    4. {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.
      Thomas Braun Most Active @ESP8266 last edited by Thomas Braun
      @esp8266
      Ich hab jetzt mein System auf nodejs@18 gedrückt, maxcul installiert, dann nodejs@20 installiert und maxcul hat sich automatisch selber neugebaut. Es kamen zwar zunächst Meldungen wie
      2024-07-27 22:07:04.394  - info: maxcul.0 (21557) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
      2024-07-27 22:07:04.974  - error: maxcul.0 (21557) uncaught exception: Could not locate the bindings file. Tried:
       → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/compiled/20.16.0/linux/arm64/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
       → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v115-linux-arm64/bindings.node
      2024-07-27 22:07:04.980  - error: maxcul.0 (21557) Error: Could not locate the bindings file. Tried:
          at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
          at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
          at Module._compile (node:internal/modules/cjs/loader:1358:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          at Module.load (node:internal/modules/cjs/loader:1208:32)
          at Module._load (node:internal/modules/cjs/loader:1024:12)
          at Module.require (node:internal/modules/cjs/loader:1233:19)
          at require (node:internal/modules/helpers:179:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.maxcul/node_modules/serialport/lib/index.js:2:17)
      2024-07-27 22:07:04.984  - error: maxcul.0 (21557) Could not locate the bindings file. Tried:
      2024-07-27 22:07:04.998  - info: maxcul.0 (21557) terminating
      2024-07-27 22:07:05.001  - warn: maxcul.0 (21557) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-07-27 22:07:05.504  - info: maxcul.0 (21557) terminating
      2024-07-27 22:07:05.706  - error: host.chet Caught by controller[0]: Cannot load serialport module
      2024-07-27 22:07:05.709  - error: host.chet instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-07-27 22:07:41.498  - info: maxcul.0 (21900) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
      2024-07-27 22:07:41.982  - info: maxcul.0 (21900) using serial device /dev/ttyS0@38400
      2024-07-27 22:07:42.018  - info: maxcul.0 (21900) serialPort /dev/ttyS0 is open!
      2024-07-27 22:08:12.031  - info: maxcul.0 (21900) Timeout on CUL connect, cul is available but not responding
      2024-07-27 22:09:21.327  - warn: maxcul.0 (21900) Module serialport is not available
      2024-07-27 22:10:31.444  - error: host.chet iobroker npm-rebuild: Rebuilding native modules failed
      rein, da einfach ein paar Minuten abwarten, am Ende kommt dann aber:
      2024-07-27 22:14:19.035  - info: maxcul.0 (22993) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.maxcul, node: v20.16.0, js-controller: 6.0.9
      2024-07-27 22:14:19.321  - info: maxcul.0 (22993) using serial device /dev/ttyS0@38400
      2024-07-27 22:14:19.336  - info: maxcul.0 (22993) serialPort /dev/ttyS0 is open!
      2024-07-27 22:14:26.978  - info: maxcul.0 (22993) List of port: [{"manufacturer":"Silicon Labs","serialNumber":"00_12_4B_00_23_93_2C_A8","pnpId":"usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"path":"/dev/ttyS0"}]
      2024-07-27 22:14:49.340  - info: maxcul.0 (22993) Timeout on CUL connect, cul is available but not responding
      2024-07-27 22:15:33.136  - info: maxcul.0 (22993) List of port: [{"manufacturer":"Silicon Labs","serialNumber":"00_12_4B_00_23_93_2C_A8","pnpId":"usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"path":"/dev/ttyS0"}]
      und die Instanz startet.
      ESP8266 1 Reply Last reply Reply Quote 1
      • ESP8266
        ESP8266 @Thomas Braun last edited by
        @thomas-braun , Hmh, wie kann ich bei einer neu Installation umgehen, dass die Datenpunkte gelöscht werden?
