      tobiasp @Guest last edited by
      @ilovegym
      Nein nur eine Instanz
        A Former User @tobiasp last edited by
        @tobiasp
        und was zeigt das Log, wenn du die Instanz startest? Da wird doch schoen gezeigt, wie die NPM Module installiert werden..
        Poste das doch hier bitte mal.. in Code-Tags, bitte
        A 1 Reply Last reply Reply Quote 2
          aSilentSniper @Guest last edited by aSilentSniper
          @ilovegym hi ich habe den selben fehler und habe das selbe probiert leider geht es immer noch nicht hier der log:
          Node-js: v20.16.0
          NPM: 10.8.1
          Javascript: v8.7.6
          javascript.0
          2024-08-05 16:51:39.967	info	script.js.NSPanel.NSPanel_1_4401: End MQTT-Port-Check ---------------------------------------
          javascript.0
          2024-08-05 16:51:39.967	info	script.js.NSPanel.NSPanel_1_4401: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884
          javascript.0
          2024-08-05 16:51:39.966	info	script.js.NSPanel.NSPanel_1_4401: -- zigbee.0 - tcp
          javascript.0
          2024-08-05 16:51:39.965	info	script.js.NSPanel.NSPanel_1_4401: -- web.0 - 8082
          javascript.0
          2024-08-05 16:51:39.965	info	script.js.NSPanel.NSPanel_1_4401: -- telegram.0 - 8443
          javascript.0
          2024-08-05 16:51:39.965	info	script.js.NSPanel.NSPanel_1_4401: -- sonoff.0 - 1883
          javascript.0
          2024-08-05 16:51:39.964	info	script.js.NSPanel.NSPanel_1_4401: -- socketio.0 - 8084
          javascript.0
          2024-08-05 16:51:39.964	info	script.js.NSPanel.NSPanel_1_4401: -- simple-api.0 - 8087
          javascript.0
          2024-08-05 16:51:39.963	info	script.js.NSPanel.NSPanel_1_4401: -- shelly.0 - 1882
          javascript.0
          2024-08-05 16:51:39.963	info	script.js.NSPanel.NSPanel_1_4401: -- mqtt.0 - 1884
          javascript.0
          2024-08-05 16:51:39.962	info	script.js.NSPanel.NSPanel_1_4401: -- influxdb.0 - 8086
          javascript.0
          2024-08-05 16:51:39.962	info	script.js.NSPanel.NSPanel_1_4401: -- admin.0 - 8081
          javascript.0
          2024-08-05 16:51:39.961	info	script.js.NSPanel.NSPanel_1_4401: Start MQTT-Port-Check -------------------------------------
          javascript.0
          2024-08-05 16:51:37.412	info	script.js.NSPanel.NSPanel_1_4401: Installed TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:37.410	info	script.js.NSPanel.NSPanel_1_4401: Desired TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:37.294	info	script.js.NSPanel.NSPanel_1_4401: Installed TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:37.293	info	script.js.NSPanel.NSPanel_1_4401: Desired TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:36.950	debug	[sunTimeSchedules] Next: 2024-08-05T22:00:01.000Z
          javascript.0
          2024-08-05 16:51:36.580	info	script.js.NSPanel.NSPanel_1_4401: Debug mode disabled
          javascript.0
          2024-08-05 16:51:36.455	info	script.js.NSPanel.NSPanel_1_4401: Installed TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:36.455	info	script.js.NSPanel.NSPanel_1_4401: Desired TFT Firmware: 53 / v4.4.0
          javascript.0
          2024-08-05 16:51:36.152	info	script.js.NSPanel.NSPanel_1_4401: No Updates for NSPanel available
          javascript.0
          2024-08-05 16:51:36.141	info	script.js.NSPanel.NSPanel_1_4401: registered 28 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:36.141	info	script.js.NSPanel.NSPanel_1_4401: No Updates for NSPanel available
          javascript.0
          2024-08-05 16:51:36.051	info	script.js.NSPanel.NSPanel_1_4401: weather alias for accuweather.0. already exists
          javascript.0
          2024-08-05 16:51:36.042	info	script.js.NSPanel.NSPanel_1_4401: setObjects enabled - create Alias Channels possible
          javascript.0
          2024-08-05 16:51:36.015	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:36.014	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:36.014	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:36.014	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:36.014	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
          javascript.0
          2024-08-05 16:51:36.014	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
          javascript.0
          2024-08-05 16:51:36.014	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:36.013	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:36.013	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:36.013	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:36.012	debug	Try direct require of "dayjs/locale/zh-tw" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:36.011	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:36.011	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:36.011	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:36.011	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:36.010	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
          javascript.0
          2024-08-05 16:51:36.010	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
          javascript.0
          2024-08-05 16:51:36.010	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:36.010	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:36.010	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:36.010	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:36.009	debug	Try direct require of "dayjs/locale/zh-cn" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:36.008	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:36.007	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:36.007	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:36.007	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:36.007	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
          javascript.0
          2024-08-05 16:51:36.007	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
          javascript.0
          2024-08-05 16:51:36.007	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:36.006	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:36.006	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:36.006	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:36.005	debug	Try direct require of "dayjs/locale/vi" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:36.004	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:36.004	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:36.004	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:36.004	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:36.003	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
          javascript.0
          2024-08-05 16:51:36.003	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
          javascript.0
          2024-08-05 16:51:36.003	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:36.003	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:36.003	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:36.003	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:36.002	debug	Try direct require of "dayjs/locale/uk" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:36.001	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:36.000	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:36.000	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:36.000	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:36.000	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
          javascript.0
          2024-08-05 16:51:36.000	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
          javascript.0
          2024-08-05 16:51:36.000	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:36.000	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.999	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.999	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.998	debug	Try direct require of "dayjs/locale/tr" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.997	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.997	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.997	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.997	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.997	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
          javascript.0
          2024-08-05 16:51:35.996	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
          javascript.0
          2024-08-05 16:51:35.996	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.996	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.996	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.996	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.995	debug	Try direct require of "dayjs/locale/th" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.994	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.994	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.993	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.993	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.993	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
          javascript.0
          2024-08-05 16:51:35.993	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
          javascript.0
          2024-08-05 16:51:35.993	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.993	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.992	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.992	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.991	debug	Try direct require of "dayjs/locale/sv" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.990	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.990	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.990	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.989	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.989	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
          javascript.0
          2024-08-05 16:51:35.989	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
          javascript.0
          2024-08-05 16:51:35.989	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.989	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.989	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.988	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.987	debug	Try direct require of "dayjs/locale/sl" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.986	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.986	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.986	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.986	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.986	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
          javascript.0
          2024-08-05 16:51:35.985	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
          javascript.0
          2024-08-05 16:51:35.985	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.985	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.985	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.985	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.984	debug	Try direct require of "dayjs/locale/sk" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.983	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.983	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.982	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.982	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.982	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
          javascript.0
          2024-08-05 16:51:35.982	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
          javascript.0
          2024-08-05 16:51:35.982	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.982	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.981	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.981	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.980	debug	Try direct require of "dayjs/locale/ro" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.979	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.979	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.979	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.979	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.979	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
          javascript.0
          2024-08-05 16:51:35.978	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
          javascript.0
          2024-08-05 16:51:35.978	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.978	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.978	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.977	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.976	debug	Try direct require of "dayjs/locale/lt" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.975	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.975	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.975	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.975	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.975	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
          javascript.0
          2024-08-05 16:51:35.974	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
          javascript.0
          2024-08-05 16:51:35.974	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.974	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.974	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.974	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.973	debug	Try direct require of "dayjs/locale/lb" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.972	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.972	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.971	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.971	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.971	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
          javascript.0
          2024-08-05 16:51:35.971	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
          javascript.0
          2024-08-05 16:51:35.971	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.971	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.971	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.970	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.969	debug	Try direct require of "dayjs/locale/is" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.968	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.968	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.968	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.968	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.968	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
          javascript.0
          2024-08-05 16:51:35.967	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
          javascript.0
          2024-08-05 16:51:35.967	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.967	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.967	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.967	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.966	debug	Try direct require of "dayjs/locale/id" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.965	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.964	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.964	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.964	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.964	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
          javascript.0
          2024-08-05 16:51:35.964	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
          javascript.0
          2024-08-05 16:51:35.964	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.963	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.963	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.963	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.962	debug	Try direct require of "dayjs/locale/hy-am" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.961	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.961	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.961	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.960	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.960	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
          javascript.0
          2024-08-05 16:51:35.960	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
          javascript.0
          2024-08-05 16:51:35.960	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.960	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.960	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.959	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.958	debug	Try direct require of "dayjs/locale/hu" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.957	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.957	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.957	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.957	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.957	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
          javascript.0
          2024-08-05 16:51:35.956	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
          javascript.0
