    4. [GELÖST] Umzug vom Pin64 auf Proxmox schlägt fehl.
      kurt_88 @Thomas Braun last edited by
      @thomas-braun Die Langfassung ...
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker01
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
      model name      : Intel(R) Pentium(R) Silver J5005 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:11:15 up  3:38,  2 users,  load average: 0.74, 0.42, 0.16
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Wed 2024-08-07 19:11:15 UTC
                 Universal time: Wed 2024-08-07 19:11:15 UTC
                       RTC time: n/a
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            4.3G        240M        3.6G        118K        414M        4.1G
      Swap:           1.1G          0B        1.1G
      Total:          5.4G        240M        4.7G
      Active iob-Instances:   2
               4096 M total memory
                230 M used memory
                217 M active memory
                368 M inactive memory
               3470 M free memory
                  0 M buffer memory
                395 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      top - 19:11:15 up  3:38,  2 users,  load average: 0.74, 0.42, 0.16
      Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,   3468.8 free,    231.6 used,    395.6 buff/cache
      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   3864.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       44G  4.5G   38G  11% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  112K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1588148k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/ttyUSB0                                        udev[/ttyACM0]                   devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3935852k,nr_inodes=983963,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      453M    /var/
      251M    /var/cache
      247M    /var/cache/apt
      171M    /var/cache/apt/archives
      146M    /var/lib
      Archived and active journals take up 55.5M in the file system.
      /opt/iobroker/backups:
      3.9M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      299M    /opt/iobroker/iobroker-data/
      269M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/backitup.admin
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/telegram.admin
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812141627-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      npm:                    N/A
      npx:                    N/A
      /usr/bin/corepack       0.28.2
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          6.3.5
      javascript:     6.1.4
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker01                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker01                               - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker01                               - disabled
      + system.adapter.backitup.0               : backitup              : iobroker01                               -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker01                               - disabled
        system.adapter.devices.0                : devices               : iobroker01                               - disabled
        system.adapter.discovery.0              : discovery             : iobroker01                               - disabled
        system.adapter.history.0                : history               : iobroker01                               - disabled
        system.adapter.ical.0                   : ical                  : iobroker01                               - disabled
        system.adapter.jarvis.0                 : jarvis                : iobroker01                               - disabled
        system.adapter.javascript.0             : javascript            : iobroker01                               - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker01                               - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : iobroker01                               - disabled
        system.adapter.ping.0                   : ping                  : iobroker01                               - disabled
        system.adapter.sonoff.0                 : sonoff                : iobroker01                               - disabled, port: 1888, bind: 0.0.0.0
        system.adapter.telegram.0               : telegram              : iobroker01                               - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : iobroker01                               - disabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker01                               - disabled
        system.adapter.tuya.0                   : tuya                  : iobroker01                               - disabled
        system.adapter.web.0                    : web                   : iobroker01                               - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : iobroker01                               - disabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812141627-if00
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 6.3.5  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.23.2 [Updatable]
      Adapter    "backitup"     : 3.0.16   , installed 2.5.10 [Updatable]
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.4  [Updatable]
      Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
      Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
      Adapter    "ical"         : 1.15.0   , installed 1.13.2 [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.2  [Updatable]
      Adapter    "javascript"   : 8.7.6    , installed 6.1.4  [Updatable]
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "mqtt"         : 5.2.0    , installed 4.0.7  [Updatable]
      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
      Adapter    "sonoff"       : 3.1.0    , installed 2.5.1  [Updatable]
      Adapter    "telegram"     : 3.3.2    , installed 1.15.2 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.17 [Updatable]
      Adapter    "trashschedule": 3.3.0    , installed 2.0.3  [Updatable]
      Adapter    "tuya"         : 3.15.0   , installed 3.12.1 [Updatable]
      Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 1.10.3   , installed 1.8.10 [Updatable]
      Objects and States
      Objects:        8926
      States:         8169
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          499376     1/init
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          499841     315/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       838771     33332/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       836556     33332/iobroker.js-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          496489     1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          499378     1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          499842     315/master
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          496522     95/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          499377     1/init
      udp6       0      0 :::111                  :::*                                0          499379     1/init
      2024-08-07 19:09:19.252  - info: host.iobroker01 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2024-08-07 19:09:19.604  - info: host.iobroker01 21 instances found
      2024-08-07 19:09:19.619  - info: host.iobroker01 starting 2 instances
      2024-08-07 19:09:19.863  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeCurrent"
      2024-08-07 19:09:19.883  - info: host.iobroker01 instance system.adapter.admin.0 in version "6.3.5" started with pid 33353
      2024-08-07 19:09:19.915  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeNewest"
      2024-08-07 19:09:19.918  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.nodeNewestNext"
      2024-08-07 19:09:19.921  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmCurrent"
      2024-08-07 19:09:19.923  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmNewest"
      2024-08-07 19:09:19.925  - info: host.iobroker01 Delete state "system.host.iobroker01.versions.npmNewestNext"
      2024-08-07 19:09:19.928  - info: host.iobroker01 Some obsolete host states deleted.
