1-19/19 (END)...skipping...
              CPU: 32.665s
              ├─847 io.admin.0
              ├─862 io.backitup.0
              Jul 25 17:52:08 pibroker bash[718]: host.pibroker check instance "system.adapter.admin.0" for host "pibroker"
              Jul 25 17:52:08 pibroker bash[718]: host.pibroker check instance "system.adapter.backitup.0" for host "pibroker"
              Jul 25 17:52:08 pibroker bash[718]: host.pibroker check instance "system.adapter.discovery.0" for host "pibroker"
              Jul 25 17:52:11 pibroker bash[718]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
              Jul 25 17:52:11 pibroker bash[718]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
              lines 1-19/19 (END)
                ├─847 io.admin.0
                ├─862 io.backitup.0
                Läuft doch.
                  Läuft doch.
                  Das mag sein aber ich kann iobroker über die IP Adresse nicht erreichen.
                  "Fehler: Verbindung unterbrochen
                  Die Verbindung zum Server wurde zurückgesetzt, während die Seite geladen wurde.
                  Die Website könnte vorübergehend nicht erreichbar sein, versuchen Sie es bitte später nochmals.
                  Wenn Sie auch keine andere Website aufrufen können, überprüfen Sie bitte die Netzwerk-/Internetverbindung.
                  Wenn Ihr Computer oder Netzwerk von einer Firewall oder einem Proxy geschützt wird, stellen Sie bitte sicher, dass Firefox auf das Internet zugreifen darf.
                    @postworld
                    Per https?
                      Per https?
                      Oh, ja per https:// gehts, hatte ich zuvor wohl nicht im Bookmark gespeichert.
                      Danke.
                      Von dem Backup ist leider nichts zu erkennen, also keine Instanzen oder ähnliches wurden übernommen.
                      Ich probier das nochmal, mal sehen ob sich was ändert.
                        postworld @postworld last edited by Samson71
                        @postworld said in Alexa Sprachausgabe funktioniert nicht mehr:
                        pi@pibroker:~ $  sudo iobroker stop
                        pi@pibroker:~ $  sudo iobroker restore 0
                        host.pibroker Using backup file 2024_07_25-09_58_40_backupiobroker.tar.gz
                        iobroker controller daemon is not running
                        host.pibroker OK.
                        The current version of js-controller differs from the version in the backup.
                        The js-controller version of the backup can not be restored automatically.
                        To restore the js-controller version of the backup, execute "npm i iobroker.js-c        ontroller@4.0.23 --omit=dev" inside your ioBroker directory
                        If you really want to restore the backup with the current installed js-controlle        r, execute the restore command with the --force flag
                        pi@pibroker:~ $
                        .. hat aber scheinbar keinen Effekt, das Backup einzuspielen bzw. es funktioniert so nicht.
                          @postworld
                          NIE, NIE, NIE, NIEMALS den iobroker mit sudo anpacken. NIE!
                          iob stop
                          iob fix
                          iob start
                          Stimmt. In der Meldung steht auch warum das nicht funktioniert und was man dagegen tun kann (Davon abgesehen, dass man sein System beständiger aktuell hält, dann hat man nämlich das Problem erst gar nicht).
                            postworld last edited by postworld
                            Ok, bin halt nach Anleitung vorgegangen:
                            siehe:
                            Wieder per SSH an dem PI anmelden
                            Falls das Verzeichnis backups unter /opt/iobroker nicht existiert, dies zunächst anlegen
                            Sicherungsdatei .tar.gz in das Verzeichnis backups kopieren
                            ioBroker stoppen
                            sudo iobroker stop
                            Backup zurück spielen
                            ioBroker starten
                            sudo iobroker start all
                            sudo iobroker start
                            sudo iobroker upload all
                              @postworld
                              Die ist steinalt.
                                Die Meldung habe ich gesehen aber mir erklärt sich daraus nicht was zu tun ist.
                                pi@pibroker:~ $
                                  Thomas Braun Most Active @postworld last edited by Thomas Braun
                                  @postworld
                                  iob stop
                                  cd /opt/iobroker
                                  npm i iobroker.js-controller@4.0.23 --omit=dev
                                  Und dann das Backup nochmal reinjubeln.
                                    OK, danke. Nun habe ich den Hinweis selbst zumindest verstanden auch wenn ich nicht verstehe was der Befehlt macht.
                                    Leider war der erste Versuch ohne erfolg.
                                    Wie ist der letzte Satz der Fehlermeldung umzusetzen?
                                    "If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag"
                                    Versuch 2:
                                    Wahscheinlich liegt der Fehler hier bzw, der Hinweis auf selbigen:
                                    pi@pibroker:/opt/iobroker $ npm i iobroker.js-c ontroller@4.0.23 --omit=dev
                                    npm error code E404
                                    npm error 404 Not Found - GET https://registry.npmjs.org/iobroker.js-c - Not found
                                    npm error 404
                                    npm error 404 'iobroker.js-c@*' is not in this registry.
                                    npm error 404
                                    npm error 404 Note that you can also install from a
                                    npm error 404 tarball, folder, http url, or git url.
                                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-07-25T17_33_17_530Z-debug-0.log
                                    Thomas Braun 3 Replies Last reply Reply Quote 0
                                      Am besten gar nicht.
                                      Du willst das nicht per force reinballern.
                                      Und wie sah der 'Nicht-Erfolg' im Log aus?
                                        @postworld
                                        iob stop
                                        cd /opt/iobroker
                                        Da war ein Leerzeichen zuviel.
                                          @postworld
                                          Und bitte statt Spoiler besser CodeTags verwenden.
                                            Hat etwas gedauert aber ich hab das Leerzeichen gefunden, so macht das wieder etwas mehr Sinn, schön.
                                            pi@pibroker:/opt/iobroker $ npm i iobroker.js-controller@4.0.23 --omit=dev
                                            added 12 packages, and changed 17 packages in 2m
                                            73 packages are looking for funding
                                              run `npm fund` for details
                                            Codetags, so?
                                            Thomas Braun P 2 Replies Last reply Reply Quote 0
                                            1.5k
                                            77
                                            7679
