    4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
      Mathias2803 @Thomas Braun last edited by
      @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
      iob diag
      Ja, komme wieder rein, aber es "funktioniert" nicht richtig nach meinem Gefühl.
      Vis lädt z.B. nicht, Grafana hat keine aktuellen Daten, Telegram Nachricht wurde nach dem Start nicht verschickt,...
      iob diag:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-08-05 10:47:35 CEST
                 Universal time: Mon 2024-08-05 08:47:35 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        661M        2.1G        8.0M        1.0G        3.0G
      Swap:           99M          0B         99M
      Total:         3.9G        661M        2.2G
      Active iob-Instances:   5
               3838 M total memory
                661 M used memory
                301 M active memory
               1275 M inactive memory
               2138 M free memory
                 81 M buffer memory
                956 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 10:47:35 up 15 min,  2 users,  load average: 1.66, 2.56, 2.12
      Tasks: 162 total,   2 running, 160 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 24.6 us,  2.9 sy,  0.0 ni, 72.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3838.7 total,   2137.0 free,    662.7 used,   1039.1 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3030.9 avail Mem
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      Filesystem                  Type      Size  Used Avail Use% Mounted on
      /dev/root                   ext4       29G   19G  9.7G  66% /
      devtmpfs                    devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs                       tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs                       tmpfs     1.9G  8.6M  1.9G   1% /run
      tmpfs                       tmpfs     5.0M  4.0K  5.0M   1% /run/lock
      tmpfs                       tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1              vfat      253M   49M  204M  20% /boot
      /dev/sda1                   ext4      117G   43G   68G  39% /mnt/mySSD
      tmpfs                       tmpfs     384M     0  384M   0% /run/user/1000
      //192.168.0.24/nas/ioBroker cifs      5.4T  2.8T  2.7T  51% /opt/iobroker/backups
      [Mon Aug  5 10:32:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:F2:36 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f0881a94-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles ip=192.168.1.95::192.168.0.1:255.255.128.0:ioBroker:eth0:off
      [Mon Aug  5 10:32:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Aug  5 10:32:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Aug  5 10:32:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [Mon Aug  5 10:32:10 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE                      FSTYPE     OPTIONS
      /                                     /dev/mmcblk0p2              ext4       rw,noatime
      |-/dev                                devtmpfs                    devtmpfs   rw,relatime,size=1800568k,nr_inodes=84157,mode=755
      | |-/dev/shm                          tmpfs                       tmpfs      rw,nosuid,nodev
      | |-/dev/pts                          devpts                      devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue                      mqueue     rw,relatime
      |-/sys                                sysfs                       sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs                  securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs                       tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2                     cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/devices          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/blkio            cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/cpuset           cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | | |-/sys/fs/cgroup/freezer          cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/pids             cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | | `-/sys/fs/cgroup/perf_event       cgroup                      cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | |-/sys/fs/bpf                       none                        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs                     debugfs    rw,relatime
      | `-/sys/kernel/config                configfs                    configfs   rw,relatime
      |-/proc                               proc                        proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1                   autofs     rw,relatime,fd=32,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/run                                tmpfs                       tmpfs      rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs                       tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc                      rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs                       tmpfs      rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
      |-/boot                               /dev/mmcblk0p1              vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/mnt/mySSD                          /dev/sda1                   ext4       rw,relatime,sync
      `-/opt/iobroker/backups               //192.168.0.24/nas/ioBroker cifs       rw,relatime,vers=2.1,cache=strict,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.0.24,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      1.8G    /var/
      1.1G    /var/log
      408M    /var/cache
      395M    /var/cache/apt
      333M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      14G     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      640M    /opt/iobroker/iobroker-data/
      426M    /opt/iobroker/iobroker-data/files
      140M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2409981-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 600
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.20.3-1nodesource1 600
           18.20.2-1nodesource1 600
           18.20.1-1nodesource1 600
           18.20.0-1nodesource1 600
           18.19.1-1nodesource1 600
