    4. Probleme beim Update Host node.js
      Thomas Braun Most Active @keineAhnungvonProgrmieren last edited by
      @keineahnungvonprogrmieren sagte in Probleme beim Update Host node.js:
      oder deute ich das falsch?
      Jein. Hau da per
      iob nodejs-update
      die aktuell empfohlene nodejs@20 rein.
        keineAhnungvonProgrmieren @Thomas Braun last edited by
        @thomas-braun said in Probleme beim Update Host node.js:
        Jein. Hau da per
        iob nodejs-update
        so?
        SmartHome@SmartHome:~ $ iob nodejs-update
        iobroker nodejs-update [<major-version>]
        Upgrade the Node.JS installation to the current LTS
        Options:
          --help  Show help  [boolean]
          Zuvor:
          iob stop
          iob fix
          dann dürfte es funktionieren.
            Zuvor:
            iob stop
            iob fix
            hat zuerst funktioniert
            nach ca 10min war die weboberfläche noch nicht erreichbar im anschluss von mir
            iob reboot
            danach
            SmartHome@SmartHome:~ $ iob reboot
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
              iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
              iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
              iobroker rebuild [<module>]                                  Rebuild all native modules or path
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
              iobroker object                                              Object management  [aliases: o]
              iobroker state                                               State management  [aliases: s]
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation  [aliases: id]
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
            Options:
            Thomas Braun K 2 Replies Last reply Reply Quote 0
              iob reboot
              Ist mir neu...
              sudo reboot
              kenne ich aber.
                keineAhnungvonProgrmieren @keineAhnungvonProgrmieren last edited by
                @keineahnungvonprogrmieren said in Probleme beim Update Host node.js:
                Zuvor:
                iob stop
                iob fix
                iob reboot
                danach
                iobroker [command]
                Commands:
                Options:
                jetzt:
                C:\Users\Benutzer1> ssh SmartHome@Smarthome
                Warning: Permanently added the ECDSA host key for IP address 'fd00::669a:fed7:8333:5b02' to the list of known hosts.
                SmartHome@smarthome password:
                ssh_dispatch_run_fatal: Connection to fd00::669a:fed7:8333:5b02 port 22: Connection timed out
                  Warten oder über die IP versuchen. Da hat es deine ssh keys verwürfelt. Hat aber mit dem nodejs Update nix zu tun, das packt die nämlich nicht an.
                    puh läuft wieder
                    Danke euch allen für die Konstruktiven antworten👏
                      keineAhnungvonProgrmieren @Thomas Braun last edited by keineAhnungvonProgrmieren
                      @thomas-braun said in Probleme beim Update Host node.js [gelöst]:
                      ok scheinbar habe ich mir ein neues Problem eingefangen
                      bin mir nicht sicher ob es was mit dem update was zu tun hat allerding lief bis zu dem Update der letzten Tage der IO Broker sehr stabil.
                      Nun zu meinen Beobachtungen:
                      wenn ich über comand auf den Raspberry zugreifen möchte dann wird diese verbindung sehr schnell wieder unterbrochen. manchmal reicht die Zeit um befehle plazieren zu können und mit etwas Glück reicht es für die eigendiagnose mit folgendem inhalt
                      *** iob diag is starting up, please wait ***
                      client_loop: send disconnect: Connection reset
                      C:\Users\Benutzer1>ssh SmartHome@Smarthome
                      Linux SmartHome 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Tue Aug  6 19:53:43 2024 from 192.168.178.71
                      Wi-Fi is currently blocked by rfkill.
                      Use raspi-config to set the country before use.
                      SmartHome@SmartHome:~ $ sudoclient_loop: send disconnect: Connection reset
                      C:\Users\Benutzer1>ssh SmartHome@smarthome
                      SmartHome@SmartHome:~ $ iob start admin.0
                      SmartHome@SmartHome:~ $ client_loop: send disconnect: Connection reset
                      SmartHomeRohlik@smarthomerohlik's password:
                      Permission denied, please try again.
                      Last login: Wed Aug  7 05:17:40 2024 from 192.168.178.71
                      SmartHome@SmartHome:~ $ iob stop
                      SmartHome@SmartHome:~ $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
                      Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
                      Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [181 kB]
                      Fetched 827 kB in 1s (557 kB/s)
                      Reading package lists... Done
                      Building dependency tree... Done
                      1 package can be upgraded. Run 'apt list --upgradable' to see it.
                      SmartHome@SmartHome:~ $ sudo apt upgrade
                      Calculating upgrade... Done
                      The following packages will be upgraded:
                        wpasupplicant
                      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 1,189 kB of archives.
