    4. JavaScript
    5. E3DC Hauskraftwerk steuern
      Chilihead last edited by
      Hallo Arno,
      bei mir kommt immer unknown tag code und ich nehme an das es von deinem Script kommt, sonst hab ich nichts laufen. Hattest du das schon mal?
      javascript.0
      2024-07-09 12:33:54.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
      javascript.0
      2024-07-09 12:33:54.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
      e3dc-rscp.0
      2024-07-09 12:33:53.172	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:51.175	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:49.172	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:47.169	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:45.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      javascript.0
      2024-07-09 12:33:45.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
      javascript.0
      2024-07-09 12:33:45.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
      e3dc-rscp.0
      2024-07-09 12:33:43.171	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:41.166	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:39.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      javascript.0
      2024-07-09 12:33:39.004	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
      javascript.0
      2024-07-09 12:33:39.004	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
      e3dc-rscp.0
      2024-07-09 12:33:37.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:35.162	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:33.196	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:31.166	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      javascript.0
      2024-07-09 12:33:30.015	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
      javascript.0
      2024-07-09 12:33:30.015	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
      e3dc-rscp.0
      2024-07-09 12:33:29.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:27.167	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:25.165	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      javascript.0
      2024-07-09 12:33:24.008	warn	script.js.E3DC_Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
      javascript.0
      2024-07-09 12:33:24.008	info	script.js.E3DC_Charge_Control: ******************* Debug LOG Charge-Control *******************
      e3dc-rscp.0
      2024-07-09 12:33:23.157	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:21.162	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
      e3dc-rscp.0
      2024-07-09 12:33:19.155	warn	Unknown tag: tagCode=0x100003e, len=4, typeCode=0x7
        ArnoD @Chilihead last edited by ArnoD
        @chilihead
        Das kommt vom e3dc-rscp Adapter.
        Kann es sein das du beim E3DC ein neues Firmware Update erhalten hast oder den Adapter neu installiert hast ?
        Einmal auf Github e3dc-rscp prüfen ob das Problem bereits bekannt ist.
        Nachtrag:
        Kann es sich um diesen Fehler handeln: https://github.com/git-kick/ioBroker.e3dc-rscp/issues/218
        Gerhardptl created this issue in git-kick/ioBroker.e3dc-rscp
        closed Received data type ERROR #218
          Chilihead @ArnoD last edited by
          @arnod du bist der Beste! 1.2.6 installiert und gut is. Hattest du das nicht?
          Das 1.2.6 update unterdrückt ja nur die Meldung
            @chilihead
            Ist mir nicht aufgefallen.
            Ich verwende aber auch nicht die Backup Funktion um alle Adapter Einstellungen wiederherstellen zu können.
            • bluebean
              bluebean last edited by bluebean
              @ArnoD
              Letzte Nach hab ich ein neues E3DC-Update für mein S10 Pro bekommen auf Version P10_2024_024. Seitdem bekomme ich im Log lediglich noch ein "E3DC Connection closed", keinerlei Verbindung oder Regelung mehr.
              (Info: das Release liefert im Wesentlichen zwei neue Features: zum einen kann man jetzt auch die Batterie für die Ladung gegenüber der Wallbox priorisieren und dafür dann auch einen SOC einstellen, bis zu dem das gelten soll. Zu anderen kann man jetzt für dynamische Strompreise einstellen, dass die Batterie unter einem Preislimit geladen wird bis zu einem eiunstellbaren SOC - und dieses kann man für jeden Monat einzeln definieren.)
              PS: nach einem kompletten Restart vom iobroker läuft's wieder. Wer also auch damit kämpft, probiert's mal.
                ArnoD @bluebean last edited by
                @bluebean
                Danke für die Information.
                Habe gerade festgestellt das ich gestern auch das Update erhalten habe.