           18.19.0-1nodesource1 600
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           10.24.0~dfsg-1~deb10u3 500
              500 https://archive.raspbian.org/raspbian buster/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          6.13.16
      javascript:     "javascript" not found
      nodejs modules from github:     4
      | `-- node-botvac@0.4.2-schedule-write (git+ssh://git@github.com/PeterVoronov/node-botvac.git#04674af96bca09ac0db3f2f590209080474521fe)
      +-- iobroker.husq-automower@1.1.0 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#2c07e136ae715bffdde7fc1ceca07a797579735b)
      +-- iobroker.openuv@0.0.5 (git+ssh://git@github.com/x3l4c0d3/ioBroker.openuv.git#810f8d7ec1fb30af3cc77f8ee0aee709ae68dbc3)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.backitup.1               : backitup              : ioBroker                                 -  enabled
        system.adapter.botvac.0                 : botvac                : ioBroker                                 - disabled
        system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
        system.adapter.deconz.0                 : deconz                : ioBroker                                 -  enabled, port: 80
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
        system.adapter.discord.0                : discord               : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        system.adapter.husq-automower.0         : husq-automower        : ioBroker                                 - disabled
        system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
        system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.lifx.0                   : lifx                  : ioBroker                                 - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
        system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.openuv.0                 : openuv                : ioBroker                                 - disabled
        system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 - disabled
        system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
        system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        system.adapter.rpi2.0                   : rpi2                  : ioBroker                                 -  enabled
        system.adapter.rtl_433.0                : rtl_433               : ioBroker                                 - disabled
        system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 45000, bind: 0.0.0.0
        system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
        system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
        system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
        system.adapter.tr-064.2                 : tr-064                : ioBroker                                 - disabled
        system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 - disabled
        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
      Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
      Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
      Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "lifx"         : 1.0.4    , installed 1.0.4
      Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
      Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Objects and States
      Objects:        20714
      States:         17825
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://twolife.be/raspbian buster InRelease: The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
      W: Failed to fetch https://twolife.be/raspbian/dists/buster/InRelease  The following signatures were invalid: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
      Hit:4 https://phoscon.de/apt/deconz buster InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 https://archive.raspbian.org/raspbian buster InRelease
      Hit:7 https://twolife.be/raspbian buster InRelease
      Err:3 https://repos.influxdata.com/debian buster InRelease
      Err:7 https://twolife.be/raspbian buster InRelease
      Fetched 12.9 kB in 2s (5857 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18039      465/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20122      829/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17284      447/cupsd
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        33014      2041/influxd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       17214      465/deCONZ
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       26861      1547/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28924      1547/iobroker.js-co
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28191      1640/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        32541      2041/influxd
      tcp6       0      0 ::1:3350                :::*                    LISTEN      0          21758      834/xrdp-sesman
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20124      829/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17283      447/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      115        20145      733/grafana-server
      tcp6       0      0 :::3389                 :::*                    LISTEN      116        19048      854/xrdp
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18602      690/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15136      452/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17294      465/deCONZ
      udp        0      0 0.0.0.0:44442           0.0.0.0:*                           108        15138      452/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15184      806/dhcpcd
      udp6       0      0 :::57988                :::*                                108        15139      452/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        15137      452/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16330      806/dhcpcd
      2024-08-05 10:47:59.237  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Heizung.Solar-Temperatur, Alias=false, 32 points now activated
      2024-08-05 10:47:59.238  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.UVC.ELECTRIC_POWER, Alias=false, 33 points now activated
