    4. Probleme beim Update Host node.js
      keineAhnungvonProgrmieren @Thomas Braun last edited by
      @thomas-braun said in Probleme beim Update Host node.js:
      @keineahnungvonprogrmieren sagte in Probleme beim Update Host node.js:
      oder deute ich das falsch?
      Jein. Hau da per
      iob nodejs-update
      die aktuell empfohlene nodejs@20 rein.
      so?
      SmartHome@SmartHome:~ $ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
        --help  Show help  [boolean]
        Thomas Braun Most Active @keineAhnungvonProgrmieren last edited by
        Zuvor:
        iob stop
        iob fix
        dann dürfte es funktionieren.
          Zuvor:
          iob stop
          iob fix
          hat zuerst funktioniert
          nach ca 10min war die weboberfläche noch nicht erreichbar im anschluss von mir
          iob reboot
          danach
          SmartHome@SmartHome:~ $ iob reboot
          iobroker [command]
          Commands:
            iobroker setup                                               Setup ioBroker
            iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
            iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
            iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
            iobroker info                                                Shows the host info
            iobroker logs [<adapter>]                                    Monitor log
            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
            iobroker rebuild [<module>]                                  Rebuild all native modules or path
            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
            iobroker update [<repositoryUrl>]                            Update repository and list adapters
            iobroker upgrade                                             Upgrade management
            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
            iobroker object                                              Object management  [aliases: o]
            iobroker state                                               State management  [aliases: s]
            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
            iobroker list <type> [<filter>]                              List all entries, like objects
            iobroker chmod <mode> <file>                                 Change file rights
            iobroker chown <user> <group> <file>                         Change file ownership
            iobroker touch <file>                                        Touch file
            iobroker rm <file>                                           Remove file
            iobroker file                                                File management
            iobroker user                                                User commands
            iobroker group                                               group management
            iobroker host <hostname>                                     Set host to given hostname
            iobroker set <adapter>.<instance>                            Change settings of adapter config
            iobroker license <license.file or license.text>              Update license by given file
            iobroker cert                                                Certificate management
            iobroker clean <yes>                                         Clears all objects and states
            iobroker backup                                              Create backup
            iobroker restore <backup name or path>                       Restore a specified backup
            iobroker validate <backup name or path>                      Validate a specified backup
            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
            iobroker repo [<name>]                                       Show repo information
            iobroker uuid                                                Show uuid of the installation  [aliases: id]
            iobroker unsetup                                             Reset license, installation secret and language
            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
            iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
            iobroker multihost                                           Multihost management
            iobroker compact                                             compact group management
            iobroker plugin                                              Plugin management
            iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
          Options:
          Thomas Braun K 2 Replies Last reply Reply Quote 0
            iob reboot
            Ist mir neu...
            sudo reboot
            kenne ich aber.
              keineAhnungvonProgrmieren @keineAhnungvonProgrmieren last edited by
              @keineahnungvonprogrmieren said in Probleme beim Update Host node.js:
              Zuvor:
              iob stop
              iob fix
              iob reboot
              danach
              iobroker [command]
              Commands:
              Options:
              jetzt:
              C:\Users\Benutzer1> ssh SmartHome@Smarthome
              Warning: Permanently added the ECDSA host key for IP address 'fd00::669a:fed7:8333:5b02' to the list of known hosts.
              SmartHome@smarthome password:
              ssh_dispatch_run_fatal: Connection to fd00::669a:fed7:8333:5b02 port 22: Connection timed out
                Warten oder über die IP versuchen. Da hat es deine ssh keys verwürfelt. Hat aber mit dem nodejs Update nix zu tun, das packt die nämlich nicht an.
                  puh läuft wieder
                  Danke euch allen für die Konstruktiven antworten👏
                    keineAhnungvonProgrmieren @Thomas Braun last edited by keineAhnungvonProgrmieren
                    @thomas-braun said in Probleme beim Update Host node.js [gelöst]:
                    ok scheinbar habe ich mir ein neues Problem eingefangen
                    bin mir nicht sicher ob es was mit dem update was zu tun hat allerding lief bis zu dem Update der letzten Tage der IO Broker sehr stabil.
                    Nun zu meinen Beobachtungen:
                    wenn ich über comand auf den Raspberry zugreifen möchte dann wird diese verbindung sehr schnell wieder unterbrochen. manchmal reicht die Zeit um befehle plazieren zu können und mit etwas Glück reicht es für die eigendiagnose mit folgendem inhalt
                    *** iob diag is starting up, please wait ***
                    client_loop: send disconnect: Connection reset
                    C:\Users\Benutzer1>ssh SmartHome@Smarthome
                    Linux SmartHome 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Tue Aug  6 19:53:43 2024 from 192.168.178.71
                    Wi-Fi is currently blocked by rfkill.
                    Use raspi-config to set the country before use.
                    SmartHome@SmartHome:~ $ sudoclient_loop: send disconnect: Connection reset
                    C:\Users\Benutzer1>ssh SmartHome@smarthome
                    SmartHome@SmartHome:~ $ iob start admin.0
                    SmartHome@SmartHome:~ $ client_loop: send disconnect: Connection reset
                    SmartHomeRohlik@smarthomerohlik's password:
                    Permission denied, please try again.
