    4. js-controller 6.0.x jetzt für alle User im STABLE!
      Chris777 last edited by
      host.iOBrocker
      	2024-08-02 18:55:41.112	error	iobroker host.iOBrocker Cannot install iobroker.backitup@latest: 1
      host.iOBrocker
      	2024-08-02 18:55:41.111	error	iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Not compatible with your version of node/npm: minimatch@10.0.1npm error notsup Required: {"node":"20 || >=22"}npm error notsup Actual: {"npm":"10.8.2","node":"v18.20.4"}npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-08-02T16_55_34_985Z-debug-0.log
      Habe Version
      Plattform: docker (official image - v9.1.2)
      RAM: 11.5 GB
      Node.js: v18.20.4(20.16.0)
      NPM: 10.8.2
      • XBiT
        XBiT last edited by
        Nach dem update auf den js-controller 6.0.9 bekomme ich folgende Fehler im log zu so fast jeden Adapter:
        host.IoBroker
        2024-08-02 20:33:23.911	info	Restart adapter system.adapter.vis-inventwo.0 because enabled
        host.IoBroker
        2024-08-02 20:33:23.910	error	instance system.adapter.vis-inventwo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: Node.js v18.20.4
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14:33)
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: ^
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: class visInventwo extends utils.Adapter {
        host.IoBroker
        2024-08-02 20:33:23.910	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vis-inventwo/main.js:14
        host.IoBroker
        2024-08-02 20:33:23.725	info	instance system.adapter.upnp.0 in version "1.0.21" started with pid 8475
        host.IoBroker
        2024-08-02 20:33:23.709	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
        host.IoBroker
        2024-08-02 20:33:23.709	error	instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: Node.js v18.20.4
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31:36)
        host.IoBroker
        2024-08-02 20:33:23.709	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
        host.IoBroker
        2024-08-02 20:33:23.708	error	Caught by controller[0]: ^
        host.IoBroker
        2024-08-02 20:33:23.708	error	Caught by controller[0]: class Sourceanalytix extends utils.Adapter {
        host.IoBroker
        2024-08-02 20:33:23.706	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:31
        host.IoBroker
        2024-08-02 20:33:23.018	info	instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 8468
        host.IoBroker
        2024-08-02 20:33:22.942	info	instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 8461
        host.IoBroker
        2024-08-02 20:33:22.149	info	Restart adapter system.adapter.upnp.0 because enabled
        iob diag sagt:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: IoBroker
               Icon name: computer-vm
                 Chassis: vm 🖴
          Virtualization: kvm
                  Kernel: Linux 6.1.0-23-amd64
            Architecture: x86-64
         Hardware Vendor: QEMU
          Hardware Model: Standard PC _i440FX + PIIX, 1996_
        Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
        model name      : Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Fri 2024-08-02 20:39:02 CEST
                   Universal time: Fri 2024-08-02 18:39:02 UTC
                         RTC time: Fri 2024-08-02 18:39:02
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        stephan
        HOME=/home/stephan
        GROUPS=stephan cdrom floppy sudo audio dip video plugdev netdev iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             16G        4.8G         11G        524K        1.0G         11G
        Swap:           6.4G          0B        6.4G
        Total:           23G        4.8G         17G
        Active iob-Instances:   45
                15992 M total memory
                 4618 M used memory
                  478 M active memory
                 4274 M inactive memory
                10743 M free memory
                  161 M buffer memory
                  799 M swap cache
                 6140 M total swap
                    0 M used swap
                 6140 M free swap
        top - 20:39:02 up 23 min,  3 users,  load average: 3.61, 2.84, 2.11
        Tasks: 161 total,   4 running, 157 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15992.7 total,  10742.4 free,   4619.5 used,    960.9 buff/cache
        MiB Swap:   6141.0 total,   6141.0 free,      0.0 used.  11373.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  7.8G     0  7.8G   0% /dev
        tmpfs          tmpfs     1.6G  520K  1.6G   1% /run
        /dev/sda1      ext4       34G   13G   19G  42% /
        tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
        [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Aug  2 20:15:45 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE      FSTYPE      OPTIONS
        /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12580
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=8169164k,nr_inodes=2042291,mode=755,inode64
        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
        | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
        `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=1637652k,mode=755,inode64
          |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
          |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=1637648k,nr_inodes=409412,mode=700,uid=1000,gid=1000,inode64
          `-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
        /var:
        1.1G    /var/
        468M    /var/log
        450M    /var/log/journal/81661bec9382417183506b6886357c63
        409M    /var/cache
        Archived and active journals take up 41.3M in the file system.
