    4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
      Homoran Global Moderator Administrators @Mathias2803 last edited by
      @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
      Ist damit alles abgedeckt?
      wenn du sonst nichts brauchst, ja.
      javascript ist eh bei iobroker mit drin.
        Mathias2803 @Thomas Braun last edited by
        pi@ioBroker:~ $ iob stop
        pi@ioBroker:~ $ iob fix
        library: loaded
        Library version=2024-05-24
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        You are running nodejs . Do you want to install latest version from nodejs v.18        tree?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        Waiting for ioBroker to shut down - Give me a minute...
        *** These repos are active on your system:
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://phoscon.de/apt/deconz buster InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
        Hit:5 https://twolife.be/raspbian buster InRelease
        Hit:6 https://archive.raspbian.org/raspbian buster InRelease
        Err:4 https://repos.influxdata.com/debian buster InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Err:5 https://twolife.be/raspbian buster InRelease
          The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
        Fetched 12.9 kB in 2s (6162 B/s)
        Reading package lists... Done
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://twolife.be/raspbian buster InRelease: The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
        W: Failed to fetch https://twolife.be/raspbian/dists/buster/InRelease  The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 https://archive.raspbian.org/raspbian buster InRelease
        Fetched 12.9 kB in 3s (5079 B/s)
        Installing nodejs now!
        /home/iobroker/.nodejs-update.sh: line 370: [: : integer expression expected
        Exact recommended version unknown, installing a fallback!
        dpkg: warning: downgrading nodejs from 20.16.0-1nodesource1 to 18.0.0-1nodesource1
        (Reading database ... 117932 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (18.0.0-1nodesource1) over (20.16.0-1nodesource1) ...
        Setting up nodejs (18.0.0-1nodesource1) ...
        Processing triggers for man-db (2.8.5-2+deb10u1) ...
        Updating fallback to latest nodejs v18 release
        (Reading database ... 118288 files and directories currently installed.)
        Preparing to unpack .../nodejs_18.20.4-1nodesource1_armhf.deb ...
        Unpacking nodejs (18.20.4-1nodesource1) over (18.0.0-1nodesource1) ...
        Setting up nodejs (18.20.4-1nodesource1) ...
        v18.20.4 has been installed! You are using the latest version now!
        /home/iobroker/.nodejs-update.sh: line 387: [: : integer expression expected
        Installing the nodejs!
        We tried our best to fix your nodejs. Please run iob diag again to verify.
        *** RESTARTING ioBroker NOW! ***
         Please refresh or restart your browser in a few moments.
          Mathias2803 @Homoran last edited by
          Was könnte ich denn noch gebrauchen??
          Also, was muss separat abgesichert werden?
            keine Ahnung.
            ich kenne deine Installation nicht.
              It looks much better now, but still not running:
              pi@ioBroker:~ $ iobroker info
              node:internal/modules/cjs/loader:1143
                throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                  at Module._load (node:internal/modules/cjs/loader:981:27)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                  at node:internal/main/run_main_module:28:49 {
                code: 'MODULE_NOT_FOUND',
                requireStack: []
              Node.js v18.20.4
                Thomas Braun Most Active @Mathias2803 last edited by
                Kommst du jetzt wieder auf den Admin drauf?
                  Habe neu gestartet, dann "iobroker start" und es hat recht lange geladen.
                  Leider aber gab es dann diese Fehlermeldung beim Info:
                    throw err;
                    requireStack: []
                  Node.js v18.20.4
                    @mathias2803
                    Dann hau den js-controller manuell rein:
                    iob stop
                    cd /opt/iobroker
                    npm install iobroker.js-controller@6.0.9
                    sudo reboot
                      @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                      pi@ioBroker:~ $ cd /opt/iobroker
                      pi@ioBroker:/opt/iobroker $ npm install iobroker.js-controller@6.0.9
                      npm warn deprecated har-validator@5.1.5: this library is no longer supported
                      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      added 563 packages in 4m
                      59 packages are looking for funding
                        run `npm fund` for details
                      mikeal created this issue in request/request
                      open Request’s Past, Present and Future #3142
                        Platform       : linux
                        os             : linux
                        Architecture   : arm
                        CPUs           : 4
                        Speed          : 1500 MHz
                        Model          : ARMv7 Processor rev 3 (v7l)
                        RAM            : 3.7 GB
                        System uptime  : 00:06:44
                        Node.js        : v18.20.4
                        time           : 1722847123885
                        timeOffset     : -120
                        NPM            : 10.7.0
                        adapters count : 539
                        Disk size      : 28.9 GiB
                        Disk free      : 10.9 GiB
                        pi@ioBroker:~ $ iobroker start
                         Connection is closed.
