    4. js-controller 6.0.x jetzt für alle User im STABLE!
      Homoran Global Moderator Administrators @fellpower last edited by Homoran
      @fellpower sagte in Nach Update des JS Controllers einige Fehler:
      Mein Iobroker läuft auf einem Proxmox Server im Docker.
      Updates für JS Controller
      funktionieren meines Wissens bei Docker so nicht
      F crunchip 2 Replies Last reply Reply Quote 0
        fellpower @Homoran last edited by
        Und das heisst jetzt was?
          keine Ahnung!
          Docker ist mir zu komplex!
          • O
            oFbEQnpoLKKl6mbY5e13 @foxriver76 last edited by oFbEQnpoLKKl6mbY5e13
            @foxriver76
            Bleiben wir ruhig bei dem genannten Beispiel.
            Alias:
              "common": {
                "alias": {
                  "id": {
                    "read": "mqtt-client.0.stat.tasmota_A36501.POWER2",
                    "write": "mqtt-client.0.cmnd.tasmota_A36501.POWER2"
                  "read": "val == \"ON\" ? true : false",
                  "write": "val == true ? 1 : 0"
                "name": "Strahler 2",
                "role": "switch",
                "type": "boolean",
                "unit": "",
                "min": null,
                "max": null,
                "read": true,
                "write": true,
                "smartName": {
                  "de": "Strahler 2",
                  "smartType": "SWITCH"
              "native": {},
              "type": "state",
              "_id": "alias.0.Haus.Erdgeschoss.Schlafzimmer.Strahler2.switch_on",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
              "user": "system.user.admin",
              "ts": 1680780507033
            Datenpunkt lesend:
              "type": "state",
              "role": "text",
              "common": {
                "name": "POWER2",
                "type": "mixed",
                "read": true,
                "write": true,
                "desc": "created from topic",
                "custom": {
                  "mqtt-client.0": {
                    "enabled": true,
                    "topic": "stat/tasmota_A36501/POWER2",
                    "publish": false,
                    "pubChangesOnly": false,
                    "pubAsObject": false,
                    "qos": 0,
                    "retain": false,
                    "subscribe": true,
                    "subChangesOnly": false,
                    "subAsObject": false,
                    "subQos": 0,
                    "setAck": true
              "native": {
              "from": "system.adapter.mqtt-client.0",
              "ts": 1680698849842,
              "_id": "mqtt-client.0.stat.tasmota_A36501.POWER2",
              "acl": {
                "object": 1636,
                "state": 1636,
              "binary": true
            Datenpunkt schreibend:
              "type": "state",
              "role": "text",
              "common": {
                "name": "POWER2",
                "type": "mixed",
                "read": true,
                "write": true,
                "custom": {
                  "mqtt-client.0": {
                    "enabled": true,
                    "topic": "cmnd/tasmota_A36501/POWER2",
                    "publish": true,
                    "qos": 0,
                    "retain": false,
                    "subscribe": true,
                    "subQos": 0,
                    "setAck": true
              "native": {
              "_id": "mqtt-client.0.cmnd.tasmota_A36501.POWER2",
              "acl": {
                "object": 1636,
                "state": 1636,
              "ts": 1680700517346,
              "binary": true
            Edit:
            Ich schätze, die Meldung kommt jeweils vom Javascript-Adapter und vom Influxdb-Adapter für jeden Alias, der eine Konvertierungsfunktion (lesend) aktiviert hat.
            foxriver76 2 Replies Last reply Reply Quote 0
              Ahhhh, ja.
              Die Frage ist, ist der neuste Docker Container schon geupdatet, seitens iobroker? Dann bräuchte ich den "latest" ja nur neu ausrollen ^^
              • Codierknecht
                Codierknecht Developer Most Active @fellpower last edited by Codierknecht
                @fellpower
                Warum
                Proxmox bietet doch VM oder LXC als Virtualisierung an.
                Warum dann da noch Docker?
                  crunchip Forum Testing Most Active @foxriver76 last edited by crunchip
                  @foxriver76 muss ich testen, bisher nur einmal versucht
                  @foxriver76 habe es soeben nochmal probiert, lief allerdings auf den gleichen Fehler hinaus
                    fellpower @Codierknecht last edited by
                    @codierknecht
                    Weil ich damit noch andere Sachen mache. Warum, oder wieso spielt doch keine Rolle für das Problem.
