    4. GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log
      Mathias2803 @Thomas Braun last edited by
                              v.2024-05-22
         Static hostname: ioBroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         true
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    16
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      Recommended versions are nodejs 18.20.4 and npm 10.7.0
      MEMORY:
      Mem:           3.8G        1.4G        692M        8.0M        1.8G        2.3G
      Swap:           99M          0B         99M
      Total:         3.9G        1.4G        792M
      Active iob-Instances:   10
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.9
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                20349
      States:                 17590
      Size of iob-Database:
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      12M     /opt/iobroker/iobroker-data/states.jsonl
      4.0M    /opt/iobroker/iobroker-data/states.json.migrated
      4.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @Mathias2803 last edited by
        @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
        Das muss 0 werden.
        Homoran M 2 Replies Last reply Reply Quote 0
          @thomas-braun sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
          Das muss 0 werden.
          @Mathias2803
          wie sieht denn die Seite "Adapter" im admin aus.
          gefiltert auf Adapter mit Update
            pi@ioBroker:~ $ iob update
            Used repository: stable
            Adapter    "admin"        : 7.0.22   , installed 6.13.16 [Updatable]
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
            Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
            Adapter    "botvac"       : 2.2.0    , installed 2.0.2  [Updatable]
            Adapter    "chromecast"   : 3.4.0    , installed 3.2.0  [Updatable]
            Adapter    "daswetter"    : 3.1.15   , installed 3.1.13 [Updatable]
            Adapter    "deconz"       : 1.4.1    , installed 2.0.7
            Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
            Adapter    "ical"         : 1.15.0   , installed 1.14.3 [Updatable]
            Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
            Controller "js-controller": 6.0.9    , installed 6.0.9
            Adapter    "lifx"         : 1.0.4    , installed 1.0.4
            Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "panasonic-viera": 2.1.0  , installed 2.0.0  [Updatable]
            Adapter    "samsung"      : 0.6.0    , installed 0.5.11 [Updatable]
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "telegram"     : 3.3.2    , installed 3.1.0  [Updatable]
            Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
            Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            pi@ioBroker:~ $ iob upgrade all -y
            Update vis-jqui-mfd from @1.0.12 to @1.1.1
            NPM version: 10.7.0
            Installing iobroker.vis-jqui-mfd@1.1.1... (System call)
            changed 1 package in 17s
            231 packages are looking for funding
              run `npm fund` for details
            INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
            Adapter "system.adapter.vis.0" restarted.
            Update "system.adapter.vis-jqui-mfd.0"
            upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
            Update vis-hqwidgets from @1.4.0 to @1.5.1
            NPM version: 10.7.0
            Installing iobroker.vis-hqwidgets@1.5.1... (System call)
            changed 1 package in 15s
            INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
            Update "system.adapter.vis-hqwidgets.0"
            upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
            upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
            Update simple-api from @2.7.2 to @2.8.0
            host.ioBroker Adapter "system.adapter.simple-api.0" is stopped.
            NPM version: 10.7.0
            Installing iobroker.simple-api@2.8.0... (System call)
            added 55 packages, removed 167 packages, and changed 2 packages in 1m
            237 packages are looking for funding
            Update "system.adapter.simple-api.0"
            upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
            upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
            upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.json application/json
            upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
            upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
            host.ioBroker Adapter "system.adapter.simple-api.0" is started
            Update discovery from @4.4.0 to @4.5.0
            NPM version: 10.7.0
            Installing iobroker.discovery@4.5.0... (System call)
            changed 2 packages in 16s
            Update "system.adapter.discovery.0"
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
            Update daswetter from @3.1.13 to @3.1.15
            host.ioBroker Adapter "system.adapter.daswetter.0" is stopped.