          2024-08-05 16:51:35.956	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.956	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.956	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.956	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.955	debug	Try direct require of "dayjs/locale/hr" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.954	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.953	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.953	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.953	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.953	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
          javascript.0
          2024-08-05 16:51:35.953	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
          javascript.0
          2024-08-05 16:51:35.952	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.952	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.952	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.952	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.951	debug	Try direct require of "dayjs/locale/he" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.949	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.949	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.949	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.949	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.949	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
          javascript.0
          2024-08-05 16:51:35.949	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
          javascript.0
          2024-08-05 16:51:35.948	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.948	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.948	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.948	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.947	debug	Try direct require of "dayjs/locale/fi" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.945	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.945	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.945	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.945	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.945	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
          javascript.0
          2024-08-05 16:51:35.944	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
          javascript.0
          2024-08-05 16:51:35.944	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.944	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.943	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.943	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.942	debug	Try direct require of "dayjs/locale/fa" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.941	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.941	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.941	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.941	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.940	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
          javascript.0
          2024-08-05 16:51:35.940	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
          javascript.0
          2024-08-05 16:51:35.940	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.940	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.940	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.940	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.939	debug	Try direct require of "dayjs/locale/et" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.938	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.937	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.937	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.937	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.937	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
          javascript.0
          2024-08-05 16:51:35.937	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
          javascript.0
          2024-08-05 16:51:35.936	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.936	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.936	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.936	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.935	debug	Try direct require of "dayjs/locale/el" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.934	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.934	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.933	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.933	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.933	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
          javascript.0
          2024-08-05 16:51:35.933	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
          javascript.0
          2024-08-05 16:51:35.933	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.932	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.932	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.932	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.931	debug	Try direct require of "dayjs/locale/cs" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.929	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.929	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.929	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.929	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.929	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
          javascript.0
          2024-08-05 16:51:35.929	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
          javascript.0
          2024-08-05 16:51:35.928	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.928	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.928	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.928	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.927	debug	Try direct require of "dayjs/locale/ca" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.926	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.926	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.925	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.925	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.925	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
          javascript.0
          2024-08-05 16:51:35.925	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
          javascript.0
          2024-08-05 16:51:35.925	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.924	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.924	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.924	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.923	debug	Try direct require of "dayjs/locale/bg" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.922	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.922	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.922	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.922	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.921	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
          javascript.0
          2024-08-05 16:51:35.921	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
          javascript.0
          2024-08-05 16:51:35.921	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.921	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.921	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.920	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.919	debug	Try direct require of "dayjs/locale/ar" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.918	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.918	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.918	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.918	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.917	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
          javascript.0
          2024-08-05 16:51:35.917	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
          javascript.0
          2024-08-05 16:51:35.917	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.917	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.917	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.917	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.916	debug	Try direct require of "dayjs/locale/af" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.915	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.914	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.914	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.914	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.914	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
          javascript.0
          2024-08-05 16:51:35.913	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
          javascript.0
          2024-08-05 16:51:35.913	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.913	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.913	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.913	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.912	debug	Try direct require of "dayjs/locale/pt" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.910	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.910	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.910	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.910	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.910	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
          javascript.0
          2024-08-05 16:51:35.909	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
          javascript.0
          2024-08-05 16:51:35.909	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.909	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.909	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.909	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.908	debug	Try direct require of "dayjs/locale/pl" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.907	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.906	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.906	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.906	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.906	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
          javascript.0
          2024-08-05 16:51:35.906	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
          javascript.0
          2024-08-05 16:51:35.906	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.905	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.905	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.905	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.904	debug	Try direct require of "dayjs/locale/nn" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.903	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.903	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.903	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.902	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.902	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
          javascript.0
          2024-08-05 16:51:35.902	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
          javascript.0
          2024-08-05 16:51:35.902	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.902	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.901	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.901	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.900	debug	Try direct require of "dayjs/locale/nb" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.899	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.899	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.898	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.898	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.898	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
          javascript.0
          2024-08-05 16:51:35.898	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
          javascript.0
          2024-08-05 16:51:35.898	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.897	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.897	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.897	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.896	debug	Try direct require of "dayjs/locale/ru" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.894	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.894	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.894	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.894	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.893	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
          javascript.0
          2024-08-05 16:51:35.893	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
          javascript.0
          2024-08-05 16:51:35.893	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.893	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.893	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.892	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.891	debug	Try direct require of "dayjs/locale/it" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.890	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.890	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.890	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.890	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.889	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
          javascript.0
          2024-08-05 16:51:35.889	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
          javascript.0
          2024-08-05 16:51:35.889	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.889	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.888	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.888	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.887	debug	Try direct require of "dayjs/locale/fr" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.886	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.886	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.885	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.885	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.885	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
          javascript.0
          2024-08-05 16:51:35.885	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
          javascript.0
          2024-08-05 16:51:35.885	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.884	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.884	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.884	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.883	debug	Try direct require of "dayjs/locale/es" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.882	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.882	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.881	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.881	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.881	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
          javascript.0
          2024-08-05 16:51:35.881	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
          javascript.0
          2024-08-05 16:51:35.881	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.880	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.880	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.880	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.878	debug	Try direct require of "dayjs/locale/da" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.877	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.877	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.877	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.877	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.876	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
          javascript.0
          2024-08-05 16:51:35.876	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
          javascript.0
          2024-08-05 16:51:35.876	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.876	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.876	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.875	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.874	debug	Try direct require of "dayjs/locale/nl" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.872	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          javascript.0
          2024-08-05 16:51:35.872	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
          javascript.0
          2024-08-05 16:51:35.872	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          javascript.0
          2024-08-05 16:51:35.871	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
          javascript.0
          2024-08-05 16:51:35.871	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
          javascript.0
          2024-08-05 16:51:35.871	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
          javascript.0
          2024-08-05 16:51:35.871	error	at require (node:internal/modules/helpers:179:18)
          javascript.0
          2024-08-05 16:51:35.871	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
          javascript.0
          2024-08-05 16:51:35.870	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          javascript.0
          2024-08-05 16:51:35.870	error	script.js.NSPanel.NSPanel_1_4401: Error: Cannot find module 'dayjs'
          javascript.0
          2024-08-05 16:51:35.865	debug	Try direct require of "dayjs/locale/de" as not specified in the additional dependencies
          javascript.0
          2024-08-05 16:51:35.725	info	script.js.NSPanel.NSPanel_1_4401: source code did not change, using cached compilation result...
