    • Armilar
      Armilar Most Active Forum Testing @haus-automatisierung last edited by
      Ich gehe mal davon aus, dass mir bei den regelmäßigen Systemstarts dieser Fehler aufgefallen wäre... Also wenn da mal ein fehlerhaftes dayjs dabei gewesen wäre...
        TT-Tom @haus-automatisierung last edited by TT-Tom
        Das ist das Log von @MichaelF
        Er bekommt trotzdem die Fehlermeldung das dayjs nicht gefunden wird.
        javascript.0
        2024-08-06 12:44:10.233	info	requesting all objects
        javascript.0
        2024-08-06 12:44:10.231	info	requesting all states
        javascript.0
        2024-08-06 12:44:05.205	debug	Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
        javascript.0
        2024-08-06 12:44:05.171	debug	Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/assert/strict.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/diagnostics_channel.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/dns/promises.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/dom-events.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/fs/promises.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/readline/promises.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/sea.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/stream/promises.d.ts","node_modules/@types/node/stream/consumers.d.ts","node_modules/@types/node/stream/web.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/test.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/timers/promises.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/wasi.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts"]
        javascript.0
        2024-08-06 12:44:05.117	debug	Installed custom dependency: "dayjs@latest"
        javascript.0
        2024-08-06 12:43:49.595	debug	Found custom dependency in config: "dayjs@latest"
        javascript.0
        2024-08-06 12:43:49.557	debug	Installed custom dependency: "moment@latest"
        javascript.0
        2024-08-06 12:43:34.083	debug	Found custom dependency in config: "moment@latest"
        javascript.0
        2024-08-06 12:43:34.075	debug	Installed custom dependency: "moment-parseformat@latest"
        javascript.0
        2024-08-06 12:43:18.791	debug	Found custom dependency in config: "moment-parseformat@latest"
        javascript.0
        2024-08-06 12:43:18.741	debug	Installed custom dependency: "node-ssh@latest"
        javascript.0
        2024-08-06 12:43:02.887	debug	Found custom dependency in config: "node-ssh@latest"
        javascript.0
        2024-08-06 12:43:02.730	debug	Installed custom dependency: "simple-ssh@latest"
        javascript.0
        2024-08-06 12:42:46.936	debug	Found custom dependency in config: "simple-ssh@latest"
        javascript.0
        2024-08-06 12:42:46.935	debug	Found installed libraries: ["moment","moment-parseformat","node-ssh","simple-ssh"]
        javascript.0
        2024-08-06 12:42:46.883	debug	config.subscribe (Do not subscribe all states on start): false
        javascript.0
        2024-08-06 12:42:46.840	info	starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.16.0, js-controller: 6.0.9
        javascript.0
        2024-08-06 12:42:41.588	debug	Plugin sentry Initialize Plugin (enabled=true)
        post zum Inhalt des Verzeichnis
        Edit: die Daten sind alle da, auch das System ist aktuell. Trotzdem kommt es zu den Meldungen.
        Das ist der Code Ausschnitt vom Script
        async function Init_dayjs() {
            try {
                //Loading dayjs
                const dayjs = require('dayjs');
                const dayjsLanguages: any = ['en','de','nl','da','es','fr','it','ru','nb','nn',
                                             'pl','pt','af','ar','bg','ca','cs','el','et','fa',
                                             'fi','he','hr','hu','hy-am','id','is','lb','lt','ro',
                                             'sk','sl','sv','th','tr','uk','vi','zh-cn','zh-tw']
                for (let i=0; i<dayjsLanguages.length;i++) {
                    require('dayjs/locale/'+ dayjsLanguages[i]);
                dayjs.locale(getDayjsLocale());
            } catch (err: any) {
                log('error at function init_dayjs: ' + err.message,'warn');
        Init_dayjs();
        • Rene55
          Rene55 @TT-Tom last edited by
          @tt-tom Ich habe gerade nochmal ein Backup vom 09.06. draufgeworfen. Darin js-Controller 5.0.19 und javascript-adapter 8.5.0. Hier tritt kein dayjs-Fehler auf.
            TT-Tom @Rene55 last edited by TT-Tom
            @rene55
            das ist interessant, kannst du mal bitte die Pfade kontrollieren, wo die npm-Module installiert sind.
