    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      stoffel67 @Thomas Braun last edited by
      es wird immer schlimmer
      aspberrypi:/opt/iobroker $ iob stop
      iob fix
      iob update
      iob upgrade all -y
      iob upgrade self
      library: loaded
      Library version=2024-05-24
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13,2 MB]
      Es wurden 13,3 MB in 15 s geholt (855 kB/s).
      Paketlisten werden gelesen… Fertig
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "enet"         : 1.0.1    , installed 1.0.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
      Update radar2 from @2.1.0 to @2.2.0
      NPM version: 10.8.1
      Installing iobroker.radar2@2.2.0... (System call)
      npm error code 7
      npm error path /opt/iobroker/node_modules/@abandonware/noble
      npm error command failed
      npm error command sh -c node-gyp-build
      npm error gyp ERR! UNCAUGHT EXCEPTION
      npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'
      npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)
      npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
      npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)
      npm error gyp ERR! System Linux 6.1.21-v7+
      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      npm error gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/noble
      npm error gyp ERR! node -v v20.16.0
      npm error gyp ERR! node-gyp -v v7.1.2
      npm error gyp ERR! Node-gyp failed to build your package.
      npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_39_25_194Z-debug-0.log
      host.raspberrypi Cannot install iobroker.radar2@2.2.0: 7
      Update js-controller from @5.0.12 to @6.0.9
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      Installing iobroker.js-controller@6.0.9... (System call)
      Try to solve ENOTEMPTY error automatically
      Could not handle ENOTEMPTY, because no deletable files were found
      npm error code ENOTEMPTY
      npm error syscall rename
      npm error path /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
      npm error dest /opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo
      npm error errno -39
      npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket' -> '/opt/iobroker/node_modules/@abandonware/.bluetooth-hci-socket-0H6suKAo'
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_40_47_269Z-debug-0.log
      host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
        Thomas Braun Most Active @stoffel67 last edited by Thomas Braun
        @stoffel67
        iob delete ble
        iob fix
          pi@raspberrypi:/opt/iobroker $ iob delete  ble
          Delete adapter "ble"
          host.raspberrypi Counted 1 instances of ble
          host.raspberrypi Counted 1 meta of ble
          host.raspberrypi Counted 1 adapter for ble
          host.raspberrypi Counted 2 channels of ble
          host.raspberrypi Counted 3 states of ble
          host.raspberrypi Counted 14 states of system.adapter.ble
          host.raspberrypi Counted 1 states (system.adapter.ble.*) from states
          host.raspberrypi file ble.admin deleted
          host.raspberrypi object ble deleted
          host.raspberrypi object ble.admin deleted
          host.raspberrypi Deleting 22 object(s).
          host.raspberrypi Deleting 1 state(s).
          Error deleting adapter ble from disk: host.raspberrypi: Cannot uninstall iobroker.ble: 217
          You might have to delete it yourself!
            @stoffel67
            iob list adapters
            iob fix
              der fix läuft eigentlich immer durch
              pi@raspberrypi:/opt/iobroker $ iob list adapters
              iob fix
              system.adapter.admin                   : admin          - v7.0.22
              system.adapter.backitup                : backitup       - v2.11.0
              system.adapter.discovery               : discovery      - v4.5.0
              system.adapter.ds18b20                 : ds18b20        - v2.0.5
              system.adapter.enet                    : enet           - v1.0.1
              system.adapter.info                    : info           - v1.9.26
              system.adapter.javascript              : javascript     - v8.7.6
              system.adapter.linkeddevices           : linkeddevices  - v1.5.5
              system.adapter.modbus                  : modbus         - v6.1.0
              system.adapter.node-red                : node-red       - v5.2.1
              system.adapter.palazzetti              : palazzetti     - v0.0.6
              system.adapter.proxy                   : proxy          - v1.3.2
              system.adapter.radar2                  : radar2         - v2.1.0
              system.adapter.rpi2                    : rpi2           - v1.3.2
              system.adapter.shelly                  : shelly         - v7.0.0
              system.adapter.simple-api              : simple-api     - v2.8.0
              system.adapter.slideshow               : slideshow      - v0.1.4
              system.adapter.smartmeter              : smartmeter     - v3.4.0
              system.adapter.socketio                : socketio       - v6.7.0
              system.adapter.sonoff                  : sonoff         - v3.0.3
              system.adapter.terminal                : terminal       - v0.2.2
              system.adapter.tr-064                  : tr-064         - v4.2.18
              system.adapter.vis                     : vis            - v1.5.6
              system.adapter.vw-connect              : vw-connect     - v0.0.67
              system.adapter.web                     : web            - v6.2.5
              system.adapter.withings                : withings       - v0.0.13
              system.adapter.ws                      : ws             - v2.6.1
              system.adapter.yahka                   : yahka          - v1.0.3
              pi@raspberrypi:/opt/iobroker $ iob fix
              library: loaded
              OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Done.
              Autostart enabled!
                @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                Soll es ja auch. Muss da ja aufräumen.
                iob stop
                iob fix
                iob update
                iob upgrade all -y
                iob upgrade self
                Homoran S 2 Replies Last reply Reply Quote 0
                  @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                  iob stop
                  iob fix
                  iob update
                  iob upgrade all -y
                  iob upgrade self
                  @stoffel67
                  bitte einzeln aufrufen!
                    pi@raspberrypi:/opt/iobroker $ iob stop
                    iob fix
                    iob update
                    iob upgrade all -y
                    iob upgrade self
                    library: loaded
                    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Done.