          javascript.0
          2024-08-05 16:51:34.839	info	Compiling TypeScript source script.js.NSPanel.NSPanel_1_4401
          javascript.0
          2024-08-05 16:51:34.652	info	Watch /home/iobroker/backups/
          javascript.0
          2024-08-05 16:51:34.651	info	Watch /home/iobroker/backups/text_and_voice_output/
          javascript.0
          2024-08-05 16:51:34.651	info	Watch /home/iobroker/backups/notifications/
          javascript.0
          2024-08-05 16:51:34.650	info	Watch /home/iobroker/backups/global/
          javascript.0
          2024-08-05 16:51:34.650	info	Watch /home/iobroker/backups/epaperDisplays/
          javascript.0
          2024-08-05 16:51:34.649	info	Watch /home/iobroker/backups/Ventilatoren/
          javascript.0
          2024-08-05 16:51:34.648	info	Watch /home/iobroker/backups/TestFolder/
          javascript.0
          2024-08-05 16:51:34.646	info	Watch /home/iobroker/backups/TV/
          javascript.0
          2024-08-05 16:51:34.645	info	Watch /home/iobroker/backups/Rollos/
          javascript.0
          2024-08-05 16:51:34.644	info	Watch /home/iobroker/backups/NSPanel/
          javascript.0
          2024-08-05 16:51:34.642	info	Watch /home/iobroker/backups/Misc/
          javascript.0
          2024-08-05 16:51:34.639	info	Watch /home/iobroker/backups/Licht/
          javascript.0
          2024-08-05 16:51:34.636	info	Watch /home/iobroker/backups/Heizung/
          javascript.0
          2024-08-05 16:51:34.635	info	Watch /home/iobroker/backups/Alarm/
          javascript.0
          2024-08-05 16:51:34.633	info	Watch /home/iobroker/backups/Akkustände/
          javascript.0
          2024-08-05 16:51:34.630	info	Created script file on disk /home/iobroker/backups/Akkustände/Akku_Rollos.js
          javascript.0
          2024-08-05 16:51:34.629	info	Created script file on disk /home/iobroker/backups/Akkustände/Akku_Tablet_Flur.js
          javascript.0
          2024-08-05 16:51:34.628	info	Created script file on disk /home/iobroker/backups/Akkustände/Akku_Tablet_Wohnzimmer.js
          javascript.0
          2024-08-05 16:51:34.627	info	Created script file on disk /home/iobroker/backups/Heizung/Heizung_Badezimmer.js
          javascript.0
          2024-08-05 16:51:34.626	info	Created script file on disk /home/iobroker/backups/Heizung/Heizung_Kinderzimmer.js
          javascript.0
          2024-08-05 16:51:34.625	info	Created script file on disk /home/iobroker/backups/Heizung/Heizung_Küche.js
          javascript.0
          2024-08-05 16:51:34.624	info	Created script file on disk /home/iobroker/backups/Heizung/Heizung_Schlafzimmer.js
          javascript.0
          2024-08-05 16:51:34.623	info	Created script file on disk /home/iobroker/backups/Heizung/Heizung_Wohnzimmer.js
          javascript.0
          2024-08-05 16:51:34.622	info	Created script file on disk /home/iobroker/backups/Heizung/Modus_Steuerung.js
          javascript.0
          2024-08-05 16:51:34.621	info	Created script file on disk /home/iobroker/backups/Licht/LICHT_ALLES_AUS.js
          javascript.0
          2024-08-05 16:51:34.620	info	Created script file on disk /home/iobroker/backups/Licht/LichtSchalter_Nachttisch.js
          javascript.0
          2024-08-05 16:51:34.619	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Kinderzimmer.js
          javascript.0
          2024-08-05 16:51:34.618	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Schlafzimmer.js
          javascript.0
          2024-08-05 16:51:34.617	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Wohnzimmer.js
          javascript.0
          2024-08-05 16:51:34.616	info	Created script file on disk /home/iobroker/backups/Licht/XMAS_LIGHTS.js
          javascript.0
          2024-08-05 16:51:34.615	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Badezimmer.js
          javascript.0
          2024-08-05 16:51:34.614	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Küche.js
          javascript.0
          2024-08-05 16:51:34.612	info	Created script file on disk /home/iobroker/backups/Licht/Licht_Flur.js
          javascript.0
          2024-08-05 16:51:34.612	info	Created script file on disk /home/iobroker/backups/Licht/PC_Ambiente.js
          javascript.0
          2024-08-05 16:51:34.611	info	Created script file on disk /home/iobroker/backups/Licht/Portable_Light01.js
          javascript.0
          2024-08-05 16:51:34.610	info	Created script file on disk /home/iobroker/backups/Licht/Portable_Light02.js
          javascript.0
          2024-08-05 16:51:34.609	info	Created script file on disk /home/iobroker/backups/Licht/Scheinwerfer.js
          javascript.0
          2024-08-05 16:51:34.607	info	Created script file on disk /home/iobroker/backups/Misc/3D_Printer.js
          javascript.0
          2024-08-05 16:51:34.606	info	Created script file on disk /home/iobroker/backups/Misc/Anruf_Erkennung.js
          javascript.0
          2024-08-05 16:51:34.605	info	Created script file on disk /home/iobroker/backups/Misc/Busy_Light.js
          javascript.0
          2024-08-05 16:51:34.604	info	Created script file on disk /home/iobroker/backups/Misc/Day_Night.js
          javascript.0
          2024-08-05 16:51:34.604	info	Created script file on disk /home/iobroker/backups/Misc/Heizmatte_AUS.js
          javascript.0
          2024-08-05 16:51:34.603	info	Created script file on disk /home/iobroker/backups/Misc/PC_Christian.js
          javascript.0
          2024-08-05 16:51:34.602	info	Created script file on disk /home/iobroker/backups/Misc/Reboot.js
          javascript.0
          2024-08-05 16:51:34.601	info	Created script file on disk /home/iobroker/backups/Misc/Zoidberg.js
          javascript.0
          2024-08-05 16:51:34.600	info	Created script file on disk /home/iobroker/backups/Misc/Shelly_Button.js
          javascript.0
          2024-08-05 16:51:34.599	info	Created script file on disk /home/iobroker/backups/Misc/Waschmaschine.js
          javascript.0
