    4. Forecast.solar mit dem Systeminfo Adapter
      MartyBr @MartyBr last edited by
      @martybr
      Die Daten des dritten Strings fehlen in dem DP SolarJSINGraph. Ich warte mal bis morgen ab, ob das Script die Daten noch integriert.
      • Glasfaser
        Glasfaser @MartyBr last edited by Glasfaser
        @martybr
        Habe schon lange den dritten String , versuche mal hiermit
        //10 Juni 2021 .. Glasfaser Änderung auf 3 Strings
        /* read solar forecasts for 2 different orientations
        Author : gargano
        Display in VIS : use JSON Chart from Scrounger
        Version 1.0.1
        Last Update 16.3.2021
        Change history :
        1.0.1 / 16.3.2021   :   use setStateAsync(myUrl.mySolarJSON.. to avoid time conflicts
                                dp's are now saved in '0_userdata.0.'
                                use variables for setting lat, lon, color..
        const prefix = 'javascript.0.';
        const SolarJSON1            = prefix+"SolarForecast.JSON1";
        const SolarJSON2            = prefix+"SolarForecast.JSON2";
        const SolarJSON3            = prefix+"SolarForecast.JSON3";
        const SolarJSONAll1         = prefix+"SolarForecast.JSONAll1";
        const SolarJSONAll2         = prefix+"SolarForecast.JSONAll2";
        const SolarJSONAll3         = prefix+"SolarForecast.JSONAll3";
        const SolarJSONGraphAll1    = prefix+"SolarForecast.JSONGraphAll1";
        const SolarJSONGraphAll2    = prefix+"SolarForecast.JSONGraphAll2";
        const SolarJSONGraphAll3    = prefix+"SolarForecast.JSONGraphAll3";
        const SolarJSONTable        = prefix+"SolarForecast.JSONTable";
        const SolarJSONGraph        = prefix+"SolarForecast.JSONGraph";
        const createStateList = [
            {name :SolarJSON1, type:"string", role : "value"},
            {name :SolarJSON2, type:"string", role : "value"},
            {name :SolarJSON3, type:"string", role : "value"},
            {name :SolarJSONAll1, type:"string", role : "value"},
            {name :SolarJSONAll2, type:"string", role : "value"},
            {name :SolarJSONAll3, type:"string", role : "value"},
            {name :SolarJSONGraphAll1, type:"string", role : "value"},
            {name :SolarJSONGraphAll2, type:"string", role : "value"},
            {name :SolarJSONGraphAll3, type:"string", role : "value"},
            {name :SolarJSONTable, type:"string", role : "value"},
            {name :SolarJSONGraph, type:"string", role : "value"}
        // create states if not exists
        async function createMyState(item) {
            if (!existsState(item.name)) {
            await createStateAsync(item.name, {
                    type: item.type,
                    min: 0,
                    def: 0,
                    role: item.role
        async function makeMyStateList (array) {
            // map array to promises
            const promises = array.map(createMyState);
            await Promise.all(promises);
        var mySchedule = '3 1 * * *';
        async function main () {
            await makeMyStateList(createStateList);
            schedule(mySchedule, getSolar );
            getSolar();
        main();
        // set logging = true for logging
        const logging = true;
        var request = require('request');
        /* https://api.forecast.solar/estimate/:lat/:lon/:dec/:az/:kwp
        lat - latitude of location, -90 (south) … 90 (north)
        lon - longitude of location, -180 (west) … 180 (east)
        dec - plane declination, 0 (horizontal) … 90 (vertical)
        az - plane azimuth, -180 … 180 (-180 = north, -90 = east, 0 = south, 90 = west, 180 = north)
        kwp - installed modules power in kilo watt
        https://api.forecast.solar/estimate/51.38501/6.74986/35/90/2.240'
        // set lat and lon for the destination
        const lat = 'xx.xxxxx'
        const lon = 'x.xxxxx'
        const forcastUrl = 'https://api.forecast.solar';
        // if use the api key remove '//' and insert '//' in front of const api = '';
        //const api = '/xxxxxxxxxxxxxxxx;
        // else
        const api = '';
        const declination = ['30','30','4'];
        const azimuth = ['-90','90','90'];