        /opt/iobroker/backups:
        879M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.4G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        48M     /opt/iobroker/iobroker-data/objects.jsonl
        27M     /opt/iobroker/iobroker-data/states.jsonl
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 1001
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     11
        +-- iobroker.deyeidc@0.0.14 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#1e9919216a6173e4089dff844edb4abb35eb2366)
        +-- iobroker.energiefluss-erweitert@0.4.1 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#f724bf54ab9a69bc6d4533b59f560462e1bb2993)
        +-- iobroker.fullybrowser@3.0.12 (git+ssh://git@github.com/arteck/ioBroker.fullybrowser.git#e962587ed6e25b749b28c8537318c39f2c0deefe)
        +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#91ce6d3d470cba4011b7861103c4bfffa32dffbe)
        +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
        +-- iobroker.mercedesme@0.1.6 (git+ssh://git@github.com/TA2k/iobroker.mercedesme.git#b58e9673d5c28e358830fd45d231dd97ab425219)
        +-- iobroker.omada@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#8fb0331b97155bd4fae67c940d98c57b2ea34be2)
        +-- iobroker.sayit@3.0.5 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#581f2fb99f33c2b8b0a628d91be14967788ac120)
        +-- iobroker.sourceanalytix@0.4.12-2 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#c9b9e18e1694e45ce88e21e868e38e565aad6910)
        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.zendure-solarflow@1.7.0 (git+ssh://git@github.com/nograx/ioBroker.zendure-solarflow.git#f2c56c734ba9176aa75b36391c868a3c0fe33a60)
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : IoBroker                                 -  enabled
        + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : IoBroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : IoBroker                                 -  enabled
        + system.adapter.deyeidc.0                : deyeidc               : IoBroker                                 -  enabled, port: 8899
        + system.adapter.discovery.0              : discovery             : IoBroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoBroker                                 -  enabled
        + system.adapter.enigma2.0                : enigma2               : IoBroker                                 -  enabled
        + system.adapter.enigma2.1                : enigma2               : IoBroker                                 -  enabled
        + system.adapter.enigma2.2                : enigma2               : IoBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : IoBroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : IoBroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : IoBroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : IoBroker                                 -  enabled
          system.adapter.google-sharedlocations.0 : google-sharedlocations: IoBroker                                 -  enabled
        + system.adapter.govee-app.0              : govee-app             : IoBroker                                 -  enabled
        + system.adapter.govee-local.0            : govee-local           : IoBroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : IoBroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : IoBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : IoBroker                                 -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : IoBroker                                 - disabled
        + system.adapter.info.0                   : info                  : IoBroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
          system.adapter.logparser.0              : logparser             : IoBroker                                 - disabled
        + system.adapter.lovelace.0               : lovelace              : IoBroker                                 -  enabled, port: 8091, bind: 192.168.1.251, run as: admin
          system.adapter.meater.0                 : meater                : IoBroker                                 - disabled
        + system.adapter.mercedesme.0             : mercedesme            : IoBroker                                 -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 -  enabled, port: 54321
        + system.adapter.omada.0                  : omada                 : IoBroker                                 -  enabled, port: 8043
        + system.adapter.onvif.0                  : onvif                 : IoBroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        + system.adapter.ping.0                   : ping                  : IoBroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
          system.adapter.roborock.0               : roborock              : IoBroker                                 - disabled
        + system.adapter.sayit.0                  : sayit                 : IoBroker                                 -  enabled
        + system.adapter.shelly.1                 : shelly                : IoBroker                                 -  enabled, port: 2023, bind: 0.0.0.0
          system.adapter.sia.0                    : sia                   : IoBroker                                 -  enabled, port: 50001, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : IoBroker                                 -  enabled
        + system.adapter.sony-bravia.0            : sony-bravia           : IoBroker                                 -  enabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : IoBroker                                 -  enabled
        + system.adapter.sql.0                    : sql                   : IoBroker                                 -  enabled, port: 3306
        + system.adapter.synochat.0               : synochat              : IoBroker                                 -  enabled
        + system.adapter.synology.0               : synology              : IoBroker                                 -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : IoBroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.2               : telegram              : IoBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 -  enabled