                Bei mir ist aber bis jetzt kein Problem aufgetreten, kann aber auch daran liegen das ich am Abend einige Änderungen getestet habe und dadurch einige Neustarts hatte.
                  psrelax last edited by
                  ich glaube, ich habe in Zeile 683 einen Fehler gefunden.
                  if (DebugAusgabeDetail){log(`PV Leistung = ${(await getStateAsync(sID_PvLeistung_ADD_W)).val+Math.abs((await getStateAsync(sID_PvLeistung_ADD_W)).val)} W`)}
                  Es werden 2 Mal die selben Werte addiert.
                  bluebean 1 Reply Last reply Reply Quote 0
                  • bluebean
                    bluebean @psrelax last edited by
                    Ich vermute auch, dass es beim ersten Summanden sID_PvLeistung_E3DC_W heißen müsste... (vgl. Zeile 367).
                      @psrelax @bluebean
                      Ja richtig, ist ein Kopierfehler und so wäre es richtig:
                      if (DebugAusgabeDetail){log(`PV Leistung = ${(await getStateAsync(sID_PvLeistung_E3DC_W)).val+Math.abs((await getStateAsync(sID_PvLeistung_ADD_W)).val)} W`)}
                      Ist bereits korrigiert und wird mit der nächsten Version behoben sein.
                      Danke.
                        Hallo @ArnoD ,
                        ich habe seit einiger Zeit ein Problem mit dem Script und komme irgendwie nicht weiter.
                        Erst war das Problem nur hin und wieder und mittlerweile fast täglich.
                        Das Problem ist, dass einfach die Speicher -entladung/ladung stoppt.
                        Nach einem Neustart des Scriptes läuft alles wieder problemlos.
                        Zu sehen ist das in der nachfolgenden Log unter "Batterie Leistung". Vorher 0 und nach dem Neustart mit Ladeleistung.
                        Ich verwende die letzte Version des Scriptes ohne Änderungen, bis auf Zeile 11-14. -> 1.4.1
                        Ich hoffe du kannst mir dabei helfen.
                        Danke dir schonmal.
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                        2024-08-06 15:32:24.029  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                        2024-08-06 15:32:24.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                        2024-08-06 15:32:24.077  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                        2024-08-06 15:32:24.079  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                        2024-08-06 15:32:24.082  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                        2024-08-06 15:32:24.084  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                        2024-08-06 15:32:24.086  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                        2024-08-06 15:32:24.089  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                        2024-08-06 15:32:24.091  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                        2024-08-06 15:32:24.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                        2024-08-06 15:32:24.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                        2024-08-06 15:32:24.095  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                        2024-08-06 15:32:24.097  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3664W
                        2024-08-06 15:32:24.098  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                        2024-08-06 15:32:24.100  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6763 W
                        2024-08-06 15:32:24.100  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                        2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                        2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                        2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                        2024-08-06 15:32:24.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                        2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                        2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                        2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                        2024-08-06 15:32:24.183  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                        2024-08-06 15:32:24.184  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                        2024-08-06 15:32:25.434  - info: javascript.0 (193) Stopping script script.js.E3DC_ChargeControl.Charge_Control
                        2024-08-06 15:32:29.211  - info: javascript.0 (193) Start JavaScript script.js.E3DC_ChargeControl.Charge_Control (Javascript/js)
                        2024-08-06 15:32:29.241  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Charge-Control Version 1.4.1 ====- "}##
                        2024-08-06 15:32:29.258  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: registered 70 subscriptions, 5 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2024-08-06 15:32:29.258  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== alle Objekt ID's angelegt ====- "}##
                        2024-08-06 15:32:29.379  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" -==== alle Objekte ID's überprüft ====- "}##
                        2024-08-06 15:32:29.391  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Speichergroesse_kWh=15 ====- "}##
                        2024-08-06 15:32:29.392  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 2 abgerufen ****************************** "}##
                        2024-08-06 15:32:30.589  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
                        2024-08-06 15:32:30.590  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ****************************** Es wird Solcast Dach 1 abgerufen ****************************** "}##
                        2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung response.status Solcast= 200"}##
                        2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-06 pv_estimate= 6.51 pv_estimate90= 6.55"}##
                        2024-08-06 15:32:31.442  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-07 pv_estimate= 42.65 pv_estimate90= 54"}##
                        2024-08-06 15:32:31.450  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-08 pv_estimate= 30.73 pv_estimate90= 55.16"}##
                        2024-08-06 15:32:31.455  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-09 pv_estimate= 52.55 pv_estimate90= 54.69"}##
                        2024-08-06 15:32:31.460  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-10 pv_estimate= 40.89 pv_estimate90= 54.38"}##
                        2024-08-06 15:32:31.466  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-11 pv_estimate= 51.75 pv_estimate90= 52.17"}##