          @esp8266
          Werden sie nicht.
          mcm1957 ESP8266 2 Replies Last reply Reply Quote 0
          • mcm1957
            mcm1957 @Thomas Braun last edited by
            @thomas-braun said in Maxcul Adapter veraltet, bitte aktualisieren.:
            @esp8266
            Werden sie nicht.
            Ähmm - bei der Installation nicht. Aber bei der DEinstallation. Oder versteh ich da was falsch?
              Thomas Braun Most Active @mcm1957 last edited by
              @mcm1957
              Man muss den Adapter ja nicht deinstallieren, einfach nur rebuilden lassen. Funktioniert wie oben gestestet automatisch. Man muss nur abwarten.
              • ESP8266
                @thomas-braun , erklär mal. Ich lösche den Adapter und die Daten bleiben.
                Ich nehme mal an, löschen unter den Instanzen, richtig. Dann sollten die Datenpunkte erhalten werden. Ich frage nur zur Sicherheit. Zur Not kann ich dann auch ein Restore noch einspielen.
                Aber dann bleibt der Adapter so wie er ist.
                  @esp8266
                  Was soll ich denn da erklären?
                  Update nodejs und warte einfach ab.
                  • ESP8266
                    ESP8266 last edited by ESP8266
                    @thomas-braun , so sieht es seit 12:44 aus
                    logparser.0
                    	1689	2024-07-28 12:44:58.899	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.logparser, node: v20.16.0, js-controller: 6.0.9
                    host.iobroker
                    		2024-07-28 12:44:56.014	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
                    host.iobroker
                    		2024-07-28 12:44:56.013	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    		2024-07-28 12:44:56.012	error	Caught by controller[0]: Cannot load serialport module
                    maxcul.0
                    	1636	2024-07-28 12:44:55.262	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    maxcul.0
                    	1636	2024-07-28 12:44:55.247	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    maxcul.0
                    	1636	2024-07-28 12:44:55.244	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    maxcul.0
                    	1636	2024-07-28 12:44:55.238	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                    und es hat sich nichts weiter getan.
                    Das war schon der 2. Versuch.
                    Der erste sah so aus:
                    host.iobroker
                    		2024-07-28 12:23:55.288	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
                    host.iobroker
                    		2024-07-28 12:23:55.288	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    		2024-07-28 12:23:55.287	error	Caught by controller[0]: Cannot load serialport module
                    maxcul.0
                    	289114	2024-07-28 12:23:54.644	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    maxcul.0
                    	289114	2024-07-28 12:23:54.635	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    maxcul.0
                    	289114	2024-07-28 12:23:54.633	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    maxcul.0
                    	289114	2024-07-28 12:23:54.629	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    host.iobroker
                    		2024-07-28 12:23:20.908	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    		2024-07-28 12:23:20.903	error	Caught by controller[0]: Cannot load serialport module
                    maxcul.0
                    	289047	2024-07-28 12:23:20.236	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    maxcul.0
                    	289047	2024-07-28 12:23:20.224	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    maxcul.0
                    	289047	2024-07-28 12:23:20.222	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    maxcul.0
                    	289047	2024-07-28 12:23:20.217	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    host.iobroker
                    		2024-07-28 12:22:43.996	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    host.iobroker
                    		2024-07-28 12:22:43.989	error	Caught by controller[0]: Cannot load serialport module
                    maxcul.0
                    	288903	2024-07-28 12:22:43.133	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    maxcul.0
                    	288903	2024-07-28 12:22:43.105	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                    maxcul.0
                    	288903	2024-07-28 12:22:43.098	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                    maxcul.0
                    	288903	2024-07-28 12:22:43.087	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
                      @esp8266 sagte in Maxcul Adapter veraltet, bitte aktualisieren.:
                      Dann knall den nochmal rein:
                      iob upgrade maxcul@1.3.1 --debug
                      Der Rebuild schaut dann auf meiner Kiste so aus:
                      echad@chet:~ $ iob upgrade iobroker.maxcul@1.3.1 --debug
                      Would you like to reinstall version 1.3.1 of maxcul now? [(y)es, (n)o]: y
                      Update maxcul from @1.3.1 to @1.3.1
                      Uninstall npm packet "iobroker.maxcul" for a clean re-installation
                      removed 41 packages in 8s
                      191 packages are looking for funding
                        run `npm fund` for details
                      NPM version: 10.8.2
                      Installing iobroker.maxcul@1.3.1... (System call)
                      > @serialport/bindings@9.2.8 install
                      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                      prebuild-install warn install No prebuilt binaries found (target=22.5.1 runtime=node arch=arm64 libc= platform=linux)
                      gyp info it worked if it ends with ok
                      gyp info using node-gyp@10.1.0
                      gyp info using node@22.5.1 | linux | arm64
                      gyp info find Python using Python version 3.12.4 found at "/usr/bin/python3"
                      gyp info spawn /usr/bin/python3