      2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of alias.0.Pool.Filter.ELECTRIC_POWER, Alias=false, 34 points now activated
      2024-08-05 10:47:59.239  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoorhumidity, Alias=false, 35 points now activated
      2024-08-05 10:47:59.240  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.indoortemp, Alias=false, 36 points now activated
      2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.pressureabs, Alias=false, 37 points now activated
      2024-08-05 10:47:59.241  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.1.soilmoisture, Alias=false, 38 points now activated
      2024-08-05 10:47:59.242  - info: influxdb.0 (4464) enabled logging of sainlogic.0.weather.current.2.soilmoisture, Alias=false, 39 points now activated
      2024-08-05 10:47:59.243  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.PoolPumpe.Wasser-Temp-Test, Alias=false, 40 points now activated
      2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of shelly.0.SHUNI-1#3494547AD6C8#1.ADC.Power, Alias=false, 41 points now activated
      2024-08-05 10:47:59.244  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Wasserstand, Alias=false, 42 points now activated
      2024-08-05 10:47:59.245  - info: influxdb.0 (4464) enabled logging of 0_userdata.0.Regenwasserpumpe.Wasserstandsensor.Fuellstand, Alias=false, 43 points now activated
      2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of Beregnung, Alias=true, 44 points now activated
      2024-08-05 10:47:59.246  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilHumidity_value, Alias=false, 45 points now activated
      2024-08-05 10:47:59.247  - info: influxdb.0 (4464) enabled logging of smartgarden.0.LOCATION_5ec04d8f-2Dd6ec-2D4b4b-2Daa4a-2D3405684cec21.DEVICE_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.SERVICE_SENSOR_ee8a5a48-2D2c62-2D4bd6-2Db911-2D711e17b9d5f9.soilTemperature_value, Alias=false, 46 points now activated
      2024-08-05 10:48:00.753  - info: host.ioBroker iobroker npm-install: NPM version: 10.7.0Installing iobroker.javascript@7.8.0... (System call)
      2024-08-05 10:48:00.854  - info: influxdb.0 (4464) Do not store value "null" for Beregnung because no number
      2024-08-05 10:48:21.385  - info: host.ioBroker iobroker npm-install:
      2024-08-05 10:48:21.386  - info: host.ioBroker iobroker npm-install: added 17 packages in 21s184 packages are looking for funding  run `npm fund` for details
      2024-08-05 10:48:43.558  - info: host.ioBroker iobroker npm-install: host.ioBroker install adapter javascript@7.8.0
      2024-08-05 10:49:27.144  - info: host.ioBroker iobroker npm-install: upload [310] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      2024-08-05 10:49:27.446  - info: host.ioBroker iobroker npm-install: upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
      2024-08-05 10:49:27.852  - info: host.ioBroker iobroker npm-install: upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/it.js google-blockly/own/msg/it.js application/javascript
      2024-08-05 10:49:30.586  - info: host.ioBroker iobroker npm-install: upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/666.f676e7ac.chunk.js.LICENSE.txt static/js/666.f676e7ac.chunk.js.LICENSE.txt text/plain
      2024-08-05 10:49:46.127  - info: admin.0 (1640) <== Disconnect system.user.admin from ::ffff:192.168.1.87 javascript
      iob diag has finished.
      Homoran M Thomas Braun 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Mathias2803 last edited by
        @mathias2803 läuft ja auch fast nichts!
        da muss ein + vor der Zeile sein
          Mathias2803 @Mathias2803 last edited by Mathias2803
          @Homoran
          Warum läuft das alles nicht?
          Soll ich bei Instanzen einfach alles jetzt starten? Funktioniert leider so nicht.
          Warum laufen die Instanzen nicht?
            Thomas Braun Most Active @Mathias2803 last edited by
            @mathias2803
            Kiste weiter updaten.
            iob update
            iob upgrade all -y
            Dann zieh ein aktuelles Backup und zieh damit um.
            Neuinstallation wie hier:
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            OHNE Desktop und sonstigem Quatsch und in der 64Bit-Version.
                                      v.2024-05-22
                       Icon name: computer
                    Architecture: arm
              Installation:           native
              Kernel:                 armv7l
              Userland:               32 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              Boot Target:            graphical.target
              Pending OS-Updates:     0
              Pending iob updates:    16
              Nodejs-Installation:
              /usr/bin/npm            10.7.0
              /usr/bin/npx            10.7.0
              Recommended versions are nodejs 18.20.4 and npm 10.7.0
              MEMORY:
              Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
              Swap:           99M          0B         99M
              Total:         3.9G        1.4G        792M
              Active iob-Instances:   10
              ioBroker Core:          js-controller           6.0.9
                                      admin                   6.13.16
              Objects type: jsonl
              States  type: jsonl
              Objects:                20349
              States:                 17590
              Size of iob-Database:
              43M     /opt/iobroker/iobroker-data/objects.jsonl
              12M     /opt/iobroker/iobroker-data/objects.json.migrated
              12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              0       /opt/iobroker/iobroker-data/objects.json.broken
              12M     /opt/iobroker/iobroker-data/states.jsonl
              4.0M    /opt/iobroker/iobroker-data/states.json.migrated
              4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                Das muss 0 werden.
                Homoran M 2 Replies Last reply Reply Quote 0
                  @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                  Das muss 0 werden.
