    4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
      Homoran Global Moderator Administrators @Mathias2803 last edited by
      @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
      Was könnte ich denn noch gebrauchen??
      Also, was muss separat abgesichert werden?
      keine Ahnung.
      ich kenne deine Installation nicht.
        Mathias2803 @Thomas Braun last edited by
        It looks much better now, but still not running:
        pi@ioBroker:~ $ iobroker info
        node:internal/modules/cjs/loader:1143
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
            at Module._load (node:internal/modules/cjs/loader:981:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            at node:internal/main/run_main_module:28:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.20.4
          Thomas Braun Most Active @Mathias2803 last edited by
          Please refresh or restart your browser in a few moments.
          Kommst du jetzt wieder auf den Admin drauf?
            Habe neu gestartet, dann "iobroker start" und es hat recht lange geladen.
            Leider aber gab es dann diese Fehlermeldung beim Info:
              throw err;
              requireStack: []
            Node.js v18.20.4
              @mathias2803
              Dann hau den js-controller manuell rein:
              iob stop
              cd /opt/iobroker
              npm install iobroker.js-controller@6.0.9
              sudo reboot
                @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                pi@ioBroker:~ $ iob stop
                pi@ioBroker:~ $ cd /opt/iobroker
                pi@ioBroker:/opt/iobroker $ npm install iobroker.js-controller@6.0.9
                npm warn deprecated har-validator@5.1.5: this library is no longer supported
                npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                added 563 packages in 4m
                59 packages are looking for funding
                  run `npm fund` for details
                mikeal created this issue in request/request
                open Request’s Past, Present and Future #3142
                  Platform       : linux
                  os             : linux
                  Architecture   : arm
                  CPUs           : 4
                  Speed          : 1500 MHz
                  Model          : ARMv7 Processor rev 3 (v7l)
                  RAM            : 3.7 GB
                  System uptime  : 00:06:44
                  Node.js        : v18.20.4
                  time           : 1722847123885
                  timeOffset     : -120
                  NPM            : 10.7.0
                  adapters count : 539
                  Disk size      : 28.9 GiB
                  Disk free      : 10.9 GiB
                  pi@ioBroker:~ $ iobroker start
                   Connection is closed.
                  Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                      at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:492:23)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                   Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                   Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                  Was ist der nächste Schritt???
                    @mathias2803
                    iob status
                    sagt?
                      iob status
                      pi@ioBroker:~ $ iob status
                      Objects type: jsonl
                      States  type: jsonl
                        @mathias2803
                        Kommst du wieder auf die Webseite des Admin?
                        Und bitte die Langfassung von
                        iob diag
                        hier rein.
                          iob diag
                          Ja, komme wieder rein, aber es "funktioniert" nicht richtig nach meinem Gefühl.
                          Vis lädt z.B. nicht, Grafana hat keine aktuellen Daten, Telegram Nachricht wurde nach dem Start nicht verschickt,...
                          iob diag:
                          Skript v.2024-05-22
                          *** BASE SYSTEM ***
                             Static hostname: ioBroker
                                   Icon name: computer
                            Operating System: Raspbian GNU/Linux 10 (buster)
                                      Kernel: Linux 5.10.103-v7l+
                                Architecture: arm
                          Model           : Raspberry Pi 4 Model B Rev 1.2
                          Docker          : false
                          Virtualization  : none
                          Kernel          : armv7l
                          Userland        : 32 bit
                          Systemuptime and Load:
                           10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Mon 2024-08-05 10:47:35 CEST
                                     Universal time: Mon 2024-08-05 08:47:35 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          pi
                          HOME=/home/pi
                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                          *** Display-Server-Setup ***
                          Display-Server: true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           3.8G        661M        2.1G        8.0M        1.0G        3.0G
                          Swap:           99M          0B         99M
                          Total:         3.9G        661M        2.2G
                          Active iob-Instances:   5
                                   3838 M total memory
                                    661 M used memory
                                    301 M active memory
                                   1275 M inactive memory
                                   2138 M free memory
                                     81 M buffer memory
                                    956 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          top - 10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
                          Tasks: 162 total,   2 running, 160 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 24.6 us,  2.9 sy,  0.0 ni, 72.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3838.7 total,   2137.0 free,    662.7 used,   1039.1 buff/cache
                          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3030.9 avail Mem
                          *** FAILED SERVICES ***
                            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                          * lightdm.service loaded failed failed Light Display Manager
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          1 loaded units listed. Pass --all to see loaded but inactive units, too.
