    3. Entwicklung
    4. Supportthread Resol-Adapter
      ckhx78 @Gargano last edited by
      @gargano
      steht die Adresse noch irgendwo?
      Oder wird noch irgendwo eine alte Konfiguration gespeichert?
      Ich hab das dort geändert (mit Nano über die Konsole) aber irgendwo zieht er sich immer noch die 0x1050
      resol.0
      2024-08-02 18:41:30.006	debug	Finishing loadMyConfig...
      resol.0
      2024-08-02 18:41:30.005	error	Unable to create optimizer for master with address 0x1050
      resol.0
      2024-08-02 18:41:30.003	debug	received data: [{"id":"00_0010_7821_10_0100_000_2_0","name":"Temperatur Sensor 1","rawValue":59,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_002_2_0","name":"Temperatur Sensor 2","rawValue":55.300000000000004,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":2,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":3,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_004_2_0","name":"Temperatur Sensor 3","rawValue":28.700000000000003,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":4,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":5,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_006_2_0","name":"Temperatur Sensor 4","rawValue":61.400000000000006,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":6,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":7,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_008_2_0","name":"Temperatur Sensor 5","rawValue":55.800000000000004,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":8,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":9,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_010_2_0","name":"Temperatur Sensor 6","rawValue":54.300000000000004,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":10,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":11,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_012_2_0","name":"Temperatur Sensor 7","rawValue":58.800000000000004,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":12,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":13,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_014_2_0","name":"Temperatur Sensor 8","rawValue":45.2,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":14,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":15,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_016_2_0","name":"Temperatur Sensor 9","rawValue":51.2,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":16,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":17,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_018_2_0","name":"Temperatur Sensor 10","rawValue":29.400000000000002,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":18,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":19,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_020_2_0","name":"Einstrahlung CS","rawValue":72,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"WattsPerSquareMeter","unitText":" W/m²","typeId":"Number_1_WattsPerSquareMeter","precision":0,"rootTypeId":"Number","parts":[{"offset":20,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":21,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_022_2_0","name":"Impulse 1 V40","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":22,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":23,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_024_2_0","name":"Digital Input","rawValue":1,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":24,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":25,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_026_1_0","name":"Drehzahl Relais 1","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":26,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_027_1_0","name":"Drehzahl Relais 2","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":27,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_028_1_0","name":"Drehzahl Relais 3","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":28,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_029_1_0","name":"Drehzahl Relais 4","rawValue":100,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":29,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_030_1_0","name":"Drehzahl Relais 5","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":30,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_031_1_0","name":"Drehzahl Relais 6","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":31,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_032_1_0","name":"Drehzahl Relais 7","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":32,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_036_2_0","name":"Fehlermaske","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":36,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":37,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_038_2_0","name":"Meldungen","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":38,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":39,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_040_1_0","name":"System","rawValue":1,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":40,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_042_2_0","name":"Schema","rawValue":346,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":42,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":43,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_044_2_0","name":"Vorlauf Soll HK1 Modul Sensor 18","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":44,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":45,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_046_2_0","name":"Status HK1 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":46,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":47,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_048_2_0","name":"Vorlauf Soll HK2 Modul Sensor 