    4. JAVA - Script Parse Error
      Seeandfeel last edited by Seeandfeel
      Ich habe einen Parse Error im Script (was aber ziemlich sicher schon funktioniert hatte), komme aber irgendwie nicht drauf 😞 .
      Kann mir ggf. jemand weiterhelfen?
      Fehler (bei jedem CRON Aufruf):
      javascript.0 2024-08-03 13:18:00.009	error	at process.processTimers (node:internal/timers:512:7)
      javascript.0 2024-08-03 13:18:00.009	error	at listOnTimeout (node:internal/timers:569:17)
      javascript.0 2024-08-03 13:18:00.009	error	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
      javascript.0 2024-08-03 13:18:00.009	error	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
      javascript.0 2024-08-03 13:18:00.009	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
      javascript.0 2024-08-03 13:18:00.008	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1769:34)
      javascript.0 2024-08-03 13:18:00.008	error	at Object.<anonymous> (script.js.Parse.Parse_Sauna_Neu:23:5)
      javascript.0 2024-08-03 13:18:00.008	error	Error in callback: ReferenceError: Request is not defined
      Script:
      const url = 'http://192.168.5.113/api';
      const idTemp1 = 'javascript.0.Sauna.Sauna';
      const idTemp2 = 'javascript.0.Sauna.Sauna_Raum';
      createState(idTemp1, 0, {
          desc: 'Temperatur in °C',
          type: 'string',
          role: 'value',
          unit: '°C'
      createState(idTemp2, 1, {
          type: 'string',
          role: 'value',
          unit: '°C'
      schedule('*/60 * * * * *', function() { //every minute
          Request(url, function(error, response, result) {
              let obj = JSON.parse(result);
              setState(idTemp1,  parseFloat(obj.sensors['0'].value), true);
              setState(idTemp2,  parseFloat(obj.sensors['1'].value), true);
      JSON von http://192.168.5.113/api :
        "systemname": "Sauna",
        "secure_counter": 236923,
        "firmware": "2.3.05-b",
        "sensors": [
            "name": "Sauna Temperature",
            "value": 22.3125,
            "mean-1": {
              "value": 21.80416679,
              "count": 60,
              "period": 3600
            "mean-24": {
              "value": 19.52482605,
              "count": 1440,
              "period": 86400
            "unit": "Celsius",
            "time": "Sat Aug  3 13:19:48 2024"
            "name": "Gebäude Temperatur",
            "value": 20.375,
            "unit": "Celsius",
      T paul53 2 Replies Last reply Reply Quote 0
        TT-Tom @Seeandfeel last edited by TT-Tom
        @seeandfeel
        Es handelt sich bei dir um das Request Problem. Request ist abgemeldet und sollte durch httpGet bzw httpPost ersetzt werden.
        Es gibt dazu schon viele Threads hier zu diesem Thema. Zum Beispiel hier Link Text
        Edit Link angepasst
          paul53 @Seeandfeel last edited by paul53
          @seeandfeel sagte: schon funktioniert hatte
          Das kann mit groß geschriebenem Request() noch nie funktioniert haben.
          Ändere Zeilen 22 und 23 in:
              httpGet(url, function(error, response) {
                  let obj = JSON.parse(response.data);
            Perfekt, Vielen Dank euch beiden, hätte ich wohl genauer suchen müssen das "request" deprecated ist.
            @paul53 :
            Du hast recht, das Request hatte noch nie funktioniert. Ich hatte das vor kurzem erst groß geschrieben weil ich die (vorherige) Fehlermeldung dahingehenden interpretiert hatte. Leider vergessen, Sorry 😞 !
            • haus-automatisierung
              haus-automatisierung Developer Most Active @Seeandfeel last edited by
              @seeandfeel sagte in JAVA - Script Parse Error:
              Normalerweise solltest Du vor dem Upgrade eine große Warnung bekommen haben, dass das der Fall ist. Und diese muss man manuell bestätigen.
              https://github.com/ioBroker/ioBroker.javascript/blob/d5772eaf30e865c4089b83c1198a86e2aac73774/io-package.json#L343-L383
              Es ist erforderlich, alle Skripte zu aktualisieren, die das "Request"-Paket verwenden! Dieses Paket wird in zukünftigen Versionen entfernt. Bitte nutze die neuen "Bockly"-Blöcke für "httpGet" oder nutze eine andere Bibliothek (wie axios) im JavaScript-Code.
