    3. Einsteigerfragen
    4. komm nicht weiter..."dpkg was interrupted"
      ralle @Thomas Braun last edited by
      @thomas-braun said in komm nicht weiter..."dpkg was interrupted":
      sudo apt install gir1.2-gdkpixbuf-2.0=2.42.2+dfsg-1+deb11u2 libgdk-pixbuf2.0-bin=2.42.2+dfsg-1+deb11u2
        hat soweit geklappt, lief ohne Fehler durch. und nun?
          Thomas Braun Most Active @ralle last edited by
          @ralle
          sudo apt update
          sudo apt full-upgrade
          sagt nun?
            ralle @Thomas Braun last edited by ralle
            lief durch.. war es das?
            pi@raspberrypi:~ $ sudo apt full-upgrade
            Reading package lists... Done
            Building dependency tree... Done
            Calculating upgrade... Done
            The following packages were automatically installed and are no longer required:
              libfuse2 raspinfo
            Use 'sudo apt autoremove' to remove them.
            The following packages will be upgraded:
              gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-x libcurl3-gnutls
              libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libimlib2 libndp0
              libqt5concurrent5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
              libqt5test5 libqt5xml5 libvlc-bin libvlc5 libvlccore9 nodejs python3-idna
              python3-pil qt5-gtk-platformtheme vlc vlc-bin vlc-data vlc-l10n
              vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
              vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output
              vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xwayland
            36 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 0 B/53.9 MB of archives.
            After this operation, 16.4 kB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Reading changelogs... Done
            Extracting templates from packages: 100%
            (Reading database ... 117751 files and directories currently installed.)
            Preparing to unpack .../00-libgstreamer-plugins-base1.0-0_1.18.4-2+deb11u2_armhf.deb ...
            Unpacking libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
            Preparing to unpack .../01-gstreamer1.0-alsa_1.18.4-2+deb11u2_armhf.deb ...
            Unpacking gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
            Preparing to unpack .../02-gstreamer1.0-plugins-base_1.18.4-2+deb11u2_armhf.deb ...
            Unpacking gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
            Preparing to unpack .../03-gstreamer1.0-x_1.18.4-2+deb11u2_armhf.deb ...
            Unpacking gstreamer1.0-x:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
            Preparing to unpack .../04-libcurl3-gnutls_7.74.0-1.3+deb11u12_armhf.deb ...
            Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) over (7.74.0-1.3+deb11u11) ...
            Preparing to unpack .../05-libgstreamer-gl1.0-0_1.18.4-2+deb11u2_armhf.deb ...
            Unpacking libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) over (1.18.4-2+deb11u1) ...
            Preparing to unpack .../06-libimlib2_1.7.1-2+deb11u1_armhf.deb ...
            Unpacking libimlib2:armhf (1.7.1-2+deb11u1) over (1.7.1-2) ...
            Preparing to unpack .../07-libndp0_1.6-1+deb11u1_armhf.deb ...
            Unpacking libndp0:armhf (1.6-1+deb11u1) over (1.6-1) ...
            Preparing to unpack .../08-libqt5concurrent5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../09-libqt5printsupport5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../10-libqt5sql5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../11-libqt5sql5-sqlite_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../12-libqt5test5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../13-libqt5xml5_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../14-vlc_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../15-vlc-plugin-base_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../16-vlc-data_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
            Unpacking vlc-data (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../17-libvlccore9_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../18-vlc-plugin-skins2_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../19-vlc-plugin-qt_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../20-vlc-plugin-video-output_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../21-libvlc5_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../22-vlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-bin (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../23-libvlc-bin_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../24-nodejs_18.20.4-1nodesource1_armhf.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.20.4-1nodesource1) over (18.20.2-1nodesource1) ...
            Preparing to unpack .../25-python3-idna_2.10-1+deb11u1_all.deb ...
            Unpacking python3-idna (2.10-1+deb11u1) over (2.10-1) ...
            Preparing to unpack .../26-python3-pil_8.1.2+dfsg-0.3+deb11u2_armhf.deb ...
            Unpacking python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) over (8.1.2+dfsg-0.3+deb11u1) ...