25","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":48,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":49,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_050_2_0","name":"Status HK2 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":50,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":51,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_052_2_0","name":"Vorlauf Soll HK3 Modul Sensor 32","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":52,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":53,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_054_2_0","name":"Status HK3 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":54,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":55,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_056_2_0","name":"Vorlauf Soll Heizkreis Sensor 11","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":56,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":57,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_058_2_0","name":"Status Heizkreis","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":58,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":59,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_062_2_0","name":"Systemzeit","rawValue":6881,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Time_1_None","precision":0,"rootTypeId":"Time","parts":[{"offset":62,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":63,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_064_2_0","name":"Jahr","rawValue":2024,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":64,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":65,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_066_1_0","name":"Monat","rawValue":8,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":66,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_067_1_0","name":"Tag","rawValue":2,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":67,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_060_1_0","name":"Version","rawValue":1.03,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_0_01_None","precision":2,"rootTypeId":"Number","parts":[{"offset":60,"mask":255,"bitPos":0,"isSigned":true,"factor":100},{"offset":61,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7822_10_0100_000_2_0","name":"Temperatur Vorlauf","rawValue":55.800000000000004,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_002_2_0","name":"Temperatur Rücklauf","rawValue":54.300000000000004,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":2,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":3,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_004_2_0","name":"Durchfluss Sensor 8","rawValue":0,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"LitersPerHour","unitText":" l/h","typeId":"Number_1_LitersPerHour","precision":0,"rootTypeId":"Number","parts":[{"offset":4,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":5,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_006_2_0","name":"Wärmemenge","rawValue":36676850,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"WattHours","unitText":" Wh","typeId":"Number_1_WattHours","precision":0,"rootTypeId":"Number","parts":[{"offset":6,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":7,"mask":255,"bitPos":0,"isSigned":false,"factor":256},{"offset":8,"mask":255,"bitPos":0,"isSigned":false,"factor":1000},{"offset":9,"mask":255,"bitPos":0,"isSigned":false,"factor":256000},{"offset":10,"mask":255,"bitPos":0,"isSigned":false,"factor":1000000},{"offset":11,"mask":255,"bitPos":0,"isSigned":false,"factor":256000000}]}]
      resol.0
      2024-08-02 18:41:00.004	debug	Finishing loadMyConfig...
      resol.0
      2024-08-02 18:41:00.004	error	Unable to create optimizer for master with address 0x1050
      Gargano 1 Reply Last reply Reply Quote 0
      • Gargano
        Gargano @ckhx78 last edited by Gargano
        @ckhx78 such mal nach dem File. Evtl. Gibt es mehrere Installationen. Oder es ist noch im Cache, also reboot machen
          ckhx78 @Gargano last edited by ckhx78
          @gargano
          das ist irgendwie schon sehr seltsam...
          hab jetzt gestern Abend schon mehrfach rebootet (nicht nur deswegen, ein anderes Systemupdate hat auch erst nicht soo geklappt) aber irgendwie zieht der immer noch die falsche Adresse irgendwo her...
          Hab mir jetzt WinSCP besorgt obwohl ich eigentlich mit Filezilla auch ganz zufrieden war, nur die Suche... Naja ich glaub gegangen wäre es auch... ich find die Datei nur das eine mal, ich wüst auch nicht wo eine zweite Installation her kommen sollte, aber der Teufel ist ja ein Eichhörnchen... 🙂
          Das scheint doch ein größeres Problem als befürchtet... Wenns nicht geht ist auch nicht sooo schlimm, wäre nur schon geil wenn ich ein Relais schalten könnt... hab Solar auf dem Dach, einen Wasserführenden Kaminofen und einen Pelletsofen mit Wassertasche... auf der Steuerung ist ein Relais mit dem ich das Nachheizen via Ölheizung unterdrücken kann, das wäre genial dies bei bedarf via iobroker zu schalten...
          • Gargano
            @ckhx78 Jetzt habe ich nochmal geschaut, die Umsetzung erfolgt ja schon im Main.js. Da wird die Id auf 0x1050 gesetzt wenn die ID 30753 ist. Das ist schon eingebaut, nur scheint es für das Schreiben nicht zu funktionieren.
            switch (context.deviceAddress){
                                case 30753: // Cosemo-Multi-2 is a relabeld DeltaSol-E
                                    context.deviceAddress = 4176; // fake a DeltaSol-E since Cosmo-Controllers aren't supported by the Resol-Lib
                                    break;
            Allerdings nur an einer Stelle , es sollte aber an 2 Stellen die Umsetzung erfolgen.
            Also bitte alles auf Anfang, die Datei resol-deltasol-e-v2-100-configuration-optimizer.js wieder Original herstellen.