                  @Mathias2803
                  wie sieht denn die Seite "Adapter" im admin aus.
                  gefiltert auf Adapter mit Update
                    pi@ioBroker:~ $ iob update
                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                    Adapter    "chromecast"   : 3.4.0    , installed 3.2.0  [Updatable]
                    Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
                    Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                    Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                    Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                    Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
                    pi@ioBroker:~ $ iob upgrade all -y
                    Update vis-jqui-mfd from @1.0.12 to @1.1.1
                    NPM version: 10.7.0
                    Installing iobroker.vis-jqui-mfd@1.1.1... (System call)
                    changed 1 package in 17s
                    231 packages are looking for funding
                    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                    Adapter "system.adapter.vis.0" restarted.
                    Update "system.adapter.vis-jqui-mfd.0"
                    upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                    Update vis-hqwidgets from @1.4.0 to @1.5.1
                    NPM version: 10.7.0
                    Installing iobroker.vis-hqwidgets@1.5.1... (System call)
                    changed 1 package in 15s
                    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                    Update "system.adapter.vis-hqwidgets.0"
                    upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                    upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                    Update simple-api from @2.7.2 to @2.8.0
                    host.ioBroker Adapter "system.adapter.simple-api.0" is stopped.
                    NPM version: 10.7.0
                    Installing iobroker.simple-api@2.8.0... (System call)
                    added 55 packages, removed 167 packages, and changed 2 packages in 1m
                    237 packages are looking for funding
                    Update "system.adapter.simple-api.0"
                    upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                    upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                    upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
                    upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                    upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                    host.ioBroker Adapter "system.adapter.simple-api.0" is started
                    Update discovery from @4.4.0 to @4.5.0
                    NPM version: 10.7.0
                    Installing iobroker.discovery@4.5.0... (System call)
                    changed 2 packages in 16s
                    Update "system.adapter.discovery.0"
                    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                    Update daswetter from @3.1.13 to @3.1.15
                    host.ioBroker Adapter "system.adapter.daswetter.0" is stopped.
                    NPM version: 10.7.0
                    Installing iobroker.daswetter@3.1.15... (System call)
                    removed 3 packages, and changed 2 packages in 18s
                    Update "system.adapter.daswetter.0"
                    upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
                    upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image/png
                    upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
                    upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
                    upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
                    upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
                    upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
                    upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
                    upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
                    upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
                    upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
                    upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
                    upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
                    upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
                    upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
                    upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
                    upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
                    upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
                    upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
                    upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
                    upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
                    upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
                    upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
                    upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
                    upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
                    upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
                    upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
                    upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
                    upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
                    upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
                    upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
                    upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
                    upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
                    upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
                    upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
                    upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
                    upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
                    host.ioBroker Adapter "system.adapter.daswetter.0" is started
                    Update alexa2 from @3.26.4 to @3.26.5
                    NPM version: 10.7.0
                    Installing iobroker.alexa2@3.26.5... (System call)
                    changed 7 packages in 33s
                    239 packages are looking for funding
                    Update "system.adapter.alexa2.0"
                    upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                    upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                    upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                    upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                    upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                    upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                    upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                    upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                    upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                    upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                    upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                    upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                    upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                    upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                    upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                    upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                    upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                    upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                    upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                    upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                    upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                    upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                    Update admin from @6.13.16 to @7.0.22
                    host.ioBroker Adapter "system.adapter.admin.0" is stopped.
                    NPM version: 10.7.0
                    Installing iobroker.admin@7.0.22... (System call)
                    added 26 packages, removed 8 packages, and changed 21 packages in 2m
                    245 packages are looking for funding
                    host.ioBroker Cannot install iobroker.admin@7.0.22: 0
                      Danach kommt nix mehr?
                      Sind die Updates der anderen Adapter nun drin?
                      iob update
                      nochmal anschauen.
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                        Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                        Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                        Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                        Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                        Wohl leider nicht.
                        Habe auch neu starten müssen. Der IoBroker lief dann nicht mehr richtig. im Browser.
                          Mathias2803 @Thomas Braun last edited by Mathias2803
                          Aber das System scheint wieder etwas besser zu laufen.
                          Vis ist an, Daten kommen in Grafana an...
                          Aber es fehlen doch noch Elemente.
                            @mathias2803
                            Dann nochmal
                            iob upgrade all -y
                            Zur Not die Adapter einzeln updaten.