                        Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                            at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:492:23)
                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                         Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                         Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                        Was ist der nächste Schritt???
                          @mathias2803
                          iob status
                          sagt?
                            iob status
                            pi@ioBroker:~ $ iob status
                            Objects type: jsonl
                            States  type: jsonl
                              @mathias2803
                              Kommst du wieder auf die Webseite des Admin?
                              Und bitte die Langfassung von
                              iob diag
                              hier rein.
                                iob diag
                                Ja, komme wieder rein, aber es "funktioniert" nicht richtig nach meinem Gefühl.
                                Vis lädt z.B. nicht, Grafana hat keine aktuellen Daten, Telegram Nachricht wurde nach dem Start nicht verschickt,...
                                iob diag:
                                Skript v.2024-05-22
                                *** BASE SYSTEM ***
                                   Static hostname: ioBroker
                                         Icon name: computer
                                  Operating System: Raspbian GNU/Linux 10 (buster)
                                            Kernel: Linux 5.10.103-v7l+
                                      Architecture: arm
                                Model           : Raspberry Pi 4 Model B Rev 1.2
                                Docker          : false
                                Virtualization  : none
                                Kernel          : armv7l
                                Userland        : 32 bit
                                Systemuptime and Load:
                                 10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
                                CPU threads: 4
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                *** Time and Time Zones ***
                                               Local time: Mon 2024-08-05 10:47:35 CEST
                                           Universal time: Mon 2024-08-05 08:47:35 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                pi
                                HOME=/home/pi
                                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                *** Display-Server-Setup ***
                                Display-Server: true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:           3.8G        661M        2.1G        8.0M        1.0G        3.0G
                                Swap:           99M          0B         99M
                                Total:         3.9G        661M        2.2G
                                Active iob-Instances:   5
                                         3838 M total memory
                                          661 M used memory
                                          301 M active memory
                                         1275 M inactive memory
                                         2138 M free memory
                                           81 M buffer memory
                                          956 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                top - 10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
                                Tasks: 162 total,   2 running, 160 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 24.6 us,  2.9 sy,  0.0 ni, 72.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   3838.7 total,   2137.0 free,    662.7 used,   1039.1 buff/cache
                                MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3030.9 avail Mem
                                *** FAILED SERVICES ***
                                  UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                                * lightdm.service loaded failed failed Light Display Manager
                                LOAD   = Reflects whether the unit definition was properly loaded.
                                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                SUB    = The low-level unit activation state, values depend on unit type.
                                1 loaded units listed. Pass --all to see loaded but inactive units, too.
                                To show all installed unit files use 'systemctl list-unit-files'.
                                *** FILESYSTEM ***
                                Filesystem                  Type      Size  Used Avail Use% Mounted on
                                /dev/root                   ext4       29G   19G  9.7G  66% /
                                devtmpfs                    devtmpfs  1.8G     0  1.8G   0% /dev
                                tmpfs                       tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs                       tmpfs     1.9G  8.6M  1.9G   1% /run
                                tmpfs                       tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                                tmpfs                       tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                /dev/mmcblk0p1              vfat      253M   49M  204M  20% /boot
                                /dev/sda1                   ext4      117G   43G   68G  39% /mnt/mySSD
                                tmpfs                       tmpfs     384M     0  384M   0% /run/user/1000
                                //192.168.0.24/nas/ioBroker cifs      5.4T  2.8T  2.7T  51% /opt/iobroker/backups
                                [Mon Aug  5 10:32:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
                                [Mon Aug  5 10:32:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                [Mon Aug  5 10:32:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mon Aug  5 10:32:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                [Mon Aug  5 10:32:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                Show mounted filesystems:
                                TARGET                                SOURCE                      FSTYPE     OPTIONS
                                /                                     /dev/mmcblk0p2              ext4       rw,noatime
                                |-/dev                                devtmpfs                    devtmpfs   rw,relatime,size=1800568k,nr_inodes=84157,mode=755
                                | |-/dev/shm                          tmpfs                       tmpfs      rw,nosuid,nodev
                                | |-/dev/pts                          devpts                      devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                | `-/dev/mqueue                       mqueue                      mqueue     rw,relatime
                                |-/sys                                sysfs                       sysfs      rw,nosuid,nodev,noexec,relatime
                                | |-/sys/kernel/security              securityfs                  securityfs rw,nosuid,nodev,noexec,relatime
                                | |-/sys/fs/cgroup                    tmpfs                       tmpfs      ro,nosuid,nodev,noexec,mode=755
                                | | |-/sys/fs/cgroup/unified          cgroup2                     cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