            Preparing to unpack .../27-qt5-gtk-platformtheme_5.15.2+dfsg-9+rpi1+deb11u1_armhf.deb ...
            Unpacking qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) over (5.15.2+dfsg-9+rpi1) ...
            Preparing to unpack .../28-vlc-l10n_1%3a3.0.21-0+rpt1+deb11u1_all.deb ...
            Unpacking vlc-l10n (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../29-vlc-plugin-access-extra_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../30-vlc-plugin-notify_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../31-vlc-plugin-samba_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../32-vlc-plugin-video-splitter_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../33-vlc-plugin-visualization_1%3a3.0.21-0+rpt1+deb11u1_armhf.deb ...
            Unpacking vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) over (1:3.0.20-0+rpt1+deb11u1) ...
            Preparing to unpack .../34-wpasupplicant_2%3a2.9.0-21+deb11u1_armhf.deb ...
            Unpacking wpasupplicant (2:2.9.0-21+deb11u1) over (2:2.9.0-21) ...
            Preparing to unpack .../35-xwayland_2%3a1.20.11-1+rpt3+deb11u13_armhf.deb ...
            Unpacking xwayland (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u11) ...
            Setting up libgstreamer-plugins-base1.0-0:armhf (1.18.4-2+deb11u2) ...
            Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u12) ...
            Setting up vlc-l10n (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up nodejs (18.20.4-1nodesource1) ...
            Setting up qt5-gtk-platformtheme:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up libqt5sql5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up wpasupplicant (2:2.9.0-21+deb11u1) ...
            Setting up libqt5printsupport5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up python3-pil:armhf (8.1.2+dfsg-0.3+deb11u2) ...
            Setting up libqt5xml5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up libgstreamer-gl1.0-0:armhf (1.18.4-2+deb11u2) ...
            Setting up gstreamer1.0-plugins-base:armhf (1.18.4-2+deb11u2) ...
            Setting up python3-idna (2.10-1+deb11u1) ...
            Setting up libimlib2:armhf (1.7.1-2+deb11u1) ...
            Setting up libvlccore9:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-qt:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up libndp0:armhf (1.6-1+deb11u1) ...
            Setting up xwayland (2:1.20.11-1+rpt3+deb11u13) ...
            Setting up libqt5test5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up libqt5concurrent5:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up vlc-data (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-notify:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-video-output:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-samba:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up gstreamer1.0-x:armhf (1.18.4-2+deb11u2) ...
            Setting up gstreamer1.0-alsa:armhf (1.18.4-2+deb11u2) ...
            Setting up libqt5sql5-sqlite:armhf (5.15.2+dfsg-9+rpi1+deb11u1) ...
            Setting up vlc-plugin-skins2:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-video-splitter:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up libvlc5:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-visualization:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-access-extra:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-plugin-base:armhf (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc-bin (1:3.0.21-0+rpt1+deb11u1) ...
            Setting up vlc (1:3.0.21-0+rpt1+deb11u1) ...
            Processing triggers for desktop-file-utils (0.26-1) ...
            Processing triggers for hicolor-icon-theme (0.17-2) ...
            Processing triggers for gnome-menus (3.36.0-1) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u10) ...
            Processing triggers for man-db (2.9.4-2) ...
            Processing triggers for dbus (1.12.28-0+deb11u1) ...
            Processing triggers for mailcap (3.69) ...
            Processing triggers for libvlc-bin:armhf (1:3.0.21-0+rpt1+deb11u1) ...
              @ralle
              Dann
              iob stop
              sudo reboot
              und wenn die Kiste wieder oben ist die Ausgaben zu
              sudo apt update
                @ralle
                Schalt den Desktop-Krempel aus...
                Je weniger unnützes Zeuch da mitrumpelt desto einfacher sind auch Paketupdates und deren Abhängigkeiten aufzulösen.