                      gyp info spawn args [
                      gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                      gyp info spawn args 'binding.gyp',
                      gyp info spawn args '-f',
                      gyp info spawn args 'make',
                      gyp info spawn args '-I',
                      gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
                      gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                      gyp info spawn args '/home/iobroker/.cache/node-gyp/22.5.1/include/node/common.gypi',
                      gyp info spawn args '-Dlibrary=shared_library',
                      gyp info spawn args '-Dvisibility=default',
                      gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.5.1',
                      gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                      gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.5.1/<(target_arch)/node.lib',
                      gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
                      gyp info spawn args '-Dnode_engine=v8',
                      gyp info spawn args '--depth=.',
                      gyp info spawn args '--no-parallel',
                      gyp info spawn args '--generator-output',
                      gyp info spawn args 'build',
                      gyp info spawn args '-Goutput_dir=.'
                      gyp info spawn args ]
                      gyp info spawn make
                      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                      make: Entering directory '/opt/iobroker/node_modules/@serialport/bindings/build'
                        CXX(target) Release/obj.target/bindings/src/serialport.o
                      In file included from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-array-buffer.h:12,
                                       from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8.h:24,
                                       from /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:73,
                                       from ../../../nan/nan.h:62,
                                       from ../src/./serialport.h:13,
                                       from ../src/serialport.cpp:1:
                      /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: warning: template-id not allowed for constructor in C++20 [-Wtemplate-id-cdtor]
                        401 |   V8_INLINE explicit Local<T>(const LocalBase<T>& other)
                      /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: note: remove the ‘< >’
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                         78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                        412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                      ../src/serialport.cpp: At global scope:
                      ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                        433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                      ../src/serialport.cpp:433:28: note: remove parentheses
                      ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                        452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                      ../src/serialport.cpp:452:30: note: remove parentheses
                      /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1232:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                       1232 |       (node::addon_register_func) (regfunc),                          \
                      /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1266:3: note: in expansion of macro ‘NODE_MODULE_X’
                       1266 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                      ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                        486 | NODE_MODULE(serialport, init);
                        CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                                       from ../src/serialport.h:13,
                                       from ../src/serialport_unix.cpp:2:
                      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                      ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                        179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                      ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                      ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                         89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                      ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                        CXX(target) Release/obj.target/bindings/src/poller.o
                                       from ../src/poller.cpp:1:
                        CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                        SOLINK_MODULE(target) Release/obj.target/bindings.node
                        COPY Release/bindings.node
                      make: Leaving directory '/opt/iobroker/node_modules/@serialport/bindings/build'
                      gyp info ok
                      added 41 packages in 40s
                      204 packages are looking for funding
                      upload [3] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index.html index.html text/html
                      upload [2] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index_m.html index_m.html text/html
                      upload [1] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/maxcul.png maxcul.png image/png
                      upload [0] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/words.js words.js application/javascript
                      echad@chet:~ $
                      ESP8266 mcm1957 2 Replies Last reply Reply Quote 1
                      • ESP8266
                        @thomas-braun , super das hat gepasst.👍
                        Wenn ich euch nicht hätte 😊
                        • mcm1957
                          Achtung:
                          Der REinstall funktioniert erst richtig mit js-controller 6++. Erst ab 6.x.x wird zuerst ein implizites npm deinstall ausgeführt und dann ein npm i.