                                | | |-/sys/fs/cgroup/systemd          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                                | | |-/sys/fs/cgroup/devices          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,devices
                                | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                                | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                                | | |-/sys/fs/cgroup/blkio            cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,blkio
                                | | |-/sys/fs/cgroup/cpuset           cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
                                | | |-/sys/fs/cgroup/freezer          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,freezer
                                | | |-/sys/fs/cgroup/pids             cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,pids
                                | | `-/sys/fs/cgroup/perf_event       cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
                                | |-/sys/fs/bpf                       none                        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                | |-/sys/kernel/debug                 debugfs                     debugfs    rw,relatime
                                | `-/sys/kernel/config                configfs                    configfs   rw,relatime
                                |-/proc                               proc                        proc       rw,relatime
                                | `-/proc/sys/fs/binfmt_misc          systemd-1                   autofs     rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                                |-/run                                tmpfs                       tmpfs      rw,nosuid,nodev,mode=755
                                | |-/run/lock                         tmpfs                       tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                                | |-/run/rpc_pipefs                   sunrpc                      rpc_pipefs rw,relatime
                                | `-/run/user/1000                    tmpfs                       tmpfs      rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
                                |-/boot                               /dev/mmcblk0p1              vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                |-/mnt/mySSD                          /dev/sda1                   ext4       rw,relatime,sync
                                `-/opt/iobroker/backups               //192.168.0.24/nas/ioBroker cifs       rw,relatime,vers=2.1,cache=strict,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.0.24,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1
                                /var:
                                1.8G    /var/
                                1.1G    /var/log
                                408M    /var/cache
                                395M    /var/cache/apt
                                333M    /var/cache/apt/archives
                                Archived and active journals take up 8.0M in the file system.
                                /opt/iobroker/backups:
                                14G     /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                640M    /opt/iobroker/iobroker-data/
                                426M    /opt/iobroker/iobroker-data/files
                                140M    /opt/iobroker/iobroker-data/backup-objects
                                89M     /opt/iobroker/iobroker-data/files/echarts.admin
                                57M     /opt/iobroker/iobroker-data/files/javascript.admin
                                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                34M     /opt/iobroker/iobroker-data/objects.jsonl
                                24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2409981-if00
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v18.20.4
                                /usr/bin/node           v18.20.4
                                /usr/bin/npm            10.7.0
                                /usr/bin/npx            10.7.0
                                /usr/bin/corepack       0.28.0
                                nodejs:
                                  Installed: 18.20.4-1nodesource1
                                  Candidate: 18.20.4-1nodesource1
                                  Version table:
                                 *** 18.20.4-1nodesource1 600
                                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                        100 /var/lib/dpkg/status
                                     18.20.3-1nodesource1 600
                                     18.20.2-1nodesource1 600
                                     18.20.1-1nodesource1 600
                                     18.20.0-1nodesource1 600
                                     18.19.1-1nodesource1 600
                                     18.19.0-1nodesource1 600
                                     18.18.2-1nodesource1 600
                                     18.18.1-1nodesource1 600
                                     18.18.0-1nodesource1 600
                                     18.17.1-1nodesource1 600
                                     18.17.0-1nodesource1 600
                                     18.16.1-1nodesource1 600
                                     18.16.0-1nodesource1 600
                                     18.15.0-1nodesource1 600
                                     18.14.2-1nodesource1 600
                                     18.14.1-1nodesource1 600
                                     18.14.0-1nodesource1 600
                                     18.13.0-1nodesource1 600
                                     18.12.0-1nodesource1 600
                                     18.11.0-1nodesource1 600
                                     18.10.0-1nodesource1 600
                                     18.9.1-1nodesource1 600
                                     18.9.0-1nodesource1 600
                                     18.8.0-1nodesource1 600
                                     18.7.0-1nodesource1 600
                                     18.6.0-1nodesource1 600
                                     18.5.0-1nodesource1 600
                                     18.4.0-1nodesource1 600
                                     18.3.0-1nodesource1 600
                                     18.2.0-1nodesource1 600
                                     18.1.0-1nodesource1 600
                                     18.0.0-1nodesource1 600
                                     10.24.0~dfsg-1~deb10u3 500
                                        500 https://archive.raspbian.org/raspbian buster/main armhf Packages
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller:  6.0.9
                                admin:          6.13.16
                                javascript:     "javascript" not found
                                nodejs modules from github:     4
                                | `-- node-botvac@0.4.2-schedule-write (git+ssh://git@github.com/PeterVoronov/node-botvac.git#04674af96bca09ac0db3f2f590209080474521fe)
                                +-- iobroker.husq-automower@1.1.0 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#2c07e136ae715bffdde7fc1ceca07a797579735b)
                                +-- iobroker.openuv@0.0.5 (git+ssh://git@github.com/x3l4c0d3/ioBroker.openuv.git#810f8d7ec1fb30af3cc77f8ee0aee709ae68dbc3)
                                | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
                                  system.adapter.botvac.0                 : botvac                : ioBroker                                 - disabled