            Und dann folgende Änderung im main.js (/opt/iobroker/node_modules/iobroker.resol) machen :
               //--- vbus write
                async runShot(context) {
                    try {
                        this.log.debug('Waiting for free bus...');
                        const datagram = await context.connection.waitForFreeBus();
                        context.masterAddress = datagram.sourceAddress;
                        this.log.debug('Found master with address 0x' + context.masterAddress.toString(16));
                        context.deviceAddress = context.masterAddress;
            	  // --- diesen Teil einfügen -----
                                    break;
            	    // --- Ende diesen Teil einfügen -----
                        const optimizer = await vbus.ConfigurationOptimizerFactory.createOptimizerByDeviceAddress(context.deviceAddress);
            Danach den Adapter neu starten.
              @gargano Mega, Danke für Deine Geduld mit mir! 🙂
              Ein Stückchen scheinen wir weiter zu sein...
              Nur... so ganz scheint es noch nicht zu gehen...
              2024-08-03 16:29:30.009 - debug: resol.0 (51347) fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
              2024-08-03 16:29:39.731 - debug: resol.0 (51347) loadedConfig [{"valueId":"Feger_Relaismodus3","valueIndex":2243,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
              2024-08-03 16:29:39.731 - debug: resol.0 (51347) dp->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
              2024-08-03 16:29:39.732 - debug: resol.0 (51347) dp->Name found{"dpName":"Oelheizung_Status","name":"Manual control for this relay.","type":"number","min":0,"max":2,"states":{"0":"Off","1":"Auto","2":"On"}}
              2024-08-03 16:29:39.732 - debug: resol.0 (51347) fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
              2024-08-03 16:29:39.732 - debug: resol.0 (51347) Finishing loadMyConfig...
              2024-08-03 16:29:39.743 - silly: resol.0 (51347) States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":null,"ack":true,"ts":1722695379740,"q":0,"from":"system.adapter.resol.0","user":"system.user.admin","lc":1722695379740}
              2024-08-03 16:29:43.924 - silly: resol.0 (51347) States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":0,"ack":false,"ts":1722695383921,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1722695383921}
              2024-08-03 16:29:43.925 - debug: resol.0 (51347) Change on Object: "resol.0.0078210010.Actions.Oelheizung_Status"
              2024-08-03 16:29:43.926 - debug: resol.0 (51347) State of Object: {"val":0,"ack":false,"ts":1722695383921,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1722695383921}
              2024-08-03 16:29:43.927 - debug: resol.0 (51347) State :0
              2024-08-03 16:29:43.927 - debug: resol.0 (51347) "getDpFunction jsoncontrollerSetupItems [object Object]"
              2024-08-03 16:29:43.928 - debug: resol.0 (51347) getDpFunction jsoncontrollerSetupItems->item {"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
              2024-08-03 16:29:43.928 - debug: resol.0 (51347) [{"valueId":"Feger_Relaismodus3","value":0}]
              2024-08-03 16:29:43.928 - debug: resol.0 (51347) Finishing Dpfunction...
              2024-08-03 16:29:43.929 - debug: resol.0 (51347) myJSON: [{"valueId":"Feger_Relaismodus3","value":0}]
              2024-08-03 16:29:43.929 - debug: resol.0 (51347) Waiting for free bus...
              2024-08-03 16:29:44.127 - debug: resol.0 (51347) Found master with address 0x7821
              2024-08-03 16:29:44.128 - debug: resol.0 (51347) Start Optimizer
              2024-08-03 16:29:56.690 - debug: resol.0 (51347) Save config [{"valueId":"Feger_Relaismodus3","value":0,"valueIndex":2243,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
              2024-08-03 16:29:56.691 - debug: resol.0 (51347) Finishing runshot ...
              deute ich die Zeile 20 richtig?
              Er schickt die 0 für den Feger_Relaismodus3 rüber, das scheint aber nicht an zu kommen?
              Ich fürchte so ganz sind die Regler nicht gleich und die ID "Feger_Relaismodus3" heißt dort vielleicht doch anders?
              Oder bin ich da noch auf dem komplett falschen Dampfer?
              Vielen Dank auf jedenfall schonmal für Deine Mühe!!!
              • Gargano
                @ckhx78 sagte in Supportthread Resol-Adapter:
                Kann sein, bei mir ist jedenfalls "transceived":true und bei Dir false. Was auf eine nicht ordnungsgemäße Übertragung hindeutet.