            Hast du vom 9.6. dann das Update auf die aktuellen Versionen gemacht?
            @haus-automatisierung der Post von Rene55, vielleicht ist das noch ein wichtiger Hinweis.
            @Armilar was mir jetzt noch einfällt ist der Zusatz mit dem default
            const dayjs = require('dayjs').default;
            Matthias muss/soll das noch so geschrieben werden? Wurde eine zeitlang hier im Forum so erwähnt oder ist das mit der aktuellen JavaScript Version nicht mehr nötig?
            haus-automatisierung Rene55 2 Replies Last reply Reply Quote 0
            • haus-automatisierung
              haus-automatisierung Developer Most Active @TT-Tom last edited by
              @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
              Copy to Clipboardconst dayjs = require('dayjs').default;
              Wenn default existiert, wird das automatisch zurückgeliefert. Also nein, weglassen.
                SuFra last edited by
                Hallo zusammen.
                Ich habe gerade auch mein System auf JS Controller 6.0.9 upgedatet und nun die gleiche Fehlermeldung beim Starten/Compilieren der Scripte.
                frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/dayjs
                -bash: cd: /opt/iobroker/node_modules/dayjs: No such file or directory
                frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
                frank@iobroker-SuFra:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs$ ls -la
                total 152
                drwxrwxr-x+ 5 iobroker iobroker  4096 Aug  7 17:50 .
                drwxrwxr-x+ 6 iobroker iobroker  4096 Aug  7 17:50 ..
                -rw-rw-r--+ 1 iobroker iobroker 79810 Aug  7 17:50 CHANGELOG.md
                -rw-rw-r--+ 1 iobroker iobroker  7160 Aug  7 17:50 dayjs.min.js
                -rw-rw-r--+ 1 iobroker iobroker    94 Aug  7 17:50 .editorconfig
                drwxrwxr-x+ 4 iobroker iobroker  4096 Aug  7 17:50 esm
                -rw-rw-r--+ 1 iobroker iobroker 13872 Aug  7 17:50 index.d.ts
                -rw-rw-r--+ 1 iobroker iobroker  1072 Aug  7 17:50 LICENSE
                drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 locale
                -rw-rw-r--+ 1 iobroker iobroker  5033 Aug  7 17:50 locale.json
                -rw-rw-r--+ 1 iobroker iobroker  2526 Aug  7 17:50 package.json
                drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 plugin
                -rw-rw-r--+ 1 iobroker iobroker  7411 Aug  7 17:50 README.md
                Gruß Frank
                  iob diag:
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                   Static hostname: iobroker-SuFra
                         Icon name: computer-container
                           Chassis: container
                    Virtualization: lxc
                  Operating System: Ubuntu 22.04.4 LTS
                            Kernel: Linux 6.8.8-4-pve
                      Architecture: x86-64
                  model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
                  CPU threads: 4
                  *** Time and Time Zones ***
                                 Local time: Wed 2024-08-07 18:11:20 CEST
                             Universal time: Wed 2024-08-07 16:11:20 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  frank
                  HOME=/home/frank
                  GROUPS=frank sudo iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            8.2G        1.5G        6.4G        0.0K        347M        6.7G
                  Swap:           4.1G          0B        4.1G
                  Total:           12G        1.5G         10G
                  Active iob-Instances:   20
                           8192 M total memory
                           1475 M used memory
                           1621 M active memory
                            120 M inactive memory
                           6368 M free memory
                              0 M buffer memory
                            347 M swap cache
                           4096 M total swap
                              0 M used swap
                           4096 M free swap
                  top - 18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
                  Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8192.0 total,   6368.2 free,   1475.8 used,    347.9 buff/cache
                  MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6716.0 avail Mem
                  *** FAILED SERVICES ***
                    UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                  * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/rbd3      ext4       20G   12G  7.4G  61% /
                  none           tmpfs     492K  4.0K  488K   1% /dev
                  efivarfs       efivarfs  192K  110K   78K  59% /sys/firmware/efi/efivars
                  tmpfs          tmpfs      16G     0   16G   0% /dev/shm
                  tmpfs          tmpfs     6.3G  116K  6.3G   1% /run
                  tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                  dmesg: read kernel buffer failed: Operation not permitted
                  Show mounted filesystems:
                  TARGET                                        SOURCE                         FSTYPE      OPTIONS
                  /                                             /dev/rbd3                      ext4        rw,relatime,stripe=16