          2024-08-05 16:51:34.598	info	Created script file on disk /home/iobroker/backups/Misc/Time&Date.js
          javascript.0
          2024-08-05 16:51:34.597	info	Created script file on disk /home/iobroker/backups/Misc/Dishwasher.js
          javascript.0
          2024-08-05 16:51:34.597	info	Created script file on disk /home/iobroker/backups/Misc/DoorReminder.js
          javascript.0
          2024-08-05 16:51:34.595	info	Created script file on disk /home/iobroker/backups/Rollos/Rollo_Alle.js
          javascript.0
          2024-08-05 16:51:34.594	info	Created script file on disk /home/iobroker/backups/Rollos/Rollo_Kinderzimmer.js
          javascript.0
          2024-08-05 16:51:34.593	info	Created script file on disk /home/iobroker/backups/Rollos/Rollo_Schlafzimmer.js
          javascript.0
          2024-08-05 16:51:34.592	info	Created script file on disk /home/iobroker/backups/Rollos/Rollo_Büro.js
          javascript.0
          2024-08-05 16:51:34.590	info	Created script file on disk /home/iobroker/backups/TV/Doppel_Switch.js
          javascript.0
          2024-08-05 16:51:34.589	info	Created script file on disk /home/iobroker/backups/TV/PS4_auf_TV.js
          javascript.0
          2024-08-05 16:51:34.589	info	Created script file on disk /home/iobroker/backups/TV/Switch_auf_TV.js
          javascript.0
          2024-08-05 16:51:34.588	info	Created script file on disk /home/iobroker/backups/TV/Leinwand.js
          javascript.0
          2024-08-05 16:51:34.587	info	Created script file on disk /home/iobroker/backups/TV/AppleTV_auf_Beamer.js
          javascript.0
          2024-08-05 16:51:34.586	info	Created script file on disk /home/iobroker/backups/TV/AppleTV_auf_TV.js
          javascript.0
          2024-08-05 16:51:34.585	info	Created script file on disk /home/iobroker/backups/TestFolder/Test_Kopieren.js
          javascript.0
          2024-08-05 16:51:34.584	info	Created script file on disk /home/iobroker/backups/TestFolder/34r3.js
          javascript.0
          2024-08-05 16:51:34.579	info	Created script file on disk /home/iobroker/backups/global/IconsSelector.ts
          javascript.0
          2024-08-05 16:51:34.577	info	Created script file on disk /home/iobroker/backups/Ventilatoren/Schlafzimmer.js
          javascript.0
          2024-08-05 16:51:34.576	info	Created script file on disk /home/iobroker/backups/Ventilatoren/Wohnzimmer.js
          javascript.0
          2024-08-05 16:51:34.575	info	Created script file on disk /home/iobroker/backups/Alarm/freezer.js
          javascript.0
          2024-08-05 16:51:34.574	info	Created script file on disk /home/iobroker/backups/Alarm/openCar.js
          javascript.0
          2024-08-05 16:51:34.572	info	Created script file on disk /home/iobroker/backups/notifications/Text_und_Spracheausgabe.js
          javascript.0
          2024-08-05 16:51:34.572	info	Created script file on disk /home/iobroker/backups/notifications/Fung_Trinken.js
          javascript.0
          2024-08-05 16:51:34.571	info	Created script file on disk /home/iobroker/backups/notifications/light_notification.js
          javascript.0
          2024-08-05 16:51:34.565	info	Created script file on disk /home/iobroker/backups/NSPanel/NSPanel_1_43333.ts
          javascript.0
          2024-08-05 16:51:34.564	info	Created script file on disk /home/iobroker/backups/NSPanel/Fahrplan_to_NSPanel_ts.ts
          javascript.0
          2024-08-05 16:51:34.557	info	Created script file on disk /home/iobroker/backups/NSPanel/NSPanel_1_43343.ts
          javascript.0
          2024-08-05 16:51:34.552	info	Created script file on disk /home/iobroker/backups/NSPanel/NSPanel_1_4401.ts
          javascript.0
          2024-08-05 16:51:34.548	info	Created script file on disk /home/iobroker/backups/epaperDisplays/Displays.js
          javascript.0
          2024-08-05 16:51:34.427	info	script.js.Misc.Dishwasher: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.419	info	Start JavaScript script.js.Misc.Dishwasher (Blockly)
          javascript.0
          2024-08-05 16:51:34.410	info	script.js.epaperDisplays.Displays: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.402	info	Start JavaScript script.js.epaperDisplays.Displays (Blockly)
          javascript.0
          2024-08-05 16:51:34.402	info	script.js.Misc.Time&Date: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.385	info	Start JavaScript script.js.Misc.Time&Date (Blockly)
          javascript.0
          2024-08-05 16:51:34.385	info	script.js.Licht.Scheinwerfer: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.376	info	Start JavaScript script.js.Licht.Scheinwerfer (Javascript/js)
          javascript.0
          2024-08-05 16:51:34.376	info	script.js.Licht.Portable_Light02: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.368	info	Start JavaScript script.js.Licht.Portable_Light02 (Javascript/js)
          javascript.0
          2024-08-05 16:51:34.368	info	script.js.Licht.Portable_Light01: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.360	info	Start JavaScript script.js.Licht.Portable_Light01 (Javascript/js)
          javascript.0
          2024-08-05 16:51:34.350	info	script.js.Licht.PC_Ambiente: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.343	info	Start JavaScript script.js.Licht.PC_Ambiente (Javascript/js)
          javascript.0
          2024-08-05 16:51:34.342	info	script.js.NSPanel.Fahrplan_to_NSPanel_ts: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.342	info	script.js.NSPanel.Fahrplan_to_NSPanel_ts: Datenpunkte vorhanden
          javascript.0
          2024-08-05 16:51:34.341	info	script.js.NSPanel.Fahrplan_to_NSPanel_ts: Datenpunkte vorhanden
          javascript.0
          javascript.0
          2024-08-05 16:51:34.340	info	script.js.NSPanel.Fahrplan_to_NSPanel_ts: Datenpunkte vorhanden
          javascript.0
          2024-08-05 16:51:34.330	info	script.js.NSPanel.Fahrplan_to_NSPanel_ts: source code did not change, using cached compilation result...