                      After this operation, 10.2 kB disk space will be freed.
                      Do you want to continue? [Y/n] y
                      Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 wpasupplicant arm64 2:2.9.0-21+deb11u2 [1,189 kB]
                      Fetched 1,189 kB in 1s (1,588 kB/s)
                      Reading changelogs... Done
                      (Reading database ... 50170 files and directories currently installed.)
                      Preparing to unpack .../wpasupplicant_2%3a2.9.0-21+deb11u2_arm64.deb ...
                      Unpacking wpasupplicant (2:2.9.0-21+deb11u2) over (2:2.9.0-21) ...
                      Setting up wpasupplicant (2:2.9.0-21+deb11u2) ...
                      Processing triggers for man-db (2.9.4-2) ...
                      Processing triggers for dbus (1.12.28-0+deb11u1) ...
                      SmartHomeRohlik@SmartHomeRohlik:~ $ sudo reboot
                      Connection to smarthomerohlik closed by remote host.
                      Connection to smarthomerohlik closed.
                      Linux SmartHomeRohlik 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                      Last login: Wed Aug  7 05:20:31 2024 from 192.168.178.71
                      SmartHome@SmartHome:~ $ iob update
                      Used repository: stable
                      Adapter    "admin"        : 7.0.22   , installed 7.0.22
                      Adapter    "backitup"     : 3.0.16   , installed 2.11.0 [Updatable]
                      Adapter    "bshb"         : 0.2.8    , installed 0.2.8
                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                      Controller "js-controller": 6.0.9    , installed 6.0.9
                      Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
                      Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
                      SmartHomeRohlik@SmartHomeRohlik:~ $ client_loop: send disconnect: Connection reset
                      Auf die web oberfläche kann ich fast garnicht zugreifen, wenn es mal klappt dann kommt gelegentlich folgende Fehlermeldung:
                      wenn ich dem link folge dann soll ich die Admin updaten was aber schwer ist da ich ständig die verbindung via Comand verliere.
                      Hat jemand eine Idee was ich jetzt machen kann?
                        Du hast eine Knoten im Netzwerk.
                          Homoran Global Moderator Administrators @keineAhnungvonProgrmieren last edited by
                          das was im popup steht!
                          F12 -> Konsole -> Error posten
                            keineAhnungvonProgrmieren @Homoran last edited by
                            @homoran said in Probleme beim Update Host node.js:
                            Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 23
                            unreachable code after return statement
                            button.js:12:5
                            Missing key in translation token "global:" for language "en-GB"
                            der Screeshot ist von heute Morgen, denke das der Fehler aktuell nicht eingetragen ist.
                            Im Popup steht das ich die Admin instanz updaten soll was aber nicht möglich ist da ich via comand auch nicht zugreifen kann und wenn nur ganz kurz
                              woher kann der kommen?
                              viel wichtiger wie bekomme ich den wieder raus?
                                Keine Ahnung. Ich kenn dein Netzwerk ja nicht.
                                  IP ist auf jedenfall nicht doppelt vergeben
                                  kann auch nicht via IP adresse darauf zugreifen
                                  C:\Users\Benutzer1>192.168.178.52
                                  Der Befehl "192.168.178.52" ist entweder falsch geschrieben oder
                                  konnte nicht gefunden werden.
                                  C:\Users\Benutzer1>ssh 192.168.178.52
                                  benutzer1@192.168.178.52's password:
                                  Connection reset by 192.168.178.52 port 22
                                  ssh: connect to host 192.168.178.52 port 22: Connection timed out
                                  ssh_dispatch_run_fatal: Connection to 192.168.178.52 port 22: Connection timed out
                                    ??? Der user heißt doch SmartHome und nicht benutzer1
                                      normalerweise greife ich über
                                      ssh smartHome@smartHome
                                      zu habe jetzt versucht via
                                      ssh 192.168.178.52
                                      also der IP adresse zuzugreifen oder gibt es da noch andere Möglichkeiten?
                                      benutzer1 müsst eigendlich mein Windows laptop sein oder?
                                        Aber auch da gehört der username rein.
                                        Also
                                        ssh smartHome@192.168.178.52
                                          C:\Users\Benutzer1>ssh SmartHome@192.168.178.52
                                          C:\Users\Benutzer1>
                                          bis die Antwort da ist dauert es auch extrem lange
                                          ist der Port der richtige sollte bei mir der Standart sein da ich daran nix geändert habe
                                            22 ist der Standardport für SSH.
                                            4202