                  |-/run                                        tmpfs                          tmpfs       rw,nosuid,nodev,size=6503388k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                  | |-/run/lock                                 tmpfs                          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                  | `-/run/credentials/systemd-sysusers.service tmpfs                          tmpfs       ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
                  |-/dev                                        none                           tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/dev/shm                                  tmpfs                          tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
                  | |-/dev/mqueue                               mqueue                         mqueue      rw,relatime
                  | |-/dev/full                                 udev[/full]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/null                                 udev[/null]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/random                               udev[/random]                  devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/tty                                  udev[/tty]                     devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/urandom                              udev[/urandom]                 devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/zero                                 udev[/zero]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
                  | |-/dev/pts                                  devpts                         devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/ptmx                                 devpts[/ptmx]                  devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/console                              devpts[/0]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | |-/dev/tty1                                 devpts[/1]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  | `-/dev/tty2                                 devpts[/2]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                  |-/proc                                       proc                           proc        rw,nosuid,nodev,noexec,relatime
                  | |-/proc/sys                                 proc[/sys]                     proc        ro,relatime
                  | | |-/proc/sys/net                           proc[/sys/net]                 proc        rw,nosuid,nodev,noexec,relatime
                  | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc rw,nosuid,nodev,noexec,relatime
                  | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]            tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                  | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]           proc        ro,relatime
                  | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/diskstats                           lxcfs[/proc/diskstats]         fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/loadavg                             lxcfs[/proc/loadavg]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/meminfo                             lxcfs[/proc/meminfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]          fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/stat                                lxcfs[/proc/stat]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | |-/proc/swaps                               lxcfs[/proc/swaps]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  | `-/proc/uptime                              lxcfs[/proc/uptime]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  `-/sys                                        sysfs                          sysfs       ro,nosuid,nodev,noexec,relatime
                    |-/sys/fs/fuse/connections                  fusectl                        fusectl     rw,nosuid,nodev,noexec,relatime
                    |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]    sysfs       rw,nosuid,nodev,noexec,relatime
                    |-/sys/kernel/debug                         debugfs                        debugfs     rw,nosuid,nodev,noexec,relatime
                    |-/sys/kernel/security                      securityfs                     securityfs  rw,nosuid,nodev,noexec,relatime
                    |-/sys/fs/pstore                            pstore                         pstore      rw,nosuid,nodev,noexec,relatime
                    |-/sys/firmware/efi/efivars                 efivarfs                       efivarfs    rw,nosuid,nodev,noexec,relatime
                    |-/sys/fs/cgroup                            none                           cgroup2     rw,nosuid,nodev,noexec,relatime
                    `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu] fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                  /var:
                  999M    /var/
                  491M    /var/log
                  488M    /var/log/journal
                  337M    /var/log/journal/7ec90df983fc41e487e36202c16059a2
                  320M    /var/lib
                  Archived and active journals take up 24.5M in the file system.