                          To show all installed unit files use 'systemctl list-unit-files'.
                          *** FILESYSTEM ***
                          Filesystem                  Type      Size  Used Avail Use% Mounted on
                          /dev/root                   ext4       29G   19G  9.7G  66% /
                          devtmpfs                    devtmpfs  1.8G     0  1.8G   0% /dev
                          tmpfs                       tmpfs     1.9G     0  1.9G   0% /dev/shm
                          tmpfs                       tmpfs     1.9G  8.6M  1.9G   1% /run
                          tmpfs                       tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                          tmpfs                       tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                          /dev/mmcblk0p1              vfat      253M   49M  204M  20% /boot
                          /dev/sda1                   ext4      117G   43G   68G  39% /mnt/mySSD
                          tmpfs                       tmpfs     384M     0  384M   0% /run/user/1000
                          //192.168.0.24/nas/ioBroker cifs      5.4T  2.8T  2.7T  51% /opt/iobroker/backups
                          [Mon Aug  5 10:32:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
                          [Mon Aug  5 10:32:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                          [Mon Aug  5 10:32:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Mon Aug  5 10:32:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          [Mon Aug  5 10:32:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                          Show mounted filesystems:
                          TARGET                                SOURCE                      FSTYPE     OPTIONS
                          /                                     /dev/mmcblk0p2              ext4       rw,noatime
                          |-/dev                                devtmpfs                    devtmpfs   rw,relatime,size=1800568k,nr_inodes=84157,mode=755
                          | |-/dev/shm                          tmpfs                       tmpfs      rw,nosuid,nodev
                          | |-/dev/pts                          devpts                      devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                          | `-/dev/mqueue                       mqueue                      mqueue     rw,relatime
                          |-/sys                                sysfs                       sysfs      rw,nosuid,nodev,noexec,relatime
                          | |-/sys/kernel/security              securityfs                  securityfs rw,nosuid,nodev,noexec,relatime
                          | |-/sys/fs/cgroup                    tmpfs                       tmpfs      ro,nosuid,nodev,noexec,mode=755
                          | | |-/sys/fs/cgroup/unified          cgroup2                     cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
                          | | |-/sys/fs/cgroup/systemd          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
                          | | |-/sys/fs/cgroup/devices          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,devices
                          | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
                          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
                          | | |-/sys/fs/cgroup/blkio            cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,blkio
                          | | |-/sys/fs/cgroup/cpuset           cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
                          | | |-/sys/fs/cgroup/freezer          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,freezer
                          | | |-/sys/fs/cgroup/pids             cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,pids
                          | | `-/sys/fs/cgroup/perf_event       cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
                          | |-/sys/fs/bpf                       none                        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                          | |-/sys/kernel/debug                 debugfs                     debugfs    rw,relatime
                          | `-/sys/kernel/config                configfs                    configfs   rw,relatime
                          |-/proc                               proc                        proc       rw,relatime
                          | `-/proc/sys/fs/binfmt_misc          systemd-1                   autofs     rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                          |-/run                                tmpfs                       tmpfs      rw,nosuid,nodev,mode=755
                          | |-/run/lock                         tmpfs                       tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                          | |-/run/rpc_pipefs                   sunrpc                      rpc_pipefs rw,relatime
                          | `-/run/user/1000                    tmpfs                       tmpfs      rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
                          |-/boot                               /dev/mmcblk0p1              vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          |-/mnt/mySSD                          /dev/sda1                   ext4       rw,relatime,sync
                          `-/opt/iobroker/backups               //192.168.0.24/nas/ioBroker cifs       rw,relatime,vers=2.1,cache=strict,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.0.24,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1
                          /var:
                          1.8G    /var/
                          1.1G    /var/log
                          408M    /var/cache
                          395M    /var/cache/apt
                          333M    /var/cache/apt/archives
                          Archived and active journals take up 8.0M in the file system.