                        2024-08-06 15:32:31.470  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Summe PV Leistung Tag 2024-08-12 pv_estimate= 49.69 pv_estimate90= 50.53"}##
                        2024-08-06 15:32:31.579  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 0 von Proplanta abgerufen ******************* "}##
                        2024-08-06 15:32:32.092  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung InterrogateProplanta response.status = 200"}##
                        2024-08-06 15:32:32.097  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag0 =6.9  Globalstrahlung Tag1 =5.2  Globalstrahlung Tag2 =4.1  Globalstrahlung Tag3 =6.8"}##
                        2024-08-06 15:32:32.188  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Näste Aktualisierung Wetterdaten =21:45 Uhr "}##
                        2024-08-06 15:32:32.189  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" ******************* Es wird die Globalstrahlung ab Tag 4 von Proplanta abgerufen ******************* "}##
                        2024-08-06 15:32:32.737  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Rueckmeldung InterrogateProplanta response.status = 200"}##
                        2024-08-06 15:32:32.740  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Globalstrahlung Tag4 =5.5  Globalstrahlung Tag5 =6.7  Globalstrahlung Tag6 =6.7"}##
                        2024-08-06 15:32:32.799  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Solcast in kWh = 54.65"}##
                        2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Solcast 90 Perzentil in kWh = 54.71"}##
                        2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose Proplanta in kWh = 83.90400000000001"}##
                        2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose_kWh nach Abzug Korrekturfaktor  = 75.51360000000001"}##
                        2024-08-06 15:32:32.800  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bereits produzierte PV-Leistung  = 57.887489475614196"}##
                        2024-08-06 15:32:32.884  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Prognose_kWh_heute für Berechnung = 17.626110524385815"}##
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                        2024-08-06 15:32:33.075  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                        2024-08-06 15:32:33.076  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                        2024-08-06 15:32:33.076  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                        2024-08-06 15:32:33.117  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                        2024-08-06 15:32:33.158  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                        2024-08-06 15:32:33.199  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                        2024-08-06 15:32:33.240  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                        2024-08-06 15:32:33.281  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                        2024-08-06 15:32:33.283  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                        2024-08-06 15:32:33.324  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                        2024-08-06 15:32:33.367  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                        2024-08-06 15:32:33.409  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                        2024-08-06 15:32:33.411  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                        2024-08-06 15:32:33.452  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                        2024-08-06 15:32:33.493  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3664W
                        2024-08-06 15:32:33.534  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                        2024-08-06 15:32:33.537  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6747 W
                        2024-08-06 15:32:33.537  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                        2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                        2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                        2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                        2024-08-06 15:32:33.578  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                        2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                        2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                        2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 0
                        2024-08-06 15:32:33.620  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                        2024-08-06 15:32:33.620  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 0,
                        2024-08-06 15:32:33.901  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Eigenverbrauch Tag = 25"}##
                        2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" AktSpeicherSoC in % = 68"}##
                        2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Ueberschuss in kWh 6.159443857719148 = (Prognose kWh 17.626110524385815 - Berechneter Eigenverbrauch 6.666666666666668) - FreieKapBatterie_kWh 4.8"}##
                        2024-08-06 15:32:33.902  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Ueberschuss in Prozent = 41.062959051460986"}##
                        2024-08-06 15:32:33.948  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bewölkungsgrad 12 Uhr Proplanta 12.5"}##
                        2024-08-06 15:32:33.948  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":" Bewölkungsgrad 15 Uhr Proplanta 12.5"}##
                        2024-08-06 15:32:33.949  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Einstellung 2 aktiv ====-"}##
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                        2024-08-06 15:32:42.064  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                        2024-08-06 15:32:42.065  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                        2024-08-06 15:32:42.108  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                        2024-08-06 15:32:42.110  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                        2024-08-06 15:32:42.111  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                        2024-08-06 15:32:42.114  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                        2024-08-06 15:32:42.115  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                        2024-08-06 15:32:42.117  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                        2024-08-06 15:32:42.119  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                        2024-08-06 15:32:42.120  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                        2024-08-06 15:32:42.122  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                        2024-08-06 15:32:42.124  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                        2024-08-06 15:32:42.125  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                        2024-08-06 15:32:42.127  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 3698W
