    4. Probleme beim Update Host node.js
      Thomas Braun Most Active @keineAhnungvonProgrmieren last edited by
      @keineahnungvonprogrmieren
      Zuvor:
      iob stop
      iob fix
      dann dürfte es funktionieren.
        keineAhnungvonProgrmieren @Thomas Braun last edited by
        @thomas-braun said in Probleme beim Update Host node.js:
        Zuvor:
        iob stop
        iob fix
        hat zuerst funktioniert
        nach ca 10min war die weboberfläche noch nicht erreichbar im anschluss von mir
        iob reboot
        danach
        SmartHome@SmartHome:~ $ iob reboot
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
          iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
          iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all native modules or path
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
          iobroker object                                              Object management  [aliases: o]
          iobroker state                                               State management  [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation  [aliases: id]
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
          iobroker plugin                                              Plugin management
          iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        Thomas Braun K 2 Replies Last reply Reply Quote 0
          iob reboot
          Ist mir neu...
          sudo reboot
          kenne ich aber.
            keineAhnungvonProgrmieren @keineAhnungvonProgrmieren last edited by
            @keineahnungvonprogrmieren said in Probleme beim Update Host node.js:
            Zuvor:
            iob stop
            iob fix
            iob reboot
            danach
            iobroker [command]
            Commands:
            Options:
            jetzt:
            C:\Users\Benutzer1> ssh SmartHome@Smarthome
            Warning: Permanently added the ECDSA host key for IP address 'fd00::669a:fed7:8333:5b02' to the list of known hosts.
            SmartHome@smarthome password:
            ssh_dispatch_run_fatal: Connection to fd00::669a:fed7:8333:5b02 port 22: Connection timed out
              Warten oder über die IP versuchen. Da hat es deine ssh keys verwürfelt. Hat aber mit dem nodejs Update nix zu tun, das packt die nämlich nicht an.
                puh läuft wieder
                Danke euch allen für die Konstruktiven antworten👏
                  keineAhnungvonProgrmieren @Thomas Braun last edited by keineAhnungvonProgrmieren
                  @thomas-braun said in Probleme beim Update Host node.js [gelöst]:
                  ok scheinbar habe ich mir ein neues Problem eingefangen
                  bin mir nicht sicher ob es was mit dem update was zu tun hat allerding lief bis zu dem Update der letzten Tage der IO Broker sehr stabil.
                  Nun zu meinen Beobachtungen:
                  wenn ich über comand auf den Raspberry zugreifen möchte dann wird diese verbindung sehr schnell wieder unterbrochen. manchmal reicht die Zeit um befehle plazieren zu können und mit etwas Glück reicht es für die eigendiagnose mit folgendem inhalt
                  *** iob diag is starting up, please wait ***
                  client_loop: send disconnect: Connection reset
                  C:\Users\Benutzer1>ssh SmartHome@Smarthome
                  Linux SmartHome 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                  The programs included with the Debian GNU/Linux system are free software;
                  the exact distribution terms for each program are described in the
                  individual files in /usr/share/doc/*/copyright.
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Tue Aug  6 19:53:43 2024 from 192.168.178.71
                  Wi-Fi is currently blocked by rfkill.
                  Use raspi-config to set the country before use.
                  SmartHome@SmartHome:~ $ sudoclient_loop: send disconnect: Connection reset
                  C:\Users\Benutzer1>ssh SmartHome@smarthome
                  SmartHome@SmartHome:~ $ iob start admin.0
                  SmartHome@SmartHome:~ $ client_loop: send disconnect: Connection reset
                  SmartHomeRohlik@smarthomerohlik's password:
                  Permission denied, please try again.
                  Last login: Wed Aug  7 05:17:40 2024 from 192.168.178.71
                  SmartHome@SmartHome:~ $ iob stop
                  SmartHome@SmartHome:~ $ sudo apt update
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                  Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [276 kB]
                  Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [277 kB]
                  Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [181 kB]
                  Fetched 827 kB in 1s (557 kB/s)
                  Reading package lists... Done
                  Building dependency tree... Done
                  1 package can be upgraded. Run 'apt list --upgradable' to see it.
                  SmartHome@SmartHome:~ $ sudo apt upgrade
                  Calculating upgrade... Done
                  The following packages will be upgraded:
                    wpasupplicant
                  1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 1,189 kB of archives.
                  After this operation, 10.2 kB disk space will be freed.
                  Do you want to continue? [Y/n] y
                  Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 wpasupplicant arm64 2:2.9.0-21+deb11u2 [1,189 kB]
                  Fetched 1,189 kB in 1s (1,588 kB/s)
                  Reading changelogs... Done
                  (Reading database ... 50170 files and directories currently installed.)