                Da gibt es aber auch noch "Relaismodus3" und andere (also ohne Feger) geht bis Relaismodus31 in der Datei. Evtl. ist Feger für den Schornsteinfeger gedacht ?
                Wie kommst Du auf den Feger_Relaismodus3 ?
                C 2 Replies Last reply Reply Quote 0
                  @gargano
                  das kann gut sein, ich werd da noch ein bisschen probieren und Berichten.
                  Auf Feger_Relaismodus drei war ich gekommen weil das so das erste war was ich entdeckt hatte was darauf schließen ließ das dort ein Relais manuell geschaltet wird... aber hast schon Recht, beim "Schornsteinfeger Modus" auf dem Regler gibst Du vor welche Relais wie geschaltet werden sollen wenn man auf "Schornsteinfeger" am Regler manuell stellt (in meinem Fall z.B. die Rücklaufanhebung aus, damit aus dem Puffer kein heißes Wasser mehr in den Ölkessel kommt wenn dieser der Brenner zur Messung manuell Eingeschaltet wird...
                  Ich meld mich!
                  Also lag ich mit meiner Vermutung der nicht Ordnungsgemäßen Übertragung gar nicht verkehrt 🙂
                  • Gargano
                    @ckhx78 Das Relais hat 4 Modi , da mußt Du dann noch in der Datei deltasol-e-v2.js anpassen
                                "type": {
                                    "valueTexts": [
                                            "value": 0,
                                            "id": "Aus"
                                            "value": 1,
                                            "id": "Auto"
                                            "value": 2,
                                            "id": "Min"
                                            "value": 3,
                                            "id": "Max"
                                    "rootTypeId": "Quadstate_Relais",
                                    "defaults": "1"
                                "valueTexts": [],
                                "id": "Relaismodus3",
                                "idHash": 618714395,
                                "index": 499,
                                "forceUse": true
                      @gargano
                      Ich guck mir das nochmal in der Beschreibung an, da sind eigentlich nur 7 Relaisausgänge auf dem Regler, das 7. ist als Wechsler ausgelegt, bei den ersten 6 sind nur ein paar (ich weiß nicht mehr genau welche / wieviel) die An / aus / oder via PWM einen Prozentwert dazwischen können... ich vergleich das mal mit den Modi's da müsst ich ja finden welcher der richtige für mich ist 🙂
                      Aber danke für den Hinweis!! 🙂
                      • Gargano
                        Gargano @Grizzelbee last edited by
                        @grizzelbee Hab gerade mit @ckhx78 ein Problem entdeckt in Zusammenhang mit Cosmo und evtl. auch gelöst. Die Rückmeldung steht noch aus. Issue #136 ist das gleiche Problem.
                        Ich habe zwar ein Issue für die 1.3 erstellt, bin aber kein Freund von statischen Hotfixes.
                        Wir können auch eine editierbare Surrogat-Tabelle (Datei oder im Setup) in der Version 1.4 machen, dann könnte man auch zukünftige baugleiche Regler verwenden. Was meinst Du ?
                        Wenn im Setup, dann eine editierbare Zeile , die die Surrogat-ID enthält. Leer , wenn es keine gibt.
                        Werner
                          @gargano said in Supportthread Resol-Adapter:
                                      "type": {
                                          "valueTexts": [
                                                  "value": 0,
                                                  "id": "Aus"
                                                  "value": 1,
                                                  "id": "Auto"
                                                  "value": 2,
                                                  "id": "Min"
                                                  "value": 3,
                                                  "id": "Max"
                                          "defaults": "1"
                                      "valueTexts": [],
                                      "index": 499,
                                      "forceUse": true
                          Ich hab die cosmo-multi-2.js angepasst, richtig?
                          Hab mir das mit den Relais nochmal durchgelesen, hätte durchaus sein können, der Regler kann nur 7, aber optional kann man noch mehrere Heizkreismodule über den V-bus als Slave dahinter schalten, dann passt das schon...
