    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      TT-Tom last edited by
      @stoffel67
      Nix mit npm install machen, sondern über
      iob upgrade self
        stoffel67 @TT-Tom last edited by
        @tt-tom
        OK werden den JS-controller updaten
        S Thomas Braun T 3 Replies Last reply Reply Quote 0
          stoffel67 @stoffel67 last edited by
          @stoffel67
          pi@raspberrypi:/opt/iobroker $ iob stop
          pi@raspberrypi:/opt/iobroker $ iob upgrade self
          Update js-controller from @5.0.12 to @6.0.9
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.8.1
          Installing iobroker.js-controller@6.0.9... (System call)
          Try to solve ENOTEMPTY error automatically
          Could not handle ENOTEMPTY, because no deletable files were found
          npm error code ENOTEMPTY
          npm error syscall rename
          npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
          npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
          npm error errno -39
          npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_32_43_299Z-debug-0.log
          host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
            Thomas Braun Most Active @stoffel67 last edited by
            @stoffel67
            Hau den javascript-Adapter nochmal drüber.
              TT-Tom @stoffel67 last edited by
              @stoffel67
              Das mine-db Problem löst du damit aber nicht.
                @stoffel67
                iob stop
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                  stoffel67 @Thomas Braun last edited by
                  es wird immer schlimmer
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  library: loaded
                  Library version=2024-05-24
                      Welcome to the ioBroker installation fixer!
                      Script version: 2024-01-04
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                  Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                  OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
                  Es wurden 13,3 MB in 15 s geholt (855 kB/s).
                  Paketlisten werden gelesen… Fertig
                      Checking ioBroker user and directory permissions (2/5)
                  Created /etc/sudoers.d/iobroker
                  Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                  Done.
                      Database maintenance (4/5)
                  Checking for uncompressed JSONL databases... This might take a while!
                  Compressing /opt/iobroker/iobroker-data/states.jsonl
                  Compressing /opt/iobroker/iobroker-data/objects.jsonl
                  Compressed 2 JSONL files. Done
                      Checking autostart (5/5)
                  Enabling autostart...
                  Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  Used repository: stable
                  Adapter    "admin"        : 7.0.22   , installed 7.0.22
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "ble"          : 0.14.0   , installed 0.14.0
                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                  Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
                  Adapter    "enet"         : 1.0.1    , installed 1.0.1
                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                  Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
                  Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                  Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                  Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                  Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
                  Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
                  Adapter    "withings"     : 0.0.13   , installed 0.0.13
                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                  Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                  Update radar2 from @2.1.0 to @2.2.0
                  NPM version: 10.8.1
                  Installing iobroker.radar2@2.2.0... (System call)
                  npm error code 7
                  npm error path /opt/iobroker/node_modules/@abandonware/noble
                  npm error command failed
                  npm error command sh -c node-gyp-build
                  npm error gyp ERR! UNCAUGHT EXCEPTION
                  npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
                  npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
                  npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
                  npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
                  npm error gyp ERR! System Linux 6.1.21-v7+
                  npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                  npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
                  npm error gyp ERR! node -v v20.16.0
                  npm error gyp ERR! node-gyp -v v7.1.2
                  npm error gyp ERR! Node-gyp failed to build your package.
                  npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
                  host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.8.1
                  npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
                  npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
                  npm error errno -39
                  npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
                    Thomas Braun Most Active @stoffel67 last edited by Thomas Braun
                    @stoffel67
                    iob delete ble
                    iob fix
                      pi@raspberrypi:/opt/iobroker $ iob delete  ble
                      Delete adapter "ble"
                      host.raspberrypi Counted 1 instances of ble
                      host.raspberrypi Counted 1 meta of ble
                      host.raspberrypi Counted 1 adapter for ble
                      host.raspberrypi Counted 2 channels of ble
                      host.raspberrypi Counted 3 states of ble
                      host.raspberrypi Counted 14 states of system.adapter.ble
                      host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
                      host.raspberrypi file ble.admin deleted
                      host.raspberrypi object ble deleted
                      host.raspberrypi object ble.admin deleted
                      host.raspberrypi Deleting 22 object(s).
                      host.raspberrypi Deleting 1 state(s).