                  /opt/iobroker/backups:
                  139M    /opt/iobroker/backups/
                  4.0K    /opt/iobroker/backups/redistmp
                  /opt/iobroker/iobroker-data:
                  716M    /opt/iobroker/iobroker-data/
                  424M    /opt/iobroker/iobroker-data/files
                  198M    /opt/iobroker/iobroker-data/backup-objects
                  89M     /opt/iobroker/iobroker-data/files/echarts.admin
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  45M     /opt/iobroker/iobroker-data/objects.jsonl
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                  24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  HINT:
                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                  tcp
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.16.0
                  /usr/bin/node           v20.16.0
                  /usr/bin/npm            10.8.1
                  /usr/bin/npx            10.8.1
                  /usr/bin/corepack       0.28.2
                  nodejs:
                    Installed: 20.16.0-1nodesource1
                    Candidate: 20.16.0-1nodesource1
                    Version table:
                   *** 20.16.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                          100 /var/lib/dpkg/status
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       12.22.9~dfsg-1ubuntu3.6 500
                          500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                          500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                       12.22.9~dfsg-1ubuntu3 500
                          500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  Core adapters versions
                  admin:          7.0.22
                  javascript:     8.7.6
                  nodejs modules from github:     0
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : iobroker-SuFra                           -  enabled
                  + system.adapter.admin.0                  : admin                 : iobroker-SuFra                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.admin.1                  : admin                 : iobroker-SuFra                           - disabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker-SuFra                           -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker-SuFra                           -  enabled
                  + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker-SuFra                           -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker-SuFra                           -  enabled
                    system.adapter.devices.0                : devices               : iobroker-SuFra                           -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker-SuFra                           -  enabled
                    system.adapter.echarts.0                : echarts               : iobroker-SuFra                           - disabled
                    system.adapter.flot.0                   : flot                  : iobroker-SuFra                           -  enabled
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-SuFra                           -  enabled
                  + system.adapter.iot.0                    : iot                   : iobroker-SuFra                           -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker-SuFra                           -  enabled
                  + system.adapter.modbus.0                 : modbus                : iobroker-SuFra                           -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker-SuFra                           -  enabled, port: 1884, bind: 0.0.0.0
                    system.adapter.proxmox.0                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
                    system.adapter.proxmox.1                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
                    system.adapter.puppeteer.0              : puppeteer             : iobroker-SuFra                           - disabled
                  + system.adapter.shelly.0                 : shelly                : iobroker-SuFra                           -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.sonoff.0                 : sonoff                : iobroker-SuFra                           -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sql.0                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
                  + system.adapter.sql.1                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
                  + system.adapter.sql.2                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
                  + system.adapter.statistics.0             : statistics            : iobroker-SuFra                           -  enabled
                  + system.adapter.tahoma.0                 : tahoma                : iobroker-SuFra                           -  enabled
                    system.adapter.tr-064.0                 : tr-064                : iobroker-SuFra                           - disabled
                    system.adapter.vis.0                    : vis                   : iobroker-SuFra                           -  enabled
                  + system.adapter.web.0                    : web                   : iobroker-SuFra                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : iobroker-SuFra                           -  enabled, port: tcp://10.10.20.111:6638
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                  Adapter    "admin"        : 7.0.22   , installed 7.0.22
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                  Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
                  Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                  Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                  Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                  Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                  Controller "js-controller": 6.0.9    , installed 6.0.9
                  Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                  Adapter    "puppeteer"    : 0.3.0    , installed 0.3.0
                  Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
                  Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                  Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                  Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Objects and States
                  Objects:        11193
                  States:         9228
                  Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
                  Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                  Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://repo.zabbix.com/zabbix/6.4/ubuntu jammy InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        8828040    100/systemd-resolve
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8826131    1/init
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8832002    533/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8829055    503/io.sonoff.0
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8824769    488/io.mqtt.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       8824770    488/io.mqtt.0
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8828322    416/master
                  tcp6       0      0 :::10050                :::*                    LISTEN      110        8827415    116/zabbix_agent2