                  Schalt den Desktop-Krempel aus... --- für dich leicht gesagt, ist das für mich auch möglich??
                  hier die Liste nach "Full-upgrade"
                  pi@raspberrypi:~ $ sudo apt update
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                  All packages are up to date.
                    libfuse2 raspinfo
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  pi@raspberrypi:~ $
                    @ralle
                    Jetzt passt es. Bring das ganze noch auf
                    iob nodejs-update 20
                    Und in nächster Zeit per kompletter Neuinstallation (dann gleich ohne Desktop-Umgebung) auf Raspberry OS 12 'Bookworm'.
                      kannst du mir in 2-3 Sätzen sagen was du da jetzt gemacht hast, worin das Problem lag...
                      vielen Dank für deine Hilfe.
                      Neuinstallation werde ich mal machen.... nächste Herrausforderung 🙂
                        @ralle sagte in komm nicht weiter..."dpkg was interrupted":
                        Aus irgendeinem Grund konnte der Paketmanager die Abhängigkeiten nicht mehr auflösen.
                        Da haben wir dem Blechheini jetzt abgenommen, eigentlich soll der das selber machen, dafür ist der Paketmanager bzw. dessen 'solver' ja da.
                          hab mal eben nachgeschaut, es gibt 3 OS Versionen 2x mit Desktop und einmal die light.
                          ist es die Light die ich dann benötige?
                            Thomas Braun Most Active @ralle last edited by Thomas Braun
                            Ja, light in der 64Bit-Version.
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                              Happyuser20 last edited by
                              Guten Morgen
                              Ich schließe mich hier an.
                              Habe ein ähnliches Problem auf meinem Raspi IOB Slave
                              Bekomme im IOB Admin auch die Meldung das Updates verfügbar sind. funktioniert aber nicht.
                              Ich bekomme folgende Ausgabe mit Putty
                              pi@raspberrypi:~ $ iob stop
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              281 packages can be upgraded. Run 'apt list --upgradable' to see them.
                              You might want to run 'apt --fix-broken install' to correct these.
                              The following packages have unmet dependencies:
                               dmsetup : Depends: libdevmapper1.02.1 (>= 2:1.02.138) but 2:1.02.137-2 is installed
                              E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
                              pi@raspberrypi:~ $
                              Ich meine gelsen zu haben. Auf keinen Fall irgendwas mit FIX zu machen.
                              Bitte um Hilfe
                              HappyUser20
                                Homoran Global Moderator Administrators @Happyuser20 last edited by
                                @happyuser20 sagte in komm nicht weiter..."dpkg was interrupted":
                                da warst du aber lange schon nicht mehr dran.
                                ist so etwas von tot!
                                da geht ein upgrade auf bookworm sowieso nicht
                                Also komplett neu machen
                                  Na prima, aber nutzt nichts.
                                  so alt ist das noch garnicht, Anfang des Jahres 😄
                                    Homoran Global Moderator Administrators @Happyuser20 last edited by Homoran
                                    Anfang des Jahres
                                    never!
                                    buster ist Debian 10, bookworm ist Debian 12.
                                    Pro Version etwa 2 Jahre.....
                                      Thomas Braun Most Active @Happyuser20 last edited by
                                      Das war aber auch da schon abgekündigt. RaspberrryOS unterstüzt nur das aktuelle stable release (aka Version 12 'Bookworm') und die Vorversion 'Bullseye'.
                                      Warum installiert man ein abgekündigtes Release?
                                      Sprung zu weit, Änderungen zu groß -> Neuinstallation.
                                      Und das neue System dann auch beständig aktuell halten.
                                        @thomas-braun Hallo, du hattes mir gestern geholfen, nun hab ich noch eine Frage zum Speicher. Jetzt gibt mir IOB an das mein Speicher voll ist, das war vor dem Update nicht so. Wie kann ich das aufräumen / Speicher freigeben, Ein paar Befehle hab ich ausprobiert die ich gefunden habe jedoch ohne Erfolg.
                                          @ralle
                                          Schau mittels
                                          sudo ncdu /
                                          nach wo die dicken Dinger liegen.
                                            sudo ncdu /
                                            vielen Dank, hab ich gemacht aber ich glaub das ich so nicht weiter kommen mit dem Wissen was ich zu linux habe. Ich möchte damit auch keinen belasten, gibt wichtigeres.
                                            Muss mich die Tage dran machen das System neu auf zu setzten..... Das wird wieder was geben, tzzzzzzz
                                            4249