            NPM version: 10.7.0
            Installing iobroker.daswetter@3.1.15... (System call)
            removed 3 packages, and changed 2 packages in 18s
            Update "system.adapter.daswetter.0"
            upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/daswettercom.png daswettercom.png image/png
            upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image/png
            upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria3/19.png icons/tiempo-weather/galeria3/19.png image/png
            upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/PNG/White/1.png icons/tiempo-weather/galeria5/PNG/White/1.png image/png
            upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria5/SVG/White/15.svg icons/tiempo-weather/galeria5/SVG/White/15.svg image/svg+xml
            upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/tiempo-weather/galeria6/5.png icons/tiempo-weather/galeria6/5.png image/png
            upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/41.png icons/viento-wind/Beaufort-White/41.png image/png
            upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/Beaufort-White/87.png icons/viento-wind/Beaufort-White/87.png image/png
            upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/104.png icons/viento-wind/galeria2-Beaufort/104.png image/png
            upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/2.png icons/viento-wind/galeria2-Beaufort/2.png image/png
            upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/29.png icons/viento-wind/galeria2-Beaufort/29.png image/png
            upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/38.png icons/viento-wind/galeria2-Beaufort/38.png image/png
            upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/47.png icons/viento-wind/galeria2-Beaufort/47.png image/png
            upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/56.png icons/viento-wind/galeria2-Beaufort/56.png image/png
            upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/65.png icons/viento-wind/galeria2-Beaufort/65.png image/png
            upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/74.png icons/viento-wind/galeria2-Beaufort/74.png image/png
            upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/83.png icons/viento-wind/galeria2-Beaufort/83.png image/png
            upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/84.png icons/viento-wind/galeria2-Beaufort/84.png image/png
            upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/85.png icons/viento-wind/galeria2-Beaufort/85.png image/png
            upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/86.png icons/viento-wind/galeria2-Beaufort/86.png image/png
            upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/87.png icons/viento-wind/galeria2-Beaufort/87.png image/png
            upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/88.png icons/viento-wind/galeria2-Beaufort/88.png image/png
            upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/89.png icons/viento-wind/galeria2-Beaufort/89.png image/png
            upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/9.png icons/viento-wind/galeria2-Beaufort/9.png image/png
            upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/90.png icons/viento-wind/galeria2-Beaufort/90.png image/png
            upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/91.png icons/viento-wind/galeria2-Beaufort/91.png image/png
            upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/92.png icons/viento-wind/galeria2-Beaufort/92.png image/png
            upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/93.png icons/viento-wind/galeria2-Beaufort/93.png image/png
            upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/94.png icons/viento-wind/galeria2-Beaufort/94.png image/png
            upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/95.png icons/viento-wind/galeria2-Beaufort/95.png image/png
            upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/96.png icons/viento-wind/galeria2-Beaufort/96.png image/png
            upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/97.png icons/viento-wind/galeria2-Beaufort/97.png image/png
            upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/98.png icons/viento-wind/galeria2-Beaufort/98.png image/png
            upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/icons/viento-wind/galeria2-Beaufort/99.png icons/viento-wind/galeria2-Beaufort/99.png image/png
            upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/index_m.html index_m.html text/html
            upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/jsonConfig.json jsonConfig.json application/json
            upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/words.js words.js application/javascript
            host.ioBroker Adapter "system.adapter.daswetter.0" is started
            Update alexa2 from @3.26.4 to @3.26.5
            NPM version: 10.7.0
            Installing iobroker.alexa2@3.26.5... (System call)
            changed 7 packages in 33s
            239 packages are looking for funding
            Update "system.adapter.alexa2.0"
            upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
            Update admin from @6.13.16 to @7.0.22
            host.ioBroker Adapter "system.adapter.admin.0" is stopped.
            NPM version: 10.7.0
            Installing iobroker.admin@7.0.22... (System call)
            added 26 packages, removed 8 packages, and changed 21 packages in 2m
            245 packages are looking for funding
            host.ioBroker Cannot install iobroker.admin@7.0.22: 0
              Danach kommt nix mehr?
              Sind die Updates der anderen Adapter nun drin?
              iob update
              nochmal anschauen.
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                Adapter    "trashschedule": 3.3.0    , installed 3.2.0  [Updatable]
                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                Wohl leider nicht.
                Habe auch neu starten müssen. Der IoBroker lief dann nicht mehr richtig. im Browser.
                  Mathias2803 @Thomas Braun last edited by Mathias2803
                  Aber das System scheint wieder etwas besser zu laufen.
                  Vis ist an, Daten kommen in Grafana an...
                  Aber es fehlen doch noch Elemente.
                    @mathias2803
                    Dann nochmal
                    iob upgrade all -y
                    Zur Not die Adapter einzeln updaten.
                      und dazu ggf. im admin nachsehen warum die nicht wollen.
                      das steht dann 7n der Kachel
                        Mathias2803 @Homoran last edited by
                        Update vis-inventwo from @3.3.3 to @3.3.4
                        NPM version: 10.7.0
                        Installing iobroker.vis-inventwo@3.3.4... (System call)
                        added 30 packages, removed 122 packages, and changed 36 packages in 28s
                        272 packages are looking for funding
                        Adapter "system.adapter.web.0" restarted.
