    4. Probleme beim Update Host node.js
      keineAhnungvonProgrmieren last edited by
      Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Get:2 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:3 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
      Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:6 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
      Get:7 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
      Get:8 http://deb.debian.org/debian bullseye/main armhf Packages [7,840 kB]
      Get:9 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [317 kB]
      Get:10 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [9,857 B]
      Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [311 kB]
      Get:12 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages [9,794 B]
      Get:13 http://security.debian.org/debian-security bullseye-security/main Translation-en [180 kB]
      Get:14 http://deb.debian.org/debian bullseye/main arm64 Packages [7,956 kB]
      Get:15 http://deb.debian.org/debian bullseye/main Translation-en [6,236 kB]
      Get:16 http://deb.debian.org/debian bullseye/contrib arm64 Packages [40.8 kB]
      Get:17 http://deb.debian.org/debian bullseye/non-free armhf Packages [56.0 kB]
      Get:18 http://deb.debian.org/debian bullseye/non-free arm64 Packages [72.3 kB]
      Get:19 http://deb.debian.org/debian bullseye/non-free Translation-en [92.5 kB]
      Fetched 23.9 MB in 19s (1,251 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      99 packages can be upgraded. Run 'apt list --upgradable' to see them.
      N: Repository 'http://deb.debian.org/debian bullseye InRelease' changed its 'Version' value from '11.9' to '11.10'
      Hatte über die update funktion in der übersicht probiert:
      Leider ohne erfolg
        Thomas Braun Most Active @keineAhnungvonProgrmieren last edited by
        @keineahnungvonprogrmieren sagte in Probleme beim Update Host node.js:
        ??? Welche Übersicht?
        Und bitte vollständig inkl. LogIn Prompt vor und nach der Ausgabe posten, damit man sieht das die Ausgabe da aufhört.
        sudo apt full-upgrade
        sagt nun?
        T K 2 Replies Last reply Reply Quote 0
          TT-Tom @Thomas Braun last edited by TT-Tom
          Die Admin Kachel in der Übersicht hat bei einer neuen Node Version hinter den Wert / Version ein runden Pfeil. Da kann man klicken und es wird ein Update ausgeführt.
            Thomas Braun Most Active @TT-Tom last edited by
            @tt-tom sagte in Probleme beim Update Host node.js:
            Die Admin Kachel in der Übersicht hat bei einer neuen Node Version ein runden Pfeil. Da kann man klicken und aus wird ein Update ausgeführt.
            Ja, das funktioniert aber nur, wenn der Rest des Systems auch einigermaßen auf Stand ist.
            Ist er bei dir aber nicht.
            Homoran K 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
              @thomas-braun sagte in Probleme beim Update Host node.js:
              falscher adressat!
                @homoran sagte in Probleme beim Update Host node.js:
                falscher adressat!
                🙂 Stimmt. Habsch net gesähn...
                  keineAhnungvonProgrmieren @Thomas Braun last edited by keineAhnungvonProgrmieren
                  SmartHome@SmartHome:~ $ sudo apt full-upgrade
                  E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
                  Danke fürs Helfen
                    @thomas-braun said in Probleme beim Update Host node.js:
                    Ich denke das Du mein System meinst welches nicht auf Stand ist.
                    Ich mache immer ein update sobals es mir angezeigt wird in der Admin Weboberfläche.
                    Gibt es da noch mehr was man regelmäsig machen sollte?
                    Wenn ja wie?
                    Danke.
                        Wenn ja wie?
                        Da werden bzw. wurden aber keine Updates des Betriebssystems angezeigt. Auch das muss aktuell gehalten werden. Geht per
                        sudo apt update
                        Anschließender Neustart ist oft auch empfohlen.
                        iob stop
                        sudo reboot
                          Wenn ja wie?
                          sudo apt update
                          iob stop
                          sudo reboot
                          Super Danke, da hat sich was getan.
                          SmartHome@SmartHome:~ $ sudo apt update
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                          All packages are up to date.
                          in dder weboberfläche wird mir aber immernoch angezeigt das es ein Update beim Node.js. gibt.