                      Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
                      You might have to delete it yourself!
                        @stoffel67
                        iob list adapters
                        iob fix
                          der fix läuft eigentlich immer durch
                          pi@raspberrypi:/opt/iobroker $ iob list adapters
                          iob fix
                          system.adapter.admin                   : admin          - v7.0.22
                          system.adapter.backitup                : backitup       - v2.11.0
                          system.adapter.discovery               : discovery      - v4.5.0
                          system.adapter.ds18b20                 : ds18b20        - v2.0.5
                          system.adapter.enet                    : enet           - v1.0.1
                          system.adapter.info                    : info           - v1.9.26
                          system.adapter.javascript              : javascript     - v8.7.6
                          system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                          system.adapter.modbus                  : modbus         - v6.1.0
                          system.adapter.node-red                : node-red       - v5.2.1
                          system.adapter.palazzetti              : palazzetti     - v0.0.6
                          system.adapter.proxy                   : proxy          - v1.3.2
                          system.adapter.radar2                  : radar2         - v2.1.0
                          system.adapter.rpi2                    : rpi2           - v1.3.2
                          system.adapter.shelly                  : shelly         - v7.0.0
                          system.adapter.simple-api              : simple-api     - v2.8.0
                          system.adapter.slideshow               : slideshow      - v0.1.4
                          system.adapter.smartmeter              : smartmeter     - v3.4.0
                          system.adapter.socketio                : socketio       - v6.7.0
                          system.adapter.sonoff                  : sonoff         - v3.0.3
                          system.adapter.terminal                : terminal       - v0.2.2
                          system.adapter.tr-064                  : tr-064         - v4.2.18
                          system.adapter.vis                     : vis            - v1.5.6
                          system.adapter.vw-connect              : vw-connect     - v0.0.67
                          system.adapter.web                     : web            - v6.2.5
                          system.adapter.withings                : withings       - v0.0.13
                          system.adapter.ws                      : ws             - v2.6.1
                          system.adapter.yahka                   : yahka          - v1.0.3
                          pi@raspberrypi:/opt/iobroker $ iob fix
                          library: loaded
                          OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Done.
                          Autostart enabled!
                            @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                            Soll es ja auch. Muss da ja aufräumen.
                            iob stop
                            iob fix
                            iob update
                            iob upgrade all -y
                            iob upgrade self
                            Homoran S 2 Replies Last reply Reply Quote 0
                              @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                              iob stop
                              iob fix
                              iob update
                              iob upgrade all -y
                              iob upgrade self
                              @stoffel67
                              bitte einzeln aufrufen!
                                iob fix
                                iob update
                                iob upgrade all -y
                                iob upgrade self
                                library: loaded
                                OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Done.
                                Autostart enabled!
                                NPM version: 10.8.1
                                npm error code 7
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 10.8.1
                                npm error errno -39
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                                sollte ich das ganze evtl. einfach neu aufsetzen…
                                es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                                der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                                  @stoffel67
                                  Du sollst die Befehle einzeln, zeilenweise eingeben.
                                    ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                                    vielen Dank für deine Hilfe!!!!super
                                      so ich versuch es nochmal
                                      Zeilen einzeln... und es kommt das:
                                      pi@raspberrypi:~ $ iob fix
                                      library: loaded
                                      Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                      Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                                      Done.
                                      Autostart enabled!
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $ iob update
                                      pi@raspberrypi:~ $ iob upgrade all -y
                                      NPM version: 10.8.1
                                      npm error code 7
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                                      pi@raspberrypi:~ $ iob upgrade self
                                      Stopped Objects DB
                                      Stopped States DB
                                      NPM version: 10.8.1
                                      npm error errno -39
                                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                                        @stoffel67
                                        Schmeiß den radar2-Adapter mal raus.
                                        Dann nochmal wie zuvor.
                                          das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                                          Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                            @stoffel67
                                            Ja natürlich den Adapter.
                                            4417