                  Preparing to unpack .../wpasupplicant_2%3a2.9.0-21+deb11u2_arm64.deb ...
                  Unpacking wpasupplicant (2:2.9.0-21+deb11u2) over (2:2.9.0-21) ...
                  Setting up wpasupplicant (2:2.9.0-21+deb11u2) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Processing triggers for dbus (1.12.28-0+deb11u1) ...
                  SmartHomeRohlik@SmartHomeRohlik:~ $ sudo reboot
                  Connection to smarthomerohlik closed by remote host.
                  Connection to smarthomerohlik closed.
                  Linux SmartHomeRohlik 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                  Last login: Wed Aug  7 05:20:31 2024 from 192.168.178.71
                  SmartHome@SmartHome:~ $ iob update
                  Used repository: stable
                  Adapter    "admin"        : 7.0.22   , installed 7.0.22
                  Adapter    "backitup"     : 3.0.16   , installed 2.11.0 [Updatable]
                  Adapter    "bshb"         : 0.2.8    , installed 0.2.8
                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                  Controller "js-controller": 6.0.9    , installed 6.0.9
                  Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
                  Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                  Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
                  Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
                  Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
                  SmartHomeRohlik@SmartHomeRohlik:~ $ client_loop: send disconnect: Connection reset
                  Auf die web oberfläche kann ich fast garnicht zugreifen, wenn es mal klappt dann kommt gelegentlich folgende Fehlermeldung:
                  wenn ich dem link folge dann soll ich die Admin updaten was aber schwer ist da ich ständig die verbindung via Comand verliere.
                  Hat jemand eine Idee was ich jetzt machen kann?
                    @keineahnungvonprogrmieren sagte in Probleme beim Update Host node.js:
                    Du hast eine Knoten im Netzwerk.
                      Homoran Global Moderator Administrators @keineAhnungvonProgrmieren last edited by
                      das was im popup steht!
                      F12 -> Konsole -> Error posten
                        keineAhnungvonProgrmieren @Homoran last edited by
                        @homoran said in Probleme beim Update Host node.js:
                        Diese Seite verwendet die nicht standardisierte Eigenschaft "zoom". Stattdessen sollte calc() in den entsprechenden Eigenschaftswerten oder "transform" zusammen mit "transform-origin: 0 0" verwendet werden. 23
                        unreachable code after return statement
                        button.js:12:5
                        Missing key in translation token "global:" for language "en-GB"
                        der Screeshot ist von heute Morgen, denke das der Fehler aktuell nicht eingetragen ist.
                        Im Popup steht das ich die Admin instanz updaten soll was aber nicht möglich ist da ich via comand auch nicht zugreifen kann und wenn nur ganz kurz
                          woher kann der kommen?
                          viel wichtiger wie bekomme ich den wieder raus?
                            Keine Ahnung. Ich kenn dein Netzwerk ja nicht.
                              IP ist auf jedenfall nicht doppelt vergeben
                              kann auch nicht via IP adresse darauf zugreifen
                              C:\Users\Benutzer1>192.168.178.52
                              Der Befehl "192.168.178.52" ist entweder falsch geschrieben oder
                              konnte nicht gefunden werden.
                              C:\Users\Benutzer1>ssh 192.168.178.52
                              benutzer1@192.168.178.52's password:
                              Connection reset by 192.168.178.52 port 22
                              ssh: connect to host 192.168.178.52 port 22: Connection timed out
                              ssh_dispatch_run_fatal: Connection to 192.168.178.52 port 22: Connection timed out
                                ??? Der user heißt doch SmartHome und nicht benutzer1
                                  normalerweise greife ich über
                                  ssh smartHome@smartHome
                                  zu habe jetzt versucht via
                                  ssh 192.168.178.52
                                  also der IP adresse zuzugreifen oder gibt es da noch andere Möglichkeiten?
                                  benutzer1 müsst eigendlich mein Windows laptop sein oder?
                                    Aber auch da gehört der username rein.
                                    Also
                                    ssh smartHome@192.168.178.52
                                      C:\Users\Benutzer1>ssh SmartHome@192.168.178.52
                                      C:\Users\Benutzer1>
                                      bis die Antwort da ist dauert es auch extrem lange
                                      ist der Port der richtige sollte bei mir der Standart sein da ich daran nix geändert habe
                                        22 ist der Standardport für SSH.
                                        • haselchen
                                          haselchen Most Active @Thomas Braun last edited by
                                          Was ist mit dieser Aussage
                                            Thomas Braun Most Active @haselchen last edited by
                                            @haselchen
                                            Da ist halt WLAN nie eingestellt worden. Muss ja auch nicht, wenn die Kiste per Kabel angebunden ist. Empfiehlt sich für einen Server ja eh.
                                            4202
