    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      reddddich @Thomas Braun last edited by
      			v.2024-05-22
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Installation: 		native
      Kernel: 		armv7l
      Userland: 		32 bit
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      Display-Server: 	true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/nodejs 	v20.16.0
      /usr/bin/node 		v20.16.0
      /usr/bin/npm 		10.8.1
      /usr/bin/npx 		10.8.1
      /usr/bin/corepack 	0.28.2
      Recommended versions are nodejs 18.20.4 and npm 10.7.0
      MEMORY:
      Mem:            7.9G        1.8G        5.4G        4.0M        695M        6.1G
      Swap:            99M          0B         99M
      Total:          8.0G        1.8G        5.5G
      Active iob-Instances: 	29
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.19
      			admin 			6.17.14
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      Objects: 		13144
      States: 		10376
      Size of iob-Database:
      17M	/opt/iobroker/iobroker-data/objects.jsonl
      9.2M	/opt/iobroker/iobroker-data/objects.json.migrated
      9.2M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      18M	/opt/iobroker/iobroker-data/states.jsonl
      1.4M	/opt/iobroker/iobroker-data/states.json.migrated
      1.4M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
        Thomas Braun Most Active @reddddich last edited by
        @reddddich sagte in Troubleshooting NodeJS update:
        Wie hast du eigentlich nodejs v20.16.0 ohne Repo auf das System gewuchtet?
        Mach es damit:
        curl -fsSL https://deb.nodesource.com/setup_20.x | sudo bash -
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Model		: Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           23:09:24 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          *** Time and Time Zones ***
                         Local time: Tue 2024-07-30 23:09:24 CEST
                     Universal time: Tue 2024-07-30 21:09:24 UTC
                           RTC time: Tue 2024-07-30 21:09:24
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** Display-Server-Setup ***
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:            7.9G        1.8G        5.4G        4.0M        691M        6.1G
          Swap:            99M          0B         99M
                   7897 M total memory
                   1814 M used memory
                    125 M active memory
                   2265 M inactive memory
                   5391 M free memory
                     27 M buffer memory
                    663 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 23:09:25 up 4 days, 23:14,  1 user,  load average: 4.26, 4.46, 3.87
          Tasks: 219 total,   5 running, 214 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 41.1 us, 19.2 sy,  0.0 ni, 27.4 id, 11.0 wa,  0.0 hi,  1.4 si,  0.0 st
          MiB Mem :   7897.4 total,   5398.7 free,   1816.3 used,    682.4 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6060.6 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      118G   21G   92G  19% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  2.0M  1.6G   1% /run
          /dev/sda1      vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Thu Jul 25 23:54:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:5F:37:B2 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=c4837344-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Jul 25 23:55:01 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Jul 25 23:55:01 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Thu Jul 25 23:55:04 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET                       SOURCE     FSTYPE     OPTIONS
          /                            /dev/sda2  ext4       rw,noatime
          |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=3780284k,nr_inodes=25694,mode=755
          | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
          | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
          |-/proc                      proc       proc       rw,relatime
          | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
          |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=1617384k,nr_inodes=819200,mode=755
          | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
          | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=808688k,nr_inodes=202172,mode=700,uid=1000,gid=1000
          |-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          `-/var/lib/lxcfs             lxcfs      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          8.1G	/var/
          4.7G	/var/log
          3.9G	/var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
          3.2G	/var/lib
          Archived and active journals take up 3.8G in the file system.