                        Update "system.adapter.vis-inventwo.0"
                        upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
                        upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
                        upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
                        upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
                        upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
                        upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
                        upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
                        upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
                        upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
                        upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
                        upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
                        upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
                        upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
                        upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
                        upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
                        upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
                        upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
                        upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
                        upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
                        upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
                        upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
                        NPM version: 10.7.0
                        added 25 packages, removed 8 packages, and changed 21 packages in 1m
                        276 packages are looking for funding
                        Update "system.adapter.admin.0"
                        upload [67] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                        upload [60] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/it.json custom/i18n/it.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pl.json'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/pt.json'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91570.411e854b.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/_91571.499943a2.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/main.7b053dc8.js.map'
                        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23730.1d6892ae.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-de23731.c309b007.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.cd9c8e7b.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_react_index_js.d7634d5d.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_Components_jsx.10a5bf79.chunk.js.map'
                        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/src_bootstrap_jsx.aca93d2e.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_iobroker_json-config_build_index_js.4e679105.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-3b06e4.7b543b86.chunk.js.map'
                        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_FilledInput_FilledInput_js.9c980ca7.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js.f72dd42a.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.1532340b.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_system_esm_DefaultPropsPr-f385a6.31762d2f.chunk.js.map'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js'
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_x-date-pickers_index_js.b870bf6b.chunk.js.map'
                        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js'
                        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-ace_lib_index_js.55163eef.chunk.js.map'
                        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js'
                        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-color_es_index_js-node_modules_react-icons_lib_index_mjs.94169d3c.chunk.js.map'
                        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js'
                        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.8a166965.chunk.js.map'
                        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js application/javascript
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js'
                        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dropzone_dist_es_index_js.91b1d9b3.chunk.js.map'
                        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/favicon.ico'
                        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json'
                        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json'
                        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json'
                        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json'
                        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json'
                        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json'
                        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json'
                        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json'
                        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json'
                        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json'
                        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json'
                        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                        Error: Cannot upload /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5'
                        Update ws from @2.5.10 to @2.6.1
                        NPM version: 10.7.0
                        Installing iobroker.ws@2.6.1... (System call)
                        Try to solve ENOTEMPTY error automatically
                        Could not handle ENOTEMPTY, because no deletable files were found
                        npm error code ENOTEMPTY
                        npm error syscall rename
                        npm error path /opt/iobroker/node_modules/iobroker.admin
                        npm error dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                        npm error errno -39
                        npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-05T09_22_38_819Z-debug-0.log
                        host.ioBroker Cannot install iobroker.ws@2.6.1: 217
                        Thomas Braun M 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Mathias2803 last edited by Thomas Braun
                          @mathias2803
                          iob stop
                          iob fix
                          iob update
                          iob upgrade all -y
                          Das u. U. so lange wiederholen, bis keine Updates mehr vorliegen.
                            Mathias2803 @Mathias2803 last edited by
                            @mathias2803
                            pi@ioBroker:~ $ iob stop
                            pi@ioBroker:~ $ iob fix
                            library: loaded
                            Library version=2024-05-24
                                Welcome to the ioBroker installation fixer!
                                Script version: 2024-01-04
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/5)
                            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:2 http://archive.raspberrypi.org/debian buster InRelease
                            Holen:3 https://repos.influxdata.com/debian buster InRelease [12,9 kB]
                            OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                            OK:5 https://phoscon.de/apt/deconz buster InRelease
                            OK:6 https://twolife.be/raspbian buster InRelease
                            Fehl:3 https://repos.influxdata.com/debian buster InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                            Fehl:6 https://twolife.be/raspbian buster InRelease
                              Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                            OK:7 https://archive.raspbian.org/raspbian buster InRelease
                            Es wurden 12,9 kB in 6 s geholt (2.284 B/s).
                            W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian buster InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://twolife.be/raspbian buster InRelease: Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                            W: Fehlschlag beim Holen von https://twolife.be/raspbian/dists/buster/InRelease Die folgenden Signaturen waren ungültig: EXPKEYSIG ACA008B8C934A7D4 Sébastien Noel <sebastien@twolife.be>
                            W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/buster/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                            W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                Checking ioBroker user and directory permissions (2/5)
                            Created /etc/sudoers.d/iobroker
                            Fixing directory permissions...
                            This system does not support setting default permissions.
                            Do not use npm to manually install adapters unless you know what you are doing!
                                Check and cleanup npm temporary directories (3/5)
                            Done.
                                Database maintenance (4/5)
                            Checking for uncompressed JSONL databases... This might take a while!
                            Compressing /opt/iobroker/iobroker-data/states.jsonl
                            Compressing /opt/iobroker/iobroker-data/objects.jsonl
                            Compressed 2 JSONL files. Done
                                Checking autostart (5/5)
                            Enabling autostart...
                            Autostart enabled!
                                Your installation was fixed successfully
                                Run iobroker start to start ioBroker again!
                              Die Oberfläche startet gerade nicht mehr.