          system.adapter.upnp.0                   : upnp                  : IoBroker                                 -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : IoBroker                                 -  enabled
          system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IoBroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : IoBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IoBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : IoBroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : IoBroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : IoBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : IoBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : IoBroker                                 -  enabled
        + system.adapter.web.0                    : web                   : IoBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zendure-solarflow.0      : zendure-solarflow     : IoBroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        │ (index) │   name   │                           url                           │ auto upgrade │
        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "device-watcher": 2.12.1  , installed 2.12.1
        Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
        Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
        Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
        Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "govee-local"  : 0.2.6    , installed 0.2.6
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
        Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
        Adapter    "meater"       : 1.1.1    , installed 1.1.1
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "roborock"     : 0.6.4    , installed 0.6.4
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "sia"          : 1.0.4    , installed 1.0.4
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "synochat"     : 1.3.1    , installed 1.3.1
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.3.2    , installed 3.3.2
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "zendure-solarflow": 1.6.7, installed 1.7.0
        Objects and States
        Objects:        39665
        States:         34253
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:2023            0.0.0.0:*               LISTEN      1001       50826      6428/io.shelly.1
        tcp        0      0 192.168.1.251:42001     0.0.0.0:*               LISTEN      1001       49127      6181/io.hm-rpc.0
        tcp        0      0 192.168.1.251:42010     0.0.0.0:*               LISTEN      1001       49781      6210/io.hm-rpc.1
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14944      470/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          580        1/init
        tcp        0      0 192.168.1.251:8701      0.0.0.0:*               LISTEN      1001       49844      6240/io.hm-rpc.3
        tcp        0      0 192.168.1.251:49292     0.0.0.0:*               LISTEN      1001       49815      6225/io.hm-rpc.2
        tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          841        454/node
        tcp        0      0 192.168.1.251:8091      0.0.0.0:*               LISTEN      1001       52164      6930/io.lovelace.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50203      5950/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48035      5950/iobroker.js-co
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14946      470/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14335      1/init
        tcp6       0      0 :::3500                 :::*                    LISTEN      0          843        454/node
        tcp6       0      0 :::3501                 :::*                    LISTEN      1001       49964      6328/io.sonos.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       56808      7478/io.fullybrowse
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54993      7174/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       50231      5968/io.admin.0
        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       55243      7295/io.onvif.0
        udp        0      0 192.168.1.251:5353      0.0.0.0:*                           1001       50102      6375/io.tr-064.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          581        1/init
        udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       58098      7557/io.govee-local
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       52279      6270/io.mihome-vacu
        udp6       0      0 :::111                  :::*                                0          12022      1/init
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
        2024-08-02 20:39:33.951  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
        2024-08-02 20:39:33.951  - error: host.IoBroker instance system.adapter.sourceanalytix.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-08-02 20:39:33.951  - info: host.IoBroker Restart adapter system.adapter.sourceanalytix.0 because enabled
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.upnp/main.js:88
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     adapter = new utils.Adapter(options);
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:               ^
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: TypeError: utils.Adapter is not a constructor
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.upnp/main.js:88:15)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.upnp/main.js:1931:5)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49
        2024-08-02 20:39:34.096  - error: host.IoBroker Caught by controller[0]: Node.js v18.20.4
        2024-08-02 20:39:34.096  - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-08-02 20:39:34.096  - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
        2024-08-02 20:39:35.857  - info: host.IoBroker instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: DrozmotiX/ioBroker.sourceanalytix#c9b9e18e1694e45ce88e21e868e38e565aad6910) started with pid 12932
        2024-08-02 20:39:35.916  - info: host.IoBroker instance system.adapter.upnp.0 in version "1.0.21" started with pid 12939
        kann mir da wer helfen?
        mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @XBiT last edited by mcm1957
          @xbit said in js-controller 6.0.x jetzt für alle User im STABLE!:
          instance system.adapter.sourceanalytix.0 in version "0.4.12-2" (non-npm: ...