                                  system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
                                  system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                  system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
                                  system.adapter.devices.0                : devices               : ioBroker                                 - disabled
                                  system.adapter.discord.0                : discord               : ioBroker                                 -  enabled
                                + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                                  system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                                  system.adapter.husq-automower.0         : husq-automower        : ioBroker                                 - disabled
                                  system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                  system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                  system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                                  system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                  system.adapter.lifx.0                   : lifx                  : ioBroker                                 - disabled
                                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
                                  system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                                  system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                                  system.adapter.openuv.0                 : openuv                : ioBroker                                 - disabled
                                  system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
                                  system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
                                  system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                  system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
                                  system.adapter.rtl_433.0                : rtl_433               : ioBroker                                 - disabled
                                  system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 45000, bind: 0.0.0.0
                                  system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
                                  system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
                                  system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                                  system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
                                  system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
                                  system.adapter.tr-064.2                 : tr-064                : ioBroker                                 - disabled
                                  system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                                  system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                  system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                                  system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                  system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 - disabled
                                  system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
                                + instance is alive
                                ioBroker-Repositories
                                │ (index) │   name   │                           url                           │ auto upgrade │
                                │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                Active repo(s): stable
                                Upgrade policy: none
                                Installed ioBroker-Instances
                                Used repository: stable
                                Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
                                Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
                                Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
                                Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                                Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
                                Controller "js-controller": 6.0.9    , installed 6.0.9
                                Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                                Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
                                Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
                                Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
                                Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                Objects and States
                                Objects:        20714
                                States:         17825
                                Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
                                Hit:4 https://phoscon.de/apt/deconz buster InRelease
                                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Hit:7 https://twolife.be/raspbian buster InRelease
                                Err:3 https://repos.influxdata.com/debian buster InRelease
                                Err:7 https://twolife.be/raspbian buster InRelease
                                Fetched 12.9 kB in 2s (5857 B/s)
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18039      465/deCONZ
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20122      829/sshd
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17284      447/cupsd
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        33014      2041/influxd
                                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17214      465/deCONZ
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26861      1547/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28924      1547/iobroker.js-co
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28191      1640/io.admin.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        32541      2041/influxd
                                tcp6       0      0 ::1:3350                :::*                    LISTEN      0          21758      834/xrdp-sesman
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          20124      829/sshd
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17283      447/cupsd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      115        20145      733/grafana-server
                                tcp6       0      0 :::3389                 :::*                    LISTEN      116        19048      854/xrdp
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18602      690/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15136      452/avahi-daemon: r
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17294      465/deCONZ
                                udp        0      0 0.0.0.0:44442           0.0.0.0:*                           108        15138      452/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15184      806/dhcpcd
                                udp6       0      0 :::57988                :::*                                108        15139      452/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        15137      452/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          16330      806/dhcpcd
