    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      Thomas Braun Most Active @stoffel67 last edited by
      @stoffel67
      iob stop
      iob fix
      iob update
      iob upgrade all -y
      iob upgrade self
        stoffel67 @Thomas Braun last edited by
        es wird immer schlimmer
        aspberrypi:/opt/iobroker $ iob stop
        iob fix
        iob update
        iob upgrade all -y
        iob upgrade self
        library: loaded
        Library version=2024-05-24
            Welcome to the ioBroker installation fixer!
            Script version: 2024-01-04
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
        OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
        Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
        Es wurden 13,3 MB in 15 s geholt (855 kB/s).
        Paketlisten werden gelesen… Fertig
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        Used repository: stable
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
        Adapter    "enet"         : 1.0.1    , installed 1.0.1
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
        Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
        Adapter    "withings"     : 0.0.13   , installed 0.0.13
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
        Update radar2 from @2.1.0 to @2.2.0
        NPM version: 10.8.1
        Installing iobroker.radar2@2.2.0... (System call)
        npm error code 7
        npm error path /opt/iobroker/node_modules/@abandonware/noble
        npm error command failed
        npm error command sh -c node-gyp-build
        npm error gyp ERR! UNCAUGHT EXCEPTION
        npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
        npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
        npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
        npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
        npm error gyp ERR! System Linux 6.1.21-v7+
        npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
        npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
        npm error gyp ERR! node -v v20.16.0
        npm error gyp ERR! node-gyp -v v7.1.2
        npm error gyp ERR! Node-gyp failed to build your package.
        npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
        host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
        Update js-controller from @5.0.12 to @6.0.9
        Stopped Objects DB
        Stopped States DB
        NPM version: 10.8.1
        Installing iobroker.js-controller@6.0.9... (System call)
        Try to solve ENOTEMPTY error automatically
        Could not handle ENOTEMPTY, because no deletable files were found
        npm error code ENOTEMPTY
        npm error syscall rename
        npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
        npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
        npm error errno -39
        npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
        host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
          Thomas Braun Most Active @stoffel67 last edited by Thomas Braun
          @stoffel67
          iob delete ble
          iob fix
            pi@raspberrypi:/opt/iobroker $ iob delete  ble
            Delete adapter "ble"
            host.raspberrypi Counted 1 instances of ble
            host.raspberrypi Counted 1 meta of ble
            host.raspberrypi Counted 1 adapter for ble
            host.raspberrypi Counted 2 channels of ble
            host.raspberrypi Counted 3 states of ble
            host.raspberrypi Counted 14 states of system.adapter.ble
            host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
            host.raspberrypi file ble.admin deleted
            host.raspberrypi object ble deleted
            host.raspberrypi object ble.admin deleted
            host.raspberrypi Deleting 22 object(s).
            host.raspberrypi Deleting 1 state(s).
            Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
            You might have to delete it yourself!
              @stoffel67
              iob list adapters
              iob fix
                der fix läuft eigentlich immer durch
                pi@raspberrypi:/opt/iobroker $ iob list adapters
                iob fix
                system.adapter.admin                   : admin          - v7.0.22
                system.adapter.backitup                : backitup       - v2.11.0
                system.adapter.discovery               : discovery      - v4.5.0
                system.adapter.ds18b20                 : ds18b20        - v2.0.5
                system.adapter.enet                    : enet           - v1.0.1
                system.adapter.info                    : info           - v1.9.26
                system.adapter.javascript              : javascript     - v8.7.6
                system.adapter.linkeddevices           : linkeddevices  - v1.5.5
                system.adapter.modbus                  : modbus         - v6.1.0
                system.adapter.node-red                : node-red       - v5.2.1
                system.adapter.palazzetti              : palazzetti     - v0.0.6
                system.adapter.proxy                   : proxy          - v1.3.2
                system.adapter.radar2                  : radar2         - v2.1.0
                system.adapter.rpi2                    : rpi2           - v1.3.2
                system.adapter.shelly                  : shelly         - v7.0.0
                system.adapter.simple-api              : simple-api     - v2.8.0
                system.adapter.slideshow               : slideshow      - v0.1.4
                system.adapter.smartmeter              : smartmeter     - v3.4.0
                system.adapter.socketio                : socketio       - v6.7.0
                system.adapter.sonoff                  : sonoff         - v3.0.3
                system.adapter.terminal                : terminal       - v0.2.2
                system.adapter.tr-064                  : tr-064         - v4.2.18
                system.adapter.vis                     : vis            - v1.5.6
                system.adapter.vw-connect              : vw-connect     - v0.0.67
                system.adapter.web                     : web            - v6.2.5
                system.adapter.withings                : withings       - v0.0.13
                system.adapter.ws                      : ws             - v2.6.1
                system.adapter.yahka                   : yahka          - v1.0.3
                pi@raspberrypi:/opt/iobroker $ iob fix
                library: loaded
                OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
                OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Done.
