    4. js-controller 6.0.x jetzt für alle User im STABLE!
      Snopy_16 last edited by
      Hallo
      Ich habe nach dem update ein Problem mit dem Adapter E-Charts. Er startet nicht mehr und bleibt auf Rot.
      iob fix brachte nichts.
      Im Log stehten diese Meldungen.
      Soll ich das ausführen? Wo liegt das Adapter- Directory?
      host.bookworm
      2024-08-03 11:06:16.984	info	Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.bookworm
      2024-08-03 11:06:16.983	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: Node.js v18.20.4
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: }
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      host.bookworm
      2024-08-03 11:06:16.983	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
      host.bookworm
      2024-08-03 11:06:16.982	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      host.bookworm
      2024-08-03 11:06:16.981	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
      host.bookworm
      2024-08-03 11:06:16.981	error	Caught by controller[0]: Require stack:
      host.bookworm
      2024-08-03 11:06:16.981	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
      host.bookworm
      2024-08-03 11:06:16.981	error	Caught by controller[0]: ^
      host.bookworm
      2024-08-03 11:06:16.981	error	Caught by controller[0]: throw err;
      host.bookworm
      2024-08-03 11:06:16.980	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
      foxriver76 Pedder007 2 Replies Last reply Reply Quote 0
      • foxriver76
        foxriver76 Developer @Snopy_16 last edited by
        @snopy_16 man sieht leider nicht welche Version von echarts. Ältere Versionen hatten wohl vergessen adapter-core explizit als Dep hinzuzufügen. Evtl. sollte man da mal die 1.8.4 als stable deklarieren, da dies in der 1.7.2 fehlt @mcm1957
        1.7.2: https://www.npmjs.com/package/iobroker.echarts/v/1.7.2?activeTab=code
        1.8.4: https://www.npmjs.com/package/iobroker.echarts/v/1.8.4?activeTab=code
        Pedder007 mcm1957 2 Replies Last reply Reply Quote 0
        • Pedder007
          Pedder007 @Snopy_16 last edited by Pedder007
          @snopy_16
          Moin, hier das gleiche Problem. Alles up-to-date, nach dem Neustart macht er drei Versuche den e-chart adapter zu 'reparieren' dann bricht er das ab (sieht aus wie bei @Snopy_16). Adapter bleibt rot. E-Charts an sich scheinen aber zu funktionieren (werden in VIS angezeigt), sowie auch der Editor (hab' mal schnell ne Kopie von einem Chart gemacht)
          npm install --production habe ich im entsprechenden Verzeichnis ausgeführt, hat aber auch nichts gebracht.
          Ansonsten danach fix, upgrade self mit Neustart bringt auch keine Änderung.
          @foxriver76 bei mir die 1.7.2, 1.8.4 wird nicht als stable angezeigt
            @foxriver76
            Ja, die Version v1.7.2 habe ich installiert
            @Pedder007
            Genau das selbe Verhalten
            • Pedder007
              Pedder007 @foxriver76 last edited by Pedder007
              @foxriver76 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
              Habe das schnell mal getestet:
              Beta: 1.8.0 Installation zeigt Fehler und es bleibt bei 1.7.2
              Version 1.8.4 (manuell angegeben): Installation läuft durch, Adapter wird grün, allerdings zeigt kein einziges Chart vom 'Diagramm Typ'=BAR noch irgendwelche Werte mehr an. Typ Line geht. Bei mir schlecht, da 90% bei mir Bar-Charts sind 😉
              • foxriver76
                foxriver76 Developer @Pedder007 last edited by
                @pedder007 Hm ja Mist hat beanker auch in diesem Issue geschrieben https://github.com/ioBroker/ioBroker.echarts/issues/657
                GermanBluefox created this issue in ioBroker/ioBroker.echarts
                closed Update stable version in repo from 1.7.2 to 1.8.4 #657
                • mcm1957
                  mcm1957 @foxriver76 last edited by
                  @foxriver76 said in js-controller 6.0.x jetzt für alle User im STABLE!:
                  Kann ich im Prinzip machen.