                                2024-08-05 10:47:59.237  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Heizung.Solar-Temperatur, Alias=false, 32 points now activated
                                2024-08-05 10:47:59.238  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.UVC.ELECTRIC_POWER, Alias=false, 33 points now activated
                                2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.Filter.ELECTRIC_POWER, Alias=false, 34 points now activated
                                2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoorhumidity, Alias=false, 35 points now activated
                                2024-08-05 10:47:59.240  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoortemp, Alias=false, 36 points now activated
                                2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.pressureabs, Alias=false, 37 points now activated
                                2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.1.soilmoisture, Alias=false, 38 points now activated
                                2024-08-05 10:47:59.242  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.2.soilmoisture, Alias=false, 39 points now activated
                                2024-08-05 10:47:59.243  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Wasser-Temp-Test, Alias=false, 40 points now activated
                                2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of shelly.0.SHUNI-1#3494547AD6C8#1.ADC.Power, Alias=false, 41 points now activated
                                2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Wasserstand, Alias=false, 42 points now activated
                                2024-08-05 10:47:59.245  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Fuellstand, Alias=false, 43 points now activated
                                2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of Beregnung, Alias=true, 44 points now activated
                                2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilHumidity_value, Alias=false, 45 points now activated
                                2024-08-05 10:47:59.247  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilTemperature_value, Alias=false, 46 points now activated
                                2024-08-05 10:48:00.753  - info: host.ioBroker iobroker npm-install: NPM version: 10.7.0Installing iobroker.javascript@7.8.0... (System call)
                                2024-08-05 10:48:00.854  - info: influxdb.0 (4464) Do not store value "null" for Beregnung because no number
                                2024-08-05 10:48:21.385  - info: host.ioBroker iobroker npm-install:
                                2024-08-05 10:48:21.386  - info: host.ioBroker iobroker npm-install: added 17 packages in 21s184 packages are looking for funding  run `npm fund` for details
                                2024-08-05 10:48:43.558  - info: host.ioBroker iobroker npm-install: host.ioBroker install adapter javascript@7.8.0
                                2024-08-05 10:49:27.144  - info: host.ioBroker iobroker npm-install: upload [310] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                2024-08-05 10:49:27.446  - info: host.ioBroker iobroker npm-install: upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                                2024-08-05 10:49:27.852  - info: host.ioBroker iobroker npm-install: upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                                2024-08-05 10:49:30.586  - info: host.ioBroker iobroker npm-install: upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/666.f676e7ac.chunk.js.LICENSE.txt static/js/666.f676e7ac.chunk.js.LICENSE.txt text/plain
                                2024-08-05 10:49:46.127  - info: admin.0 (1640) <== Disconnect system.user.admin from ::ffff:192.168.1.87 javascript
                                iob diag has finished.
                                Homoran M Thomas Braun 3 Replies Last reply Reply Quote 0
                                  @mathias2803 läuft ja auch fast nichts!
                                  da muss ein + vor der Zeile sein
                                    Mathias2803 @Mathias2803 last edited by Mathias2803
                                    @Homoran
                                    Warum läuft das alles nicht?
                                    Soll ich bei Instanzen einfach alles jetzt starten? Funktioniert leider so nicht.
                                    Warum laufen die Instanzen nicht?
                                      @mathias2803
                                      Kiste weiter updaten.
                                      iob update
                                      iob upgrade all -y
                                      Dann zieh ein aktuelles Backup und zieh damit um.
                                      Neuinstallation wie hier:
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                      OHNE Desktop und sonstigem Quatsch und in der 64Bit-Version.
        v.2024-05-22
                                                 Icon name: computer
                                              Architecture: arm
                                        Installation:           native
                                        Kernel:                 armv7l
                                        Userland:               32 bit
                                        Timezone:               Europe/Berlin (CEST, +0200)
                                        User-ID:                1000
                                        Boot Target:            graphical.target
                                        Pending OS-Updates:     0
                                        Pending iob updates:    16
                                        Nodejs-Installation:
                                        /usr/bin/npm            10.7.0
                                        /usr/bin/npx            10.7.0
                                        Recommended versions are nodejs 18.20.4 and npm 10.7.0
                                        MEMORY:
                                        Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
                                        Swap:           99M          0B         99M
                                        Total:         3.9G        1.4G        792M
                                        Active iob-Instances:   10
                                        ioBroker Core:          js-controller           6.0.9
        admin                   6.13.16
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                20349
                                        States:                 17590
                                        Size of iob-Database:
                                        43M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/objects.json.migrated
                                        12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        0       /opt/iobroker/iobroker-data/objects.json.broken
                                        12M     /opt/iobroker/iobroker-data/states.jsonl
                                        4.0M    /opt/iobroker/iobroker-data/states.json.migrated
                                        4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          Das muss 0 werden.
                                          Homoran M 2 Replies Last reply Reply Quote 0
                                            @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                            Das muss 0 werden.
                                            @Mathias2803
                                            wie sieht denn die Seite "Adapter" im admin aus.
                                            gefiltert auf Adapter mit Update
                                            2762