          Dieser GitHub Stand wird wohl veraltet sein. Von Github Installationen wir generell abgeraten. Kontaktiere den Dev bzw. installiere eine neuere Version.
          Hast du nur 2 Adapter?
          Ich seh nur sourceanaytix und vis-inventwo. Wobei vis-inventwo ein veraltetes adapter-core benutzt; dieses Problem sollte aber seit Wochen behoben sein. Bei Github Installationen kann es divereste Gründe geben dass diese nicht funktionieren - hier bitte mit dem Dev Kontaktaufnehmen wenn er die Github Installation empfohlen hat oder selbst suchen ...
            Thomas Braun Most Active @XBiT last edited by
            @xbit
            iob nodejs-update 20
            XBiT 1 Reply Last reply Reply Quote 0
            • XBiT
              XBiT @Thomas Braun last edited by XBiT
              Danke mache ich gerade..
              @mcm1957
              die Adapter die es betrifft sind: (fast alle war sehr übertrieben sorry)
              google-sharelocation
              Sia09
              UPNP
              Sourceanalytix
              bei den oberen 2 gibt es kein update werde ich mal nachfragen... Sourceanalytix mache ich gleich ein update
              Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @XBiT last edited by Thomas Braun
                @xbit
                Das solltest du auf ein Maß zurückstutzen, das du auch noch überblicken kannst:
                • XBiT
                  @thomas-braun & @mcm1957
                  Vielen Dank es läuft soweit wieder alles.
                  Die anderen Adapter (UPNP,SIA09 etc.) gehen nun auch wieder warum auch immer ist mir leider erst nach dem update von Sourceanalytix aufgefallen habe aber nur dieses update gemacht und das nodejs update auf V20
                    @xbit
                    Du solltest das Vehikel dennoch möglichst konsistent halten und sowenig github-Zeuch wie möglich verwenden.
                    • mcm1957
                      Nehme an du meinst google-sharedlocation
                      Ich kann diesen Adapter nicht in den ioBroker rpositories finden. Er scheint auch schon lange nicht mehr gewartet worden zu sein. Prinzipiell ist es immer ein Risiko Adapter zu verwenden die nicht im Repository gelistet sind da diese weder den minimalen Review durchlaufen haben noch bei div. Checks wie z.B. einem Update des js-controllers beachtet werden können.
                      Sia09
                      Den Adapter find ich nicht. meinst du https://github.com/schmupu/ioBroker.sia
                      Der scheint eher dahin zu dämmern. Erstell bitte ggF im Adapterverzeichnis ein Issue und mention mich. Der Adaptercode ist dort total veraltet. Eine Codeanpassung könnte hier notwendig sein.
                      UPNP
                      Hier rate ich dir den dev zu kontaktieren bzw. ein Issue beim Adapter anzulegen. Da wurden erst letzte Woche Anpassungen vorgenommen die anscheinend noch nicht auf npm verfügbar sind. Repo: (https://github.com/Jey-Cee/ioBroker.upnp)
                      Sourceanalytix
                      Hier aktualisisere mal auf die aktuelle LATEST version. Falls diese nicht funktioniert erstell ein Issue im Adapter Repo.
                      • mcm1957
                        OK, dann feier mal schön 🙂
                        An sich sollte der js-controller implizit versuchen veraltete Adapter zu aktualisiseren. Scheinbar hat das bei deinem Upgrade nicht gleich gezogen.
                        Trotzdem sei dir bewußt dass wenn du Aapter verwendest die nicht im repository gelistet sind du ein erhöhtes Risiko hast, dass diese ausfallen bzw. dass niemand sich der Sache annehmen kann / wird.
                        • XBiT
                          XBiT @mcm1957 last edited by
                          @mcm1957
                          der google-sharedlocations Adapter wurde zuletzt von @Garfonso betreut welcher auch die Lovelace UI betreut warum die nicht ins rpositorie kommen oder sind kann ich nicht sagen bin ja nur Anwender 🙂
                          der SIA Adapter ist wirklich schon 5 Jahre alt versuche mal ein Issu auf Git zu machen aber was soll ich da schreiben er läuft ja jetzt wieder?