                          Nur... weiter bin ich leider noch nicht, das scheint auch noch nicht die gewünschte ID zu sein... 😞
                          resol.0
                          2024-08-03 19:11:43.255	debug	Finishing loadMyConfig...
                          resol.0
                          2024-08-03 19:11:43.254	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:43.254	debug	dp->Name found{"dpName":"Oelheizung_Status","name":"Manual control for this relay.","type":"number","min":0,"max":3,"states":{"0":"Off","1":"Auto","2":"Min","3":"Max"}}
                          resol.0
                          2024-08-03 19:11:43.254	debug	dp->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:43.253	debug	loadedConfig [{"valueId":"Relaismodus3","valueIndex":499,"priority":0,"valueTextById":{"Aus":0,"Auto":1,"Min":2,"Max":3},"pending":false,"transceived":false}]
                          resol.0
                          2024-08-03 19:11:32.282	debug	Finishing runshot ...
                          resol.0
                          2024-08-03 19:11:32.282	debug	Save config [{"valueId":"Relaismodus3","value":0,"valueIndex":499,"priority":0,"valueTextById":{"Aus":0,"Auto":1,"Min":2,"Max":3},"pending":false,"transceived":false}]
                          resol.0
                          2024-08-03 19:11:30.005	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:30.001	debug	received data: [{"id":"00_0010_7821_10_0100_000_2_0","name":"Temperatur Sensor 1","rawValue":52.300000000000004,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_002_2_0","name":"Temperatur Sensor 2","rawValue":51.900000000000006,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":2,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":3,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_004_2_0","name":"Temperatur Sensor 3","rawValue":30.1,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":4,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":5,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_006_2_0","name":"Temperatur Sensor 4","rawValue":62.900000000000006,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":6,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":7,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_008_2_0","name":"Temperatur Sensor 5","rawValue":50.2,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":8,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":9,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_010_2_0","name":"Temperatur Sensor 6","rawValue":48,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":10,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":11,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_012_2_0","name":"Temperatur Sensor 7","rawValue":72.2,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":12,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":13,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_014_2_0","name":"Temperatur Sensor 8","rawValue":53.6,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":14,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":15,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_016_2_0","name":"Temperatur Sensor 9","rawValue":71.60000000000001,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":16,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":17,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_018_2_0","name":"Temperatur Sensor 10","rawValue":29.5,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":18,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":19,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_020_2_0","name":"Einstrahlung CS","rawValue":41,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"WattsPerSquareMeter","unitText":" W/m²","typeId":"Number_1_WattsPerSquareMeter","precision":0,"rootTypeId":"Number","parts":[{"offset":20,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":21,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_022_2_0","name":"Impulse 1 V40","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":22,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":23,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_024_2_0","name":"Digital Input","rawValue":1,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":24,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":25,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_026_1_0","name":"Drehzahl Relais 1","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":26,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_027_1_0","name":"Drehzahl Relais 2","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":27,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_028_1_0","name":"Drehzahl Relais 3","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":28,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_029_1_0","name":"Drehzahl Relais 4","rawValue":100,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":29,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_030_1_0","name":"Drehzahl Relais 5","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":30,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_031_1_0","name":"Drehzahl Relais 6","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":31,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_032_1_0","name":"Drehzahl Relais 