                          /opt/iobroker/backups:
                          14G     /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          640M    /opt/iobroker/iobroker-data/
                          426M    /opt/iobroker/iobroker-data/files
                          140M    /opt/iobroker/iobroker-data/backup-objects
                          89M     /opt/iobroker/iobroker-data/files/echarts.admin
                          57M     /opt/iobroker/iobroker-data/files/javascript.admin
                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          34M     /opt/iobroker/iobroker-data/objects.jsonl
                          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                          USB-Devices by-id:
                          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2409981-if00
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.20.4
                          /usr/bin/node           v18.20.4
                          /usr/bin/npm            10.7.0
                          /usr/bin/npx            10.7.0
                          /usr/bin/corepack       0.28.0
                          nodejs:
                            Installed: 18.20.4-1nodesource1
                            Candidate: 18.20.4-1nodesource1
                            Version table:
                           *** 18.20.4-1nodesource1 600
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                  100 /var/lib/dpkg/status
                               18.20.3-1nodesource1 600
                               18.20.2-1nodesource1 600
                               18.20.1-1nodesource1 600
                               18.20.0-1nodesource1 600
                               18.19.1-1nodesource1 600
                               18.19.0-1nodesource1 600
                               18.18.2-1nodesource1 600
                               18.18.1-1nodesource1 600
                               18.18.0-1nodesource1 600
                               18.17.1-1nodesource1 600
                               18.17.0-1nodesource1 600
                               18.16.1-1nodesource1 600
                               18.16.0-1nodesource1 600
                               18.15.0-1nodesource1 600
                               18.14.2-1nodesource1 600
                               18.14.1-1nodesource1 600
                               18.14.0-1nodesource1 600
                               18.13.0-1nodesource1 600
                               18.12.0-1nodesource1 600
                               18.11.0-1nodesource1 600
                               18.10.0-1nodesource1 600
                               18.9.1-1nodesource1 600
                               18.9.0-1nodesource1 600
                               18.8.0-1nodesource1 600
                               18.7.0-1nodesource1 600
                               18.6.0-1nodesource1 600
                               18.5.0-1nodesource1 600
                               18.4.0-1nodesource1 600
                               18.3.0-1nodesource1 600
                               18.2.0-1nodesource1 600
                               18.1.0-1nodesource1 600
                               18.0.0-1nodesource1 600
                               10.24.0~dfsg-1~deb10u3 500
                                  500 https://archive.raspbian.org/raspbian buster/main armhf Packages
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  6.0.9
                          admin:          6.13.16
                          javascript:     "javascript" not found
                          nodejs modules from github:     4
                          | `-- node-botvac@0.4.2-schedule-write (git+ssh://git@github.com/PeterVoronov/node-botvac.git#04674af96bca09ac0db3f2f590209080474521fe)
                          +-- iobroker.husq-automower@1.1.0 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#2c07e136ae715bffdde7fc1ceca07a797579735b)
                          +-- iobroker.openuv@0.0.5 (git+ssh://git@github.com/x3l4c0d3/ioBroker.openuv.git#810f8d7ec1fb30af3cc77f8ee0aee709ae68dbc3)
                          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                          + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
                            system.adapter.botvac.0                 : botvac                : ioBroker                                 - disabled
                            system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
                            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                            system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
                            system.adapter.devices.0                : devices               : ioBroker                                 - disabled
                            system.adapter.discord.0                : discord               : ioBroker                                 -  enabled
                          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                            system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
                            system.adapter.husq-automower.0         : husq-automower        : ioBroker                                 - disabled
                            system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                            system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                            system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                            system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                            system.adapter.lifx.0                   : lifx                  : ioBroker                                 - disabled
                            system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
                            system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                            system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                            system.adapter.openuv.0                 : openuv                : ioBroker                                 - disabled
                            system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
                            system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
                            system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                            system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