                          Sourceanalytix von @Dutchman betreut aber soll ja komplett neu gemacht werden so meine letzte Info...
                            lamo1966 last edited by lamo1966
                            ich hab gerade den JS Controller von5.019 auf 6.09 upgedatet.
                            Zufällig stell ich gerade fest, dass in meinen Modbus Objekten hinten das Zahnrad nicht mehr aktiv ist. (
                            Ganz rechts)
                            b4fe00a5-5428-498a-a78c-a669165c0dff-image.png Sorry, kann es nicht besser beschreiben
                            Beispiel
                            Ich erzeuge seit Tagen ein EChart mit den Spannungs-Werten der PV-Strings. Dazu hab ich die Werte in die Histroy geschrieben.
                            Unter dem Chart sind die History-Einträge schön zu sehen, die es jetzt nicht mehr gibt
                            Ich hoffe dass es zufällig ein anderer Fehler ist, aber ich hab nichts anderes gemacht. Nein stimmt nicht, die Admin Instanz hab ich auch noch upgedatet.
                              crunchip Forum Testing Most Active @lamo1966 last edited by
                              @lamo1966 werden die Datenpunkte gelistet, wenn du history auswählst
                              • fAz3rs adventures
                                fAz3rs adventures @foxriver76 last edited by
                                @foxriver76
                                Servus,
                                Ich wollte meinen IoBroker wieder auf neuesten Stand bringen und scheitere aber an dem js-controller Update.
                                Node.js und NPM updaten klappt, ebenso wie alle Adapter Updates.
                                Liegt auch alles (aus meiner Sicht) korrekt ab
                                nodejs liegt in /usr/bin
                                node liegt in /usr/bin
                                npm liegt in /usr/bin
                                führe ich das Update über die iob Oberfläche in Hosts aus bekomme ich folgende Rückmeldung:
                                36 verbose stack     at callLimit (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:35:69)
                                537 verbose pkgid iobroker.js-controller@6.0.9
                                538 error code 1
                                539 error path /opt/iobroker/node_modules/iobroker.js-controller
                                540 error command failed
                                541 error command sh -c node iobroker.js setup first
                                542 error file:///opt/iobroker/node_modules/axios/lib/helpers/parseHeaders.js:1
                                542 error   },
                                542 error   ^
                                542 error
                                542 error SyntaxError: Unexpected token '}'
                                542 error     at ModuleLoader.moduleStrategy (node:internal/modules/esm/translators:169:18)
                                542 error     at callTranslator (node:internal/modules/esm/loader:272:14)
                                542 error     at ModuleLoader.moduleProvider (node:internal/modules/esm/loader:278:30)
                                542 error
                                542 error Node.js v20.16.0
                                543 silly unfinished npm timer reify 1722633029717
                                544 silly unfinished npm timer reify:build 1722633047822
                                545 silly unfinished npm timer build 1722633047827
                                546 silly unfinished npm timer build:deps 1722633047827
                                547 silly unfinished npm timer build:run:install 1722633049025
                                548 silly unfinished npm timer build:run:install:node_modules/iobroker.js-controller 1722633049025
                                549 verbose cwd /opt/iobroker
                                550 verbose os Linux 6.1.21-v8+
                                551 verbose node v20.16.0
                                552 verbose npm  v10.8.1
                                553 verbose exit 1
                                554 verbose code 1
                                Auch über
                                iobroker stop
                                iobroker update
                                iobroker fix bzw ( - curl -sLf https://iobroker.net/install.sh | bash -)
                                iobroker upgrade self
                                iobroker start
                                erfolglos
                                Dann habe ich es über npm install iobroker.js-controller@6.0.9 versucht mit folgendem Ergebnis
                                1236 error code EACCES
                                1237 error syscall open
                                1238 error path /home/pi/package.json
                                1239 error errno -13
                                1240 error Error: EACCES: permission denied, open '/home/pi/package.json'
                                1240 error     at async open (node:internal/fs/promises:639:25)
                                1240 error     at async writeFile (node:internal/fs/promises:1219:14)
                                1240 error     at async PackageJson.save (/usr/lib/node_modules/npm/node_modules/@npmcli/package-json/lib/index.js:255:14)
                                1240 error     at async [saveIdealTree] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1512:9)
                                1240 error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)
                                1240 error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
                                1240 error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
                                1240 error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
                                1240 error   errno: -13,
                                1240 error   code: 'EACCES',
                                1240 error   syscall: 'open',
                                1240 error   path: '/home/pi/package.json'
                                1240 error }
                                1241 error
                                1241 error The operation was rejected by your operating system.