7","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"Percent","unitText":"%","typeId":"Number_1_Percent","precision":0,"rootTypeId":"Number","parts":[{"offset":32,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_036_2_0","name":"Fehlermaske","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":36,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":37,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_038_2_0","name":"Meldungen","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":38,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":39,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_040_1_0","name":"System","rawValue":1,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":40,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_042_2_0","name":"Schema","rawValue":346,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":42,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":43,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_044_2_0","name":"Vorlauf Soll HK1 Modul Sensor 18","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":44,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":45,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_046_2_0","name":"Status HK1 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":46,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":47,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_048_2_0","name":"Vorlauf Soll HK2 Modul Sensor 25","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":48,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":49,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_050_2_0","name":"Status HK2 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":50,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":51,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_052_2_0","name":"Vorlauf Soll HK3 Modul Sensor 32","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":52,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":53,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_054_2_0","name":"Status HK3 Modul","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":54,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":55,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_056_2_0","name":"Vorlauf Soll Heizkreis Sensor 11","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":56,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":57,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_058_2_0","name":"Status Heizkreis","rawValue":0,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":58,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":59,"mask":255,"bitPos":0,"isSigned":false,"factor":256}]},{"id":"00_0010_7821_10_0100_062_2_0","name":"Systemzeit","rawValue":8351,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Time_1_None","precision":0,"rootTypeId":"Time","parts":[{"offset":62,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":63,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_064_2_0","name":"Jahr","rawValue":2024,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":64,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":65,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7821_10_0100_066_1_0","name":"Monat","rawValue":8,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":66,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_067_1_0","name":"Tag","rawValue":3,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_1_None","precision":0,"rootTypeId":"Number","parts":[{"offset":67,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7821_10_0100_060_1_0","name":"Version","rawValue":1.03,"deviceName":"COSMO Multi [Regler]","deviceId":"0078210010","addressId":30753,"unitId":"None","unitText":"","typeId":"Number_0_01_None","precision":2,"rootTypeId":"Number","parts":[{"offset":60,"mask":255,"bitPos":0,"isSigned":true,"factor":100},{"offset":61,"mask":255,"bitPos":0,"isSigned":true,"factor":1}]},{"id":"00_0010_7822_10_0100_000_2_0","name":"Temperatur Vorlauf","rawValue":50.2,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":0,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":1,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_002_2_0","name":"Temperatur Rücklauf","rawValue":48,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"DegreesCelsius","unitText":" °C","typeId":"Number_0_1_DegreesCelsius","precision":1,"rootTypeId":"Number","parts":[{"offset":2,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":3,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_004_2_0","name":"Durchfluss Sensor 8","rawValue":0,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"LitersPerHour","unitText":" l/h","typeId":"Number_1_LitersPerHour","precision":0,"rootTypeId":"Number","parts":[{"offset":4,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":5,"mask":255,"bitPos":0,"isSigned":true,"factor":256}]},{"id":"00_0010_7822_10_0100_006_2_0","name":"Wärmemenge","rawValue":36684077,"deviceName":"COSMO Multi [WMZ]","deviceId":"0078220010","addressId":30754,"unitId":"WattHours","unitText":" Wh","typeId":"Number_1_WattHours","precision":0,"rootTypeId":"Number","parts":[{"offset":6,"mask":255,"bitPos":0,"isSigned":false,"factor":1},{"offset":7,"mask":255,"bitPos":0,"isSigned":false,"factor":256},{"offset":8,"mask":255,"bitPos":0,"isSigned":false,"factor":1000},{"offset":9,"mask":255,"bitPos":0,"isSigned":false,"factor":256000},{"offset":10,"mask":255,"bitPos":0,"isSigned":false,"factor":1000000},{"offset":11,"mask":255,"bitPos":0,"isSigned":false,"factor":256000000}]}]
                          resol.0
                          2024-08-03 19:11:20.136	debug	Start Optimizer
                          resol.0
                          2024-08-03 19:11:20.136	debug	Found master with address 0x7821
                          resol.0
                          2024-08-03 19:11:17.602	debug	Waiting for free bus...
                          resol.0
                          2024-08-03 19:11:17.601	debug	myJSON: [{"valueId":"Relaismodus3","value":0}]
                          resol.0
                          2024-08-03 19:11:17.601	debug	Finishing Dpfunction...
