    3. Einsteigerfragen
    4. komm nicht weiter..."dpkg was interrupted"
      Thomas Braun Most Active @ralle last edited by
      @ralle
      sudo apt install libgdk-pixbuf2.0-bin libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-2.0-0
        ralle @Thomas Braun last edited by
        gemacht....
        pi@raspberrypi:~ $ sudo apt install libgdk-pixbuf2.0-bin libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-2.0-0
        Reading package lists... Done
        Building dependency tree... Done
        libgdk-pixbuf-2.0-0 is already the newest version (2.42.2+dfsg-1+deb11u2).
        libgdk-pixbuf-2.0-0 set to manually installed.
        libgdk-pixbuf-xlib-2.0-0 is already the newest version (2.40.2-2).
        libgdk-pixbuf-xlib-2.0-0 set to manually installed.
        You might want to run 'apt --fix-broken install' to correct these.
        The following packages have unmet dependencies:
         libgdk-pixbuf-2.0-dev : Depends: gir1.2-gdkpixbuf-2.0 (= 2.42.2+dfsg-1+deb11u2) but 2.42.2+dfsg-1+deb11u1 is to be installed
        E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
          @ralle sagte in komm nicht weiter..."dpkg was interrupted":
          sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2
            pi@raspberrypi:~ $ sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2
             libgdk-pixbuf-2.0-dev : Depends: libgdk-pixbuf2.0-bin (= 2.42.2+dfsg-1+deb11u2) but 2.42.2+dfsg-1+deb11u1 is to be installed
              sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2 libgdk-pixbuf2.0-bin=2.42.2+dfsg-1+deb11u2
                @thomas-braun said in komm nicht weiter..."dpkg was interrupted":
                  hat soweit geklappt, lief ohne Fehler durch. und nun?
                    @ralle
                    sudo apt update
                    sudo apt full-upgrade
                    sagt nun?
                      ralle @Thomas Braun last edited by ralle
                      lief durch.. war es das?
                      pi@raspberrypi:~ $ sudo apt full-upgrade
                      Calculating upgrade... Done
                      The following packages were automatically installed and are no longer required:
                        libfuse2 raspinfo
                      Use 'sudo apt autoremove' to remove them.
                      The following packages will be upgraded:
                        gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-x libcurl3-gnutls
                        libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libimlib2 libndp0
                        libqt5concurrent5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                        libqt5test5 libqt5xml5 libvlc-bin libvlc5 libvlccore9 nodejs python3-idna
                        python3-pil qt5-gtk-platformtheme vlc vlc-bin vlc-data vlc-l10n
                        vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
                        vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output
                        vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xwayland
                      36 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 0 B/53.9 MB of archives.
                      After this operation, 16.4 kB of additional disk space will be used.
                      Do you want to continue? [Y/n] y
                      Reading changelogs... Done
                      Extracting templates from packages: 100%
                      (Reading database ... 117751 files and directories currently installed.)
                      Preparing to unpack .../00-libgstreamer-plugins-base1.0-0_1.18.4-2+deb11u2_armhf.deb ...
                      Unpacking libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                      Preparing to unpack .../01-gstreamer1.0-alsa_1.18.4-2+deb11u2_armhf.deb ...
                      Unpacking gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                      Preparing to unpack .../02-gstreamer1.0-plugins-base_1.18.4-2+deb11u2_armhf.deb ...
                      Unpacking gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                      Preparing to unpack .../03-gstreamer1.0-x_1.18.4-2+deb11u2_armhf.deb ...
                      Unpacking gstreamer1.0-x:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                      Preparing to unpack .../04-libcurl3-gnutls_7.74.0-1.3+deb11u12_armhf.deb ...
                      Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) over (7.74.0-1.3+deb11u11) ...
                      Preparing to unpack .../05-libgstreamer-gl1.0-0_1.18.4-2+deb11u2_armhf.deb ...
                      Unpacking libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
                      Preparing to unpack .../06-libimlib2_1.7.1-2+deb11u1_armhf.deb ...
                      Unpacking libimlib2:armhf (1.7.1-2+deb11u1) over (1.7.1-2) ...
                      Preparing to unpack .../07-libndp0_1.6-1+deb11u1_armhf.deb ...
                      Unpacking libndp0:armhf (1.6-1+deb11u1) over (1.6-1) ...
                      Preparing to unpack .../08-libqt5concurrent5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../09-libqt5printsupport5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../10-libqt5sql5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../11-libqt5sql5-sqlite_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../12-libqt5test5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../13-libqt5xml5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../14-vlc_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../15-vlc-plugin-base_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../16-vlc-data_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
                      Unpacking vlc-data (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../17-libvlccore9_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../18-vlc-plugin-skins2_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../19-vlc-plugin-qt_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../20-vlc-plugin-video-output_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../21-libvlc5_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../22-vlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-bin (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../23-libvlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../24-nodejs_18.20.4-1nodesource1_armhf.deb ...
                      Detected old npm client, removing...
                      Unpacking nodejs (18.20.4-1nodesource1) over (18.20.2-1nodesource1) ...
                      Preparing to unpack .../25-python3-idna_2.10-1+deb11u1_all.deb ...
                      Unpacking python3-idna (2.10-1+deb11u1) over (2.10-1) ...
                      Preparing to unpack .../26-python3-pil_8.1.2+dfsg-0.3+deb11u2_armhf.deb ...