                        2024-08-06 15:32:42.129  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
                        2024-08-06 15:32:42.135  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6761 W
                        2024-08-06 15:32:42.135  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                        2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                        2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                        2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                        2024-08-06 15:32:42.176  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                        2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                        2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                        2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                        2024-08-06 15:32:42.218  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                        2024-08-06 15:32:42.218  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 90
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 10
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikAnwahl =true
                        2024-08-06 15:32:48.093  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: AutomatikRegelung =true
                        2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =2
                        2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                        2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                        2024-08-06 15:32:48.094  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 16:17
                        2024-08-06 15:32:48.137  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unload = 0
                        2024-08-06 15:32:48.139  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 50
                        2024-08-06 15:32:48.141  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 99
                        2024-08-06 15:32:48.144  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                        2024-08-06 15:32:48.146  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 0
                        2024-08-06 15:32:48.148  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                        2024-08-06 15:32:48.189  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                        2024-08-06 15:32:48.191  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 04:30
                        2024-08-06 15:32:48.193  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 10
                        2024-08-06 15:32:48.195  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 5
                        2024-08-06 15:32:48.196  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 0.725
                        2024-08-06 15:32:48.199  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 4441W
                        2024-08-06 15:32:48.201  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 2079 W
                        2024-08-06 15:32:48.204  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 6767 W
                        2024-08-06 15:32:48.204  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 15kWh
                        2024-08-06 15:32:48.246  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 68 %
                        2024-08-06 15:32:48.246  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
                        2024-08-06 15:32:48.249  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                        2024-08-06 15:32:48.249  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: NotstromAusNetz =false
                        2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                        2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                        2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
                        2024-08-06 15:32:48.295  - info: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
                        2024-08-06 15:32:48.295  - warn: javascript.0 (193) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,10,
                          ArnoD @psrelax last edited by ArnoD
                          @psrelax
                          Nach dem LOG Eintrag wird in dem Moment vom Script nichts geregelt. ProgrammAblauf 10 sagt aus das die Ladeschwelle 70% nicht erreicht wurde und E3DC die Steuerung überlassen wird, da das Standardverhalten vom E3DC ist, alles an Überschuss in die Batterie zu laden.
                          Notstrom SOC wurde auch nicht erreich, was der einzige Grund wäre, warum das Entladen vom Script verhindert wird.
                          15:32 Uhr wurde das Script neu gestartet und danach eigentlich das Gleiche verhalten, ProgrammAblauf 10
                          Wenn das Problem wieder auftritt, versuch mal nur das Script zu stoppen und nicht neu zu starten, es dürfte sich dann an deinem Problem nichts ändern.
                          Kannst du mal prüfen, was du im Adapter e3dc-rscp unter Einstellungen/Zeitintervalle für Senden/SET_POWER Wiederholintervall eingetragen hast.
                            psrelax @ArnoD last edited by
                            @arnod
                            Danke für die schnelle Rückmeldung.
                            "SET_POWER Wiederholintervall" war auf 1 gestellt. Ist anscheinend mal bei einem Update rein gekommen.
                            Kann es das gewesen sein? Was hat das für eine Auswirkung?
                              @psrelax
                              Ja das war der Fehler 🙂
                              E3DC hat bei seiner Schnittstelle eine Sicherheit eingebaut, nämlich dass die Werte zur Leistungssteuerung min. alle 6 sek, wiederholt werden müssen, wenn das nicht erfolgt übernimmt E3DC wieder die Steuerung.
                              "SET_POWER Wiederholintervall" bewirkt, dass der e3dc-rscp Adapter den Wert SET_POWER_VALUE innerhalb der eingestellten Zeit wiederholt.
                              Das Problem ist jetzt aber, dass mein Script genau diesen Sicherheitsmechanismus nutzt und einfach keine Werte mehr setzt, wenn E3DC die Regelung wieder übernehmen soll.
