    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Thomas Braun Most Active @reddddich last edited by
      @reddddich
      Und wie hat es der n00b gemacht?
        @reddddich
        Jetzt passt es.
        Das nodesource-Repo ist jetzt richtig auf 20 gesetzt worden.
        Dann kannste jetzt den Desktop ausschalten und zigbee auf den 'by-id'-Link setzen.
          reddddich @Thomas Braun last edited by
          @thomas-braun said in Troubleshooting NodeJS update:
          @reddddich
          wine and n00bness did its job... als typischer copy paste mensch der befehle lief da bestimmt was schief
            @reddddich
            Und welche Befehle hast du da woher kopiert?
              zumindest alles aus dem Forum...
              weiterhin starten adapter aber nicht...
              	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.raspberrypi
              2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
              host.raspberrypi
              2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.raspberrypi
              2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.raspberrypi
              2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
              host.raspberrypi
              2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.raspberrypi
              2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
              host.raspberrypi
              2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
              host.raspberrypi
              2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
              host.raspberrypi
              2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.raspberrypi
              2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
              host.raspberrypi
              2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
              host.raspberrypi
              2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
              host.raspberrypi
              2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
              host.raspberrypi
              2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
              host.raspberrypi
              2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
              host.raspberrypi
              2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
                @reddddich
                Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
                  Ich kann dir nur noch Recht geben... 🙂
                  • BananaJoe
                    BananaJoe Most Active @reddddich last edited by
                    @reddddich mit dem Befehl
                    history
                    bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
                      tony63526 last edited by
                      ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
                      Installiert habe ich es nach dieser Anleitung
                      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                      iob diag ergab folgendes:
                                              v.2024-05-22
                         Static hostname: raspberrypi
                               Icon name: computer
                        Operating System: Raspbian GNU/Linux 10 (buster)
                                  Kernel: Linux 5.10.103-v7l+
                            Architecture: arm
                      Installation:           native
                      Kernel:                 armv7l
                      Userland:               32 bit
                      Timezone:               Europe/Berlin (CEST, +0200)
                      User-ID:                1000
                      Display-Server:         true
                      Boot Target:            graphical.target
                      Pending OS-Updates:     0
                      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                      Pending iob updates:    0
                      Nodejs-Installation:
                      nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      /usr/bin/corepack
                      Recommended versions are nodejs  and npm
                      MEMORY:
                      Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
                      Swap:           99M          0B         99M
                      Total:         8.0G        232M        6.5G
                      Active iob-Instances:   0
                      ioBroker Core:          js-controller
                                              admin
                      ioBroker Status:
                      Objects:                0
                      States:                 0
                      Size of iob-Database:
                      29M     /opt/iobroker/iobroker-data/objects.jsonl
                      5.3M    /opt/iobroker/iobroker-data/states.jsonl
                      === Mark text until here for copying ===
                      pi@raspberrypi:~ $ iob fix
                      library: loaded
                      Library version=2024-05-24
                      Welcome to the ioBroker installation fixer!
                      Script version: 2024-01-04
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/5)
                      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists... Done
                      Checking ioBroker user and directory permissions (2/5)
                      Created /etc/sudoers.d/iobroker
                      Fixing directory permissions...
                      Check and cleanup npm temporary directories (3/5)
                      Done.
                      Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
                      Checking autostart (5/5)
                      Enabling autostart...
                      Autostart enabled!
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                      pi@raspberrypi:~ $ iob start
                        Thomas Braun Most Active @tony63526 last edited by Thomas Braun
                        @tony63526 sagte in Troubleshooting NodeJS update:
                        buster
                        Ist zu alt, installier da dringend was lebendiges.
                        Diesmal gleich in der 64Bit-Lite Version.
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          tony63526 @Thomas Braun last edited by
                          Würde bedeuten ich muss alles neu aufsetzten?
                          • Zigbee gereate neu anlernen
                          • Text2command neu eintippen.
                            eigentlich alles, weil ich mein backup nicht nutzen kann?
                          mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @tony63526 last edited by
                            @tony63526
                            Wieso kannst du dein Backup nicht nutzen?
                              Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                              Warum nicht?
                                tony63526 @mcm1957 last edited by
                                @mcm1957
                                Weis ich nicht.
                                War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                                mcm1957 Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                • mcm1957
                                  @tony63526
                                  Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                                    Ein Backup via backitup ist unabhängig vom Betriebssystem.
                                      Homoran Global Moderator Administrators @tony63526 last edited by
                                      warum nicht?
                                      was war daran "zu alt"?
                                        @mcm1957
                                        rein iobroker backup.
                                        Ueber den Backitup adapter
                                          Danke Thomas
                                            tony63526 @Homoran last edited by
                                            Denke das Image 🤷‍♂️
                                            Beziehe mich jetzt nur auf die Aussage von Thomas.
                                            buster
                                            "Ist zu alt, installier da dringend was lebendiges.
                                            Diesmal gleich in der 64Bit-Lite Version".
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143163