          /opt/iobroker/backups:
          3.2G	/opt/iobroker/backups/
          4.0K	/opt/iobroker/backups/redistmp
          /opt/iobroker/iobroker-data:
          1.3G	/opt/iobroker/iobroker-data/
          652M	/opt/iobroker/iobroker-data/files
          227M	/opt/iobroker/iobroker-data/ring_0/snapshot
          227M	/opt/iobroker/iobroker-data/files/ring.0/doorbell_118278720
          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          27M	/opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          19M	/opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD48FA-if00
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyACM0
          *** NodeJS-Installation ***
          /usr/bin/npm 		10.8.1
          /usr/bin/npx 		10.8.1
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 600
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               20.15.1-1nodesource1 600
               20.15.0-1nodesource1 600
               20.14.0-1nodesource1 600
               20.13.1-1nodesource1 600
               20.13.0-1nodesource1 600
               20.12.2-1nodesource1 600
               20.12.1-1nodesource1 600
               20.12.0-1nodesource1 600
               20.11.1-1nodesource1 600
               20.11.0-1nodesource1 600
               20.10.0-1nodesource1 600
               20.9.0-1nodesource1 600
               20.8.1-1nodesource1 600
               20.8.0-1nodesource1 600
               20.7.0-1nodesource1 600
               20.6.1-1nodesource1 600
               20.6.0-1nodesource1 600
               20.5.1-1nodesource1 600
               20.5.0-1nodesource1 600
               20.4.0-1nodesource1 600
               20.3.1-1nodesource1 600
               20.3.0-1nodesource1 600
               20.2.0-1nodesource1 600
               20.1.0-1nodesource1 600
               20.0.0-1nodesource1 600
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.19
          admin: 		6.17.14
          javascript: 	8.3.1
          nodejs modules from github: 	2
          +-- iobroker.mercedesme@0.2.3 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#127508de20b11a628957ab2478fbf590ef99cf9f)
          +-- iobroker.telegram@3.9.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.telegram.git#d0b5366c77d6e7f1656dc53648d9cb160d3b66b2)
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
          + system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.heos.0                   : heos                  : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
          + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
          + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
            system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
            system.adapter.midea.0                  : midea                 : raspberrypi                              - disabled
            system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1894
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1894, bind: 192.168.5.206
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.ring.0                   : ring                  : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1893, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
            system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.17.14  , installed 6.17.14
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "denon"        : 1.15.5   , installed 1.15.5
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "eusec"        : 1.2.1    , installed 1.2.1
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "heos"         : 2.2.1    , installed 2.2.1
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "ical"         : 1.15.0   , installed 1.15.0
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "midea"        : 0.0.7    , installed 0.0.7
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "ring"         : 5.1.0    , installed 5.1.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
          Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 3.3.2    , installed 3.9.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "worx"         : 3.0.2    , installed 3.0.2
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects: 	13144
          States: 	10376
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 https://repos.influxdata.com/debian stable InRelease
          Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15383      894/sshd: /usr/sbin
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16415      911/dnsmasq
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          15408      921/lighttpd
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        15520      817/influxd
          tcp        0      0 192.168.5.206:1895      0.0.0.0:*               LISTEN      1001       26900300   10369/io.mqtt.0
          tcp        0      0 192.168.5.206:1894      0.0.0.0:*               LISTEN      1001       26900299   10369/io.mqtt.0
          tcp        0      0 192.168.5.206:18701     0.0.0.0:*               LISTEN      1001       26900112   10222/io.hm-rpc.2
          tcp        0      0 127.0.0.1:34001         0.0.0.0:*               LISTEN      1001       26904227   11155/io.yahka.1
          tcp        0      0 192.168.5.206:12001     0.0.0.0:*               LISTEN      1001       26896947   10262/io.hm-rpc.3
          tcp        0      0 192.168.5.206:12010     0.0.0.0:*               LISTEN      1001       26897068   10307/io.hm-rpc.4
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       26899050   9931/iobroker.js-co
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       26898098   9931/iobroker.js-co
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26897360   10245/node-red
          tcp        0      0 0.0.0.0:1893            0.0.0.0:*               LISTEN      1001       26900842   10471/io.shelly.0