      2024-08-07 19:09:21.340  - info: admin.0 (33353) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.16.0, js-controller: 6.0.9
      2024-08-07 19:09:21.360  - info: admin.0 (33353) requesting all states
      2024-08-07 19:09:21.361  - info: admin.0 (33353) requesting all objects
      2024-08-07 19:09:21.674  - warn: admin.0 (33353) Cannot get current npm version: Cannot find npm version
      2024-08-07 19:09:22.251  - info: admin.0 (33353) received all objects
      2024-08-07 19:09:22.326  - error: admin.0 (33353) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      2024-08-07 19:09:22.327  - info: admin.0 (33353) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-07 19:09:22.700  - error: admin.0 (33353) Cannot update news: TypeError: newNews.forEach is not a function
      2024-08-07 19:09:22.861  - info: admin.0 (33353) terminating http server on port 8081
      2024-08-07 19:09:22.904  - info: host.iobroker01 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-08-07 19:09:22.905  - info: host.iobroker01 Do not restart adapter system.adapter.admin.0 because desired by instance
      2024-08-07 19:09:23.838  - info: host.iobroker01 instance system.adapter.backitup.0 in version "2.5.10" started with pid 33371
      2024-08-07 19:09:25.051  - info: backitup.0 (33371) starting. Version 2.5.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.16.0, js-controller: 6.0.9
      2024-08-07 19:09:25.085  - info: backitup.0 (33371) [iobroker] backup was activated at 02:40 every 1 day(s)
      iob diag has finished.
        Thomas Braun Most Active @kurt_88 last edited by
        @kurt_88 sagte in Umzug vom Pin64 auf Proxmox schlägt fehl.:
        root
        Kerl...
          @thomas-braun Bin noch dabei, sofern etwas Luft ist lege ich einen eigenen Nutzer an, versprochen 🙂
            NEIN! Das ist dass ALLERERSTE (UND DAS ALLEREINZIGSTE!!!) WAS MAN ALS ROOT TUT.
            Danach NUR NOCH ALS USER!!!!!!!!!!!!!
              @thomas-braun Ja, ist schon erledigt.
                @kurt_88
                iob diag
                  @kurt_88
                  npm haste dir über den root verhunzt. Als user kannst du die Datei gar nicht löschen:
                  echad@chet:~ $ rm /usr/bin/npm
                  rm: cannot remove '/usr/bin/npm': Permission denied
                  echad@chet:~ $
                  Und deswegen halt NIE, NIE, NIE als root herumhampeln.
                    @thomas-braun Die lange Version
                    Skript v.2024-05-22
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                     19:28:57 up  3:56,  2 users,  load average: 0.03, 0.09, 0.13
                    CPU threads: 2
                                   Local time: Wed 2024-08-07 19:28:57 UTC
                               Universal time: Wed 2024-08-07 19:28:57 UTC
                                     RTC time: n/a
                              RTC in local TZ: no
                    kurt
                    HOME=/home/kurt
                    GROUPS=kurt sudo users
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:            4.3G        258M        3.6G        122K        425M        4.0G
                    Swap:           1.1G          0B        1.1G
                    Total:          5.4G        258M        4.7G
                             4096 M total memory
                              247 M used memory
                              220 M active memory
                              391 M inactive memory
                             3443 M free memory
                                0 M buffer memory
                              405 M swap cache
                             1024 M total swap
                                0 M used swap
                             1024 M free swap
                    top - 19:28:57 up  3:56,  2 users,  load average: 0.03, 0.09, 0.13
                    Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   4096.0 total,   3441.6 free,    248.8 used,    405.6 buff/cache
                    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   3847.2 avail Mem
                    *** FILESYSTEM ***
                    /dev/mapper/pve-vm--100--disk--0 ext4       44G  4.6G   38G  11% /
                    tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
                    /var:
                    461M    /var/
                    251M    /var/cache
                    247M    /var/cache/apt
                    146M    /var/lib
                    Archived and active journals take up 8.0M in the file system.
                    USB-Devices by-id:
                    HINT:
                    npm:                    N/A
                    npx:                    N/A
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        8926
                    States:         8169
                    Pending Updates: 0
                    und die Zusammenfassung
                                            v.2024-05-22
                      Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               64 bit
                    Timezone:               Etc/UTC (UTC, +0000)
                    User-ID:                1001
                    Boot Target:            graphical.target
                    Pending OS-Updates:     0
                    Pending iob updates:    21
                    Nodejs-Installation:
                    npm:                    N/A
                    npx:                    N/A
                    Recommended versions are nodejs 16.20.2 and npm 8.19.4
                    Wrong installation path detected. This needs to be fixed.
