    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Thomas Braun Most Active @reddddich last edited by
      @reddddich
      Und welche Befehle hast du da woher kopiert?
        reddddich @Thomas Braun last edited by
        zumindest alles aus dem Forum...
        weiterhin starten adapter aber nicht...
        	2024-07-30 23:12:13.735	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi
        2024-07-30 23:12:13.735	error	Caught by controller[0]: Node.js v20.16.0
        host.raspberrypi
        2024-07-30 23:12:13.735	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        host.raspberrypi
        2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        host.raspberrypi
        2024-07-30 23:12:13.734	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/sshpk/lib/certificate.js:21:18)
        host.raspberrypi
        2024-07-30 23:12:13.734	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        host.raspberrypi
        2024-07-30 23:12:13.734	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
        host.raspberrypi
        2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
        host.raspberrypi
        2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
        host.raspberrypi
        2024-07-30 23:12:13.733	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        host.raspberrypi
        2024-07-30 23:12:13.732	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1321:27)
        host.raspberrypi
        2024-07-30 23:12:13.732	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1281:20)
        host.raspberrypi
        2024-07-30 23:12:13.732	error	Caught by controller[0]: SyntaxError: Unexpected token '!'
        host.raspberrypi
        2024-07-30 23:12:13.731	error	Caught by controller[0]: ^
        host.raspberrypi
        2024-07-30 23:12:13.731	error	Caught by controller[0]: var!x00) = requiru8'..x509�);
        host.raspberrypi
        2024-07-30 23:12:13.730	error	Caught by controller[0]: /opt/iobroker/node_modules/sshpk/lib/formats/x509-pem.js:3
        host.raspberrypi
        2024-07-30 23:12:05.243	info	Restart adapter system.adapter.sony-bravia.0 because enabled
          @reddddich
          Ohne zu wissen was du da genau gemacht hast kann man auch nicht nachvollziehen, was da nun vielleicht alles krumm ist.
            Ich kann dir nur noch Recht geben... 🙂
            • BananaJoe
              BananaJoe Most Active @reddddich last edited by
              @reddddich mit dem Befehl
              history
              bekommt man eine Liste mit dem was man gemacht hat. Ohne Anspruch auf Vollständigkeit (z.B. bei mehreren Sitzungen gleichzeitig)
                tony63526 last edited by
                ich bekomme die node.js 20x nicht installiert, bzw Iobroker leasst sich sobal alle befehle ausgefuehrt sind nicht mehr oeffnen.
                Installiert habe ich es nach dieser Anleitung
                https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
                iob diag ergab folgendes:
                                        v.2024-05-22
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 10 (buster)
                            Kernel: Linux 5.10.103-v7l+
                      Architecture: arm
                Installation:           native
                Kernel:                 armv7l
                Userland:               32 bit
                Timezone:               Europe/Berlin (CEST, +0200)
                User-ID:                1000
                Display-Server:         true
                Boot Target:            graphical.target
                Pending OS-Updates:     0
                node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
                Pending iob updates:    0
                Nodejs-Installation:
                nodejs: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by nodejs)
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                /usr/bin/corepack
                Recommended versions are nodejs  and npm
                MEMORY:
                Mem:           7.9G        232M        6.4G         16M        1.3G        7.4G
                Swap:           99M          0B         99M
                Total:         8.0G        232M        6.5G
                Active iob-Instances:   0
                ioBroker Core:          js-controller
                                        admin
                ioBroker Status:
                Objects:                0
                States:                 0
                Size of iob-Database:
                29M     /opt/iobroker/iobroker-data/objects.jsonl
                5.3M    /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                pi@raspberrypi:~ $ iob fix
                library: loaded
                Library version=2024-05-24
                Welcome to the ioBroker installation fixer!
                Script version: 2024-01-04
                You might need to enter your password a couple of times.
                Installing prerequisites (1/5)
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:3 https://apt.pivccu.de/piVCCU stable InRelease
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Reading package lists... Done
                Checking ioBroker user and directory permissions (2/5)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                Check and cleanup npm temporary directories (3/5)
                Done.
                Database maintenance (4/5)
                Checking for uncompressed JSONL databases... This might take a while!
                node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node) main: line 14: [: -lt: unary operator expected node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.26' not found (required by node)
                Checking autostart (5/5)
                Enabling autostart...
                Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
                pi@raspberrypi:~ $ iob start
                  Thomas Braun Most Active @tony63526 last edited by Thomas Braun
                  @tony63526 sagte in Troubleshooting NodeJS update:
                  buster
                  Ist zu alt, installier da dringend was lebendiges.
                  Diesmal gleich in der 64Bit-Lite Version.
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    tony63526 @Thomas Braun last edited by
                    Würde bedeuten ich muss alles neu aufsetzten?
                    • Zigbee gereate neu anlernen
                    • Text2command neu eintippen.
                      eigentlich alles, weil ich mein backup nicht nutzen kann?
                    mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                    • mcm1957
                      mcm1957 @tony63526 last edited by
                      @tony63526
                      Wieso kannst du dein Backup nicht nutzen?
                        Ja. Musst du so oder so, weil ein Architektur-Wechsel nicht möglich ist und die Änderungen von RPi OS 10 zu 12 zu groß sind.
                        Warum nicht?
                          tony63526 @mcm1957 last edited by
                          @mcm1957
                          Weis ich nicht.
                          War eine Frage. Mein backup bassiert ja auf dem alten system, kann ich es einfach auf dem neuen aufspielen?
                          mcm1957 Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                          • mcm1957
                            @tony63526
                            Reden wir von einem IOBROKER Backup oder eine Imagebackup des Betreibssystems ?
                              Ein Backup via backitup ist unabhängig vom Betriebssystem.
                                Homoran Global Moderator Administrators @tony63526 last edited by
                                warum nicht?
                                was war daran "zu alt"?
                                  @mcm1957
                                  rein iobroker backup.
                                  Ueber den Backitup adapter
                                    Danke Thomas
                                      tony63526 @Homoran last edited by
                                      Denke das Image 🤷‍♂️
                                      Beziehe mich jetzt nur auf die Aussage von Thomas.
                                      buster
                                      "Ist zu alt, installier da dringend was lebendiges.
                                      Diesmal gleich in der 64Bit-Lite Version".
                                        Denke das Image
                                        = das OS.
                                        damit hat ein iob backup nichts zu tun.
                                        Schwieriger wird es wenn der Controller < v5 ist.
                                          Okay, danke für die Info.
                                          Du siehst, ich habe mit Linux nichts am Hut, aber ich lerne immer gerne dazu.. 😊
                                          Ich versuche, mein System immer auf dem neuesten Stand zu halten, um genau das zu vermeiden, aber jetzt hat mir mein altes Image einen Strich durch die Rechnung gemacht.
                                          Hab ich jetzt bissi was zu tun.
                                          Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                                            HUST...
                                            buster ist schon geraume Zeit abgekündigt.
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143633
