    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      Thomas Braun Most Active @stoffel67 last edited by
      @stoffel67
      Hau den javascript-Adapter nochmal drüber.
        TT-Tom @stoffel67 last edited by
        @stoffel67
        Das mine-db Problem löst du damit aber nicht.
          @stoffel67
          iob stop
          iob fix
          iob update
          iob upgrade all -y
          iob upgrade self
            stoffel67 @Thomas Braun last edited by
            es wird immer schlimmer
            aspberrypi:/opt/iobroker $ iob stop
            iob fix
            iob update
            iob upgrade all -y
            iob upgrade self
            library: loaded
            Library version=2024-05-24
                Welcome to the ioBroker installation fixer!
                Script version: 2024-01-04
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
            Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
            OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
            OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
            Es wurden 13,3 MB in 15 s geholt (855 kB/s).
            Paketlisten werden gelesen… Fertig
                Checking ioBroker user and directory permissions (2/5)
            Created /etc/sudoers.d/iobroker
            Fixing directory permissions...
                Check and cleanup npm temporary directories (3/5)
            Done.
                Database maintenance (4/5)
            Checking for uncompressed JSONL databases... This might take a while!
            Compressing /opt/iobroker/iobroker-data/states.jsonl
            Compressing /opt/iobroker/iobroker-data/objects.jsonl
            Compressed 2 JSONL files. Done
                Checking autostart (5/5)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            Used repository: stable
            Adapter    "admin"        : 7.0.22   , installed 7.0.22
            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
            Adapter    "enet"         : 1.0.1    , installed 1.0.1
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
            Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
            Adapter    "proxy"        : 1.3.2    , installed 1.3.2
            Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
            Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
            Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
            Adapter    "withings"     : 0.0.13   , installed 0.0.13
            Adapter    "ws"           : 2.6.1    , installed 2.6.1
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
            Update radar2 from @2.1.0 to @2.2.0
            NPM version: 10.8.1
            Installing iobroker.radar2@2.2.0... (System call)
            npm error code 7
            npm error path /opt/iobroker/node_modules/@abandonware/noble
            npm error command failed
            npm error command sh -c node-gyp-build
            npm error gyp ERR! UNCAUGHT EXCEPTION
            npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
            npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
            npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
            npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
            npm error gyp ERR! System Linux 6.1.21-v7+
            npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
            npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
            npm error gyp ERR! node -v v20.16.0
            npm error gyp ERR! node-gyp -v v7.1.2
            npm error gyp ERR! Node-gyp failed to build your package.
            npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
            host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
            Update js-controller from @5.0.12 to @6.0.9
            Stopped Objects DB
            Stopped States DB
            NPM version: 10.8.1
            Installing iobroker.js-controller@6.0.9... (System call)
            Try to solve ENOTEMPTY error automatically
            Could not handle ENOTEMPTY, because no deletable files were found
            npm error code ENOTEMPTY
            npm error syscall rename
            npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
            npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
            npm error errno -39
            npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
            host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
              Thomas Braun Most Active @stoffel67 last edited by Thomas Braun
              @stoffel67
              iob delete ble
              iob fix
                pi@raspberrypi:/opt/iobroker $ iob delete  ble
                Delete adapter "ble"
                host.raspberrypi Counted 1 instances of ble
                host.raspberrypi Counted 1 meta of ble
                host.raspberrypi Counted 1 adapter for ble
                host.raspberrypi Counted 2 channels of ble
                host.raspberrypi Counted 3 states of ble
                host.raspberrypi Counted 14 states of system.adapter.ble
                host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
                host.raspberrypi file ble.admin deleted
                host.raspberrypi object ble deleted
                host.raspberrypi object ble.admin deleted
                host.raspberrypi Deleting 22 object(s).
                host.raspberrypi Deleting 1 state(s).
                Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
                You might have to delete it yourself!