                              Dafür aber VIS und die Skripte. 🙂
                              Ich lasse die Updates mehrfach laufen oder einzeln in Putty.
                              Admin konnte ich einzeln durchbekommen.
                                Versuch mal
                                iob start admin
                                  NPM version: 10.7.0
                                  added 3 packages, removed 1 package, and changed 2 packages in 13s
                                  296 packages are looking for funding
                                  upload [11] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [0] ws.admin /opt/iobroker/node_modules/iobroker.ws/admin/ws.png ws.png image/png
                                  Update web from @6.2.3 to @6.2.5
                                  host.ioBroker Adapter "system.adapter.web.0" is stopped.
                                  NPM version: 10.7.0
                                  Installing iobroker.web@6.2.5... (System call)
                                  removed 2 packages, and changed 5 packages in 24s
                                  295 packages are looking for funding
                                  upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                  upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                  upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                  upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                  upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                  upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                  upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                  upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                  upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                  upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                  upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                  upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                  upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                  upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                  upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                  upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                  upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                  upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                  upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                  upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                  upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                  upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                  upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                  upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                  upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                  upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                  upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                  upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                  upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                  upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                  upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                  upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                  upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                  upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                  upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                  Update "system.adapter.web.0"
                                  upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                  upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                  upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                  upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                  upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                  upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                  upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                  upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                  upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                  upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                  upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                  upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                  upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                  upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                  upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                  upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                  upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                  upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                  upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
                                  upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                  upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
                                  upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
                                  upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                  upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
                                  upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                  upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
                                  upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
                                  upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                  upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                  host.ioBroker Adapter "system.adapter.web.0" is started
                                  Update vis from @1.5.4 to @1.5.6
                                  NPM version: 10.7.0
                                  Installing iobroker.vis@1.5.6... (System call)
                                  changed 1 package in 1m
                                  upload [746] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                  upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/stateful.png icon/stateful.png image/png
                                  upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/js/connSignalR.js js/connSignalR.js application/javascript
                                  upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/zip.png js/fm/icon/mine/24/zip.png image/png
                                  upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/dropzone.js lib/js/dropzone.js application/javascript
                                  upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_StatefulContainerView8.png widgets/basic/img/Prev_StatefulContainerView8.png image/png
                                  upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/echarts/img/Prev_tplEchartsChart.png widgets/echarts/img/Prev_tplEchartsChart.png image/png
                                  upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png widgets/hqwidgets/img/prev/Prev_hqwidgetsDimmer.png image/png
                                  upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_20.png widgets/jqui-mfd/img/fts_shutter_20.png image/png
                                  upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.png widgets/jqui-mfd/img/fts_window_roof.png image/png
                                  upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_50.svg widgets/jqui-mfd/img/sani_valve_50.svg image/svg+xml
                                  upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/001-3.png widgets/timeandweather/img/clock/001-3.png image/png
                                  upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-3.png widgets/timeandweather/img/clock/511-3.png image/png
                                  upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Image.png widgets/vis-inventwo/img/0_Image.png image/png
                                  upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/0_Switch1.png widgets/vis-inventwo/img/0_Switch1.png image/png
                                  upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/Multi.gif widgets/vis-inventwo/img/Multi.gif image/gif
                                  upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png widgets/vis-inventwo/img/ToggleSwitch/switch-1-hor-on-black.png image/png
                                  upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/01/min.png widgets/vis-inventwo/img/clock_analog/01/min.png image/png
                                  upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/03/std.png widgets/vis-inventwo/img/clock_analog/03/std.png image/png
                                  upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/vis-inventwo/img/clock_analog/frame.png widgets/vis-inventwo/img/clock_analog/frame.png image/png
                                  upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.browser.js widgets/weather/lib/js/flot/jquery.flot.browser.js application/javascript
                                  upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.js widgets/weather/lib/js/flot/jquery.flot.js application/javascript
                                  upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.legend.js widgets/weather/lib/js/flot/jquery.flot.legend.js application/javascript
                                  upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.logaxis.js widgets/weather/lib/js/flot/jquery.flot.logaxis.js application/javascript
                                  upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js widgets/weather/lib/js/flot/jquery.flot.navigate.js application/javascript
                                  upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js widgets/weather/lib/js/flot/jquery.flot.pie.js application/javascript
                                  upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js widgets/weather/lib/js/flot/jquery.flot.resize.js application/javascript
                                  upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js widgets/weather/lib/js/flot/jquery.flot.saturated.js application/javascript
                                  upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js widgets/weather/lib/js/flot/jquery.flot.selection.js application/javascript
                                  upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js widgets/weather/lib/js/flot/jquery.flot.stack.js application/javascript
                                  upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js widgets/weather/lib/js/flot/jquery.flot.symbol.js application/javascript
                                  upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js widgets/weather/lib/js/flot/jquery.flot.threshold.js application/javascript
                                  upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js widgets/weather/lib/js/flot/jquery.flot.time.js application/javascript
                                  upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js widgets/weather/lib/js/flot/jquery.flot.touch.js application/javascript
                                  upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js application/javascript
                                  upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js widgets/weather/lib/js/flot/jquery.flot.uiConstants.js application/javascript
                                  upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                  upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                  upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                  upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                  upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                  upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                  Update "system.adapter.vis.0"
                                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                  Update trashschedule from @3.2.0 to @3.3.0
                                  NPM version: 10.7.0
                                  Installing iobroker.trashschedule@3.3.0... (System call)
                                  changed 1 package in 13s
                                    run `npm fund` for details
                                  Adapter "system.adapter.vis.0" restarted.