                Autostart enabled!
                  @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                  Soll es ja auch. Muss da ja aufräumen.
                  iob stop
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  Homoran S 2 Replies Last reply Reply Quote 0
                    @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                    iob stop
                    iob fix
                    iob update
                    iob upgrade all -y
                    iob upgrade self
                    @stoffel67
                    bitte einzeln aufrufen!
                      pi@raspberrypi:/opt/iobroker $ iob stop
                      iob fix
                      iob update
                      iob upgrade all -y
                      iob upgrade self
                      library: loaded
                      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Done.
                      Autostart enabled!
                      NPM version: 10.8.1
                      npm error code 7
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.8.1
                      npm error errno -39
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                      sollte ich das ganze evtl. einfach neu aufsetzen…
                      es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                      der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                        @stoffel67
                        Du sollst die Befehle einzeln, zeilenweise eingeben.
                          ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                          vielen Dank für deine Hilfe!!!!super
                            so ich versuch es nochmal
                            Zeilen einzeln... und es kommt das:
                            pi@raspberrypi:~ $ iob fix
                            library: loaded
                            Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                            Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                            Done.
                            Autostart enabled!
                            pi@raspberrypi:~ $
                            pi@raspberrypi:~ $ iob update
                            pi@raspberrypi:~ $ iob upgrade all -y
                            NPM version: 10.8.1
                            npm error code 7
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                            pi@raspberrypi:~ $ iob upgrade self
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 10.8.1
                            npm error errno -39
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                              @stoffel67
                              Schmeiß den radar2-Adapter mal raus.
                              Dann nochmal wie zuvor.
                                das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                                Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                  @stoffel67
                                  Ja natürlich den Adapter.
                                  • mcm1957
                                    mcm1957 @stoffel67 last edited by
                                    @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                    Instanz löschen:
                                    löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                                    Adapter löschen:
                                    Löscht den Adaptercode und seine Dependencies
                                    Löscht auch alle Instanzen.
                                      stoffel67 @mcm1957 last edited by
                                      @mcm1957
                                      es ist seltsam, ichbekomm den Adapter nicht weg....
                                      $ iobroker del radar2 --debug
                                      Delete adapter "radar2"
                                      host.raspberrypi Counted 1 meta of radar2
                                      host.raspberrypi Counted 1 adapter for radar2
                                      host.raspberrypi Counted 1 states (io.radar2.*) from states
                                      host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
                                      host.raspberrypi file radar2.admin deleted
                                      host.raspberrypi object radar2 deleted
                                      host.raspberrypi object radar2.admin deleted
                                      host.raspberrypi Deleting 2 object(s).
                                      host.raspberrypi Deleting 2 state(s).
                                      Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
                                      Process exited with code 0
                                        @stoffel67
                                        iob fix
                                        iob list adapters
                                          stoffel67 @Thomas Braun last edited by stoffel67
                                          auf ein neues...
                                          library: loaded
                                          Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
                                          Done.
                                          Autostart enabled!
                                            @stoffel67
                                            Also ist sowohl ble wie auch radar2 nun weg.
                                            iob update
                                            iog upgrade all -y
                                            iob stop
                                            iob upgrade self
                                            iob start
                                            4389
