    4. VIS startet nicht mehr - vermutlich Eigenverschulden
    • rtwl
      rtwl @OliverIO last edited by
      @oliverio
      iob diag kommt gleich.
      hab zusätzlich (ich glaube bevor ich bemerkt hab, dass die vis nicht mehr geht) mein System aktualisiert und das dort empfohlene "autoremove" gemacht. Kann es daran liegen?
      rtwl@smarthome:~ $ sudo apt update
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [166 kB]
      Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [163 kB]
      Fetched 377 kB in 2s (217 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      rtwl@smarthome:~ $ iob stop
      rtwl@smarthome:~ $ sudo apt full-upgrade
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        libcamera0.2 linux-headers-6.6.20+rpt-common-rpi linux-kbuild-6.6.20+rpt
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      rtwl@smarthome:~ $ sudo apt autoremove
      The following packages will be REMOVED:
      0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
      After this operation, 51.4 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 95684 files and directories currently installed.)
      Removing libcamera0.2:arm64 (0.2.0+rpt20240418-1) ...
      Removing linux-headers-6.6.20+rpt-common-rpi (1:6.6.20-1+rpt1) ...
      Removing linux-kbuild-6.6.20+rpt (1:6.6.20-1+rpt1) ...
      Processing triggers for libc-bin (2.36-9+rpt2+deb12u7) ...
      rtwl@smarthome:~ $ sudo reboot
      Broadcast message from root@smarthome on pts/1 (Sun 2024-07-28 00:25:30 CEST):
      The system will reboot now!
      • OliverIO
        OliverIO @rtwl last edited by
        @rtwl
        eigentlich nicht.
        autoremove deinstalliert Pakete die kein anderes Paket mehr benötigt.
        hat mit iobroker eigentlich nicht wirklich was zu tun.
        je nachdem wie man mit seinem system umgegangen ist kann man es auch nicht komplett ausschließen. aber da würde ich jetzt nicht davon ausgehen.
        • rtwl
          @oliverio sagte in VIS startet nicht mehr - vermutlich Eigenverschulden:
          iob diag hier posten
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: smarthome
                 Icon name: computer
                    Kernel: Linux 6.6.31+rpt-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           00:57:57 up 31 min,  2 users,  load average: 0.98, 0.86, 0.98
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-07-28 00:57:57 CEST
                     Universal time: Sat 2024-07-27 22:57:57 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          rtwl
          HOME=/home/rtwl
          GROUPS=rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            4.0G        2.6G        1.1G        1.2M        308M        1.4G
          Swap:           209M          0B        209M
          Total:          4.2G        2.6G        1.3G
          Active iob-Instances:   26
                   3792 M total memory
                   2484 M used memory
                   2467 M active memory
                    123 M inactive memory
                   1084 M free memory
                     42 M buffer memory
                    251 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 00:57:57 up 31 min,  2 users,  load average: 0.98, 0.86, 0.98
          Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 12.5 us,  0.0 sy,  0.0 ni, 87.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3792.1 total,   1082.4 free,   2487.0 used,    294.1 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   1305.1 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  379M   1% /run
          /dev/mmcblk0p2 ext4       15G  8.8G  4.7G  66% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sun Jul 28 00:26:19 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c17d14e5-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Jul 28 00:26:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
          [Sun Jul 28 00:26:24 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET                                                  SOURCE         FSTYPE      OPTIONS
          /                                                       /dev/mmcblk0p2 ext4        rw,noatime,commit=600
          |-/sys                                                  sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security                                securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                                      cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore                                      pstore         pstore      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf                                         bpf            bpf         rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug                                   debugfs        debugfs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing                                 tracefs        tracefs     rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/fuse/connections                            fusectl        fusectl     rw,nosuid,nodev,noexec,relatime
          | `-/sys/kernel/config                                  configfs       configfs    rw,nosuid,nodev,noexec,relatime
          |-/proc                                                 proc           proc        rw,relatime
          | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2635
          |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_misc rw,nosuid,nodev,noexec,relatime
          |-/dev                                                  udev           devtmpfs    rw,nosuid,relatime,size=1671308k,nr_inodes=417827,mode=755
          | |-/dev/pts                                            devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | |-/dev/shm                                            tmpfs          tmpfs       rw,nosuid,nodev
          | `-/dev/mqueue                                         mqueue         mqueue      rw,nosuid,nodev,noexec,relatime
          |-/run                                                  tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
          | |-/run/lock                                           tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/rpc_pipefs                                     sunrpc         rpc_pipefs  rw,relatime
          | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | `-/run/user/1000                                      tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,gid=1000
          `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          787M    /var/
          219M    /var/log
          218M    /var/log/journal/7abd16222f504c5aa6afc24d57aa23d1
          202M    /var/cache
          Journal file /var/log/journal/7abd16222f504c5aa6afc24d57aa23d1/system@00061d73cad1ee20-8fe04835cf89423d.journal~ is truncated, ignoring file.