                                1241 error It is likely you do not have the permissions to access this file as the current user
                                1241 error
                                1241 error If you believe this might be a permissions issue, please double-check the
                                1241 error permissions of the file and its containing directories, or try running
                                1241 error the command again as root/Administrator.
                                1242 silly unfinished npm timer reify 1722634042338
                                1243 silly unfinished npm timer reify:save 1722634104770
                                1244 verbose cwd /home/pi
                                1245 verbose os Linux 6.1.21-v8+
                                1246 verbose node v20.16.0
                                1247 verbose npm  v10.8.1
                                Das ist wohl ein anderer Pfad der entweder korrekt oder falsch ist (jaaa es ist nur gefährliches Halbwissen am start.. ich lerne beim tun)
                                Kann mir jemand für dumme sagen was mein Fehler ist?
                                Grüßle Timo
                                  Thomas Braun Most Active @fAz3rs adventures last edited by
                                  @faz3rs-adventures sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                  Du stehst für solche Aktionen via npm im falschen Verzeichnis.
                                  Versuch es erstmal so:
                                  iob update
                                  iob stop
                                  iob upgrade all -y
                                  iob upgrade self
                                  iob start
                                  fAz3rs adventures 1 Reply Last reply Reply Quote 0
                                  • fAz3rs adventures
                                    fAz3rs adventures @Thomas Braun last edited by
                                    Moinmoin
                                    danke schonmal für die Antwort
                                    nach dem
                                    iob upgrade all -y
                                    kommt All adapters are up to date
                                    beim
                                    iob upgrade self
                                    passiert folgendes
                                    Update js-controller from @5.0.19 to @6.0.9
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 10.8.1
                                    Installing iobroker.js-controller@6.0.9... (System call)
                                    es läuft jedoch nicht fertig durch
                                      @faz3rs-adventures
                                      Bitte immer vollständige Ein- wie Ausgabezeilen posten.
                                      Damit man sowas wie 'falsches Verzeichnis' auch sieht.
                                      Keine Screenshots!
                                      • fAz3rs adventures
                                        pi@raspberrypi:~ $ iob update
                                        Adapter    "acme"         : 0.1.2    , installed 0.1.2
                                        Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                        Adapter    "alexa-shoppinglist": 0.1.5, installed 0.1.5
                                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                        Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                        Adapter    "email"        : 1.3.1    , installed 1.3.1
                                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                        Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                                        Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                        Adapter    "iwg-vpn"      : 3.0.0    , installed 3.0.0
                                        Controller "js-controller": 6.0.9    , installed 5.0.19 [Updatable]
                                        Adapter    "material"     : 1.3.1    , installed 1.3.1
                                        Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
                                        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "mqtt-client"  : 2.0.0    , installed 2.0.0
                                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                        Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                                        Adapter    "residents"    : 0.1.1    , installed 0.1.1
                                        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                        Adapter    "welcome"      : 0.3.0    , installed 0.3.0
                                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                        Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                                        pi@raspberrypi:~ $ iob stop
                                        pi@raspberrypi:~ $ iob upgrade all -y
                                        pi@raspberrypi:~ $ iob upgrade self
                                        Stopped Objects DB
                                        Stopped States DB
                                        NPM version: 10.8.1
                                        pi@raspberrypi:~ $
                                        das steht in der console
                                          @faz3rs-adventures
                                          Sondern?
                                          • fAz3rs adventures
                                            Es passiert nichts weiter
                                            Es kommt eine neue eingabe Zeile in der ich Iobroker wieder starten könnte
                                            Thomas Braun E 2 Replies Last reply Reply Quote 0
                                            controller js-controller kiera stable
                                            47
                                            257
                                            63694