                          Wenn ich auf Update drücke wird mir geschrieben das es erfolgreich ist allerding zeigt er mir immer noch die alter version an.
                          oder deute ich das falsch?
                            Jein. Hau da per
                            iob nodejs-update
                            die aktuell empfohlene nodejs@20 rein.
                              Jein. Hau da per
                              iob nodejs-update
                              so?
                              SmartHome@SmartHome:~ $ iob nodejs-update
                              iobroker nodejs-update [<major-version>]
                              Upgrade the Node.JS installation to the current LTS
                              Options:
                                --help  Show help  [boolean]
                                Zuvor:
                                iob stop
                                iob fix
                                dann dürfte es funktionieren.
                                  Zuvor:
                                  iob stop
                                  iob fix
                                  hat zuerst funktioniert
                                  nach ca 10min war die weboberfläche noch nicht erreichbar im anschluss von mir
                                  iob reboot
                                  danach
                                  SmartHome@SmartHome:~ $ iob reboot
                                  iobroker [command]
                                  Commands:
                                    iobroker setup                                               Setup ioBroker
                                    iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                                    iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                                    iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                                    iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                    iobroker info                                                Shows the host info
                                    iobroker logs [<adapter>]                                    Monitor log
                                    iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                    iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                    iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                    iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
                                    iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                    iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                    iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                    iobroker upgrade                                             Upgrade management
                                    iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                    iobroker object                                              Object management  [aliases: o]
                                    iobroker state                                               State management  [aliases: s]
                                    iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                    iobroker list <type> [<filter>]                              List all entries, like objects
                                    iobroker chmod <mode> <file>                                 Change file rights
                                    iobroker chown <user> <group> <file>                         Change file ownership
                                    iobroker touch <file>                                        Touch file
                                    iobroker rm <file>                                           Remove file
                                    iobroker file                                                File management
                                    iobroker user                                                User commands
                                    iobroker group                                               group management
                                    iobroker host <hostname>                                     Set host to given hostname
                                    iobroker set <adapter>.<instance>                            Change settings of adapter config
                                    iobroker license <license.file or license.text>              Update license by given file
                                    iobroker cert                                                Certificate management
                                    iobroker clean <yes>                                         Clears all objects and states
                                    iobroker backup                                              Create backup
                                    iobroker restore <backup name or path>                       Restore a specified backup
                                    iobroker validate <backup name or path>                      Validate a specified backup
                                    iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                    iobroker repo [<name>]                                       Show repo information
                                    iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                    iobroker unsetup                                             Reset license, installation secret and language
                                    iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                    iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                                    iobroker multihost                                           Multihost management
                                    iobroker compact                                             compact group management
                                    iobroker plugin                                              Plugin management
                                    iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                                    iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                                  Options:
                                  Thomas Braun K 2 Replies Last reply Reply Quote 0
                                    iob reboot
                                    Ist mir neu...
                                    sudo reboot
                                    kenne ich aber.
                                      keineAhnungvonProgrmieren @keineAhnungvonProgrmieren last edited by
                                      @keineahnungvonprogrmieren said in Probleme beim Update Host node.js:
                                      Zuvor:
                                      iob stop
                                      iob fix
                                      iob reboot
                                      danach
                                      iobroker [command]
                                      Commands:
                                      Options:
                                      jetzt:
                                      C:\Users\Benutzer1> ssh SmartHome@Smarthome
                                      Warning: Permanently added the ECDSA host key for IP address 'fd00::669a:fed7:8333:5b02' to the list of known hosts.
                                      SmartHome@smarthome password:
                                      ssh_dispatch_run_fatal: Connection to fd00::669a:fed7:8333:5b02 port 22: Connection timed out
                                        Warten oder über die IP versuchen. Da hat es deine ssh keys verwürfelt. Hat aber mit dem nodejs Update nix zu tun, das packt die nämlich nicht an.
                                          puh läuft wieder
                                          Danke euch allen für die Konstruktiven antworten👏
                                            @thomas-braun said in Probleme beim Update Host node.js [gelöst]:
                                            ok scheinbar habe ich mir ein neues Problem eingefangen
                                            bin mir nicht sicher ob es was mit dem update was zu tun hat allerding lief bis zu dem Update der letzten Tage der IO Broker sehr stabil.