                                  Update "system.adapter.trashschedule.0"
                                  upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                  Update tr-064 from @4.2.18 to @4.3.0
                                  NPM version: 10.7.0
                                  Installing iobroker.tr-064@4.3.0... (System call)
                                  Update "system.adapter.tr-064.0"
                                  Update "system.adapter.tr-064.1"
                                  Update "system.adapter.tr-064.2"
                                  upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                  upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                  upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                  Update telegram from @3.1.0 to @3.3.2
                                  host.ioBroker Adapter "system.adapter.telegram.0" is stopped.
                                  NPM version: 10.7.0
                                  Installing iobroker.telegram@3.3.2... (System call)
                                  changed 2 packages in 16s
                                  Update "system.adapter.telegram.0"
                                  upload [70] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                  upload [60] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
                                  upload [50] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js custom/static/js/node_modules_prop-types_index_js.6da256b6.chunk.js application/javascript
                                  upload [40] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/i18n/es.json i18n/es.json application/json
                                  upload [30] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                  upload [20] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pl.json rules/i18n/pl.json application/json
                                  upload [19] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/pt.json rules/i18n/pt.json application/json
                                  upload [18] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/ru.json rules/i18n/ru.json application/json
                                  upload [17] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/uk.json rules/i18n/uk.json application/json
                                  upload [16] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/i18n/zh-cn.json rules/i18n/zh-cn.json application/json
                                  upload [15] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js rules/static/js/main.a721e2f4.js application/javascript
                                  upload [14] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/main.a721e2f4.js.map rules/static/js/main.a721e2f4.js.map application/json
                                  upload [13] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js application/javascript
                                  upload [12] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694110.50566baf.chunk.js.map application/json
                                  upload [11] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js application/javascript
                                  upload [10] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map rules/static/js/node_modules_iobroker_adapter-react-v5_assets_devices_sync_recursive_-node_modules_iobroker_a-b694111.f34776f9.chunk.js.map application/json
                                  upload [9] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js application/javascript
                                  upload [8] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map rules/static/js/node_modules_prop-types_index_js.c5b5d86f.chunk.js.map application/json
                                  upload [7] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js rules/static/js/node_modules_react_index_js.6114a944.chunk.js application/javascript
                                  upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map rules/static/js/node_modules_react_index_js.6114a944.chunk.js.map application/json
                                  upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js application/javascript
                                  upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map rules/static/js/src_ActionTelegram_jsx.606264b1.chunk.js.map application/json
                                  upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js application/javascript
                                  upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map rules/static/js/src_bootstrap_jsx.daa4bc6c.chunk.js.map application/json
                                  upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                  upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                  host.ioBroker Adapter "system.adapter.telegram.0" is started
                                  Update socketio from @6.6.1 to @6.7.0
                                  NPM version: 10.7.0
                                  Installing iobroker.socketio@6.7.0... (System call)
                                  added 1 package, and changed 1 package in 14s
                                  upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
                                  Update smartgarden from @2.0.0 to @2.0.1
                                  NPM version: 10.7.0
                                  Installing iobroker.smartgarden@2.0.1... (System call)
                                  Update "system.adapter.smartgarden.0"
                                  upload [4] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [3] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/index_m.html index_m.html text/html
                                  upload [2] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [1] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/smartgarden.png smartgarden.png image/png
                                  upload [0] smartgarden.admin /opt/iobroker/node_modules/iobroker.smartgarden/admin/tsconfig.json tsconfig.json application/json
                                  Update samsung from @0.5.11 to @0.6.0
                                  NPM version: 10.7.0
                                  Installing iobroker.samsung@0.6.0... (System call)
                                  Update "system.adapter.samsung.0"
                                  upload [1] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/index.html index.html text/html
                                  upload [0] samsung.admin /opt/iobroker/node_modules/iobroker.samsung/admin/samsung.png samsung.png image/png
                                  Update sainlogic from @0.10.5 to @0.11.4
                                  NPM version: 10.7.0
                                  Installing iobroker.sainlogic@0.11.4... (System call)
                                  Update "system.adapter.sainlogic.0"
                                  upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
                                  upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
                                  upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
                                  upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
                                  Update panasonic-viera from @2.0.0 to @2.1.0
                                  NPM version: 10.7.0
                                  Installing iobroker.panasonic-viera@2.1.0... (System call)
                                  Update "system.adapter.panasonic-viera.0"