                    Please execute
                    iobroker nodejs-update
                    to fix these errors.
                    MEMORY:
                    Mem:            4.3G        260M        3.6G        122K        425M        4.0G
                    Swap:           1.1G          0B        1.1G
                    Total:          5.4G        260M        4.7G
                    ioBroker Core:          js-controller           6.0.9
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                8926
                    States:                 8169
                    Size of iob-Database:
                    5.1M    /opt/iobroker/iobroker-data/states.jsonl
                      nen neuen LXC einrichten dauert 5 min, iobroker drauf und backup einspielen, oder man diskutiert und blödelt noch mehrere Stunden herum😜
                      wie man einen LXC korrekt aufsetzt steht in der Doku
                        Zeitzone setzen.
                        sudo systemd set-default multi-user.target
                        Setz den kurt in die Gruppe adm.
                        nodejs:
                        sudo apt update
                        sudo apt install --reinstall nodejs
                        Bring den ganzen ioBroker-Kram auf Stand.
                          Thomas Braun Most Active @crunchip last edited by
                          @crunchip sagte in Umzug vom Pin64 auf Proxmox schlägt fehl.:
                          Ja, ist die beste Variante. Wer weiß was da sonst noch verrootet worden ist.
                            kurt_88 @Thomas Braun last edited by kurt_88
                            @thomas-braun Es klappt jetzt.
                            Ich habe einmal
                            ausprobiert und es hat geklappt.
                            Dann habe ich iobroker gestoppt und das momentane iobroker Verzeichnis umbenannt und iobroker noch mal installiert mit
                            sudo curl -sL -v https://iobroker.net/install.sh | bash -
                            Auf dem alten geupdateten iobroker Server nochmal ein Backup erstellt und auf den LXC Container übertragen und mit dem neuen iobroker das restore angestoßen.
                            Es ist alles sauber durchgelaufen und die Admin Oberfläche ist auch erreichbar, anbei das kleine Diag.
                                                    v.2024-05-22
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                0
                            Pending iob updates:    0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            Recommended versions are nodejs 20.16.0 and npm 10.8.1
                            MEMORY:
                            Mem:            4.3G        918M        403M        122K        3.0G        3.4G
                            Swap:           1.1G          0B        1.1G
                            Total:          5.4G        918M        1.5G
                            Active iob-Instances:   3
                                                    admin                   7.0.22
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : iobroker01                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            Objects:                9030
                            States:                 8093
                            15M     /opt/iobroker/iobroker-data/objects.jsonl
                            1.8M    /opt/iobroker/iobroker-data/states.jsonl
                            Schönen Abend noch und ein großes Dankschön an Thomas und Crunchip
                            Viele Grüße Kurt
                            Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
                              Immer noch falsch. Das ist WICHTIG!
                              sudo timedatectl set-timezone America/Los_Angeles
                              oder wo auch immer du residierst.
                              Boot Target auch nicht richtig gesetzt. Liest du eigentlich was man dir schreibt?
                              UND DU HAMPELST DA SCHON WIEDER ALS ROOT UMHER!
                              Echt, ich hab da KEINEN BOCK MEHR DRAUF!
                                crunchip Forum Testing Most Active @kurt_88 last edited by
                                Es klappt jetzt.
                                ne, nicht wirklich
                                lies doch bitte mal die Doku, wie ein LXC aufgesetzt werden muss
                                  @thomas-braun war ein bisschen viel heute, habe auch noch ander Sachen zu tun gehabt. Das mit root stimmt schon mal nicht ...
                                  === Mark text until here for copying ===
                                  kurt@iobroker01:/opt/iobroker$
                                  Und das mit der Zeitzone habe ich noch auf den Schirm, morgen ist aber auch noch ein Tag ... :)
                                    Thomas Braun Most Active @kurt_88 last edited by Thomas Braun
                                    User-ID: 0
                                    Da bist du ROOT. Das sieht man.
                                    Also hast du dich da schon mal nicht daran gehalten, das man sich gar nicht erst als root einloggt.
                                    Ich muss mal wieder den root aussperren in dem Skript... Nervt mich.
                                      @thomas-braun nob, ich habe sudo iob diag ausgeführt.
                                        @kurt_88
                                        Nächstes Ding...
                                        ioBroker-Kommandos werden auch NIE, NIE, NIE als root / per sudo ausgeführt.
                                        Also warst du doch root. Wenn auch nur für den Befehl.
                                          @thomas-braun Danke für den Tipp.
                                            @kurt_88
                                            Zum selberausprobieren:
                                            whoami
                                            sudo whoami
                                            whoami
                                            Gucken und staunen.
                                            2325