          Archived and active journals take up 217.9M in the file system.
          /opt/iobroker/backups:
          1.9G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.7G    /opt/iobroker/iobroker-data/
          1.2G    /opt/iobroker/iobroker-data/history
          357M    /opt/iobroker/iobroker-data/files
          138M    /opt/iobroker/iobroker-data/files/javascript.admin
          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          44M     /opt/iobroker/iobroker-data/states.jsonl
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          34M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          23M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.7fc1c2df.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.4
          /usr/bin/node           v18.20.4
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 1001
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.17.14
          javascript:     8.3.1
          nodejs modules from github:     4
          +-- iobroker.alexa-timer-vis@0.3.0 (git+ssh://git@github.com/MiRo1310/ioBroker.alexa-timer-vis.git#c3aaeb68786ce591dd164a98677895d817ca6f0c)
          +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
          +-- iobroker.operating-hours@1.0.6 (git+ssh://git@github.com/BenAhrdt/ioBroker.operating-hours.git#b0c1a343737cab4bc5f74ed0d72fffe6a39c9ec6)
          +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
          Adapter State
          + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : smarthome                                -  enabled
          + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
            system.adapter.alias-manager.0          : alias-manager         : smarthome                                - disabled
          + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
          + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
            system.adapter.cloud.0                  : cloud                 : smarthome                                - disabled
            system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
            system.adapter.discovery.0              : discovery             : smarthome                                - disabled
            system.adapter.drops-weather.0          : drops-weather         : smarthome                                - disabled
            system.adapter.feiertage.0              : feiertage             : smarthome                                -  enabled
            system.adapter.flot.0                   : flot                  : smarthome                                - disabled
          + system.adapter.fronius.0                : fronius               : smarthome                                -  enabled
          + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
          + system.adapter.history.0                : history               : smarthome                                -  enabled
            system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
            system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
            system.adapter.iot.0                    : iot                   : smarthome                                - disabled
          + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
          + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
            system.adapter.openligadb.0             : openligadb            : smarthome                                - disabled
          + system.adapter.operating-hours.0        : operating-hours       : smarthome                                -  enabled
            system.adapter.pi-hole.0                : pi-hole               : smarthome                                - disabled
          + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
            system.adapter.pvforecast.0             : pvforecast            : smarthome                                - disabled
          + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
          + system.adapter.radar2.1                 : radar2                : smarthome                                -  enabled
          + system.adapter.radar2.2                 : radar2                : smarthome                                -  enabled
          + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
          + system.adapter.simple-api.0             : simple-api            : smarthome                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0               : socketio              : smarthome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                - disabled
          + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
            system.adapter.uv-protect.0             : uv-protect            : smarthome                                - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                - disabled
            system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
          + system.adapter.weather-warnings.0       : weather-warnings      : smarthome                                -  enabled
          + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : smarthome                                -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804163324-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
          Adapter    "fronius"      : 2.1.0    , installed 2.1.0
          Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
          Adapter    "harmony"      : 1.4.0    , installed 1.4.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
          Adapter    "operating-hours": 1.0.6  , installed 1.0.6
          Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
          Adapter    "radar2"       : 2.2.0    , installed 2.2.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        13311
          States:         11526
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6479       944/io.mqtt.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1951       667/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6201       667/iobroker.js-con
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1928       675/sshd: /usr/sbin
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19983      1540/io.socketio.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       12612      1374/io.simple-api.