        const kwp = ['x.xx','x.xx','x.xx'];
        var options1 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[0]+'/'+azimuth[0]+'/'+kwp[0], method: 'GET', headers: { 'User-Agent': 'request' }};
        var options2 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[1]+'/'+azimuth[1]+'/'+kwp[1], method: 'GET', headers: { 'User-Agent': 'request' }};
        var options3 = {url: forcastUrl+api+'/estimate/'+lat+'/'+lon+'/'+declination[2]+'/'+azimuth[2]+'/'+kwp[2], method: 'GET', headers: { 'User-Agent': 'request' }};
        const legendTest = ["Ost","West","West_Carport"];
        const graphColor = ["red","green","blue"];
        const datalabelColor = ["lightgreen","lightblue","lightred"];
        const tooltip_AppendText= " Watt";
        var urls = [
          {myUrl:options1,mySolarJSON:SolarJSON1,mySolarJSONAll:SolarJSONAll1,mySolarJSONGraphAll:SolarJSONGraphAll1},
          {myUrl:options2,mySolarJSON:SolarJSON2,mySolarJSONAll:SolarJSONAll2,mySolarJSONGraphAll:SolarJSONGraphAll2},
          {myUrl:options3,mySolarJSON:SolarJSON3,mySolarJSONAll:SolarJSONAll3,mySolarJSONGraphAll:SolarJSONGraphAll3}
        // handle the request : convert the result to table and graph
        function myAsyncRequest(myUrl) {
          log('Request '+myUrl.myUrl.url);
          return new Promise((resolve, reject) => {
             request(myUrl.myUrl.url, async function(error, response, body) {
                if (!error && response.statusCode == 200) {
                    if (logging) console.log ('body : '+body);
                    let watts = JSON.parse(body).result.watts;
                    setState(myUrl.mySolarJSONAll, JSON.stringify(watts), true);
                    let table = [];
                    for(let time in watts) {
                            let entry = {};
                            entry.Uhrzeit = time;
                            entry.Leistung = watts[time];
                            table.push(entry);
                    if (logging) console.log ('JSON: '+myUrl.mySolarJSON);
                    await setStateAsync(myUrl.mySolarJSON, JSON.stringify(table), true);
                    // make GraphTable
                    let graphTimeData = [];
                            let graphEntry ={};
                            graphEntry.t = Date.parse(time);
                            graphEntry.y = watts[time];
                            graphTimeData.push(graphEntry);
                    var graph = {};
                    var graphData ={};
                    var graphAllData = [];
                    graphData.data = graphTimeData;
                    graphAllData.push(graphData);
                    graph.graphs=graphAllData;
                    setState(myUrl.mySolarJSONGraphAll, JSON.stringify(graph), true);
                    resolve (body);
                } else
                    reject(new Error("Could not load " + myUrl.myUrl.url+' Error '+error +'Status '+ response.statusCode));
        // summarize the single watts results to table and graph
        function makeTable () {
            if (logging) console.log ('MakeTable');
            let watts1 = JSON.parse(getState(SolarJSON1).val);
            let watts2 = JSON.parse(getState(SolarJSON2).val);
            let watts3 = JSON.parse(getState(SolarJSON3).val);
            if (logging) console.log ('Items: '+watts1.length);
            let table = [];
        	let axisLabels = [];
            // make table
            for(var n=0;n<watts1.length;n++) {
                    let entry = {};
                    entry.Uhrzeit = watts1[n].Uhrzeit;
                    entry.Leistung1 = watts1[n].Leistung;
                    entry.Leistung2 = watts2[n].Leistung;
                    entry.Leistung3 = watts3[n].Leistung;
                    entry.Summe = watts1[n].Leistung + watts2[n].Leistung + watts3[n].Leistung;
                    table.push(entry);
            // prepare data for graph
        	let graphTimeData1 = [];
            	graphTimeData1.push(watts1[n].Leistung);
                let time = watts1[n].Uhrzeit.substr(11,5);
                axisLabels.push(time);
        	let graphTimeData2 = [];
            for(var n=0;n<watts2.length;n++) {