                              Durch die Einstellung 1 hat aber der e3dc-rscp Adapter den letzten Wert 0 vom Skript jede sek. gesetzt und somit das Entladen der Batterie verhindert.
                                @arnod
                                Ok, vielen Dank für die Info.
                                Wie geht es mit der Tibber-Implementation voran? 🙂
                                  Nicht einfach, aber es wird schon. 🙂
                                  • azzkikrboy
                                    azzkikrboy last edited by
                                    Hallo @ArnoD
                                    Ich habe gerade ioBroker upgedated und dann folgede Meldung im Log gesehen.
                                    Sieht so aus, als ob der javascript-Adapter das zusätzliche Package "FS" nicht installieren kann.
                                    Script scheint aber trotzdem zu laufen (auf den ersten Blick ...).
                                    Cannot install custom npm package "fs@latest": Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/fs/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                                    Sollte das per Hand nachinstalliert werden?
                                      Thomas Braun Most Active @azzkikrboy last edited by
                                      @azzkikrboy sagte in E3DC Hauskraftwerk steuern:
                                      Nein, lass das so.
                                      azzkikrboy 1 Reply Last reply Reply Quote 1
                                      • azzkikrboy
                                        azzkikrboy @Thomas Braun last edited by
                                        OK. Danke.
                                          @psrelax
                                          Ich habe jetzt mal die erste Version vom Tibber Skript und ChargeControl v. 1.5.0 auf Github hochgeladen.
                                          Branch Issue#10
                                          Wenn du Lust hast, kannst du das so weit mal testen.
                                          Es fehlen noch einige Funktionen und aktuell funktioniert das Laden zum günstigsten Stundenblock.
                                          Die View findest du auch auf Github zum Importieren: View Import Dateien
                                          Bei ChargeControl Version 1.5.0 hat sich einiges geändert und wenn du die History Daten der PV-Prognose für August benötigst, kannst du bis zum 01.09 warten oder die Daten manuell in die jeweiligen Array Objekte eintragen.
                                          Hier die Auflistung der Änderungen:
                                          • Es wird überprüft ob bei den Instanzeinstellungen des e3dc-rscp Adapter __SET_POWER Wiederholintervall auf 0 eingestellt ist.
                                          • Fehler behoben, dass bei Leerlauf Script ChargeControl SET_POWER_MODE nicht auf 0 gesetzt wurde.
                                          • Fehler im DebugLog behoben, wo zweimal die gleichen Werte sID_PvLeistung_ADD_W addiert wurden. (Danke an @psrelax für den Hinweis)
                                          • Kleinere Optimierungen und Fehler behoben für das Script my-pv Heizstab
                                          • Schnittstelle für das Skript Tibber integriert
                                          • Berechnung des durchschnittlichen Hausverbrauchs neu erstellt. Es wird jetzt der Durchschnitt für jeden Tag, getrennt in Verbrauch Tag und Nacht berechnet.
                                            Die Anzeige Autonomiezeit in VIS wurde dadurch auch angepasst. Es wird jetzt die Reichweite der Batterie mit dem neuen Durchschnittsverbrauch berechnet und mit dem aktuellen Verbrauch bei Entladung der Batterie.
                                          • Alle Objekt ID's IstPvLeistung_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.istPV_LeistungTag_kWh gespeichert.
                                          • Alle Objekt ID's PrognoseProp_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseProp_kWh gespeichert.
                                          • Alle Objekt ID's PrognoseAuto_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseAuto_kWh gespeichert.
                                          • Alle Objekt ID's PrognoseSolcast90_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseSolcast90_kWh gespeichert.
                                          • Alle Objekt ID's PrognoseSolcast_kWh_1 bis 31 werden nicht mehr benötigt. Daten werden unter der neuen Objekt ID 0_userdata.0.Charge_Control.History.PrognoseSolcast_kWh gespeichert.
                                            MaLei last edited by
                                            wie upgrade ich eigentlich auf eine neue Charge Control Version?
                                            Meine Version (1.3.1) läuft seit längerer Zeit sehr gut und ich möchte sie mir nicht "zerstören", indem ich einfach die aktuelle drüber kopiere.
                                            MaLei
                                            3399
                                            1457452