                            system.adapter.rtl_433.0                : rtl_433               : ioBroker                                 - disabled
                            system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 45000, bind: 0.0.0.0
                            system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
                            system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                            system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
                            system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                            system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
                            system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
                            system.adapter.tr-064.2                 : tr-064                : ioBroker                                 - disabled
                            system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                            system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                            system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                            system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                            system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 - disabled
                            system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
                          + instance is alive
                          ioBroker-Repositories
                          │ (index) │   name   │                           url                           │ auto upgrade │
                          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                          Active repo(s): stable
                          Upgrade policy: none
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
                          Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
                          Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
                          Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                          Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
                          Controller "js-controller": 6.0.9    , installed 6.0.9
                          Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                          Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
                          Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
                          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
                          Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                          Objects and States
                          Objects:        20714
                          States:         17825
                          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://twolife.be/raspbian buster InRelease: The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                          W: Failed to fetch https://twolife.be/raspbian/dists/buster/InRelease  The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                          W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                          W: Some index files failed to download. They have been ignored, or old ones used instead.
                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
                          Hit:4 https://phoscon.de/apt/deconz buster InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Hit:6 https://archive.raspbian.org/raspbian buster InRelease
                          Hit:7 https://twolife.be/raspbian buster InRelease
                          Err:3 https://repos.influxdata.com/debian buster InRelease
                          Err:7 https://twolife.be/raspbian buster InRelease
                          Fetched 12.9 kB in 2s (5857 B/s)
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18039      465/deCONZ
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20122      829/sshd
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17284      447/cupsd
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        33014      2041/influxd
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17214      465/deCONZ
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26861      1547/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28924      1547/iobroker.js-co
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28191      1640/io.admin.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        32541      2041/influxd
                          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          21758      834/xrdp-sesman
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          20124      829/sshd
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17283      447/cupsd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      115        20145      733/grafana-server
                          tcp6       0      0 :::3389                 :::*                    LISTEN      116        19048      854/xrdp
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18602      690/cups-browsed
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15136      452/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17294      465/deCONZ
                          udp        0      0 0.0.0.0:44442           0.0.0.0:*                           108        15138      452/avahi-daemon: r
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15184      806/dhcpcd
                          udp6       0      0 :::57988                :::*                                108        15139      452/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        15137      452/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          16330      806/dhcpcd
                          2024-08-05 10:47:59.237  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Heizung.Solar-Temperatur, Alias=false, 32 points now activated
                          2024-08-05 10:47:59.238  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.UVC.ELECTRIC_POWER, Alias=false, 33 points now activated
                          2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.Filter.ELECTRIC_POWER, Alias=false, 34 points now activated
                          2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoorhumidity, Alias=false, 35 points now activated
                          2024-08-05 10:47:59.240  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoortemp, Alias=false, 36 points now activated