          tcp        0      0 192.168.5.206:2087      0.0.0.0:*               LISTEN      1001       26902560   10245/node-red
          tcp        0      0 192.168.5.206:2088      0.0.0.0:*               LISTEN      1001       26902561   10245/node-red
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15385      894/sshd: /usr/sbin
          tcp6       0      0 :::80                   :::*                    LISTEN      0          15409      921/lighttpd
          tcp6       0      0 :::42775                :::*                    LISTEN      1001       26903307   11155/io.yahka.1
          tcp6       0      0 :::8554                 :::*                    LISTEN      1001       26903034   11150/go2rtc
          tcp6       0      0 :::8555                 :::*                    LISTEN      1001       26903038   11150/go2rtc
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26896763   10009/io.admin.0
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       26905949   11072/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        18493      817/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       26904793   10997/io.simple-api
          tcp6       0      0 :::3000                 :::*                    LISTEN      111        14047      809/grafana-server
          tcp6       0      0 :::991                  :::*                    LISTEN      1001       26902026   10245/node-red
          tcp6       0      0 :::1984                 :::*                    LISTEN      1001       26903048   11150/go2rtc
          tcp6       0      0 :::992                  :::*                    LISTEN      1001       26902024   10245/node-red
          tcp6       0      0 :::993                  :::*                    LISTEN      1001       26902022   10245/node-red
          tcp6       0      0 :::994                  :::*                    LISTEN      1001       26902014   10245/node-red
          tcp6       0      0 :::995                  :::*                    LISTEN      1001       26902012   10245/node-red
          tcp6       0      0 :::996                  :::*                    LISTEN      1001       26902010   10245/node-red
          tcp6       0      0 :::997                  :::*                    LISTEN      1001       26902008   10245/node-red
          tcp6       0      0 :::998                  :::*                    LISTEN      1001       26902017   10245/node-red
          tcp6       0      0 :::999                  :::*                    LISTEN      1001       26902003   10245/node-red
          udp        0      0 0.0.0.0:44041           0.0.0.0:*                           108        1810       458/avahi-daemon: r
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16414      911/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16411      911/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14688      700/dhclient
          udp        0      0 0.0.0.0:52309           0.0.0.0:*                           1001       26903063   10761/io.eusec.0
          udp        0      0 0.0.0.0:42662           0.0.0.0:*                           1001       26932801   10894/io.heos.0
          udp        0      0 0.0.0.0:39622           0.0.0.0:*                           1001       26903058   10761/io.eusec.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26903089   11123/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1808       458/avahi-daemon: r
          udp        0      0 0.0.0.0:56565           0.0.0.0:*                           1001       26903053   10761/io.eusec.0
          udp        0      0 0.0.0.0:48394           0.0.0.0:*                           1001       26903990   10761/io.eusec.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       26900965   10245/node-red
          udp        0      0 0.0.0.0:51662           0.0.0.0:*                           1001       26903970   10761/io.eusec.0
          udp6       0      0 :::5353                 :::*                                108        1809       458/avahi-daemon: r
          udp6       0      0 :::57656                :::*                                108        1811       458/avahi-daemon: r
          udp6       0      0 :::8555                 :::*                                1001       26903039   11150/go2rtc
          2024-07-30 23:10:56.760  - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-07-30 23:10:56.761  - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
          2024-07-30 23:10:57.034  - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: var!x00) = requiru8'..x509�);
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:    ^
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Unexpected token '!'
          2024-07-30 23:10:57.035  - error: host.raspberrypi Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1281:20)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1321:27)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-07-30 23:10:57.036  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
          2024-07-30 23:10:57.037  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-07-30 23:10:57.038  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/fingerprint.js:12:19)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-07-30 23:10:57.039  - error: host.raspberrypi Caught by controller[0]: Node.js v20.16.0
          2024-07-30 23:10:57.040  - error: host.raspberrypi instance system.adapter.sony-bravia.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-07-30 23:10:57.040  - info: host.raspberrypi Restart adapter system.adapter.sony-bravia.0 because enabled
            @thomas-braun said in Troubleshooting NodeJS update:
            Mach es damit:
            wie gesagt...: n00b
              @reddddich
              Und wie hat es der n00b gemacht?
