    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      stoffel67 @Thomas Braun last edited by stoffel67
      auf ein neues...
      pi@raspberrypi:/opt/iobroker $ iob fix
      library: loaded
      Library version=2024-05-24
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Holen:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Es wurden 15,0 kB in 2 s geholt (6.669 B/s).
      Paketlisten werden gelesen… Fertig
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ iob list adapters
      system.adapter.admin                   : admin          - v7.0.22
      system.adapter.backitup                : backitup       - v2.11.0
      system.adapter.discovery               : discovery      - v4.5.0
      system.adapter.ds18b20                 : ds18b20        - v2.0.5
      system.adapter.enet                    : enet           - v1.0.1
      system.adapter.info                    : info           - v1.9.26
      system.adapter.javascript              : javascript     - v8.7.6
      system.adapter.linkeddevices           : linkeddevices  - v1.5.5
      system.adapter.modbus                  : modbus         - v6.1.0
      system.adapter.node-red                : node-red       - v5.2.1
      system.adapter.palazzetti              : palazzetti     - v0.0.6
      system.adapter.proxy                   : proxy          - v1.3.2
      system.adapter.rpi2                    : rpi2           - v1.3.2
      system.adapter.shelly                  : shelly         - v7.0.0
      system.adapter.simple-api              : simple-api     - v2.8.0
      system.adapter.slideshow               : slideshow      - v0.1.4
      system.adapter.smartmeter              : smartmeter     - v3.4.0
      system.adapter.socketio                : socketio       - v6.7.0
      system.adapter.sonoff                  : sonoff         - v3.0.3
      system.adapter.terminal                : terminal       - v0.2.2
      system.adapter.tr-064                  : tr-064         - v4.2.18
      system.adapter.vis                     : vis            - v1.5.6
      system.adapter.vw-connect              : vw-connect     - v0.0.67
      system.adapter.web                     : web            - v6.2.5
      system.adapter.withings                : withings       - v0.0.13
      system.adapter.ws                      : ws             - v2.6.1
      system.adapter.yahka                   : yahka          - v1.0.3
        Thomas Braun Most Active @stoffel67 last edited by
        @stoffel67
        Also ist sowohl ble wie auch radar2 nun weg.
        iob update
        iog upgrade all -y
        iob stop
        iob upgrade self
        iob start
          scheinbar nicht, obwohl ich die Adapter gelöscht habe
          in "iob list adpaters" sind sie weg
          bei "iob update" tauchen sie wieder auf
          pi@raspberrypi:/opt/iobroker $ iob update
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 7.0.22
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
          Adapter    "enet"         : 1.0.1    , installed 1.0.1
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "proxy"        : 1.3.2    , installed 1.3.2
          Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
          Adapter    "withings"     : 0.0.13   , installed 0.0.13
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          und nochmal von vorne...
          pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
          Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
          Update modbus from @6.1.0 to @6.2.3
          NPM version: 10.8.1
          Installing iobroker.modbus@6.2.3... (System call)
          changed 1 package in 35s
          153 packages are looking for funding
            run `npm fund` for details
          Update "system.adapter.modbus.0"
          upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
          upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
          upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
          upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
          upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
          upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
          upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
          upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
          upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
          upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
          pi@raspberrypi:/opt/iobroker $ iob stop
          pi@raspberrypi:/opt/iobroker $ iob upgrade self
          Update js-controller from @5.0.12 to @6.0.9
          Stopped Objects DB
          Stopped States DB
          NPM version: 10.8.1
          Installing iobroker.js-controller@6.0.9... (System call)
          added 7 packages, removed 45 packages, and changed 26 packages in 2m
          pi@raspberrypi:/opt/iobroker $ iob start
          ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
          javascript.0
          2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
          javascript.0
          2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
          javascript.0
          2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
          javascript.0
          2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
          javascript.0
          2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
          javascript.0
          2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
          javascript.0
          2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
          javascript.0
          2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
          javascript.0
          2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
          javascript.0
          2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
          javascript.0
          2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
          rpi2.0
          2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
            @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
            Das dürfte von einem zusätzlich im javascript-Adapter eingetragenen Modul kommen.
              ich glaube ich habs jetzt wieder "im Griff"...
              hab ein npm rebuild für i2c-bus gemacht... jetzt scheint dieser Fehler weg zu sein..
              nur noch etwas vom RPI2 adapter
              rpi2.0
              2024-08-03 17:53:04.517	error
              Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node /opt/iobroker/node_modules/epoll/out/Release/epoll.node  /opt/iobroker/node_modules/epoll/Release/epoll.node /opt/iobroker/node_modules/epoll/build/default/epoll.node /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
                Installier den mal in der Beta-Version 2.0. Der ist relativ umfangreich umgebaut worden.
                mcm1957 S 2 Replies Last reply Reply Quote 1
                • mcm1957
                  mcm1957 @Thomas Braun last edited by
                  Ja - ist unbedingt notwendig.
                  Falls es mit rpi2 Probleme gibt bitte ium diesbezüglichen Test Topic ansprechen.
                    stoffel67 @mcm1957 last edited by
                    @mcm1957 @Thomas-Braun
                    ja werde ich testen, heute nicht mehr
                    vielen Dank an euch für eure Hilfe… ist einfach super die Unterstützung hier…
                      so, habe mal die 2.0.0 installiert....läuft auch nicht ...
                      rpi2.0
                      2024-08-04 11:12:46.507	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
                      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                        Wie installiert? Denn das vermisste Modul 'opengpio' wird bei der sauberen Installation mitinstalliert:
                        echad@chet:/opt/iobroker $ npm ls opengpio
                        iobroker.inst@3.0.0 /opt/iobroker
                        └─┬ iobroker.rpi2@2.0.0
                          └── opengpio@1.1.0
                        • mcm1957
                          mcm1957 @stoffel67 last edited by
                          @stoffel67
                          rpi2 test thread:
                          https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
                          Dort liest / antwortet auch der Dev
                            pi@raspberrypi:~ $ cd /opt/iobroker/
                            pi@raspberrypi:/opt/iobroker $ npm ls opengpio
                              └── opengpio@1.1.0
                            4387