                  @stoffel67
                  iob list adapters
                  iob fix
                    der fix läuft eigentlich immer durch
                    pi@raspberrypi:/opt/iobroker $ iob list adapters
                    iob fix
                    system.adapter.admin                   : admin          - v7.0.22
                    system.adapter.backitup                : backitup       - v2.11.0
                    system.adapter.discovery               : discovery      - v4.5.0
                    system.adapter.ds18b20                 : ds18b20        - v2.0.5
                    system.adapter.enet                    : enet           - v1.0.1
                    system.adapter.info                    : info           - v1.9.26
                    system.adapter.javascript              : javascript     - v8.7.6
                    system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                    system.adapter.modbus                  : modbus         - v6.1.0
                    system.adapter.node-red                : node-red       - v5.2.1
                    system.adapter.palazzetti              : palazzetti     - v0.0.6
                    system.adapter.proxy                   : proxy          - v1.3.2
                    system.adapter.radar2                  : radar2         - v2.1.0
                    system.adapter.rpi2                    : rpi2           - v1.3.2
                    system.adapter.shelly                  : shelly         - v7.0.0
                    system.adapter.simple-api              : simple-api     - v2.8.0
                    system.adapter.slideshow               : slideshow      - v0.1.4
                    system.adapter.smartmeter              : smartmeter     - v3.4.0
                    system.adapter.socketio                : socketio       - v6.7.0
                    system.adapter.sonoff                  : sonoff         - v3.0.3
                    system.adapter.terminal                : terminal       - v0.2.2
                    system.adapter.tr-064                  : tr-064         - v4.2.18
                    system.adapter.vis                     : vis            - v1.5.6
                    system.adapter.vw-connect              : vw-connect     - v0.0.67
                    system.adapter.web                     : web            - v6.2.5
                    system.adapter.withings                : withings       - v0.0.13
                    system.adapter.ws                      : ws             - v2.6.1
                    system.adapter.yahka                   : yahka          - v1.0.3
                    pi@raspberrypi:/opt/iobroker $ iob fix
                    library: loaded
                    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Done.
                    Autostart enabled!
                      @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                      Soll es ja auch. Muss da ja aufräumen.
                      iob stop
                      iob fix
                      iob update
                      iob upgrade all -y
                      iob upgrade self
                      Homoran S 2 Replies Last reply Reply Quote 0
                        @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                        iob stop
                        iob fix
                        iob update
                        iob upgrade all -y
                        iob upgrade self
                        @stoffel67
                        bitte einzeln aufrufen!
                          pi@raspberrypi:/opt/iobroker $ iob stop
                          iob fix
                          iob update
                          iob upgrade all -y
                          iob upgrade self
                          library: loaded
                          OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Done.
                          Autostart enabled!
                          NPM version: 10.8.1
                          npm error code 7
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.8.1
                          npm error errno -39
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                          sollte ich das ganze evtl. einfach neu aufsetzen…
                          es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                          der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                            @stoffel67
                            Du sollst die Befehle einzeln, zeilenweise eingeben.
                              ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                              vielen Dank für deine Hilfe!!!!super
                                so ich versuch es nochmal
                                Zeilen einzeln... und es kommt das:
                                pi@raspberrypi:~ $ iob fix
                                library: loaded
                                Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                                Done.
                                Autostart enabled!
                                pi@raspberrypi:~ $
                                pi@raspberrypi:~ $ iob update
                                pi@raspberrypi:~ $ iob upgrade all -y
                                NPM version: 10.8.1
                                npm error code 7
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                                pi@raspberrypi:~ $ iob upgrade self
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 10.8.1
                                npm error errno -39
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                                  @stoffel67
                                  Schmeiß den radar2-Adapter mal raus.
                                  Dann nochmal wie zuvor.
                                    das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                                    Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                      @stoffel67
                                      Ja natürlich den Adapter.
                                      • mcm1957
                                        mcm1957 @stoffel67 last edited by
                                        @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                        Instanz löschen:
                                        löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                                        Adapter löschen:
                                        Löscht den Adaptercode und seine Dependencies
                                        Löscht auch alle Instanzen.
                                          stoffel67 @mcm1957 last edited by
                                          @mcm1957
                                          es ist seltsam, ichbekomm den Adapter nicht weg....
                                          $ iobroker del radar2 --debug
                                          Delete adapter "radar2"
                                          host.raspberrypi Counted 1 meta of radar2
                                          host.raspberrypi Counted 1 adapter for radar2
                                          host.raspberrypi Counted 1 states (io.radar2.*) from states
                                          host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
                                          host.raspberrypi file radar2.admin deleted
                                          host.raspberrypi object radar2 deleted
                                          host.raspberrypi object radar2.admin deleted
                                          host.raspberrypi Deleting 2 object(s).
                                          host.raspberrypi Deleting 2 state(s).
                                          Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
                                          Process exited with code 0
                                            @stoffel67
                                            iob fix
                                            iob list adapters
                                            4394