                          2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.pressureabs, Alias=false, 37 points now activated
                          2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.1.soilmoisture, Alias=false, 38 points now activated
                          2024-08-05 10:47:59.242  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.2.soilmoisture, Alias=false, 39 points now activated
                          2024-08-05 10:47:59.243  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Wasser-Temp-Test, Alias=false, 40 points now activated
                          2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of shelly.0.SHUNI-1#3494547AD6C8#1.ADC.Power, Alias=false, 41 points now activated
                          2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Wasserstand, Alias=false, 42 points now activated
                          2024-08-05 10:47:59.245  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Fuellstand, Alias=false, 43 points now activated
                          2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of Beregnung, Alias=true, 44 points now activated
                          2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilHumidity_value, Alias=false, 45 points now activated
                          2024-08-05 10:47:59.247  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilTemperature_value, Alias=false, 46 points now activated
                          2024-08-05 10:48:00.753  - info: host.ioBroker iobroker npm-install: NPM version: 10.7.0Installing iobroker.javascript@7.8.0... (System call)
                          2024-08-05 10:48:00.854  - info: influxdb.0 (4464) Do not store value "null" for Beregnung because no number
                          2024-08-05 10:48:21.385  - info: host.ioBroker iobroker npm-install:
                          2024-08-05 10:48:21.386  - info: host.ioBroker iobroker npm-install: added 17 packages in 21s184 packages are looking for funding  run `npm fund` for details
                          2024-08-05 10:48:43.558  - info: host.ioBroker iobroker npm-install: host.ioBroker install adapter javascript@7.8.0
                          2024-08-05 10:49:27.144  - info: host.ioBroker iobroker npm-install: upload [310] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                          2024-08-05 10:49:27.446  - info: host.ioBroker iobroker npm-install: upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                          2024-08-05 10:49:27.852  - info: host.ioBroker iobroker npm-install: upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
                          2024-08-05 10:49:30.586  - info: host.ioBroker iobroker npm-install: upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/666.f676e7ac.chunk.js.LICENSE.txt static/js/666.f676e7ac.chunk.js.LICENSE.txt text/plain
                          2024-08-05 10:49:46.127  - info: admin.0 (1640) <== Disconnect system.user.admin from ::ffff:192.168.1.87 javascript
                          iob diag has finished.
                          Homoran M Thomas Braun 3 Replies Last reply Reply Quote 0
                            @mathias2803 läuft ja auch fast nichts!
                            da muss ein + vor der Zeile sein
                              Mathias2803 @Mathias2803 last edited by Mathias2803
                              @Homoran
                              Warum läuft das alles nicht?
                              Soll ich bei Instanzen einfach alles jetzt starten? Funktioniert leider so nicht.
                              Warum laufen die Instanzen nicht?
                                @mathias2803
                                Kiste weiter updaten.
                                iob update
                                iob upgrade all -y
                                Dann zieh ein aktuelles Backup und zieh damit um.
                                Neuinstallation wie hier:
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                OHNE Desktop und sonstigem Quatsch und in der 64Bit-Version.
                                                          v.2024-05-22
                                           Icon name: computer
                                        Architecture: arm
                                  Installation:           native
                                  Kernel:                 armv7l
                                  Userland:               32 bit
                                  Timezone:               Europe/Berlin (CEST, +0200)
                                  User-ID:                1000
                                  Boot Target:            graphical.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    16
                                  Nodejs-Installation:
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  Recommended versions are nodejs 18.20.4 and npm 10.7.0
                                  MEMORY:
                                  Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
                                  Swap:           99M          0B         99M
                                  Total:         3.9G        1.4G        792M
                                  Active iob-Instances:   10
                                  ioBroker Core:          js-controller           6.0.9
                                                          admin                   6.13.16
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                20349
                                  States:                 17590
                                  Size of iob-Database:
                                  43M     /opt/iobroker/iobroker-data/objects.jsonl
                                  12M     /opt/iobroker/iobroker-data/objects.json.migrated
                                  12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  0       /opt/iobroker/iobroker-data/objects.json.broken
                                  12M     /opt/iobroker/iobroker-data/states.jsonl
                                  4.0M    /opt/iobroker/iobroker-data/states.json.migrated
                                  4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Das muss 0 werden.
                                    Homoran M 2 Replies Last reply Reply Quote 0
                                      @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                      Das muss 0 werden.
                                      @Mathias2803
                                      wie sieht denn die Seite "Adapter" im admin aus.