          javascript.0
          2024-08-05 16:51:34.228	info	Compiling TypeScript source script.js.NSPanel.Fahrplan_to_NSPanel_ts
          javascript.0
          2024-08-05 16:51:34.227	info	script.js.notifications.Fung_Trinken: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.172	info	Start JavaScript script.js.notifications.Fung_Trinken (Blockly)
          javascript.0
          2024-08-05 16:51:34.172	info	script.js.notifications.Text_und_Spracheausgabe: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.164	info	Start JavaScript script.js.notifications.Text_und_Spracheausgabe (Blockly)
          javascript.0
          2024-08-05 16:51:34.163	info	script.js.Rollos.Rollo_Büro: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.155	info	Start JavaScript script.js.Rollos.Rollo_Büro (Blockly)
          javascript.0
          2024-08-05 16:51:34.154	info	script.js.TV.Leinwand: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.147	info	Start JavaScript script.js.TV.Leinwand (Blockly)
          javascript.0
          2024-08-05 16:51:34.146	info	script.js.Licht.Licht_Flur: registered 9 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.139	info	Start JavaScript script.js.Licht.Licht_Flur (Blockly)
          javascript.0
          2024-08-05 16:51:34.139	info	script.js.Licht.Licht_Küche: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.132	info	Start JavaScript script.js.Licht.Licht_Küche (Blockly)
          javascript.0
          2024-08-05 16:51:34.132	info	script.js.Licht.Licht_Badezimmer: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.125	info	Start JavaScript script.js.Licht.Licht_Badezimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.124	info	script.js.Misc.Shelly_Button: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.117	info	Start JavaScript script.js.Misc.Shelly_Button (Blockly)
          javascript.0
          2024-08-05 16:51:34.117	info	script.js.Rollos.Rollo_Schlafzimmer: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.110	info	Start JavaScript script.js.Rollos.Rollo_Schlafzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.110	info	script.js.Rollos.Rollo_Kinderzimmer: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.104	info	Start JavaScript script.js.Rollos.Rollo_Kinderzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.103	info	script.js.Rollos.Rollo_Alle: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.097	info	Start JavaScript script.js.Rollos.Rollo_Alle (Blockly)
          javascript.0
          2024-08-05 16:51:34.097	info	script.js.Misc.Zoidberg: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.090	info	Start JavaScript script.js.Misc.Zoidberg (Blockly)
          javascript.0
          2024-08-05 16:51:34.090	info	script.js.Misc.PC_Christian: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.083	info	Start JavaScript script.js.Misc.PC_Christian (Blockly)
          javascript.0
          2024-08-05 16:51:34.082	info	script.js.Misc.Heizmatte_AUS: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.075	info	Start JavaScript script.js.Misc.Heizmatte_AUS (Blockly)
          javascript.0
          2024-08-05 16:51:34.075	info	script.js.Misc.Day_Night: registered 0 subscriptions, 4 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.062	info	Start JavaScript script.js.Misc.Day_Night (Blockly)
          javascript.0
          2024-08-05 16:51:34.062	info	script.js.Misc.Busy_Light: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.055	info	Start JavaScript script.js.Misc.Busy_Light (Blockly)
          javascript.0
          2024-08-05 16:51:34.041	info	script.js.Misc.3D_Printer: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.035	info	Start JavaScript script.js.Misc.3D_Printer (Blockly)
          javascript.0
          2024-08-05 16:51:34.034	info	script.js.Licht.XMAS_LIGHTS: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.028	info	Start JavaScript script.js.Licht.XMAS_LIGHTS (Blockly)
          javascript.0
          2024-08-05 16:51:34.028	info	script.js.Licht.Licht_Wohnzimmer: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.022	info	Start JavaScript script.js.Licht.Licht_Wohnzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.021	info	script.js.Licht.Licht_Schlafzimmer: registered 7 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.012	info	Start JavaScript script.js.Licht.Licht_Schlafzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.011	info	script.js.Licht.Licht_Kinderzimmer: registered 16 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:34.004	info	Start JavaScript script.js.Licht.Licht_Kinderzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:34.003	info	script.js.Licht.LichtSchalter_Nachttisch: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:33.986	info	Start JavaScript script.js.Licht.LichtSchalter_Nachttisch (Blockly)
          javascript.0
          2024-08-05 16:51:33.986	info	script.js.Licht.LICHT_ALLES_AUS: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:33.979	info	Start JavaScript script.js.Licht.LICHT_ALLES_AUS (Blockly)
          javascript.0
          2024-08-05 16:51:33.979	info	script.js.Akkustände.Akku_Tablet_Wohnzimmer: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:33.979	info	script.js.Akkustände.Akku_Tablet_Wohnzimmer: subscribe: {"pattern":{"id":"fullybrowser.0.Remote-Tablet.Info.batteryLevel","change":"ne","q":0},"name":"script.js.Akkustände.Akku_Tablet_Wohnzimmer"}
          javascript.0
          2024-08-05 16:51:33.972	info	Start JavaScript script.js.Akkustände.Akku_Tablet_Wohnzimmer (Blockly)
          javascript.0
          2024-08-05 16:51:33.971	info	script.js.Akkustände.Akku_Rollos: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          javascript.0
          2024-08-05 16:51:33.930	info	Start JavaScript script.js.Akkustände.Akku_Rollos (Blockly)
          javascript.0
          2024-08-05 16:51:33.794	info	script.js.global.IconsSelector: source code did not change, using cached compilation result...
          javascript.0
          2024-08-05 16:51:33.481	info	script.js.global.IconsSelector: compiling TypeScript source...
          javascript.0
          2024-08-05 16:51:33.179	debug	[sunTimeSchedules] Times: {"solarNoon":"2024-08-05T11:28:18.814Z","nadir":"2024-08-05T23:28:18.814Z","sunrise":"2024-08-05T03:49:03.018Z","sunset":"2024-08-05T19:07:34.611Z","sunriseEnd":"2024-08-05T03:53:03.710Z","sunsetStart":"2024-08-05T19:03:33.919Z","dawn":"2024-08-05T03:08:11.466Z","dusk":"2024-08-05T19:48:26.163Z","nauticalDawn":"2024-08-05T02:13:30.256Z","nauticalDusk":"2024-08-05T20:43:07.373Z","nightEnd":"2024-08-05T00:57:50.639Z","night":"2024-08-05T21:58:46.990Z","goldenHourEnd":"2024-08-05T04:38:31.585Z","goldenHour":"2024-08-05T18:18:06.043Z"}
          javascript.0
          2024-08-05 16:51:33.174	info	received all states
          javascript.0
          2024-08-05 16:51:32.859	info	received all objects
          javascript.0
          2024-08-05 16:51:30.985	info	requesting all objects
          javascript.0
          2024-08-05 16:51:30.984	info	requesting all states
          javascript.0
          2024-08-05 16:51:30.356	debug	Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
          javascript.0
          2024-08-05 16:51:30.332	debug	Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/assert/strict.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/diagnostics_channel.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/dns/promises.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/dom-events.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/fs/promises.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/readline/promises.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/sea.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/stream/promises.d.ts","node_modules/@types/node/stream/consumers.d.ts","node_modules/@types/node/stream/web.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/test.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/timers/promises.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/wasi.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts"]
          javascript.0
          2024-08-05 16:51:30.304	debug	Installed custom dependency: "dayjs@latest"
          radar2.0
          2024-08-05 16:51:27.338	warn	arp-scan maybe without rights because no data returned!
          javascript.0
          2024-08-05 16:51:23.547	debug	Found custom dependency in config: "dayjs@latest"
          javascript.0
          2024-08-05 16:51:23.537	debug	Installed custom dependency: "moment-parseformat@latest"
          javascript.0
          2024-08-05 16:51:16.553	debug	Found custom dependency in config: "moment-parseformat@latest"
          javascript.0
          2024-08-05 16:51:16.526	debug	Installed custom dependency: "moment@latest"
          javascript.0
          2024-08-05 16:51:09.607	debug	Found custom dependency in config: "moment@latest"
          javascript.0
          2024-08-05 16:51:09.606	debug	Found installed libraries: ["dayjs","moment","moment-parseformat"]
          javascript.0
          2024-08-05 16:51:09.565	debug	config.subscribe (Do not subscribe all states on start): false
          javascript.0
          2024-08-05 16:51:09.532	info	starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.16.0, js-controller: 6.0.9
            A Former User @aSilentSniper last edited by
            @asilentsniper
            Bitte das logfile vom Adapter start, wo die Module installiert werden, zeigen. Mittendrin bringt nix..