                    Last login: Wed Aug  7 05:17:40 2024 from 192.168.178.71
                    SmartHome@SmartHome:~ $ iob stop
                    SmartHome@SmartHome:~ $ sudo apt update
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
                    Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
                    Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [181 kB]
                    Fetched 827 kB in 1s (557 kB/s)
                    Reading package lists... Done
                    Building dependency tree... Done
                    1 package can be upgraded. Run 'apt list --upgradable' to see it.
                    SmartHome@SmartHome:~ $ sudo apt upgrade
                    Calculating upgrade... Done
                    The following packages will be upgraded:
                      wpasupplicant
                    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 1,189 kB of archives.
                    After this operation, 10.2 kB disk space will be freed.
                    Do you want to continue? [Y/n] y
                    Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 wpasupplicant arm64 2:2.9.0-21+deb11u2 [1,189 kB]
                    Fetched 1,189 kB in 1s (1,588 kB/s)
                    Reading changelogs... Done
                    (Reading database ... 50170 files and directories currently installed.)
                    Preparing to unpack .../wpasupplicant_2%3a2.9.0-21+deb11u2_arm64.deb ...
                    Unpacking wpasupplicant (2:2.9.0-21+deb11u2) over (2:2.9.0-21) ...
                    Setting up wpasupplicant (2:2.9.0-21+deb11u2) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    Processing triggers for dbus (1.12.28-0+deb11u1) ...
                    SmartHomeRohlik@SmartHomeRohlik:~ $ sudo reboot
                    Connection to smarthomerohlik closed by remote host.
                    Connection to smarthomerohlik closed.
                    Linux SmartHomeRohlik 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                    Last login: Wed Aug  7 05:20:31 2024 from 192.168.178.71
                    SmartHome@SmartHome:~ $ iob update
                    Used repository: stable
                    Adapter    "admin"        : 7.0.22   , installed 7.0.22
                    Adapter    "backitup"     : 3.0.16   , installed 2.11.0 [Updatable]
                    Adapter    "bshb"         : 0.2.8    , installed 0.2.8
                    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                    Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                    Controller "js-controller": 6.0.9    , installed 6.0.9
                    Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
                    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                    Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                    Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                    Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
                    Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
                    Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
                    SmartHomeRohlik@SmartHomeRohlik:~ $ client_loop: send disconnect: Connection reset
                    Auf die web oberfläche kann ich fast garnicht zugreifen, wenn es mal klappt dann kommt gelegentlich folgende Fehlermeldung:
                    wenn ich dem link folge dann soll ich die Admin updaten was aber schwer ist da ich ständig die verbindung via Comand verliere.
                    Hat jemand eine Idee was ich jetzt machen kann?
                      Du hast eine Knoten im Netzwerk.
                        Homoran Global Moderator Administrators @keineAhnungvonProgrmieren last edited by
                        das was im popup steht!
                        F12 -> Konsole -> Error posten
                          keineAhnungvonProgrmieren @Homoran last edited by
                          @homoran said in Probleme beim Update Host node.js:
                          Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 23
                          unreachable code after return statement
                          button.js:12:5
                          Missing key in translation token "global:" for language "en-GB"
                          der Screeshot ist von heute Morgen, denke das der Fehler aktuell nicht eingetragen ist.
                          Im Popup steht das ich die Admin instanz updaten soll was aber nicht möglich ist da ich via comand auch nicht zugreifen kann und wenn nur ganz kurz
                            woher kann der kommen?
                            viel wichtiger wie bekomme ich den wieder raus?
                              Keine Ahnung. Ich kenn dein Netzwerk ja nicht.
                                IP ist auf jedenfall nicht doppelt vergeben
                                kann auch nicht via IP adresse darauf zugreifen
                                C:\Users\Benutzer1>192.168.178.52
                                Der Befehl "192.168.178.52" ist entweder falsch geschrieben oder
                                konnte nicht gefunden werden.
                                C:\Users\Benutzer1>ssh 192.168.178.52
                                benutzer1@192.168.178.52's password:
                                Connection reset by 192.168.178.52 port 22
                                ssh: connect to host 192.168.178.52 port 22: Connection timed out
                                ssh_dispatch_run_fatal: Connection to 192.168.178.52 port 22: Connection timed out
                                  ??? Der user heißt doch SmartHome und nicht benutzer1
                                    normalerweise greife ich über
                                    ssh smartHome@smartHome
                                    zu habe jetzt versucht via
                                    ssh 192.168.178.52
                                    also der IP adresse zuzugreifen oder gibt es da noch andere Möglichkeiten?
                                    benutzer1 müsst eigendlich mein Windows laptop sein oder?
                                      Aber auch da gehört der username rein.
                                      Also
                                      ssh smartHome@192.168.178.52
                                        C:\Users\Benutzer1>ssh SmartHome@192.168.178.52
                                        C:\Users\Benutzer1>
                                        bis die Antwort da ist dauert es auch extrem lange
                                        ist der Port der richtige sollte bei mir der Standart sein da ich daran nix geändert habe
                                          22 ist der Standardport für SSH.
                                          • haselchen
                                            haselchen Most Active @Thomas Braun last edited by
                                            Was ist mit dieser Aussage
                                            4779