                                  upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.html text/html
                                  upload [2] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index_m.html index_m.html text/html
                                  upload [1] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/panasonic-viera.png panasonic-viera.png image/png
                                  upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js application/javascript
                                  Update modbus from @6.1.0 to @6.2.3
                                  NPM version: 10.7.0
                                  Installing iobroker.modbus@6.2.3... (System call)
                                  Update "system.adapter.modbus.0"
                                  upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/asset-manifest.json asset-manifest.json application/json
                                  upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                  upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index_m.html index_m.html text/html
                                  upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/manifest.json manifest.json application/json
                                  upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png
                                  upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css static/css/main.96b3c861.css text/css
                                  upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/css/main.96b3c861.css.map static/css/main.96b3c861.css.map application/json
                                  upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js static/js/main.18496c94.js application/javascript
                                  upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.LICENSE.txt static/js/main.18496c94.js.LICENSE.txt text/plain
                                  upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/static/js/main.18496c94.js.map static/js/main.18496c94.js.map application/json
                                  Update javascript from @7.8.0 to @8.7.6
                                  NPM version: 10.7.0
                                  Installing iobroker.javascript@8.7.6... (System call)
                                  removed 1 package, and changed 2 packages in 4m
                                  Update "system.adapter.javascript.0"
                                  upload [881] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                  upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.fa0e4301.chunk.js application/javascript
                                  upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_object.js google-blockly/own/blocks_object.js application/javascript
                                  upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/css/864.4c85ffd6.chunk.css static/css/864.4c85ffd6.chunk.css text/css
                                  upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js static/js/173.4e774f7f.chunk.js application/javascript
                                  upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/26.79c81b4e.chunk.js static/js/26.79c81b4e.chunk.js application/javascript
                                  upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/320.d9816b46.chunk.js.map static/js/320.d9816b46.chunk.js.map application/json
                                  upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
                                  upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.97a46315.chunk.js.LICENSE.txt static/js/456.97a46315.chunk.js.LICENSE.txt text/plain
                                  upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/61.913ccfa8.chunk.js.map static/js/61.913ccfa8.chunk.js.map application/json
                                  upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/709.88d87b7c.chunk.js.map static/js/709.88d87b7c.chunk.js.map application/json
                                  upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/826.76c09000.chunk.js.map static/js/826.76c09000.chunk.js.map application/json
                                  upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/880.e4029d50.chunk.js static/js/880.e4029d50.chunk.js application/javascript
                                  upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/961.02d44700.chunk.js.map static/js/961.02d44700.chunk.js.map application/json
                                  upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.720010c8.js static/js/main.720010c8.js application/javascript
                                  upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Cellar.7ec1b1803a2437c8b78c.svg static/media/Cellar.7ec1b1803a2437c8b78c.svg image/svg+xml
                                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Room.3c380ab767be35f904e1.svg static/media/Living Room.3c380ab767be35f904e1.svg image/svg+xml
                                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/People.12a7e9127e72f3259186.svg static/media/People.12a7e9127e72f3259186.svg image/svg+xml
                                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Security.1ec78971bd34efa950f8.svg static/media/Security.1ec78971bd34efa950f8.svg image/svg+xml
                                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Storeroom.7de4e6f3364554459b8a.svg static/media/Storeroom.7de4e6f3364554459b8a.svg image/svg+xml
                                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
                                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                  Update ical from @1.14.3 to @1.15.0
                                  NPM version: 10.7.0
                                  Installing iobroker.ical@1.15.0... (System call)
                                  Update "system.adapter.ical.0"
                                  upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [13] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [12] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [11] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [10] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [9] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [8] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [7] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [6] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [5] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
                                  upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
                                  upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                  Update discord from @2.2.0 to @2.4.0
                                  NPM version: 10.7.0
                                  Installing iobroker.discord@2.4.0... (System call)
                                  Update "system.adapter.discord.0"
                                  upload [18] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/blockly.js blockly.js application/javascript
                                  upload [17] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-text.svg channel-text.svg image/svg+xml
                                  upload [16] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/channel-voice.svg channel-voice.svg image/svg+xml
                                  upload [15] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/discord.png discord.png image/png
                                  upload [14] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/de.json i18n/de.json application/json