            • Armilar
              Armilar Most Active Forum Testing last edited by Armilar
              @asilentsniper
              Kannst du mal ein "iob diag" posten?
              Sieht für mich auf den ersten Blick so aus, als würde der js-controller nicht passen... Der js-controller sollte bei deiner JS-Adapter-Version (v8.7.6) auf mindestens 6.0.9 sein, wenn ich das richtig gelesen habe:
              ansonsten mal die komplette Liste durchackern:
              iob stop
              iob update
              iob upgrade self
              iob upgrade
              iob fix
              iob start
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
              • MichaelF
                MichaelF last edited by
                ich habe das bei mir auch grade nochmal gemacht:
                javascript.0
                2024-08-06 12:44:10.233	info	requesting all objects
                javascript.0
                2024-08-06 12:44:10.231	info	requesting all states
                javascript.0
                2024-08-06 12:44:05.205	debug	Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
                javascript.0
                2024-08-06 12:44:05.171	debug	Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/assert/strict.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/diagnostics_channel.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/dns/promises.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/dom-events.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/fs/promises.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/readline/promises.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/sea.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/stream/promises.d.ts","node_modules/@types/node/stream/consumers.d.ts","node_modules/@types/node/stream/web.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/test.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/timers/promises.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/wasi.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts"]
                javascript.0
                2024-08-06 12:44:05.117	debug	Installed custom dependency: "dayjs@latest"
                javascript.0
                2024-08-06 12:43:49.595	debug	Found custom dependency in config: "dayjs@latest"
                javascript.0
                2024-08-06 12:43:49.557	debug	Installed custom dependency: "moment@latest"
                javascript.0
                2024-08-06 12:43:34.083	debug	Found custom dependency in config: "moment@latest"
                javascript.0
                2024-08-06 12:43:34.075	debug	Installed custom dependency: "moment-parseformat@latest"
                javascript.0
                2024-08-06 12:43:18.791	debug	Found custom dependency in config: "moment-parseformat@latest"
                javascript.0
                2024-08-06 12:43:18.741	debug	Installed custom dependency: "node-ssh@latest"
                javascript.0
                2024-08-06 12:43:02.887	debug	Found custom dependency in config: "node-ssh@latest"
                javascript.0
                2024-08-06 12:43:02.730	debug	Installed custom dependency: "simple-ssh@latest"
                javascript.0
                2024-08-06 12:42:46.936	debug	Found custom dependency in config: "simple-ssh@latest"
                javascript.0
                2024-08-06 12:42:46.935	debug	Found installed libraries: ["moment","moment-parseformat","node-ssh","simple-ssh"]
                javascript.0
                2024-08-06 12:42:46.883	debug	config.subscribe (Do not subscribe all states on start): false
                javascript.0
                2024-08-06 12:42:46.840	info	starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.16.0, js-controller: 6.0.9
                javascript.0
                2024-08-06 12:42:41.588	debug	Plugin sentry Initialize Plugin (enabled=true)
                Das neu installieren tut er auch.
                  TT-Tom last edited by TT-Tom
                  @michaelf
                  @aSilentSniper
                  @tobiasp
                  @lesiflo
                  @Joker
                  Könnt Ihr bitte in der Konsole des Rechner, wo der iobroker läuft folgende Sachen prüfen und die Ausgaben posten.
                  cd /opt/iobroker/node_modules/dayjs
                  ls -la
                  ggf. die Instanznummer anpassen
                  cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
                  ls -la
                  T MichaelF 3 Replies Last reply Reply Quote 1
                    tobiasp @TT-Tom last edited by
                    @tt-tom ```
                    pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
                    ls -la
                    total 152
                    drwxrwxr-x+ 5 iobroker iobroker 4096 Aug 5 07:52 .
                    drwxrwxr-x+ 6 iobroker iobroker 4096 Aug 5 12:43 ..
                    -rw-rwxr--+ 1 iobroker iobroker 79810 Aug 5 07:52 CHANGELOG.md
                    -rw-rwxr--+ 1 iobroker iobroker 7160 Aug 5 07:52 dayjs.min.js
                    -rw-rwxr--+ 1 iobroker iobroker 94 Aug 5 07:52 .editorconfig
                    drwxrwxr-x+ 4 iobroker iobroker 4096 Aug 5 07:52 esm
                    -rw-rwxr--+ 1 iobroker iobroker 13872 Aug 5 07:52 index.d.ts
                    -rw-rwxr--+ 1 iobroker iobroker 1072 Aug 5 07:52 LICENSE
                    drwxrwxr-x+ 2 iobroker iobroker 4096 Aug 5 07:52 locale
                    -rw-rwxr--+ 1 iobroker iobroker 5033 Aug 5 07:52 locale.json
                    -rw-rwxr--+ 1 iobroker iobroker 2526 Aug 5 07:52 package.json
                    drwxrwxr-x+ 2 iobroker iobroker 4096 Aug 5 07:52 plugin
                    -rw-rwxr--+ 1 iobroker iobroker 7411 Aug 5 07:52 README.md
                    pi@raspberrypi:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs $
                      @tt-tom ```
                      pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/dayjs
                      ls -la
                      bash: cd: /opt/iobroker/node_modules/dayjs: No such file or directory
                      total 188
                      drwxr-xr-x 21 pi pi 4096 Aug 6 14:50 .
                      drwxr-xr-x 4 root root 4096 Jan 15 2024 ..