                @reddddich
                Jetzt passt es.
                Das nodesource-Repo ist jetzt richtig auf 20 gesetzt worden.
                Dann kannste jetzt den Desktop ausschalten und zigbee auf den 'by-id'-Link setzen.
                  @reddddich
                  wine and n00bness did its job... als typischer copy paste mensch der befehle lief da bestimmt was schief
                    @reddddich
                    Und welche Befehle hast du da woher kopiert?
                      zumindest alles aus dem Forum...
                      weiterhin starten adapter aber nicht...
                      	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.raspberrypi
                      2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
                      host.raspberrypi
                      2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                      host.raspberrypi
                      2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.raspberrypi
                      2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
                      host.raspberrypi
                      2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
                      host.raspberrypi
                      2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
                      host.raspberrypi
                      2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
                      host.raspberrypi
                      2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
                      host.raspberrypi
                      2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
                        @reddddich
                        Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
                          Ich kann dir nur noch Recht geben... 🙂
                          • BananaJoe
                            BananaJoe Most Active @reddddich last edited by
                            @reddddich mit dem Befehl
                            history
                            bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
                              tony63526 last edited by
                              ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
                              Installiert habe ich es nach dieser Anleitung
                              https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                              iob diag ergab folgendes:
                                                      v.2024-05-22
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 10 (buster)
                                          Kernel: Linux 5.10.103-v7l+
                                    Architecture: arm
                              Kernel:                 armv7l
                              Userland:               32 bit
                              User-ID:                1000
                              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                              nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              /usr/bin/corepack
                              Recommended versions are nodejs  and npm
                              MEMORY:
                              Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
                              Swap:           99M          0B         99M
                              Total:         8.0G        232M        6.5G
                              Active iob-Instances:   0
                                                      admin
                              ioBroker Status:
                              Objects:                0
                              States:                 0
                              29M     /opt/iobroker/iobroker-data/objects.jsonl
                              5.3M    /opt/iobroker/iobroker-data/states.jsonl
                              === Mark text until here for copying ===
                              pi@raspberrypi:~ $ iob fix
                              library: loaded
                              Library version=2024-05-24
                              Welcome to the ioBroker installation fixer!
                              Script version: 2024-01-04
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/5)
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Reading package lists... Done
                              Checking ioBroker user and directory permissions (2/5)
                              Created /etc/sudoers.d/iobroker
                              Fixing directory permissions...
                              Check and cleanup npm temporary directories (3/5)
                              Done.
                              Database maintenance (4/5)
                              Checking for uncompressed JSONL databases... This might take a while!
                              node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
                              Checking autostart (5/5)
                              Enabling autostart...
                              Autostart enabled!
                              Your installation was fixed successfully
                              Run iobroker start to start ioBroker again!
                              pi@raspberrypi:~ $ iob start
                                Thomas Braun Most Active @tony63526 last edited by Thomas Braun
                                @tony63526 sagte in Troubleshooting NodeJS update:
                                buster
                                Ist zu alt, installier da dringend was lebendiges.
                                Diesmal gleich in der 64Bit-Lite Version.
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                  tony63526 @Thomas Braun last edited by
                                  Würde bedeuten ich muss alles neu aufsetzten?
                                  • Zigbee gereate neu anlernen
                                  • Text2command neu eintippen.
                                    eigentlich alles, weil ich mein backup nicht nutzen kann?
                                  mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @tony63526 last edited by
                                    @tony63526
                                    Wieso kannst du dein Backup nicht nutzen?
                                      Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                                      Warum nicht?
                                        tony63526 @mcm1957 last edited by
                                        @mcm1957
                                        Weis ich nicht.
                                        War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                                        mcm1957 Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                        • mcm1957
                                          @tony63526
                                          Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                                            Ein Backup via backitup ist unabhängig vom Betriebssystem.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143186