                          Der 5er macht nur ein npm i - und npm optimiert alles weg wenn die Version schon installiert ist. Beim 5er sollte es helfen zuerst eine version downzugraden und dann wieder upzugraden. Da tut npm dann was.
                            @mcm1957
                            Hatte mich schon gewundert.
                            war mir nämlich neu. Aber ich rebuilde auch nicht sooooo oft meine Adapter.
                            ESP8266 mcm1957 2 Replies Last reply Reply Quote 0
                            • ESP8266
                              Nun ist die "beta" Repository bei mir komplett Aktuell....
                              • mcm1957
                                @mcm1957
                                Bei Tests hat sich gezeigt, dass npm zu viel optimiert. Ein REinstall hat daher nicht wirklich das gebracht was man erwartet - nämlich dass der Stand installiert wird der im Package drinnen ist. Hat man (- ja soll man nicht-) eine Datei des Adapters verändert dann hat ein Reinstall nicht wie erwartet den Stand wiederhergestellt der im Package drinnen ist sondern (im allgeminen) nichts gemacht... js-controller 6 macht daher bei reinstall nun zuerst ein (npm only) deinstall gefolgt von einem npm install. Npm only deinstall soll heißen, dass nur das npm package deinstalliert wird nicht aber der normale Deinstall Ablauf durchgeführt wird. Kurz - Einstellungen, States, ... bleiben alle erhalten.
                                  guergen @ESP8266 last edited by guergen
                                  @esp8266 Hast Du jetzt mit Node 20 den Maxcul 1.3.1 laufen, sehe ich das richtig?
                                  Also erst den Node auf 20 und dann den Befehl von thomas?
                                    guergen @haus-automatisierung last edited by
                                    @haus-automatisierung Zum Testen hätt ich dir was geben können, den Cul hast Du ja noch, nen Fensterkontakt ist schnell abgebaut 😉
                                    Leider zu spät gesehen, aber es scheint ja zu funktionieren...
                                    haus-automatisierung ESP8266 2 Replies Last reply Reply Quote 0
                                    • haus-automatisierung
                                      haus-automatisierung Developer Most Active @guergen last edited by
                                      @guergen Klar, irgendwie bekommt man das hin. Ich mache nur aktuell schon super viel an Adaptern, welche ich selbst nicht nutze (nur um die am leben zu halten). Mir fehlt die Zeit an allen Ecken und Enden weiter zu machen.
                                      Und wir sprechen ja von einem recht selten genutzten Adapter. Die Dankbarkeit wird sich in Grenzen halten und die Produkte und Protokolle sind ja eh schon abgekündigt.
                                      ESP8266 1 Reply Last reply Reply Quote 2
                                      • ESP8266
                                        ESP8266 @guergen last edited by ESP8266
                                        @guergen , ich betreibe Maxcul im Cube modus und brauche den Adapter trotzdem. Der cul liegt in der Schublade.
                                        Aber schau mal dort, wie ich das gelöst habe... https://forum.iobroker.net/topic/61650/usb-port-to-ip-oder-maxcube-mit-maxcul-adapter-via-lan?_=1723539547532
                                        Das läuft schon über ein Jahr bei mir.
                                        • ESP8266
                                          ESP8266 @haus-automatisierung last edited by
                                          @haus-automatisierung sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                                          Der beste Beweis, das wir in einer Wegwerfgesellschaft leben.
                                            haus-automatisierung Developer Most Active @ESP8266 last edited by
                                            @esp8266 sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                                            Was man dann unterstützt, wenn man auf proprietäre Produkte und Protokolle einzelner Hersteller setzt.
                                            2018
