    4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
      stoffel67 @Thomas Braun last edited by stoffel67
      scheinbar nicht, obwohl ich die Adapter gelöscht habe
      in "iob list adpaters" sind sie weg
      bei "iob update" tauchen sie wieder auf
      pi@raspberrypi:/opt/iobroker $ iob update
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "enet"         : 1.0.1    , installed 1.0.1
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "withings"     : 0.0.13   , installed 0.0.13
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      und nochmal von vorne...
      pi@raspberrypi:/opt/iobroker $ iob upgrade all -y
      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
      Update modbus from @6.1.0 to @6.2.3
      NPM version: 10.8.1
      Installing iobroker.modbus@6.2.3... (System call)
      changed 1 package in 35s
      153 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.modbus.0"
      upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
      upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
      upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
      upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
      upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
      upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
      upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
      upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
      upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
      pi@raspberrypi:/opt/iobroker $ iob stop
      pi@raspberrypi:/opt/iobroker $ iob upgrade self
      Update js-controller from @5.0.12 to @6.0.9
      Stopped Objects DB
      Stopped States DB
      NPM version: 10.8.1
      Installing iobroker.js-controller@6.0.9... (System call)
      added 7 packages, removed 45 packages, and changed 26 packages in 2m
      pi@raspberrypi:/opt/iobroker $ iob start
      ich denke... Systemseitig ist fast alles wieder Ok... im Log kommt nach iob start noch folgendes:
      javascript.0
      2024-08-03 17:16:09.567	error	at Script.runInContext (node:vm:148:12)
      javascript.0
      2024-08-03 17:16:09.565	error	at script.js.common.sh1106:707:3
      javascript.0
      2024-08-03 17:16:09.563	error	at script.js.common.sh1106:5:18
      javascript.0
      2024-08-03 17:16:09.561	error	script.js.common.sh1106: TypeError: Cannot read properties of undefined (reading 'openSync')
      javascript.0
      2024-08-03 17:16:09.544	error	at Script.runInContext (node:vm:148:12)
      javascript.0
      2024-08-03 17:16:09.543	error	at script.js.common.sh1106:707:3
      javascript.0
      2024-08-03 17:16:09.541	error	at script.js.common.sh1106:4:11
      javascript.0
      2024-08-03 17:16:09.538	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:552:28)
      javascript.0
      2024-08-03 17:16:09.536	error	at require (node:internal/modules/helpers:179:18)
      javascript.0
      2024-08-03 17:16:09.534	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
      javascript.0
      2024-08-03 17:16:09.531	error	script.js.common.sh1106: Error: Cannot find module '@iobroker-javascript.0/i2c-bus'
      javascript.0
      2024-08-03 17:15:27.591	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`). at Object.Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Function.Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32)
      javascript.0
      2024-08-03 17:15:27.589	error	Error: The module '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 115. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
      javascript.0
      2024-08-03 17:15:27.583	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
      rpi2.0
      2024-08-03 17:12:24.679	error	Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: → /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node  /opt/iobroker/node_modules/epoll/out/Release/epoll.node /opt/iobroker/node_modules/epoll/Release/epoll.node  /opt/iobroker/node_modules/epoll/build/default/epoll.node  /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node  /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
        Thomas Braun Most Active @stoffel67 last edited by
        @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
        Das dürfte von einem zusätzlich im javascript-Adapter eingetragenen Modul kommen.
          ich glaube ich habs jetzt wieder "im Griff"...
          hab ein npm rebuild für i2c-bus gemacht... jetzt scheint dieser Fehler weg zu sein..
          nur noch etwas vom RPI2 adapter
          rpi2.0
          2024-08-03 17:53:04.517	error
          Cannot initialize/setMode GPIO: Error: Could not locate the bindings file. Tried: /opt/iobroker/node_modules/epoll/build/epoll.node /opt/iobroker/node_modules/epoll/build/Debug/epoll.node /opt/iobroker/node_modules/epoll/build/Release/epoll.node /opt/iobroker/node_modules/epoll/out/Debug/epoll.node /opt/iobroker/node_modules/epoll/Debug/epoll.node /opt/iobroker/node_modules/epoll/out/Release/epoll.node  /opt/iobroker/node_modules/epoll/Release/epoll.node /opt/iobroker/node_modules/epoll/build/default/epoll.node /opt/iobroker/node_modules/epoll/compiled/20.16.0/linux/arm/epoll.node /opt/iobroker/node_modules/epoll/addon-build/release/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/debug/install-root/epoll.node /opt/iobroker/node_modules/epoll/addon-build/default/install-root/epoll.node /opt/iobroker/node_modules/epoll/lib/binding/node-v115-linux-arm/epoll.node
            Installier den mal in der Beta-Version 2.0. Der ist relativ umfangreich umgebaut worden.
            mcm1957 S 2 Replies Last reply Reply Quote 1
            • mcm1957
              mcm1957 @Thomas Braun last edited by
              Ja - ist unbedingt notwendig.
              Falls es mit rpi2 Probleme gibt bitte ium diesbezüglichen Test Topic ansprechen.
                stoffel67 @mcm1957 last edited by
                @mcm1957 @Thomas-Braun
                ja werde ich testen, heute nicht mehr
                vielen Dank an euch für eure Hilfe… ist einfach super die Unterstützung hier…
                  so, habe mal die 2.0.0 installiert....läuft auch nicht ...
                  rpi2.0
                  2024-08-04 11:12:46.507	error	Cannot initialize/setMode GPIO: Error: Cannot find module 'opengpio' Require stack: - /opt/iobroker/node_modules/iobroker.rpi2/lib/gpioControl.js - /opt/iobroker/node_modules/iobroker.rpi2/main.js
                  Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                    Wie installiert? Denn das vermisste Modul 'opengpio' wird bei der sauberen Installation mitinstalliert:
                    echad@chet:/opt/iobroker $ npm ls opengpio
                    iobroker.inst@3.0.0 /opt/iobroker
                    └─┬ iobroker.rpi2@2.0.0
                      └── opengpio@1.1.0
                    • mcm1957
                      mcm1957 @stoffel67 last edited by
                      @stoffel67
                      rpi2 test thread:
                      https://forum.iobroker.net/topic/75290/test-adapter-rpi2-2-x
                      Dort liest / antwortet auch der Dev
                        pi@raspberrypi:~ $ cd /opt/iobroker/
                        pi@raspberrypi:/opt/iobroker $ npm ls opengpio
                          └── opengpio@1.1.0
                        4387