                          resol.0
                          2024-08-03 19:11:17.601	debug	[{"valueId":"Relaismodus3","value":0}]
                          resol.0
                          2024-08-03 19:11:17.601	debug	getDpFunction jsoncontrollerSetupItems->item {"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:17.600	debug	"getDpFunction jsoncontrollerSetupItems [object Object]"
                          resol.0
                          2024-08-03 19:11:17.599	debug	State :0
                          resol.0
                          2024-08-03 19:11:17.599	debug	State of Object: {"val":0,"ack":false,"ts":1722705077594,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1722705077594}
                          resol.0
                          2024-08-03 19:11:17.598	debug	Change on Object: "resol.0.0078210010.Actions.Oelheizung_Status"
                          resol.0
                          2024-08-03 19:11:17.597	silly	States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":0,"ack":false,"ts":1722705077594,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1722705077594}
                          resol.0
                          2024-08-03 19:11:09.693	silly	States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":null,"ack":true,"ts":1722705069690,"q":0,"from":"system.adapter.resol.0","user":"system.user.admin","lc":1722705069690}
                          resol.0
                          2024-08-03 19:11:09.683	debug	Finishing loadMyConfig...
                          resol.0
                          2024-08-03 19:11:09.683	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:09.682	debug	dp->Name found{"dpName":"Oelheizung_Status","name":"Manual control for this relay.","type":"number","min":0,"max":3,"states":{"0":"Off","1":"Auto","2":"Min","3":"Max"}}
                          resol.0
                          2024-08-03 19:11:09.682	debug	dp->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          resol.0
                          2024-08-03 19:11:09.681	debug	loadedConfig [{"valueId":"Relaismodus3","valueIndex":499,"priority":0,"valueTextById":{"Aus":0,"Auto":1,"Min":2,"Max":3},"pending":false,"transceived":false}]
                          resol.0
                          2024-08-03 19:11:00.008	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Relaismodus3","val":"val"}
                          Ich such noch ein bisschen 🙂
                            glaube inzwischen das der Feger_Relaismodus wohl der richtige ist. Auf der Steuerung im Keller heißt das "Handbetrieb" dort kann ich die Relais 1-7 auswählen und zwischen Ein, Auto und Aus wählen, das wäre genau der Punkt den ich benötige, da trifft in der resol-deltasol-e-v2-100-data.js eigentlich nur der Punkt zu.
                            zum Thema Übertragungsfehler...
                            Ich hab den Resol DL2 bei mir zur Kommunikation mit dem Vbus... kann ich da noch irgendwas falsch gemacht haben?
                            • Gargano
                              @ckhx78 Da gibt es wohl inzwischen 2 Typen von DL 2. Einen grünen, viereckigen (den habe ich) und einen grauen runden. Welchen hast Du?
                                ich hab den grauen runden
                                Hab mir grade aber irgendwas zerschossen und noch ein ganz anderes Problem eingebaut 😞
                                war wohl zuviel gebastel heute 🙂
                                • Gargano
                                  @ckhx78 nicht, dass der graue gar nicht zum Steuern geht. Der grüne geht auf jeden Fall. Ich verwende den um den Puffer rückzukühlen im Sommer.
                                    würd mich inzwischen auch nicht wundern...
                                    Bekomm grad gar nix an's laufen... bin unten am Regler alle Menüs mal durch... Feger_Relaismodus könnten natürlich auch genau die Einstellungen für den Schornsteinfegermodus sein 😞
                                    Dann würde aber quasi der Handbetrieb komplett fehlen 😕
                                    Ich muss da glaube nochmal ein paar Nächte drüber schlafen...
                                      ckhx78 @ckhx78 last edited by ckhx78
                                      @ckhx78
                                      Ich krieg gar nix mehr an's laufen...
                                      Was kommt denn da für ein Passwort rein?
                                      einen Vbus.net Zugang hab ich nicht... das Gerät sollte ohne Passwort erreichbar sein, hat aber eben auch einen reset auf Werkseinstellung erfahren, aber das Standard admin Passwort schluckt er auch nicht mehr
                                      Edit: Ok... das läuft schonmal wieder
                                      • Gargano
                                        @ckhx78
                                        Ich hab in den Einstellungen den VBus/Lan (Ich habe den günstigeren Lan Schnittstellen-Adapter ohne Datenlogger). Läuft bei mir aber auch mit KM/DL2
                                          @gargano
                                          Moin!
                                          Das macht kein Unterschied, egal was ich dort Einstelle, es ändert nichts...