                                  upload [13] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/en.json i18n/en.json application/json
                                  upload [12] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/es.json i18n/es.json application/json
                                  upload [11] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/fr.json i18n/fr.json application/json
                                  upload [10] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/it.json i18n/it.json application/json
                                  upload [9] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/nl.json i18n/nl.json application/json
                                  upload [8] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pl.json i18n/pl.json application/json
                                  upload [7] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/pt.json i18n/pt.json application/json
                                  upload [6] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/ru.json i18n/ru.json application/json
                                  upload [5] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/uk.json i18n/uk.json application/json
                                  upload [4] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                                  upload [3] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/index_m.html index_m.html text/html
                                  upload [2] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [1] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/jsonCustom.json jsonCustom.json application/json
                                  upload [0] discord.admin /opt/iobroker/node_modules/iobroker.discord/admin/style.css style.css text/css
                                  Update chromecast from @3.2.0 to @3.4.0
                                  NPM version: 10.7.0
                                  Installing iobroker.chromecast@3.4.0... (System call)
                                  changed 1 package in 17s
                                  Update "system.adapter.chromecast.0"
                                  upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                  upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                  upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                  upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                  Update botvac from @2.0.2 to @2.2.0
                                  NPM version: 10.7.0
                                  Installing iobroker.botvac@2.2.0... (System call)
                                  Update "system.adapter.botvac.0"
                                  upload [1] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/botvac.png botvac.png image/png
                                  upload [0] botvac.admin /opt/iobroker/node_modules/iobroker.botvac/admin/index.html index.html text/html
                                  Update backitup from @2.10.11 to @2.11.0
                                  host.ioBroker Adapter "system.adapter.backitup.0" is stopped.
                                  host.ioBroker Adapter "system.adapter.backitup.1" is stopped.
                                  NPM version: 10.7.0
                                  Installing iobroker.backitup@2.11.0... (System call)
                                  Update "system.adapter.backitup.0"
                                  Update "system.adapter.backitup.1"
                                  upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                  upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                  upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                  upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                  upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                  upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                  upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                  upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                  upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                  upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                  upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                  upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                  host.ioBroker Adapter "system.adapter.backitup.0" is started
                                  host.ioBroker Adapter "system.adapter.backitup.1" is started
                                  code_textpi@ioBroker:~ $ iob update
                                  Used repository: stable
                                  Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                  Adapter    "botvac"       : 2.2.0    , installed 2.2.0
                                  Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                                  Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                                  Adapter    "deconz"       : 1.4.1    , installed 2.0.7
                                  Adapter    "discord"      : 2.4.0    , installed 2.4.0
                                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                  Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                  Controller "js-controller": 6.0.9    , installed 6.0.9
                                  Adapter    "lifx"         : 1.0.4    , installed 1.0.4
                                  Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "panasonic-viera": 2.1.0  , installed 2.1.0
                                  Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                  Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                  Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                  Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                  Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                    @mathias2803 sagte in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                    Was haste denn da installiert? Soweit ich das sehe ist 1.4.1 aktuell:
                                    github:	1.4.1
                                    latest:	1.4.1 for 88 days
                                    stable:	1.4.1 for 88 days
                                      Mathias2803 @Thomas Braun last edited by
                                      @thomas-braun said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                      iob start admin
                                      Die Benutzeroberfläche läuft wieder. Alle Adapter sind aktuell.
                                      Alle Instanzen außer "info.0" laufen wieder. Was die macht, weiß ich gar nicht.
                                      VIS läuft wieder.
                                      Alles ist aktuell etwas "träge", aber vielleicht macht er im Hintergrund noch sehr vieles
                                        info.0
                                        Den Info-Adapter gibt es nicht mehr. Schmeiß den raus.
                                        iob del info
                                          Homoran Global Moderator Administrators @Mathias2803 last edited by
                                          das könnte dir top sagen
                                            Mathias2803 @Homoran last edited by
                                            @homoran said in GLIBCXX_3.4.26 not found -> rm -v /home/pi/.pm2/logs/*.log:
                                            top
                                            Ist da alles in Ordnung?