                              und dazu ggf. im admin nachsehen warum die nicht wollen.
                              das steht dann 7n der Kachel
                                Mathias2803 @Homoran last edited by
                                Update vis-inventwo from @3.3.3 to @3.3.4
                                NPM version: 10.7.0
                                Installing iobroker.vis-inventwo@3.3.4... (System call)
                                added 30 packages, removed 122 packages, and changed 36 packages in 28s
                                272 packages are looking for funding
                                Adapter "system.adapter.web.0" restarted.
                                Update "system.adapter.vis-inventwo.0"
                                upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                                upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                                upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                                upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                                upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                                upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                                upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                                upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                                upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                                upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                                upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                                upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                                upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                                upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                                upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                                upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                                upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                                upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                                upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                                upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                                upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                                NPM version: 10.7.0
                                added 25 packages, removed 8 packages, and changed 21 packages in 1m
                                276 packages are looking for funding
                                Update "system.adapter.admin.0"
                                upload [67] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map'
                                upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map'
                                upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map'
                                upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js'
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map'
                                upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js'
                                upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map'
                                upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js'
                                upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map'
                                upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js'
                                upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map'
                                upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js'
                                upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map'
                                upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico'
                                upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json'
                                upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json'
                                upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json'
                                upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json'
                                upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json'
                                upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json'
                                upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json'
                                upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json'
                                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json'
                                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json'
                                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json'
                                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5'
                                Update ws from @2.5.10 to @2.6.1
                                NPM version: 10.7.0
                                Installing iobroker.ws@2.6.1... (System call)
                                Try to solve ENOTEMPTY error automatically
                                Could not handle ENOTEMPTY, because no deletable files were found
                                npm error code ENOTEMPTY
                                npm error syscall rename
                                npm error path /opt/iobroker/node_modules/iobroker.admin
                                npm error dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                                npm error errno -39
                                npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-05T09_22_38_819Z-debug-0.log
                                host.ioBroker Cannot install iobroker.ws@2.6.1: 217
                                Thomas Braun M 2 Replies Last reply Reply Quote 0
                                  Thomas Braun Most Active @Mathias2803 last edited by Thomas Braun
                                  @mathias2803
                                  iob stop
                                  iob fix
                                  iob update
                                  iob upgrade all -y
                                  Das u. U. so lange wiederholen, bis keine Updates mehr vorliegen.
                                    @mathias2803
                                    pi@ioBroker:~ $ iob stop
                                    pi@ioBroker:~ $ iob fix
                                    library: loaded
                                    Library version=2024-05-24
                                        Welcome to the ioBroker installation fixer!
                                        Script version: 2024-01-04
                                        You might need to enter your password a couple of times.
                                        Installing prerequisites (1/5)
                                    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                    Holen:3 https://repos.influxdata.com/debian buster InRelease [12,9 kB]
                                    OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    OK:5 https://phoscon.de/apt/deconz buster InRelease
                                    OK:6 https://twolife.be/raspbian buster InRelease
                                    Fehl:3 https://repos.influxdata.com/debian buster InRelease
                                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                    Fehl:6 https://twolife.be/raspbian buster InRelease
                                      Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                    OK:7 https://archive.raspbian.org/raspbian buster InRelease
                                    Es wurden 12,9 kB in 6 s geholt (2.284 B/s).
                                    W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://twolife.be/raspbian buster InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                    W: Fehlschlag beim Holen von https://twolife.be/raspbian/dists/buster/InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                                    W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                    W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                        Checking ioBroker user and directory permissions (2/5)
                                    Created /etc/sudoers.d/iobroker
                                    Fixing directory permissions...
                                    This system does not support setting default permissions.
                                    Do not use npm to manually install adapters unless you know what you are doing!
                                        Check and cleanup npm temporary directories (3/5)
                                    Done.
                                        Database maintenance (4/5)
                                    Checking for uncompressed JSONL databases... This might take a while!
                                    Compressing /opt/iobroker/iobroker-data/states.jsonl
                                    Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                    Compressed 2 JSONL files. Done
                                        Checking autostart (5/5)
                                    Enabling autostart...
                                    Autostart enabled!
                                        Your installation was fixed successfully
                                        Run iobroker start to start ioBroker again!