                                          resol.0
                                          2024-08-05 20:27:41.027	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
                                          Was mich noch wundert, meist gibt es beim Start des Adapters noch folgende Meldungen... wenn man Ihn dann irgendwann nochmal neu startet, dann sind die meist weg:
                                          resol.0
                                          2024-08-05 20:28:48.411	error	[generateDP] Error: TypeError: Cannot read properties of undefined (reading 'setup')
                                          resol.0
                                          2024-08-05 20:28:48.410	warn	[getJSONByResolId] Controller type not found in setup file.
                                          resol.0
                                          2024-08-05 20:28:47.176	info	Connection established
                                          resol.0
                                          2024-08-05 20:28:47.144	info	Connection state changed to CONNECTING
                                          resol.0
                                          2024-08-05 20:28:47.144	info	Waiting for Connection...
                                          resol.0
                                          2024-08-05 20:28:47.143	info	TCP Connection to KM2/DL2 on [192.168.200.35:7053] selected
                                          resol.0
                                          2024-08-05 20:28:47.130	info	Config seems to be valid for KM2/DL2/DL3.
                                          resol.0
                                          2024-08-05 20:28:47.114	info	starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.resol, node: v18.20.4, js-controller: 6.0.9
                                          resol.0
                                          2024-08-05 20:28:27.119	info	terminating
                                          resol.0
                                          2024-08-05 20:28:26.624	info	Connection state changed to DISCONNECTED
                                          resol.0
                                          2024-08-05 20:28:26.616	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          resol.0
                                          2024-08-05 20:28:26.616	debug	Plugin sentry destroyed
                                          resol.0
                                          2024-08-05 20:28:26.615	info	terminating
                                          resol.0
                                          2024-08-05 20:28:26.614	info	Cleaned up everything...
                                          resol.0
                                          2024-08-05 20:28:26.614	info	Connection state changed to DISCONNECTING
                                          resol.0
                                          2024-08-05 20:28:26.612	info	Got terminate signal TERMINATE_YOURSELF
                                          resol.0
                                          2024-08-05 20:28:26.612	silly	States system redis pmessage system.adapter.resol.0.sigKill/system.adapter.resol.0.sigKill:{"val":-1,"ack":false,"ts":1722882506609,"q":0,"from":"system.host.ubuntu","lc":1722882506609}
                                          resol.0
                                          2024-08-05 20:28:12.019	silly	States user redis pmessage resol.0.0078210010.Actions.Oelheizung_Status/resol.0.0078210010.Actions.Oelheizung_Status:{"val":null,"ack":true,"ts":1722882492018,"q":0,"from":"system.adapter.resol.0","user":"system.user.admin","lc":1722882492018}
                                          resol.0
                                          2024-08-05 20:28:12.010	debug	Finishing loadMyConfig...
                                          resol.0
                                          2024-08-05 20:28:12.010	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
                                          resol.0
                                          2024-08-05 20:28:12.010	debug	dp->Name found{"dpName":"Oelheizung_Status","name":"Manual control for this relay.","type":"number","min":0,"max":2,"states":{"0":"Off","1":"Auto","2":"On"}}
                                          resol.0
                                          2024-08-05 20:28:12.009	debug	dp->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
                                          resol.0
                                          2024-08-05 20:28:12.009	debug	loadedConfig [{"valueId":"Feger_Relaismodus3","valueIndex":2243,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
                                          resol.0
                                          2024-08-05 20:28:00.016	debug	fct->item found{"name":"Oelheizung_Status","cmd":"Feger_Relaismodus3","val":"val"}
                                          • Gargano
                                            @ckhx78 Ich habe jetzt mal bei mir den Index in dem Data-File von meinem Controller geändert , so daß er den Index nicht kennt.
                                            Save config [{"valueId":"THolyCool","value":500,"valueIndex":9999,"priority":0,"valueTextById":{},"pending":false,"transceived":false}]
                                            Also das gleiche Verhalten wie bei Dir. Der Controller kennt den Index nicht.
                                            Hast Du mal etwas anderes probiert, außer die Relais ?
                                            Noch ein Idee :
                                            Hast Du mal den User Code im Cosmo auf Expert geändert ?
                                            18534