                                            pi@ioBroker:~ $ top
                                            top - 12:29:25 up  1:17,  3 users,  load average: 0,64, 1,02, 1,85
                                            Tasks: 178 total,   1 running, 177 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s): 27,2 us,  2,8 sy,  0,0 ni, 69,6 id,  0,0 wa,  0,0 hi,  0,5 si,  0,0 st
                                            MiB Mem :   3838,7 total,    471,4 free,   1621,5 used,   1745,9 buff/cache
                                            MiB Swap:    100,0 total,     96,7 free,      3,2 used.   2089,3 avail Mem
                                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                            11821 iobroker  20   0  364272 251512  40980 S  69,5   6,4   7:10.41 iobroker.js-con
                                            12095 iobroker  20   0  246996 136616  40836 S  15,6   3,5   2:16.72 io.shelly.0
                                              992 pi        20   0   52788   3376   2440 S   7,3   0,1   7:39.68 rtl_433
                                            11887 iobroker  20   0  226156  85232  36328 S   4,6   2,2   1:01.07 io.influxdb.0
                                            12530 iobroker  20   0  256228 108964  37288 S   4,0   2,8   1:17.08 io.web.0
                                            11918 iobroker  20   0  293592 157764  40784 S   3,6   4,0   1:54.33 io.javascript.0
                                            12040 iobroker  20   0  227228  97940  36892 S   3,0   2,5   1:19.58 io.mqtt.0
                                            12569 iobroker  20   0  193616  63756  36936 S   2,6   1,6   0:07.09 io.sainlogic.0
                                            12145 iobroker  20   0  209428  85356  40776 S   2,0   2,2   0:32.93 io.shelly.1
                                             1843 influxdb  20   0 1041476 166020  26936 S   1,3   4,2   3:52.60 influxd
                                              513 pi        20   0  179416  75840  31176 S   1,0   1,9   0:47.37 deCONZ
                                            12024 iobroker  20   0  195160  65640  36332 S   1,0   1,7   0:09.64 io.modbus.0
                                            12077 iobroker  20   0  196160  67412  36264 S   1,0   1,7   0:11.80 io.ping.0
                                            11954 iobroker  20   0  214464  82464  37168 S   0,7   2,1   0:37.26 io.alexa2.0
                                            15704 pi        20   0   10420   3076   2540 R   0,7   0,1   0:00.21 top
                                              121 root      20   0   29596  17944  16856 S   0,3   0,5   0:05.99 systemd-journal
                                              459 root      20   0   25500   3404   2500 S   0,3   0,1   0:02.04 rsyslogd
                                            11857 iobroker  20   0  248996 125240  42016 S   0,3   3,2   0:50.79 io.admin.0
                                            11992 iobroker  20   0  202952  77088  41276 S   0,3   2,0   0:08.37 io.backitup.1
                                            12016 iobroker  20   0  197736  68088  36264 S   0,3   1,7   0:08.56 io.chromecast.0
                                            12137 root      20   0       0      0      0 I   0,3   0,0   0:01.08 kworker/u8:0-brcmf_wq/mmc1:0001:1
                                            14850 root      20   0       0      0      0 I   0,3   0,0   0:00.13 kworker/0:2-events
                                                1 root      20   0   34852   8344   6420 S   0,0   0,2   0:09.06 systemd
                                                2 root      20   0       0      0      0 S   0,0   0,0   0:00.02 kthreadd
                                                3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                                                4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                                                8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                                                9 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_rude_
                                               10 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_trace
                                               11 root      20   0       0      0      0 S   0,0   0,0   0:03.40 ksoftirqd/0
                                               12 root      20   0       0      0      0 I   0,0   0,0   0:04.34 rcu_sched
                                               13 root      rt   0       0      0      0 S   0,0   0,0   0:00.17 migration/0
                                               14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                                               15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                                               16 root      rt   0       0      0      0 S   0,0   0,0   0:00.16 migration/1
                                               17 root      20   0       0      0      0 S   0,0   0,0   0:00.53 ksoftirqd/1
                                               20 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                                               21 root      rt   0       0      0      0 S   0,0   0,0   0:00.14 migration/2
                                               22 root      20   0       0      0      0 S   0,0   0,0   0:00.55 ksoftirqd/2
                                               25 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                                               26 root      rt   0       0      0      0 S   0,0   0,0   0:00.12 migration/3
                                               27 root      20   0       0      0      0 S   0,0   0,0   0:00.47 ksoftirqd/3
                                               30 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kdevtmpfs
                                               31 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                                               34 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                                               36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 khungtaskd
                                               37 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                                               38 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                                               39 root      20   0       0      0      0 S   0,0   0,0   0:00.26 kcompactd0
                                               59 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                                               60 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                                               61 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                                               63 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                                               65 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 xprtiod
                                               68 root      20   0       0      0      0 S   0,0   0,0   0:02.08 kswapd0
                                               69 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nfsiod
                                               70 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
                                            2762