                                      Die Oberfläche startet gerade nicht mehr.
                                      Dafür aber VIS und die Skripte. 🙂
                                      Ich lasse die Updates mehrfach laufen oder einzeln in Putty.
                                      Admin konnte ich einzeln durchbekommen.
                                        Versuch mal
                                        iob start admin
                                          NPM version: 10.7.0
                                          added 3 packages, removed 1 package, and changed 2 packages in 13s
                                          296 packages are looking for funding
                                          upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                                          Update web from @6.2.3 to @6.2.5
                                          host.ioBroker Adapter "system.adapter.web.0" is stopped.
                                          NPM version: 10.7.0
                                          Installing iobroker.web@6.2.5... (System call)
                                          removed 2 packages, and changed 5 packages in 24s
                                          295 packages are looking for funding
                                          upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                          upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                          upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                          upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                          upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                          upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                          upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                          upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                          upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                          upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                          upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                          upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                          upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                          upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                          upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                          upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                          upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                          upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                          upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                          upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                          upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                          upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                          upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                          upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                          upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                          upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                          upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                          upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                          upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                          upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                          upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                          upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                          upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                          upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                          upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                          Update "system.adapter.web.0"
                                          upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                          upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                          upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                          upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                          upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                          upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                          upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                          upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                          upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                          upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                          upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                          upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                          upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                          upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                          upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                          upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                          upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                          upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                          upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                          upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                          upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                          upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                          upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                          upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                          upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                          upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                          upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                          upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                          upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                          upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                          host.ioBroker Adapter "system.adapter.web.0" is started
                                          Update vis from @1.5.4 to @1.5.6
                                          NPM version: 10.7.0
                                          Installing iobroker.vis@1.5.6... (System call)
                                          changed 1 package in 1m
                                            run `npm fund` for details
                                          upload [746] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                          upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/stateful.png icon/stateful.png image/png
                                          upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/js/connSignalR.js js/connSignalR.js application/javascript
                                          upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/zip.png js/fm/icon/mine/24/zip.png image/png
                                          upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/dropzone.js lib/js/dropzone.js application/javascript
                                          upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_StatefulContainerView8.png widgets/basic/img/Prev_StatefulContainerView8.png image/png
                                          upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/img/Prev_tplEchartsChart.png widgets/echarts/img/Prev_tplEchartsChart.png image/png
                                          upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png image/png
                                          upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_20.png widgets/jqui-mfd/img/fts_shutter_20.png image/png
                                          upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.png widgets/jqui-mfd/img/fts_window_roof.png image/png
                                          upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_50.svg widgets/jqui-mfd/img/sani_valve_50.svg image/svg+xml
                                          upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/001-3.png widgets/timeandweather/img/clock/001-3.png image/png
                                          upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-3.png widgets/timeandweather/img/clock/511-3.png image/png
                                          upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Image.png widgets/vis-inventwo/img/0_Image.png image/png
                                          upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Switch1.png widgets/vis-inventwo/img/0_Switch1.png image/png
                                          upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Multi.gif widgets/vis-inventwo/img/Multi.gif image/gif
                                          upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                                          upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01/min.png widgets/vis-inventwo/img/clock_analog/01/min.png image/png
                                          upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                                          upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                                          upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.browser.js widgets/weather/lib/js/flot/jquery.flot.browser.js application/javascript
                                          upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.js widgets/weather/lib/js/flot/jquery.flot.js application/javascript
                                          upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.legend.js widgets/weather/lib/js/flot/jquery.flot.legend.js application/javascript
                                          upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.logaxis.js widgets/weather/lib/js/flot/jquery.flot.logaxis.js application/javascript
                                          upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js widgets/weather/lib/js/flot/jquery.flot.navigate.js application/javascript
                                          upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js widgets/weather/lib/js/flot/jquery.flot.pie.js application/javascript
                                          upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js widgets/weather/lib/js/flot/jquery.flot.resize.js application/javascript
                                          upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js widgets/weather/lib/js/flot/jquery.flot.saturated.js application/javascript
                                          upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js widgets/weather/lib/js/flot/jquery.flot.selection.js application/javascript
                                          upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js widgets/weather/lib/js/flot/jquery.flot.stack.js application/javascript
                                          upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js widgets/weather/lib/js/flot/jquery.flot.symbol.js application/javascript
                                          upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js widgets/weather/lib/js/flot/jquery.flot.threshold.js application/javascript
                                          upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js widgets/weather/lib/js/flot/jquery.flot.time.js application/javascript
                                          upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js widgets/weather/lib/js/flot/jquery.flot.touch.js application/javascript
                                          upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js application/javascript
                                          upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js widgets/weather/lib/js/flot/jquery.flot.uiConstants.js application/javascript
                                          upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                          upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                          upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                          upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                          upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                          upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                          Update "system.adapter.vis.0"
                                          upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                          Update trashschedule from @3.2.0 to @3.3.0
                                          NPM version: 10.7.0
                                          Installing iobroker.trashschedule@3.3.0... (System call)
                                          changed 1 package in 13s
                                          Adapter "system.adapter.vis.0" restarted.