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5035       756/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14014      1470/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1930       675/sshd: /usr/sbin
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       6437       903/io.harmony.0
          udp        0      0 0.0.0.0:39175           0.0.0.0:*                           1001       20530      1010/io.shelly.0
          udp        0      0 0.0.0.0:57791           0.0.0.0:*                           104        5589       532/avahi-daemon: r
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       6438       903/io.harmony.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5587       532/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       6577       1010/io.shelly.0
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       9336       1076/io.radar2.2
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       9241       1051/io.radar2.1
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       5994       974/io.radar2.0
          udp6       0      0 :::57995                :::*                                104        5590       532/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        5588       532/avahi-daemon: r
          2024-07-28 00:40:55.628  - info: web.0 (1455) terminating
          2024-07-28 00:40:55.631  - info: web.0 (1455) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-07-28 00:40:55.756  - info: web.0 (1455) <== Disconnect system.user.admin from ::ffff:192.168.0.110
          2024-07-28 00:41:00.690  - info: web.0 (1470) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.4, js-controller: 5.0.19
          2024-07-28 00:41:00.981  - info: web.0 (1470) socket.io server listening on port 8082
          2024-07-28 00:41:00.992  - info: web.0 (1470) simpleAPI server listening on port 8082
          2024-07-28 00:41:00.993  - info: web.0 (1470) Allow states only when user is owner: false
          2024-07-28 00:41:01.016  - info: web.0 (1470) http server listening on port 8082
          2024-07-28 00:41:20.820  - info: web.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.0.110
          2024-07-28 00:41:37.276  - info: web.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.0.110
          2024-07-28 00:41:41.640  - info: web.0 (1470) <== Disconnect system.user.admin from ::ffff:192.168.0.110 vis.0
          2024-07-28 00:41:46.399  - info: web.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.0.110
          2024-07-28 00:53:40.268  - info: web.0 (1470) <== Disconnect system.user.admin from ::ffff:192.168.0.110 vis.0
          2024-07-28 00:53:41.557  - info: web.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.0.110
          2024-07-28 00:53:50.042  - info: socketio.0 (1220) Got terminate signal TERMINATE_YOURSELF
          2024-07-28 00:53:50.046  - info: socketio.0 (1220) terminating http server on port 8084
          2024-07-28 00:53:50.049  - info: socketio.0 (1220) terminating
          2024-07-28 00:53:50.052  - info: socketio.0 (1220) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-07-28 00:53:55.677  - info: javascript.0 (793) script.js.common.Adapter_check: 🟥 socketio
          2024-07-28 00:54:00.509  - info: socketio.0 (1540) starting. Version 6.7.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.20.4, js-controller: 5.0.19
          2024-07-28 00:54:00.642  - info: socketio.0 (1540) socket.io server listening on port 8084
          2024-07-28 00:56:30.549  - info: javascript.0 (793) script.js.common.Adapter_check: 🟩 socketio
          2024-07-28 00:57:10.903  - info: history.0 (767) Delete old history "/opt/iobroker/iobroker-data/history/20240723/history.0_userdata.0.Status.Toni.imFreien.json"
          2024-07-28 00:58:49.755  - info: javascript.0 (793) script.js.Haussteuerung.Beleuchtung.Küche_Bewegungsmelder: Bewegung erkannt
          2024-07-28 00:58:56.823  - info: web.0 (1470) ==> Connected system.user.admin from ::ffff:192.168.0.3
          • OliverIO
            OliverIO @rtwl last edited by OliverIO
            @rtwl
            bin da beim interpretieren nicht ganz so gut.
            hab nix spezielles gesehen, meine vermutung war, das noch adapter fehlen, doch die sind alle da (js-controller,admin,web,ws)
            kommt eine fehlermeldung? so wie ich das sehe, müsste die weboberfläche des iobrokers sich öffnen.
            ist die installation mit deinem post von vorhin zusammen gefallen als wir die erhöhte prozessorlast hatten? da wurde dann ein rebuild durchgeführt, der dauert eine weile.
            evtl kann da @Thomas-Braun drauf schauen, der ist da profi
            rtwl 1 Reply Last reply Reply Quote 0
            • rtwl
              @oliverio
              nein, keine Fehlermeldung. es bleibt nur hier hängen:
              Auf allen Browsern sowie auch Windows und Android Geräten das gleiche.
              Mein System läuft seit dem Absturz von gestern normal, heute also alles gut - bis auf das VIS Problem eben.
              OliverIO Thomas Braun 2 Replies Last reply Reply Quote 0
              • OliverIO
                @rtwl
                dann schau mal in die browser console mit F12 und dann den reiter console/Konsole suchen
                und mal alle Fehlermeldungen hier posten
                  Thomas Braun Most Active @rtwl last edited by
                  @rtwl
                  iob start vis
                  mal ausgeführt?
                  Ansonsten sieht das sehr ordentlich aus.
                  Vielleicht beizeiten nodejs@20 draufwerfen.
                  • rtwl
                    rtwl @Thomas Braun last edited by
                    @thomas-braun sagte in VIS startet nicht mehr - vermutlich Eigenverschulden:
                    iob start vis
                    hab ich soeben gemacht. zu sehen war nichts. ein reload der Runtime bleibt wieder hängen.