                      Unpacking python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) over (8.1.2+dfsg-0.3+deb11u1) ...
                      Preparing to unpack .../27-qt5-gtk-platformtheme_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
                      Unpacking qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
                      Preparing to unpack .../28-vlc-l10n_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
                      Unpacking vlc-l10n (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../29-vlc-plugin-access-extra_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../30-vlc-plugin-notify_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../31-vlc-plugin-samba_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../32-vlc-plugin-video-splitter_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../33-vlc-plugin-visualization_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
                      Unpacking vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
                      Preparing to unpack .../34-wpasupplicant_2%3a2.9.0-21+deb11u1_armhf.deb ...
                      Unpacking wpasupplicant (2:2.9.0-21+deb11u1) over (2:2.9.0-21) ...
                      Preparing to unpack .../35-xwayland_2%3a1.20.11-1+rpt3+deb11u13_armhf.deb ...
                      Unpacking xwayland (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u11) ...
                      Setting up libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) ...
                      Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) ...
                      Setting up vlc-l10n (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up nodejs (18.20.4-1nodesource1) ...
                      Setting up qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up wpasupplicant (2:2.9.0-21+deb11u1) ...
                      Setting up libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) ...
                      Setting up libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) ...
                      Setting up gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) ...
                      Setting up python3-idna (2.10-1+deb11u1) ...
                      Setting up libimlib2:armhf (1.7.1-2+deb11u1) ...
                      Setting up libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up libndp0:armhf (1.6-1+deb11u1) ...
                      Setting up xwayland (2:1.20.11-1+rpt3+deb11u13) ...
                      Setting up libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up vlc-data (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up gstreamer1.0-x:armhf (1.18.4-2+deb11u2) ...
                      Setting up gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) ...
                      Setting up libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
                      Setting up vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc-bin (1:3.0.21-0+rpt1+deb11u1) ...
                      Setting up vlc (1:3.0.21-0+rpt1+deb11u1) ...
                      Processing triggers for desktop-file-utils (0.26-1) ...
                      Processing triggers for hicolor-icon-theme (0.17-2) ...
                      Processing triggers for gnome-menus (3.36.0-1) ...
                      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u10) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Processing triggers for dbus (1.12.28-0+deb11u1) ...
                      Processing triggers for mailcap (3.69) ...
                      Processing triggers for libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
                        @ralle
                        Dann
                        iob stop
                        sudo reboot
                        und wenn die Kiste wieder oben ist die Ausgaben zu
                        sudo apt update
                          @ralle
                          Schalt den Desktop-Krempel aus...
                          Je weniger unnützes Zeuch da mitrumpelt desto einfacher sind auch Paketupdates und deren Abhängigkeiten aufzulösen.
                            Schalt den Desktop-Krempel aus... --- für dich leicht gesagt, ist das für mich auch möglich??
                            hier die Liste nach "Full-upgrade"
                            pi@raspberrypi:~ $ sudo apt update
                            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                            All packages are up to date.
                              libfuse2 raspinfo
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            pi@raspberrypi:~ $
                              @ralle
                              Jetzt passt es. Bring das ganze noch auf
                              iob nodejs-update 20
                              Und in nächster Zeit per kompletter Neuinstallation (dann gleich ohne Desktop-Umgebung) auf Raspberry OS 12 'Bookworm'.
                                kannst du mir in 2-3 Sätzen sagen was du da jetzt gemacht hast, worin das Problem lag...
                                vielen Dank für deine Hilfe.
                                Neuinstallation werde ich mal machen.... nächste Herrausforderung 🙂
                                  Aus irgendeinem Grund konnte der Paketmanager die Abhängigkeiten nicht mehr auflösen.
                                  Da haben wir dem Blechheini jetzt abgenommen, eigentlich soll der das selber machen, dafür ist der Paketmanager bzw. dessen 'solver' ja da.
                                    hab mal eben nachgeschaut, es gibt 3 OS Versionen 2x mit Desktop und einmal die light.
                                    ist es die Light die ich dann benötige?
                                      Thomas Braun Most Active @ralle last edited by Thomas Braun
                                      Ja, light in der 64Bit-Version.
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        Happyuser20 last edited by
                                        Guten Morgen
                                        Ich schließe mich hier an.
                                        Habe ein ähnliches Problem auf meinem Raspi IOB Slave
                                        Bekomme im IOB Admin auch die Meldung das Updates verfügbar sind. funktioniert aber nicht.
                                        Ich bekomme folgende Ausgabe mit Putty
                                        pi@raspberrypi:~ $ iob stop
                                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        281 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                         dmsetup : Depends: libdevmapper1.02.1 (>= 2:1.02.138) but 2:1.02.137-2 is installed
                                        pi@raspberrypi:~ $
                                        Ich meine gelsen zu haben. Auf keinen Fall irgendwas mit FIX zu machen.
                                        Bitte um Hilfe
                                        HappyUser20
                                          Homoran Global Moderator Administrators @Happyuser20 last edited by
                                          @happyuser20 sagte in komm nicht weiter..."dpkg was interrupted":
                                          da warst du aber lange schon nicht mehr dran.
                                          ist so etwas von tot!
                                          da geht ein upgrade auf bookworm sowieso nicht
                                          Also komplett neu machen
                                            Na prima, aber nutzt nichts.
                                            so alt ist das noch garnicht, Anfang des Jahres 😄
                                            4252