                                          Update "system.adapter.trashschedule.0"
                                          upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                          Update tr-064 from @4.2.18 to @4.3.0
                                          NPM version: 10.7.0
                                          Installing iobroker.tr-064@4.3.0... (System call)
                                          Update "system.adapter.tr-064.0"
                                          Update "system.adapter.tr-064.1"
                                          Update "system.adapter.tr-064.2"
                                          upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                          upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                          upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                          Update telegram from @3.1.0 to @3.3.2
                                          host.ioBroker Adapter "system.adapter.telegram.0" is stopped.
                                          NPM version: 10.7.0
                                          Installing iobroker.telegram@3.3.2... (System call)
                                          changed 2 packages in 16s
                                          Update "system.adapter.telegram.0"
                                          upload [70] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                          upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                          upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js application/javascript
                                          upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es.json i18n/es.json application/json
                                          upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                          upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                          upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pt.json rules/i18n/pt.json application/json
                                          upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/ru.json rules/i18n/ru.json application/json
                                          upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/uk.json rules/i18n/uk.json application/json
                                          upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/zh-cn.json rules/i18n/zh-cn.json application/json
                                          upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js rules/static/js/main.a721e2f4.js application/javascript
                                          upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js.map rules/static/js/main.a721e2f4.js.map application/json
                                          upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js application/javascript
                                          upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map application/json
                                          upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js application/javascript
                                          upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map application/json
                                          upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js application/javascript
                                          upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map application/json
                                          upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js rules/static/js/node_modules_react_index_js.6114a944.chunk.js application/javascript
                                          upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map application/json
                                          upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js application/javascript
                                          upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map application/json
                                          upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js application/javascript
                                          upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map application/json
                                          upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                          upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                          host.ioBroker Adapter "system.adapter.telegram.0" is started
                                          Update socketio from @6.6.1 to @6.7.0
                                          NPM version: 10.7.0
                                          Installing iobroker.socketio@6.7.0... (System call)
                                          added 1 package, and changed 1 package in 14s
                                          upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                          Update smartgarden from @2.0.0 to @2.0.1
                                          NPM version: 10.7.0
                                          Installing iobroker.smartgarden@2.0.1... (System call)
                                          Update "system.adapter.smartgarden.0"
                                          upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                          upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                          upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                          upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                          Update samsung from @0.5.11 to @0.6.0
                                          NPM version: 10.7.0
                                          Installing iobroker.samsung@0.6.0... (System call)
                                          Update "system.adapter.samsung.0"
                                          upload [1] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/index.html index.html text/html
                                          upload [0] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/samsung.png samsung.png image/png
                                          Update sainlogic from @0.10.5 to @0.11.4
                                          NPM version: 10.7.0
                                          Installing iobroker.sainlogic@0.11.4... (System call)
                                          Update "system.adapter.sainlogic.0"
                                          upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                          upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                          upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                          upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                          upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                          Update panasonic-viera from @2.0.0 to @2.1.0
                                          NPM version: 10.7.0
                                          Installing iobroker.panasonic-viera@2.1.0... (System call)
                                          Update "system.adapter.panasonic-viera.0"
                                          upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.html text/html
                                          upload [2] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index_m.html index_m.html text/html
                                          upload [1] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/panasonic-viera.png panasonic-viera.png image/png
                                          upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js application/javascript
                                          Update modbus from @6.1.0 to @6.2.3
                                          NPM version: 10.7.0
                                          Installing iobroker.modbus@6.2.3... (System call)
                                          Update "system.adapter.modbus.0"
                                          upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                                          upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                          upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                                          upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                                          upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                          upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                          upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                          upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                                          upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                                          upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                                          Update javascript from @7.8.0 to @8.7.6
                                          NPM version: 10.7.0
                                          Installing iobroker.javascript@8.7.6... (System call)
                                          removed 1 package, and changed 2 packages in 4m
                                          Update "system.adapter.javascript.0"