                      -rw------- 1 pi pi 5773 Aug 6 14:53 .bash_history
                      -rw-r--r-- 1 pi pi 220 Dec 5 2023 .bash_logout
                      -rw-r--r-- 1 pi pi 3716 Aug 6 14:47 .bashrc
                      drwxr-xr-x 12 pi pi 4096 Feb 21 10:28 .cache
                      drwx------ 13 pi pi 4096 Feb 21 10:31 .config
                      drwxr-xr-x 3 pi pi 4096 Feb 21 10:33 Desktop
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Documents
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Downloads
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 .iobroker
                      drwxr-xr-x 8 pi pi 4096 Jan 15 2024 LCD-show
                      drwxr-xr-x 3 pi pi 4096 Jan 15 2024 .local
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Music
                      drwxr-xr-x 3 pi pi 4096 Aug 5 10:53 node_modules
                      drwxr-xr-x 4 pi pi 4096 Jan 15 2024 .npm
                      -rw------- 1 pi pi 36 Jan 15 2024 .npmrc
                      -rw-r--r-- 1 pi pi 52 Aug 5 10:53 package.json
                      -rw-r--r-- 1 pi pi 414 Aug 5 10:53 package-lock.json
                      drwx------ 2 pi pi 4096 Aug 6 14:50 .pcsc10
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Pictures
                      drwx------ 3 pi pi 4096 Feb 21 10:28 .pki
                      -rw-r--r-- 1 pi pi 807 Dec 5 2023 .profile
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Public
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Templates
                      drwx------ 1 pi pi 0 Aug 6 14:50 thinclient_drives
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 Videos
                      drwxr-xr-x 2 pi pi 4096 Jan 15 2024 wetterstation
                      -rw-r--r-- 1 pi pi 218 Jan 15 2024 .wget-hsts
                      -rw------- 1 pi pi 170 Aug 6 14:50 .Xauthority
                      -rw-r--r-- 1 pi pi 15129 Aug 6 14:52 .xorgxrdp.10.log
                      -rw-r--r-- 1 pi pi 27469 Aug 6 14:49 .xorgxrdp.10.log.old
                      -rw-r--r-- 1 pi pi 15345 Jan 18 2024 .xorgxrdp.11.log
                      -rw------- 1 pi pi 1443 Aug 6 14:50 .xsession-errors
                      -rw------- 1 pi pi 1443 Aug 5 11:57 .xsession-errors.old
                        TT-Tom @tobiasp last edited by
                        @tobiasp
                        Danke für die Post, kannst du bitte mit den Codetags in einer neuen Zeile anfangen. Sonst kann man es nicht lesen. Siehst ja selbst.
                          lesiflo Most Active @TT-Tom last edited by
                          @tt-tom
                          pi@iobroker:~$ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
                          ls -la
                          total 152
                          drwxrwxr-x+ 5 iobroker iobroker  4096 Aug  1 19:20 .
                          drwxrwxr-x+ 6 iobroker iobroker  4096 Aug  1 19:20 ..
                          -rw-rwxr--+ 1 iobroker iobroker    94 Aug  1 19:20 .editorconfig
                          -rw-rwxr--+ 1 iobroker iobroker 79810 Aug  1 19:20 CHANGELOG.md
                          -rw-rwxr--+ 1 iobroker iobroker  1072 Aug  1 19:20 LICENSE
                          -rw-rwxr--+ 1 iobroker iobroker  7411 Aug  1 19:20 README.md
                          -rw-rwxr--+ 1 iobroker iobroker  7160 Aug  1 19:20 dayjs.min.js
                          drwxrwxr-x+ 4 iobroker iobroker  4096 Aug  1 19:20 esm
                          -rw-rwxr--+ 1 iobroker iobroker 13872 Aug  1 19:20 index.d.ts
                          drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  1 19:20 locale
                          -rw-rwxr--+ 1 iobroker iobroker  5033 Aug  1 19:20 locale.json
                          -rw-rwxr--+ 1 iobroker iobroker  2526 Aug  1 19:20 package.json
                          drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  1 19:20 plugin
                          pi@iobroker:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs$
                            TT-Tom @lesiflo last edited by
                            @lesiflo
                            im anderen Pfad ist nix, oder?
                              @tt-tom Der Pfad existiert nicht.
                              pi@iobroker:~$ cd /opt/iobroker/node_modules/dayjs
                              ls -la
                              -bash: cd: /opt/iobroker/node_modules/dayjs: No such file or directory
                              • MichaelF
                                MichaelF @TT-Tom last edited by
                                @tt-tom
                                pi@iobroker:~ $ cd /opt/iobroker/node_modules/dayjs
                                -bash: cd: /opt/iobroker/node_modules/dayjs: Datei oder Verzeichnis nicht gefunden
                                pi@iobroker:~ $
                                pi@iobroker:~ $ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
                                pi@iobroker:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs $ ls -la
                                insgesamt 152
                                drwxrwxr-x+ 5 iobroker iobroker  4096  6. Aug 12:44 .
                                drwxrwxr-x+ 7 iobroker iobroker  4096  6. Aug 12:43 ..
                                -rw-rw-r--+ 1 iobroker iobroker 79810  6. Aug 12:44 CHANGELOG.md
                                -rw-rw-r--+ 1 iobroker iobroker  7160  6. Aug 12:44 dayjs.min.js
                                -rw-rw-r--+ 1 iobroker iobroker    94  6. Aug 12:44 .editorconfig
                                drwxrwxr-x+ 4 iobroker iobroker  4096  6. Aug 12:44 esm
                                -rw-rw-r--+ 1 iobroker iobroker 13872  6. Aug 12:44 index.d.ts
                                -rw-rw-r--+ 1 iobroker iobroker  1072  6. Aug 12:44 LICENSE
                                drwxrwxr-x+ 2 iobroker iobroker  4096  6. Aug 12:44 locale
                                -rw-rw-r--+ 1 iobroker iobroker  5033  6. Aug 12:44 locale.json
                                -rw-rw-r--+ 1 iobroker iobroker  2526  6. Aug 12:44 package.json
                                drwxrwxr-x+ 2 iobroker iobroker  4096  6. Aug 12:44 plugin
                                -rw-rw-r--+ 1 iobroker iobroker  7411  6. Aug 12:44 README.md
                                  TT-Tom @MichaelF last edited by
                                  @michaelf
                                  @aSilentSniper
                                  @tobiasp
                                  @lesiflo
                                  @Joker
                                  Danke schon mal an euch? Noch ein gegen Test mit moment-parseformat
                                  cd /opt/iobroker/node_modules/moment-parseformat
                                  ls -la
                                  cd /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
                                  ls -la
                                  MichaelF 1 Reply Last reply Reply Quote 1
                                  • MichaelF
                                    @tt-tom
                                    pi@iobroker:~ $ cd /opt/iobroker/node_modules/moment-parseformat
                                    -bash: cd: /opt/iobroker/node_modules/moment-parseformat: Datei oder Verzeichnis nicht gefunden
                                    pi@iobroker:~ $
                                    pi@iobroker:~ $ cd /opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat
                                    pi@iobroker:/opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat $ ls -la
                                    insgesamt 40
                                    drwxrwxr-x+ 4 iobroker iobroker  4096  2. Aug 08:11 .
                                    drwxrwxr-x+ 2 iobroker iobroker  4096  2. Aug 08:11 dist
                                    -rw-rw-r--+ 1 iobroker iobroker   202  2. Aug 08:11 index.js
                                    drwxrwxr-x+ 2 iobroker iobroker  4096  2. Aug 08:11 lib
                                    -rw-rw-r--+ 1 iobroker iobroker 11345  2. Aug 08:11 LICENSE.md
                                    -rw-rw-r--+ 1 iobroker iobroker  1687  2. Aug 08:11 package.json
                                    -rw-rw-r--+ 1 iobroker iobroker  2036  2. Aug 08:11 README.md
                                      Eine bitte an die User die diese Fehlermeldung mit dayjs nicht haben, könnt ihr bitte mal diese Verzeichnisse überprüfen. Ob die Ausgaben dieselben sind. Danke und schön Abend noch.