                  Da es aber eine Fehlermeldung gab (https://github.com/ioBroker/ioBroker.echarts/issues/657#issuecomment-2225982405) bzw. ein referenziertes Issue (https://github.com/ioBroker/ioBroker.echarts/issues/630) hab ich hier ohne Reaktion des Devs nicht pe Timeout ins stable gepushed.
                  Kannst du bitte entscheiden bzw. mit @Bluefox(?) abstimmen ob echarts 1,8,4 ins stable soll?
                  Bzw. was mit den Issues ist?
                  sigi2345 created this issue in ioBroker/ioBroker.echarts
                  closed Update Fehler 1.8.1 #630
                  foxriver76 1 Reply Last reply Reply Quote 1
                  • foxriver76
                    foxriver76 Developer @mcm1957 last edited by
                    @mcm1957 Habe BF eben gepingt, sollte er vorher fixen, bringt ja sonst nix.
                    Pedder007 1 Reply Last reply Reply Quote 1
                    • Pedder007
                      @foxriver76 bin erstmal wieder auf 1.7.2 und wird wieder alles angezeigt (bei rotem Adapter)
                      Muss mich für heute leider ausklinken ...
                      Viel Erfolg 🙂
                      PS.Wollt ihr mal lachen?
                      NAch dem Downgrade wird der Adapter auch mit der 1.7.2 grün 🤣
                      mcm1957 S Dr. Bakterius 3 Replies Last reply Reply Quote 0
                        Jack01 @foxriver76 last edited by
                        @foxriver76 Also ich habe auch die Version V1.7.2 installiert und es hat alles problemlos funktioniert.
                        • mcm1957
                          mcm1957 @Pedder007 last edited by
                          @pedder007 said in js-controller 6.0.x jetzt für alle User im STABLE!:
                          Eine mögliche Erklärung:
                          Ja, die neuere Version installiert ja adapter-core. Und da dieser auch von anderen Adaptern benutzt wird, deinstalliert diese der Downgrade nicht.
                            Snopy_16 @Pedder007 last edited by
                            @pedder007
                            Bei mir bleibt der adapter auch nach dem Prozedere von up/downgrade auf rot.
                            F mcm1957 2 Replies Last reply Reply Quote 0
                              fellpower @Snopy_16 last edited by
                              Ich habe leider seit dem Controller Update auch Probleme. Mein PI Script funktioniert nicht mehr - und zeigt komisches Verhalten.
                              Siehe hier: https://forum.iobroker.net/topic/46948/leistungssteuerung-pv-wechselrichter-0-einspeisung/116?_=1722669581681
                              • isi07
                                isi07 @foxriver76 last edited by
                                @foxriver76 @oFbEQnpoLKKl6mbY5e13
                                Ich habe ein ähnliches Problem. Nach dem Upgrade auf den neuen js-controller bekomme ich Fehlermeldungen vom Adapter jarvis, dass es Probleme mit einigen alias DPs gibt, die eine read Konvertierung haben. Diese Fehlermeldungen kommen bei jedem Neustart des Adapters.
                                Was mich wundert ist, dass eigentlich gar nicht alle dieser DP in jarvis kofiguriert/genutzt werden.