                                          upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                          upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                                          upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                                          upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                                          upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                                          upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                                          upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                                          upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                                          upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                                          upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                                          upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                                          upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                                          upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                                          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                                          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                                          upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                                          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                                          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                                          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                                          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                                          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                          Update ical from @1.14.3 to @1.15.0
                                          NPM version: 10.7.0
                                          Installing iobroker.ical@1.15.0... (System call)
                                          Update "system.adapter.ical.0"
                                          upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                          upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                          upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                          Update discord from @2.2.0 to @2.4.0
                                          NPM version: 10.7.0
                                          Installing iobroker.discord@2.4.0... (System call)
                                          Update "system.adapter.discord.0"
                                          upload [18] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/blockly.js blockly.js application/javascript
                                          upload [17] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-text.svg channel-text.svg image/svg+xml
                                          upload [16] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-voice.svg channel-voice.svg image/svg+xml
                                          upload [15] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/discord.png discord.png image/png
                                          upload [14] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/de.json i18n/de.json application/json
                                          upload [13] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/en.json i18n/en.json application/json
                                          upload [12] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/es.json i18n/es.json application/json
                                          upload [11] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/fr.json i18n/fr.json application/json
                                          upload [10] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/it.json i18n/it.json application/json
                                          upload [9] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/nl.json i18n/nl.json application/json
                                          upload [8] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pl.json i18n/pl.json application/json
                                          upload [7] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pt.json i18n/pt.json application/json
                                          upload [6] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/ru.json i18n/ru.json application/json
                                          upload [5] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/uk.json i18n/uk.json application/json
                                          upload [4] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                          upload [3] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/index_m.html index_m.html text/html
                                          upload [2] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonConfig.json jsonConfig.json application/json
                                          upload [1] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonCustom.json jsonCustom.json application/json
                                          upload [0] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/style.css style.css text/css
                                          Update chromecast from @3.2.0 to @3.4.0
                                          NPM version: 10.7.0
                                          Installing iobroker.chromecast@3.4.0... (System call)
                                          changed 1 package in 17s
                                          Update "system.adapter.chromecast.0"
                                          upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                          upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                          upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                          upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                          Update botvac from @2.0.2 to @2.2.0
                                          NPM version: 10.7.0
                                          Installing iobroker.botvac@2.2.0... (System call)
                                          Update "system.adapter.botvac.0"
                                          upload [1] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/botvac.png botvac.png image/png
                                          upload [0] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/index.html index.html text/html
                                          Update backitup from @2.10.11 to @2.11.0
                                          host.ioBroker Adapter "system.adapter.backitup.0" is stopped.
                                          host.ioBroker Adapter "system.adapter.backitup.1" is stopped.
                                          NPM version: 10.7.0
                                          Installing iobroker.backitup@2.11.0... (System call)
                                          Update "system.adapter.backitup.0"
                                          Update "system.adapter.backitup.1"
                                          upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                          upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                          upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                          upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                          upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                          upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                          upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                          upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                          upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                          upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                          upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                          upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                          host.ioBroker Adapter "system.adapter.backitup.0" is started
                                          host.ioBroker Adapter "system.adapter.backitup.1" is started
                                          code_textpi@ioBroker:~ $ iob update
                                          Used repository: stable
                                          Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                          Adapter    "botvac"       : 2.2.0    , installed 2.2.0
                                          Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                                          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                          Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                                          Adapter    "discord"      : 2.4.0    , installed 2.4.0
                                          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                          Controller "js-controller": 6.0.9    , installed 6.0.9
                                          Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                                          Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                          Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                                          Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                          Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                          Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                          Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                          Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                            @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                            Was haste denn da installiert? Soweit ich das sehe ist 1.4.1 aktuell:
                                            github:	1.4.1
                                            latest:	1.4.1 for 88 days
                                            stable:	1.4.1 for 88 days
                                            2762