           		graphTimeData2.push(watts2[n].Leistung);
            let graphTimeData3 = [];
            for(var n=0;n<watts3.length;n++) {
           		graphTimeData3.push(watts3[n].Leistung);
            // make total graph
            var graph = {};
            var graphData = {"tooltip_AppendText":  tooltip_AppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
            graphData.data = graphTimeData1;
        	graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
            graphData.data = graphTimeData2;
            graphData = {"tooltip_AppendText": tooltip_AppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
            graphData.data = graphTimeData3;
        	graph.axisLabels =  axisLabels;
            setState(SolarJSONTable, JSON.stringify(table), true);
            setState(SolarJSONGraph, JSON.stringify(graph), true);
        // get the requests
        async function getSolar() {
           let promises = urls.map(myAsyncRequest);
            .then(function(bodys) {
                if (logging) console.log("All url loaded");
                makeTable();
            .catch(error => {
                console.log('Error : '+error)
          MartyBr @Glasfaser last edited by
          @glasfaser
          Super, klappt. Alle Strings in dem JSON! Ganz herzlichen Dank.
            Tigger66 last edited by
            Ein Hallo in die Runde
            und eine Frage an die Nutzer dieses Adapters. Ich hab das Problem, das ich bei den Einstellungen in den Instanzen, eigentlich keine Einstellmöglichkeit habe. Bei mir erscheint: "This adapter version has no support for "Admin 4" configuration. Please switch to "Admin 5" UI or downgrade to an older version (see changelog for details). "
            Ich habe aber die Admin Version 5.3.8 installiert. Hat jemand eine Idee woran dass liegen kann? Danke für Eure Unterstützung...
            • Glasfaser
              Glasfaser @Tigger66 last edited by
              @tigger66 sagte in Forecast.solar mit dem Systeminfo Adapter:
              ... das wäre dann hier ...
              https://forum.iobroker.net/topic/45315/test-pv-forecast-adapter
                ...da habe ich wohl nicht richtig gelesen...danke für den Hinweis...
                • chriz77
                  chriz77 last edited by
                  wäre es möglich, die "Adjust forecast" von Forecast.solar einzubauen? Hat jemand damit Erfahrung? Werden die Prognosen damit besser?
                  Viele Grüße
                  Chris
                  Edde 1 Reply Last reply Reply Quote 0
                  • Edde
                    Edde @chriz77 last edited by
                    Hallo zusammen.
                    Ich wüsste gerne wie Ihr die Vorhersage für eine 2 String Anlage wählen würdet.
                    Ich habe 24 PV Module Richtung osten und weitere 14 Richtung Westen. Alle zusammen liefern etwa 16kw Peak mit einem 11kw Wechselrichter.
                    Wie müsste ich nun meine Api erstellen bzw. Mit welchem Azimuth? Die zwei String Auflösung findet dann erst im Adapter statt? Ich mochte natürlich eine theoretische Gesamtprognose für die gesamte Anlage über den Tag verteilt bekommen.
                    Screenshot_20240312-045834.png Screenshot_20240312-045853.png Screenshot_20240312-045958~2.png
                    • JB_Sullivan
                      JB_Sullivan last edited by
                      @Gargano
                      Da du der Ersteller des Java Skriptes bist eine Frage:
                      Ich habe aktuell den JavaSkript Adapter auf 8.7.5 aktualisiert.
                      Als Meldung bekomme ich seit dem für dein Forecast Skript die folgende Meldung. Gibt es schon eine neuere Version die auf httpGet oder axios aufsetzt?
                      javascript.0
                      8144	2024-07-28 13:17:45.887	warn	script.js.Solar.SolarForcast: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                      Gargano 1 Reply Last reply Reply Quote 0
                      • Gargano
                        Gargano @JB_Sullivan last edited by Gargano
                        @jb_sullivan Hier der Code mit axios:
                        getSolar() ist die eigentliche Funktion.