                                jarvis.0	2024-08-03 12:25:04.342	error	source in "alias.0.awtrix.electricity_meter_power_export" does not exist for "read" function: "val/1000"
                                jarvis.0	2024-08-03 12:25:04.342	error	source in "alias.0.energy.electricity.meter.PowerIn" does not exist for "read" function: "val < 0 ? -1 * val : 0"
                                jarvis.0	2024-08-03 12:25:04.342	error	source in "alias.0.energy.electricity.meter.PowerOut" does not exist for "read" function: "val > 0 ? val : 0"
                                jarvis.0	2024-08-03 12:25:04.341	error	source in "alias.0.awtrix.electricity_meter_power_pvgeneration" does not exist for "read" function: "val/1000"
                                jarvis.0	2024-08-03 12:24:49.292	error	source in "alias.0.awtrix.electricity_meter_power_export" does not exist for "read" function: "val/1000"
                                jarvis.0	2024-08-03 12:24:49.292	error	source in "alias.0.energy.electricity.meter.PowerIn" does not exist for "read" function: "val < 0 ? -1 * val : 0"
                                jarvis.0	2024-08-03 12:24:49.292	error	source in "alias.0.energy.electricity.meter.PowerOut" does not exist for "read" function: "val > 0 ? val : 0"
                                jarvis.0	2024-08-03 12:24:49.290	error	source in "alias.0.awtrix.electricity_meter_power_pvgeneration" does not exist for "read" function: "val/1000"
                                jarvis.0	2024-08-03 12:24:35.772	info	Found Backups for devices.
                                jarvis.0	2024-08-03 12:24:35.728	info	Found Backups for widgets.
                                jarvis.0	2024-08-03 12:24:35.665	info	Found Backups for settings.
                                jarvis.0	2024-08-03 12:24:35.663	info	Found Backups for layout.
                                jarvis.0	2024-08-03 12:24:35.657	info	Connection: WebSocket opened on port 8400 using http...
                                jarvis.0	2024-08-03 12:24:35.580	info	No Backup found for styles, thus backing up initially.
                                jarvis.0	2024-08-03 12:24:35.579	info	No Backup found for scripts, thus backing up initially.
                                jarvis.0	2024-08-03 12:24:35.556	info	starting. Version 3.1.8 in /opt/iobroker/node_modules/iobroker.jarvis, node: v20.16.0, js-controller: 6.0.9
                                • Dr. Bakterius
                                  Dr. Bakterius Most Active @Pedder007 last edited by
                                  @pedder007 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                  War bei mir genauso. Wäre ja bei beta geblieben hätte BAR noch funktioniert. Hauptsache es läuft wieder.
                                  • mcm1957
                                    mcm1957 @Snopy_16 last edited by
                                    @snopy_16 said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                    @pedder007
                                    Ok - da wird es wohl notwendig sein, dass der Dev den Adapter anpasst bzw die Fehler die in der aktuellen Version existieren behebt.
                                    • mcm1957
                                      mcm1957 @fellpower last edited by
                                      @fellpower said in js-controller 6.0.x jetzt für alle User im STABLE!:
                                      Wie schon im andren Topic geschrieben würde ich das geänderte Verhalten deines Blockly Scripts eher im (wahrscheinlich) ebenfalls aktualisiserten javascript Adapter suchen. In jeden Fall grenz das Problem mal ein indem du eruierts wo genau sich dein Skript nun anders verhält. Liest es andere Werte? Funktionieren Berechnungen nicht? Ich würde jedenfalls anregen das Problem im referenzierten Topic weiter zu verfolgen - außer es gibt noch mehr Indizien dass es sich doch um Problem des js-controllers handelt.
                                      • foxriver76
                                        foxriver76 Developer @isi07 last edited by
                                        @isi07 hm spannend, für mich schon mal gut dass du es nachstellen kannst mit jedem Neustart. Falls es keine sensiblen Daten in deiner Installation gibt könntest du mir evtl. dein DB File schicken, damit könnte ich es vermutlich nachstellen, ansonsten muss ich nochmal Code schauen wie wir am ehesten uns annähern an das Problem.
                                        isi07 O 2 Replies Last reply Reply Quote 0
                                        • isi07
                                          @foxriver76
                                          habe Objects und States in redis. Möchte ungern die ganze DB rausgeben. Kann ich irgendetwas nachschauen oder suchen, um das Problem einzugrenzen?
                                          • foxriver76
                                            @isi07 das ist auch gut zu wissen, ich schaue morgen nochmal im Detail welche Infos helfen könnten - heute werde ich nicht dazu kommen
                                            1.2k
                                            controller js-controller kiera stable
                                            47
                                            257
                                            63787