                    In der Browser Console hab ich folgende Fehlermeldungen:
                    POST https://sentry.iobroker.net/api/77/envelope/?sentry_key=888b0efc877b4b12a8a83e3c1fb7fe1a&sentry_version=7 403 (Forbidden)
                    (anonymous) @ fetch.ts:126
                    t @ syncpromise.ts:34
                    n.Ft @ fetch.ts:125
                    n.sendSession @ fetch.ts:91
                    t.sendSession @ basebackend.ts:108
                    t.ht @ baseclient.ts:262
                    t.captureSession @ baseclient.ts:158
                    t.Y @ hub.ts:425
                    t.captureSession @ hub.ts:371
                    (anonymous) @ sdk.ts:200
                    t.init @ sdk.ts:94
                    _initializeSentry @ widgets.min.js:1
                    await in initializeSentry (async)
                    (anonymous) @ materialdesign.js:35
                    (anonymous) @ widgets.min.js:1
                    r.onack @ socket.io.js:8
                    r.onpacket @ socket.io.js:8
                    (anonymous) @ socket.io.js:8
                    r.emit @ socket.io.js:6
                    r.ondecoded @ socket.io.js:6
                    a.add @ socket.io.js:6
                    r.ondata @ socket.io.js:6
                    r.onPacket @ socket.io.js:6
                    (anonymous) @ socket.io.js:6
                    r.onPacket @ socket.io.js:7
                    r.onData @ socket.io.js:7
                    ws.onmessage @ socket.io.js:8
                    helpers.ts:111 Uncaught
                    TypeError: Cannot read properties of undefined (reading 'data')
                        at getUsedObjectIDs (visUtils.js:479:97)
                        at Object.getUsedObjectIDs (vis.js:525:22)
                        at vis.js:2061:34
                        at conn.js:593:25
                        at sentryWrapped (helpers.ts:87:17)
                    getUsedObjectIDs	@	visUtils.js:479
                    getUsedObjectIDs	@	vis.js:525
                    (anonymous)	@	vis.js:2061
                    (anonymous)	@	conn.js:593
                    sentryWrapped	@	helpers.ts:87
                    setTimeout (async)
                    (anonymous)	@	trycatch.ts:119
                    (anonymous)	@	conn.js:592
                    • rtwl
                      rtwl @rtwl last edited by
                      @rtwl
                      wenn ich mit der Maus hier auf den Link bei der Fehlermeldung gehe, kommt was vom MaterialDesign Adapter.
                      Kann es damit zusammenhängen?
                      rtwl Thomas Braun 2 Replies Last reply Reply Quote 0
                      • rtwl
                        @rtwl
                        Auch hier ein Fehler den ich nicht entschlüsseln kann.
                          @rtwl
                          Materialdesign ist auch disabled. Schalt den mal aktiv.
                          • rtwl
                            da gibts keinen "play" button.
                            kann ich den via console starten?
                            sigi234 haselchen 2 Replies Last reply Reply Quote 0
                              sigi234 Forum Testing Most Active @rtwl last edited by sigi234
                              @rtwl sagte in VIS startet nicht mehr - vermutlich Eigenverschulden:
                              Nein ist schon Richtig so, aber du hast in einer oder mehreren Views Widgets die du gruppiert hast? Diese machen Probleme was bekannt ist.
                              • haselchen
                                haselchen Most Active @rtwl last edited by
                                @rtwl
                                Schalt mal den Adapter socket.io aus.
                                Der darf nicht gleichzeitig mit Web und WS laufen.
                                  Homoran Global Moderator Administrators @haselchen last edited by
                                  @haselchen sagte in VIS startet nicht mehr - vermutlich Eigenverschulden:
                                  warum nicht?
                                  tut er bei mir ohne Probleme.
                                  haselchen 1 Reply Last reply Reply Quote 1
                                  • haselchen
                                    haselchen Most Active @Homoran last edited by
                                    Guck mal in sein Log.
                                    Terminated…..
                                    Möglich weil beide den gleichen Port benutzen.
                                    Ich muss gestehen, dass ich nicht wüsste wozu ich den Socket.io noch bräuchte .
                                    Mit Einführung des WS meine ich , wurde der obsolet.
                                    • rtwl
                                      rtwl @sigi234 last edited by
                                      @sigi234 sagte in VIS startet nicht mehr - vermutlich Eigenverschulden:
                                      ja, ich hab da in einer view ein paar widget gruppiert. Diese view hab ich gestern dubliziert. Dann ging die runtime nicht mehr.
                                      ist das hier von @Homoran immer noch der korrekte Weg den Fehler zu beheben? https://forum.iobroker.net/topic/75565/zugriff-auf-vis-nicht-mehr-möglich/5?_=1722147764089
                                      • rtwl
                                        rtwl last edited by
                                        braucht man Socket io wirklich nicht mehr? Kann ich den wieder deinstallieren?
                                          Homoran Global Moderator Administrators @rtwl last edited by
                                          @rtwl Du hast so viele Baustellen!
                                          Warum stocherst du immer weiter im System herum, anstelle es erst einmal stabil zur Ruhe kommen zu lassen?
                                          Damit wird es jetzt bestimmt nicht leichter die Ursachen der anderen Issues systematisch anzugehen
                                          • rtwl
                                            rtwl @Homoran last edited by
                                            @homoran da hast du vollkommen recht. Aber ich kann auch nichts dafür, dass ich vor 6 Monaten ein paar widget gruppiert und gestern zufällig kopiert habe.
                                            Homoran mcm1957 2 Replies Last reply Reply Quote 0
                                            989