                        Es gibt auch einen Adapter, der aus dem Script hervorging
                        hier der Adapter
                        // Test mit VS Code Extension
                        /* read solar forecasts for 3 different orientations
                        Author : gargano
                        Version 1.1.0
                        Last Update 13.3.2022
                        Change history :
                        use axios
                        const prefix = '0_userdata.0.';
                        const idSolarJSON1        = prefix+"SolarForecast3.SuedOst.JSON";
                        const idSolarJSON2        = prefix+"SolarForecast3.Dach.JSON";
                        const idSolarJSON3        = prefix+"SolarForecast3.SuedWest.JSON";
                        const idSolarToday1       = prefix+"SolarForecast3.SuedOst.Today";
                        const idSolarToday2       = prefix+"SolarForecast3.Dach.Today";
                        const idSolarToday3       = prefix+"SolarForecast3.SuedWest.Today";
                        const idSolarTomorrow1    = prefix+"SolarForecast3.SuedOst.Tomorrow";
                        const idSolarTomorrow2    = prefix+"SolarForecast3.Dach.Tomorrow";
                        const idSolarPanelTomorrow= prefix+"SolarForecast3.Solar.Tomorrow";
                        const idSolarPanelToDay   = prefix+"SolarForecast3.Solar.ToDay";
                        const idSolarTomorrow3    = prefix+"SolarForecast3.SuedWest.Tomorrow";
                        const idSolarJSONTable    = prefix+"SolarForecast3.JSONTable";
                        const idSolarJSONGraph    = prefix+"SolarForecast3.JSONGraph";
                        const idSolarDachJSONGraph    = prefix+"SolarForecast3.Dach.JSONGraph";
                            {name :idSolarJSON1, type:"string", role : "value"},
                            {name :idSolarJSON2, type:"string", role : "value"},
                            {name :idSolarJSON3, type:"string", role : "value"},
                            {name :idSolarToday1, type:"number", role : "value"},
                            {name :idSolarToday2, type:"number", role : "value"},
                            {name :idSolarToday3, type:"number", role : "value"},
                            {name :idSolarTomorrow1, type:"number", role : "value"},
                            {name :idSolarTomorrow2, type:"number", role : "value"},
                            {name :idSolarTomorrow3, type:"number", role : "value"},
                            {name :idSolarPanelTomorrow, type:"number", role : "value"},
                            {name :idSolarPanelToDay, type:"number", role : "value"},
                            {name :idSolarJSONTable, type:"string", role : "value"},
                            {name :idSolarJSONGraph, type:"string", role : "value"},
                            {name :idSolarDachJSONGraph, type:"string", role : "value"}
                                    type: item.type,
                                    min: 0,
                                    def: 0,
                                    role: item.role
                            getSolar();
                        main();
                        // define axios and url
                        const axios = require('axios');
                        const lat = myLat;      // defined in global
                        const long = myLon;     // defined in global
                        const url = 'https://api.forecast.solar/estimate/';
                        // Fenster Wohnzimmer
                        var url1 = url+lat+'/'+long+'/90/-30/1';
                        // Dach
                        var url2 = url+lat+'/'+long+'/35/60/6.2';
                        // Fenster Küche / Schlafzimmer
                        var url3 = url+lat+'/'+long+'/90/60/1';
                        const legendTest = ["Wohn","Dach","Küche"];
                        const graphColor = ["red","green","yellow"];
                        const datalabelColor = ["lightgreen","lightblue","lightblue"];
                        const tooltipAppendText= " kWh";
                        var solarJson1;
                        var solarJson2;
                        var solarJson3;
                        var solarJsons = [solarJson1,solarJson2,solarJson3];
                        const idSolarJSONS = [idSolarJSON1,idSolarJSON2,idSolarJSON3]
                        const idSolarToDayS = [idSolarToday1,idSolarToday2,idSolarToday3]
                        const idSolarTomorrowS = [idSolarTomorrow1,idSolarTomorrow2,idSolarTomorrow3]
                        const mySchedule ='{"time":{"start":"03:00","end":"23:00","mode":"hours","interval":1},"period":{"days":1}}'
                        async function makeResponse (thisResponse,thisIDSolarJSON,idx,thisIDSolarToDay,thisIDSolarTomorrow) {