                    Autostart enabled!
                    NPM version: 10.8.1
                    npm error code 7
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_07_10_998Z-debug-0.log
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.8.1
                    npm error errno -39
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T19_08_31_744Z-debug-0.log
                    sollte ich das ganze evtl. einfach neu aufsetzen…
                    es ist wohl „nur“ meine Testumgebung, aber wenn da schon Probleme bekomme, trau ich mich nicht an meine Produktivumgebung, die muss laufen sonst gibts hier zuhause Ärger,
                    der Auslöser war eigentlich ein Anwender meines Adapters, der upgegradet hat und darauf Problem bekam…
                      @stoffel67
                      Du sollst die Befehle einzeln, zeilenweise eingeben.
                        ich muss hier unterbrechen… sonst bekomm ich Ärger, werden morgen weiter machen,
                        vielen Dank für deine Hilfe!!!!super
                          so ich versuch es nochmal
                          Zeilen einzeln... und es kommt das:
                          pi@raspberrypi:~ $ iob fix
                          library: loaded
                          Holen:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                          Es wurden 15,0 kB in 2 s geholt (7.092 B/s).
                          Done.
                          Autostart enabled!
                          pi@raspberrypi:~ $
                          pi@raspberrypi:~ $ iob update
                          pi@raspberrypi:~ $ iob upgrade all -y
                          NPM version: 10.8.1
                          npm error code 7
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_13_06_761Z-debug-0.log
                          pi@raspberrypi:~ $ iob upgrade self
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 10.8.1
                          npm error errno -39
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-03T05_14_51_457Z-debug-0.log
                            @stoffel67
                            Schmeiß den radar2-Adapter mal raus.
                            Dann nochmal wie zuvor.
                              das hab ich gemacht… Instanz gelöscht, muss ich noch den Adapter (unter Adapter) löschen?
                              Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                @stoffel67
                                Ja natürlich den Adapter.
                                • mcm1957
                                  mcm1957 @stoffel67 last edited by
                                  @stoffel67 said in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                  Instanz löschen:
                                  löscht im wesentlichen die Konfigurationsdaten und States einer Instanz. Der Code des Adapetrs wird dabei nicht gelöscht.
                                  Adapter löschen:
                                  Löscht den Adaptercode und seine Dependencies
                                  Löscht auch alle Instanzen.
                                    stoffel67 @mcm1957 last edited by
                                    @mcm1957
                                    es ist seltsam, ichbekomm den Adapter nicht weg....
                                    $ iobroker del radar2 --debug
                                    Delete adapter "radar2"
                                    host.raspberrypi Counted 1 meta of radar2
                                    host.raspberrypi Counted 1 adapter for radar2
                                    host.raspberrypi Counted 1 states (io.radar2.*) from states
                                    host.raspberrypi Counted 1 states (system.adapter.radar2.*) from states
                                    host.raspberrypi file radar2.admin deleted
                                    host.raspberrypi object radar2 deleted
                                    host.raspberrypi object radar2.admin deleted
                                    host.raspberrypi Deleting 2 object(s).
                                    host.raspberrypi Deleting 2 state(s).
                                    Error deleting adapter radar2 from disk: host.raspberrypi: Cannot uninstall iobroker.radar2: 217
                                    Process exited with code 0
                                      @stoffel67
                                      iob fix
                                      iob list adapters
                                        stoffel67 @Thomas Braun last edited by stoffel67
                                        auf ein neues...
                                        library: loaded
                                        Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
                                        Done.
                                        Autostart enabled!
                                          @stoffel67
                                          Also ist sowohl ble wie auch radar2 nun weg.
                                          iob update
                                          iog upgrade all -y
                                          iob stop
                                          iob upgrade self
                                          iob start
                                            scheinbar nicht, obwohl ich die Adapter gelöscht habe
                                            in "iob list adpaters" sind sie weg
                                            bei "iob update" tauchen sie wieder auf
                                            pi@raspberrypi:/opt/iobroker $ iob update
                                            und nochmal von vorne...
                                            pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
                                            Update modbus from @6.1.0 to @6.2.3
                                            NPM version: 10.8.1
                                            Installing iobroker.modbus@6.2.3... (System call)
                                            changed 1 package in 35s
                                            153 packages are looking for funding
                                              run `npm fund` for details
                                            Update "system.adapter.modbus.0"
                                            upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                                            upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                            upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                                            upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                                            upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                            upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                            upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                            upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                                            upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                                            upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                                            pi@raspberrypi:/opt/iobroker $ iob upgrade self
                                            Stopped Objects DB
                                            Stopped States DB
                                            NPM version: 10.8.1
                                            added 7 packages, removed 45 packages, and changed 26 packages in 2m
                                            pi@raspberrypi:/opt/iobroker $ iob start
                                            ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
                                            javascript.0
                                            2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
                                            javascript.0
                                            2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
                                            javascript.0
                                            2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
                                            javascript.0
                                            2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
                                            javascript.0
                                            2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
                                            javascript.0
                                            2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
                                            javascript.0
                                            2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
                                            javascript.0
                                            2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
                                            javascript.0
                                            2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
                                            javascript.0
                                            2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                            javascript.0
                                            2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
                                            javascript.0
                                            2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                            javascript.0
                                            2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
                                            javascript.0
                                            2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                                            rpi2.0
                                            2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                                            4399