                                            Nun zu meinen Beobachtungen:
                                            wenn ich über comand auf den Raspberry zugreifen möchte dann wird diese verbindung sehr schnell wieder unterbrochen. manchmal reicht die Zeit um befehle plazieren zu können und mit etwas Glück reicht es für die eigendiagnose mit folgendem inhalt
                                            *** iob diag is starting up, please wait ***
                                            client_loop: send disconnect: Connection reset
                                            C:\Users\Benutzer1>ssh SmartHome@Smarthome
                                            Linux SmartHome 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                            The programs included with the Debian GNU/Linux system are free software;
                                            the exact distribution terms for each program are described in the
                                            individual files in /usr/share/doc/*/copyright.
                                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                            permitted by applicable law.
                                            Last login: Tue Aug  6 19:53:43 2024 from 192.168.178.71
                                            Wi-Fi is currently blocked by rfkill.
                                            Use raspi-config to set the country before use.
                                            SmartHome@SmartHome:~ $ sudoclient_loop: send disconnect: Connection reset
                                            C:\Users\Benutzer1>ssh SmartHome@smarthome
                                            SmartHome@SmartHome:~ $ iob start admin.0
                                            SmartHome@SmartHome:~ $ client_loop: send disconnect: Connection reset
                                            SmartHomeRohlik@smarthomerohlik's password:
                                            Permission denied, please try again.
                                            Last login: Wed Aug  7 05:17:40 2024 from 192.168.178.71
                                            SmartHome@SmartHome:~ $ iob stop
                                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                                            Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                            Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
                                            Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
                                            Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [181 kB]
                                            Fetched 827 kB in 1s (557 kB/s)
                                            1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                            SmartHome@SmartHome:~ $ sudo apt upgrade
                                            Calculating upgrade... Done
                                            The following packages will be upgraded:
                                              wpasupplicant
                                            1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                            Need to get 1,189 kB of archives.
                                            After this operation, 10.2 kB disk space will be freed.
                                            Do you want to continue? [Y/n] y
                                            Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 wpasupplicant arm64 2:2.9.0-21+deb11u2 [1,189 kB]
                                            Fetched 1,189 kB in 1s (1,588 kB/s)
                                            Reading changelogs... Done
                                            (Reading database ... 50170 files and directories currently installed.)
                                            Preparing to unpack .../wpasupplicant_2%3a2.9.0-21+deb11u2_arm64.deb ...
                                            Unpacking wpasupplicant (2:2.9.0-21+deb11u2) over (2:2.9.0-21) ...
                                            Setting up wpasupplicant (2:2.9.0-21+deb11u2) ...
                                            Processing triggers for man-db (2.9.4-2) ...
                                            Processing triggers for dbus (1.12.28-0+deb11u1) ...
                                            SmartHomeRohlik@SmartHomeRohlik:~ $ sudo reboot
                                            Connection to smarthomerohlik closed by remote host.
                                            Connection to smarthomerohlik closed.
                                            Linux SmartHomeRohlik 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                            Last login: Wed Aug  7 05:20:31 2024 from 192.168.178.71
                                            SmartHome@SmartHome:~ $ iob update
                                            Used repository: stable
                                            Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                            Adapter    "backitup"     : 3.0.16   , installed 2.11.0 [Updatable]
                                            Adapter    "bshb"         : 0.2.8    , installed 0.2.8
                                            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                            Controller "js-controller": 6.0.9    , installed 6.0.9
                                            Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
                                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                            Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
                                            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
                                            Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
                                            SmartHomeRohlik@SmartHomeRohlik:~ $ client_loop: send disconnect: Connection reset
                                            Auf die web oberfläche kann ich fast garnicht zugreifen, wenn es mal klappt dann kommt gelegentlich folgende Fehlermeldung:
                                            wenn ich dem link folge dann soll ich die Admin updaten was aber schwer ist da ich ständig die verbindung via Comand verliere.
                                            Hat jemand eine Idee was ich jetzt machen kann?
                                            4188