                            // handle success
                            var datetoday = new Date();
                            var datetomorrow = new Date(datetoday.getTime()+(1000 * 60 * 60 * 24 * 1)); // übermorgen wäre dann am Ende eine 2 anstatt 1
                            let today = formatDate(datetoday, 'YYYY-MM-DD');
                            let tomorrow = formatDate(datetomorrow, 'YYYY-MM-DD');
                            var watts = thisResponse.data.result.watts;
                            if (logging) log ('Watts '+JSON.stringify(watts));
                            let table = [];
                                    let entry = {};
                                    table.push(entry);
                            let kWhToDay = thisResponse.data.result.watt_hours_day[today]/1000;
                            let kWhTomorrow = thisResponse.data.result.watt_hours_day[tomorrow]/1000;
                            solarJsons[idx] = JSON.stringify(table);
                            await setStateAsync(thisIDSolarJSON, JSON.stringify(table), true);
                            await setStateAsync(thisIDSolarToDay, kWhToDay, true);
                            await setStateAsync(thisIDSolarTomorrow, kWhTomorrow, true);
                        async function makeTable () {
                            if (logging) log ('MakeTable');
                            let watts1 = JSON.parse(solarJsons[0]);
                            let watts2 = JSON.parse(solarJsons[1]);
                            let watts3 = JSON.parse(solarJsons[2]);
                            if (logging) log ('Items: '+watts1.length);
                            let table = [];
                            // make table
                                    let entry = {};
                                    entry.Summe = watts1[n].Leistung + watts2[n].Leistung+ watts3[n].Leistung;
                                    table.push(entry);
                            // make total graph
                            var graph = {};
                            var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[0],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                        	graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 2,"barIsStacked": true,"color":graphColor[1],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[1],"datalabel_fontSize":10};
                            graphData = {"tooltip_AppendText": tooltipAppendText,"legendText": legendTest[2],"yAxis_id": 1,"type": "bar","displayOrder": 3,"barIsStacked": true,"color":graphColor[2],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[2],"datalabel_fontSize":10};
                            setState(idSolarJSONTable, JSON.stringify(table), true);
                            setState(idSolarJSONGraph, JSON.stringify(graph), true);
                             // make Dach graph
                            var graph = {};
                            var graphData = {"tooltip_AppendText":tooltipAppendText,"legendText": legendTest[1],"yAxis_id": 1,"type": "bar","displayOrder": 1,"barIsStacked": true,"color":graphColor[0],"barStackId":1,"datalabel_rotation":-90,"datalabel_color":datalabelColor[0],"datalabel_fontSize":10};
                            setState(idSolarDachJSONGraph, JSON.stringify(graph), true);
                            const request1 = axios.get(url1);
                            const request2 = axios.get(url2);
                            const request3 = axios.get(url3);
                            let requests = [request1,request2,request3];
                            await axios
                                .all(requests)
                                .then (axios.spread(async (...responses) =>  {
                                    // use/access the results
                                    for (var n=0;n<responses.length;n++) {
                                        if (logging) console.log(responses[n].data);
                                        await makeResponse (responses[n],idSolarJSONS[n],n,idSolarToDayS[n],idSolarTomorrowS[n]);
                                    await makeTable();
                                    let vDachToDay = parseFloat(((await getStateAsync(idSolarToday2)).val).toFixed(2));
                                    setState(idSolarPanelToDay,vDachToDay);
                                    let vDachTomorrow = parseFloat(((await getStateAsync(idSolarTomorrow2)).val).toFixed(2));
                                    setState(idSolarPanelTomorrow,vDachTomorrow);
                                .catch(errors => {
                                    // react on errors.
                                    console.log(errors)
                        json solar systeminfo
                        15
                        188
                        20758