                                      Armilar 1 Reply Last reply Reply Quote 1
                                      • Armilar
                                        Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
                                        @tt-tom
                                        Ich bin ein User ohne Fehler 😉
                                        armilar@iobroker:/opt/iobroker/node_modules/moment-parseformat$ ls -la
                                        total 92
                                        drwxrwxr-x+    4 iobroker iobroker  4096 Feb 22 17:40 .
                                        drwxrwxr-x+ 1340 iobroker iobroker 53248 Aug  5 20:31 ..
                                        -rw-rwxr--+    1 iobroker iobroker 11345 Feb 22 17:40 LICENSE.md
                                        -rw-rwxr--+    1 iobroker iobroker  2036 Feb 22 17:40 README.md
                                        drwxrwxr-x+    2 iobroker iobroker  4096 Feb 22 17:40 dist
                                        -rw-rwxr--+    1 iobroker iobroker   202 Feb 22 17:40 index.js
                                        drwxrwxr-x+    2 iobroker iobroker  4096 Feb 22 17:40 lib
                                        -rw-rwxr--+    1 iobroker iobroker  1687 Feb 22 17:40 package.json
                                        armilar@iobroker:/opt/iobroker/node_modules/@iobroker-javascript.0/moment-parseformat$ ls -la
                                        total 40
                                        drwxrwxr-x+  4 iobroker iobroker  4096 Jul  4 20:07 .
                                        drwxrwxr-x+ 21 iobroker iobroker  4096 Aug  5 18:31 ..
                                        -rw-rwxr--+  1 iobroker iobroker 11345 Jul  4 20:07 LICENSE.md
                                        -rw-rwxr--+  1 iobroker iobroker  2036 Jul  4 20:07 README.md
                                        drwxrwxr-x+  2 iobroker iobroker  4096 Jul  4 20:07 dist
                                        -rw-rwxr--+  1 iobroker iobroker   202 Jul  4 20:07 index.js
                                        drwxrwxr-x+  2 iobroker iobroker  4096 Jul  4 20:07 lib
                                        -rw-rwxr--+  1 iobroker iobroker  1687 Jul  4 20:07 package.json
                                        Du machst es spannend... Wie man sieht sind beide Verzeichnisse vorhanden:
                                        • /opt/iobroker/node_modules --> vom Februar
                                        • /opt/iobroker/node_modules/@iobroker-javascript.0 --> vom Juli
                                        naja, das Jahr kann man nicht wirklich sehen... und das System ist wirklich alt - aber absolut aktuell
                                        EDIT: Jetzt für dayjs
                                        armilar@iobroker:/opt/iobroker/node_modules/dayjs$ ls -la
                                        total 204
                                        drwxrwxr-x+    5 iobroker iobroker  4096 Feb 22 17:40 .
                                        -rw-rwxr--+    1 iobroker iobroker    94 Feb 22 17:40 .editorconfig
                                        -rw-rwxr--+    1 iobroker iobroker 77898 Feb 22 17:40 CHANGELOG.md
                                        -rw-rwxr--+    1 iobroker iobroker  1072 Feb 22 17:40 LICENSE
                                        -rw-rwxr--+    1 iobroker iobroker  7266 Feb 22 17:40 README.md
                                        -rw-rwxr--+    1 iobroker iobroker  7160 Feb 22 17:40 dayjs.min.js
                                        drwxrwxr-x+    4 iobroker iobroker  4096 Feb 22 17:40 esm
                                        -rw-rwxr--+    1 iobroker iobroker 13853 Feb 22 17:40 index.d.ts
                                        drwxrwxr-x+    2 iobroker iobroker  4096 Feb 22 17:40 locale
                                        -rw-rwxr--+    1 iobroker iobroker  5033 Feb 22 17:40 locale.json
                                        -rw-rwxr--+    1 iobroker iobroker  2526 Feb 22 17:40 package.json
                                        drwxrwxr-x+    2 iobroker iobroker  4096 Feb 22 17:40 plugin
                                        armilar@iobroker:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs$ ls -la
                                        total 152
                                        drwxrwxr-x+  5 iobroker iobroker  4096 Jul 18 21:35 .
                                        -rw-rwxr--+  1 iobroker iobroker    94 Jul 18 21:35 .editorconfig
                                        -rw-rwxr--+  1 iobroker iobroker 79810 Jul 18 21:35 CHANGELOG.md
                                        -rw-rwxr--+  1 iobroker iobroker  1072 Jul 18 21:35 LICENSE
                                        -rw-rwxr--+  1 iobroker iobroker  7411 Jul 18 21:35 README.md
                                        -rw-rwxr--+  1 iobroker iobroker  7160 Jul 18 21:35 dayjs.min.js
                                        drwxrwxr-x+  4 iobroker iobroker  4096 Jul 18 21:35 esm
                                        -rw-rwxr--+  1 iobroker iobroker 13872 Jul 18 21:35 index.d.ts
                                        drwxrwxr-x+  2 iobroker iobroker  4096 Jul 18 21:35 locale
                                        -rw-rwxr--+  1 iobroker iobroker  5033 Jul 18 21:35 locale.json
                                        -rw-rwxr--+  1 iobroker iobroker  2526 Jul 18 21:35 package.json
                                        drwxrwxr-x+  2 iobroker iobroker  4096 Jul 18 21:35 plugin
                                        EDIT2:
                                        noch ein paar Systemdaten
                                                 Chassis: vm
                                          Virtualization: kvm
                                        Operating System: Ubuntu 22.04.4 LTS
                                                  Kernel: Linux 5.15.0-117-generic
                                            Architecture: x86-64
                                        Nodejs-Installation:
                                        /usr/bin/nodejs         v20.16.0
                                        /usr/bin/node           v20.16.0
                                        /usr/bin/npm            10.8.1
                                        /usr/bin/npx            10.8.1
                                        /usr/bin/corepack       0.28.2
                                        ioBroker Core:          js-controller           6.0.10
        admin                   7.0.23
        javascript              8.8.0
                                        T haus-automatisierung 2 Replies Last reply Reply Quote 0
                                          TT-Tom @Armilar last edited by
                                          @armilar
                                          So sieht es bei mir auch aus. Die aktuellen liegen unter @javascript.x , die alten halt unter node_modules. Ich habe unter node_modules den Ordner dayjs mal umbenannt in dayjs1, nach einem Neustart der JavaScript Instanz war der Ordner wieder automatisch dayjs. Kannst du mir das bitte erklären. Ein neuer Ordner dayjs hätte ich verstanden, aber das nicht.
                                          • Armilar
                                            @tt-tom
                                            Vielleicht wurschteln da alte und neue Sourcen im Adapter... Altlasten oder so... keine Ahnung... Sehe das Problem aber nicht im Script...
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6655323