                                      gefiltert auf Adapter mit Update
                                        pi@ioBroker:~ $ iob update
                                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                                        Adapter    "chromecast"   : 3.4.0    , installed 3.2.0  [Updatable]
                                        Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
                                        Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                                        Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                                        Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                        Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
                                        pi@ioBroker:~ $ iob upgrade all -y
                                        Update vis-jqui-mfd from @1.0.12 to @1.1.1
                                        NPM version: 10.7.0
                                        Installing iobroker.vis-jqui-mfd@1.1.1... (System call)
                                        changed 1 package in 17s
                                        231 packages are looking for funding
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                        Adapter "system.adapter.vis.0" restarted.
                                        Update "system.adapter.vis-jqui-mfd.0"
                                        upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                        Update vis-hqwidgets from @1.4.0 to @1.5.1
                                        NPM version: 10.7.0
                                        Installing iobroker.vis-hqwidgets@1.5.1... (System call)
                                        changed 1 package in 15s
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                        Update "system.adapter.vis-hqwidgets.0"
                                        upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                        upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                        Update simple-api from @2.7.2 to @2.8.0
                                        host.ioBroker Adapter "system.adapter.simple-api.0" is stopped.
                                        NPM version: 10.7.0
                                        Installing iobroker.simple-api@2.8.0... (System call)
                                        added 55 packages, removed 167 packages, and changed 2 packages in 1m
                                        237 packages are looking for funding
                                        Update "system.adapter.simple-api.0"
                                        upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                                        upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                                        upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                                        upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                                        host.ioBroker Adapter "system.adapter.simple-api.0" is started
                                        Update discovery from @4.4.0 to @4.5.0
                                        NPM version: 10.7.0
                                        Installing iobroker.discovery@4.5.0... (System call)
                                        changed 2 packages in 16s
                                        Update "system.adapter.discovery.0"
                                        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                        upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                        upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                        upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                        Update daswetter from @3.1.13 to @3.1.15
                                        host.ioBroker Adapter "system.adapter.daswetter.0" is stopped.
                                        NPM version: 10.7.0
                                        Installing iobroker.daswetter@3.1.15... (System call)
                                        removed 3 packages, and changed 2 packages in 18s
                                        Update "system.adapter.daswetter.0"
                                        upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                                        upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image/png
                                        upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
                                        upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
                                        upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
                                        upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
                                        upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
                                        upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
                                        upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
                                        upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
                                        upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
                                        upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
                                        upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
                                        upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
                                        upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
                                        upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
                                        upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
                                        upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
                                        upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
                                        upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
                                        upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
                                        upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
                                        upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
                                        upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
                                        upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
                                        upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
                                        upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
                                        upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
                                        upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
                                        upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
                                        upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
                                        upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
                                        upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
                                        upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
                                        upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
                                        upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
                                        host.ioBroker Adapter "system.adapter.daswetter.0" is started
                                        Update alexa2 from @3.26.4 to @3.26.5
                                        NPM version: 10.7.0
                                        Installing iobroker.alexa2@3.26.5... (System call)
                                        changed 7 packages in 33s
                                        239 packages are looking for funding
                                        Update "system.adapter.alexa2.0"
                                        upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                                        upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                                        upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                                        upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                                        upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                                        upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                                        upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                                        upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                                        upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                                        upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                                        upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                                        upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                                        upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                                        upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                                        upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                                        upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                                        upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                                        upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                                        upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                                        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                                        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                                        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                                        Update admin from @6.13.16 to @7.0.22
                                        host.ioBroker Adapter "system.adapter.admin.0" is stopped.
                                        NPM version: 10.7.0
                                        Installing iobroker.admin@7.0.22... (System call)
                                        added 26 packages, removed 8 packages, and changed 21 packages in 2m
                                        245 packages are looking for funding
                                        host.ioBroker Cannot install iobroker.admin@7.0.22: 0
                                          Danach kommt nix mehr?
                                          Sind die Updates der anderen Adapter nun drin?
                                          iob update
                                          nochmal anschauen.
                                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                            Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                            Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                                            Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                            Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                            Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                                            Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                                            Wohl leider nicht.
                                            Habe auch neu starten müssen. Der IoBroker lief dann nicht mehr richtig. im Browser.
                                            2762