                    Wie könnte man das jetzt lösen? Das Container Image neu downloaden und einfach neu ausrollen? Ist der denn schon up-to-date? Wie finde ich das raus?
                    • Codierknecht
                      Ein neues Image gibt's nur, wenn sich am Unterbau (OS) etwas ändert.
                      Updates des js-controllers oder der einzelnen Adapter muss man schon selbst ausführen.
                        @codierknecht
                        Okay, aber dann lese ich hier, das geht nicht im Docker. Wat denn nu?
                        • Codierknecht
                          Ich auch. Darum gibt's bei mir jeweils eigene LXC-Container (ioBroker, MariaDB, Grafana, AdGuard) bzw. VM's (Octoprint).
                          • Codierknecht
                            "Geht nicht" ist so nicht korrekt. Gehen tut's schon - wenn damit z.B. ein Update von Node oder Packet-Updates gemeint ist - macht man aber nicht. Wäre ja beim re-launch auch weg.
                            Den js-controller und/oder die Adapter kann (und sollte) man sehr wohl aktuell halten.
                            Es sei denn, man wartet immer bis zur nächsten Version des Image. Das geht natürlich auch.
                            Wo läuft denn da Dein Docker?
                            Parallel zu Proxmox als weitere Virtualisierung?
                            Oder innerhalb einer VM/LXC?
                              fellpower @Codierknecht last edited by fellpower
                              @codierknecht
                              Mein Docker läuft auf einem Ubuntu LXC, welches aufm Proxmox läuft.
                              Wie bekomme ich denn jetzt den node.js Controller dauerhaft geupdatet? Das scheint ja noch/wieder die "alte" Version zu sein, weil ich den Container neu gestartet habe.
                              Oder geht das nur, wenn es von iobroker n neues Docker Image gibt?
                              • Codierknecht
                                Richtig!
                                Was man im Container am OS bastelt, ist weg wenn der Container neu gestartet wird.
                                Das ist ja Sinn und Zweck von Containern.
                                Da musst Du warten, bis @buanet ein neues Image bereitstellt.
                                Docker in einem LXC hört sich irgendwie schräg an.
                                Virtualisierung in einer Virtualisierung 🤔
                                  crunchip Forum Testing Most Active @Homoran last edited by
                                  @homoran doch
                                  Der neuste(v10) beta bringt Nodejs v20 mit
                                    @codierknecht
                                    Ja, wenn man ein Linux Profi ist, macht man das natürlich anders - bin ich aber nicht!
                                    Und für das bisschen, was der machen soll, spielt es für mich keine Rolle, ob es virtualvirtualisiert ist 😉
                                    • Codierknecht
                                      Ich mit Sicherheit auch nicht 😉
                                      • foxriver76
                                        foxriver76 Developer @oFbEQnpoLKKl6mbY5e13 last edited by
                                        @ofbeqnpolkkl6mby5e13 Hm schaut eigentlich ok aus, muss ich probieren nachzustellen.
                                          @codierknecht
                                          Also fassen wir zusammen:
                                          Ich habe den js-controller geupdatet, das hat wohl funktioniert.
                                          Aufgrund der Docker "Problematik" kann ich mein node.js irgendwie nicht updaten.
                                          Wenn ich es mit den bekannten Befehlen versuche (Wie hier beschrieben: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18), dann funktioniert das irgendwie nicht. node.js bleibt auf 18.20.4.
                                          Also muss ich warten, bis buanet was neues bringt - oder selbst n Container bauen, wäre noch ne Möglichkeit.
                                          Was ist mit den Node-Red Fehlern auf dem Bild? Woher kommen die - und wie löse ich das?
                                            crunchip Forum Testing Most Active @fellpower last edited by
                                            Also muss ich warten, bis buanet was neues bringt?
                                            https://github.com/buanet/ioBroker.docker/releases/tag/v10.0.0-beta.1
                                            controller js-controller kiera stable
                                            47
                                            257
                                            63717