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          8828000    1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          8826133    1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8828323    416/master
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8831226    652/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8824491    173/io.admin.0
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        8828039    100/systemd-resolve
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8826132    1/init
                  udp6       0      0 :::111                  :::*                                0          8826134    1/init
                  2024-08-07 18:02:59.701  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: registered 30 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                  2024-08-07 18:02:59.704  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: No Updates for NSPanel available
                  2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:02:59.768  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Debug mode disabled
                  2024-08-07 18:03:00.206  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:03:00.207  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Start MQTT-Port-Check -------------------------------------
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- admin.0                   - 8081
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- mqtt.0                    - 1884
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- shelly.0                  - 1882
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sonoff.0                  - 1883
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.0                     - 3306
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.1                     - 3306
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.2                     - 3306
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- web.0                     - 8082
                  2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- zigbee.0                  - tcp
                  2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884
                  2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: End MQTT-Port-Check ---------------------------------------
                  2024-08-07 18:03:07.443  - info: sonoff.0 (503) Client [Shelly-Wz-Decke] connected with secret 1723046587442_9493
                  2024-08-07 18:04:50.965  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
                  2024-08-07 18:11:39.077  - info: admin.0 (173) <== Disconnect system.user.admin from ::ffff:10.10.20.229 admin
                  2024-08-07 18:11:40.923  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
                                          v.2024-05-22
                           Chassis: container
                    Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CEST, +0200)
                  User-ID:                1000
                  Pending OS-Updates:     0
                  Pending iob updates:    2
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.1
                  /usr/bin/npx            10.8.1
                  Recommended versions are nodejs 20.16.0 and npm 10.8.1
                  MEMORY:
                  Mem:            8.2G        1.6G        5.9G        0.0K        636M        6.6G
                  Swap:           4.1G          0B        4.1G
                  Total:           12G        1.6G         10G
                  ioBroker Core:          js-controller           6.0.9
                                          admin                   7.0.22
                  Objects type: redis
                  States  type: redis
                  Objects:                11193
                  States:                 9228
                  Size of iob-Database:
                  15M     /opt/iobroker/iobroker-data/objects.json.migrated
                  15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  0       /opt/iobroker/iobroker-data/objects.json.broken
                  17M     /opt/iobroker/iobroker-data/states.jsonl
                  2.0M    /opt/iobroker/iobroker-data/states.json.migrated
                  2.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                  0       /opt/iobroker/iobroker-data/states.json.broken
                  • Rene55
                    @tt-tom Sorry für die späte Antwort. Ich habe in meiner Installation die Module dayjs, moment und moment-parseformat hier /opt/iobroker/node_modules/iobroker.javascript/node_modules/ gefunden.
                    Ich hab hier noch nicht weiter upgedatet. Womit sollte ich anfangen?
                    Armilar 2 Replies Last reply Reply Quote 1
                    • Armilar
                      Armilar Most Active Forum Testing @Rene55 last edited by
                      @rene55
                      gefunden
                      das ist sehr interessant, denn die sollten eigentlich in:
                      etc.
                      liegen.
                      • Armilar
                        Armilar Most Active Forum Testing @Rene55 last edited by Armilar
                        @rene55 sagte in SONOFF NSPanel mit Lovelace UI:
                        Wenn das ein altes Backup ist, bringe erstmal das System auf den neuesten Stand
                        sudo apt-get update
                        sudo apt-get full-upgrade
                        sudo reboot
                        dann
                        iob stop
                        iob update
                        iob upgrade self
                        iob upgrade
                        iob fix
                        iob start
                        falls nodeJS noch 18 ist, sollte es jetzt mit nochmaligem:
                        sudo apt-get update
                        sudo reboot
                        aktualisiert werden...
                        Falls das OS ein Debian Buster sein sollte, dann gibt es außer einer Neuinstallation mit anschließenden Backup-Einstellungen keine andere Wahl...
                        • Rene55
                          @armilar Ich habe gerade nochmals gesucht. In dieser Richtung hab eich nur Fundstelle_atIOB.png
                          Ich habe auf dem System kein '@iobroker-javascript'
                          • Rene55
                            Rene55 @Armilar last edited by
                            @armilar Wie gesagt: ich habe extra ein 'uralt' Backup rausgesucht. Ich wollte jetzt eigentlich Schritt für Schritt updaten um den Fehler -möglicherweise- einzugrenzen. Wenn ich das so mache, wird der Fehler wahrscheinlich wieder da sein. Oder?
                            • Armilar
                              @rene55
                              das Verzeichnis sollte sich nach der beschriebenen Update-Variante aber dann finden lassen.
                              Da wir nicht wissen, warum sich das so unterschiedlich darstellt, können wir auch nicht sagen, ob das Problem danach gelöst ist oder nicht... Lässt sich ja bei uns nicht reproduzieren...
                              Rene55 2 Replies Last reply Reply Quote 1
                              • Rene55
                                @armilar OK. Dann arbeite ich mal eben die Updates durch.
                                • Rene55
                                  @armilar So. Updates sind komplett durch. Habe jetzt das aktuellste Beta-System. Und der Fehler ist auch wieder da. Und nu??
                                  • Armilar
                                    @rene55
                                    1. Jetzt poste mal ein iob diag
                                    2. Stelle sicher, dass dayjs auch in der Javascript Instanz eingetragen ist
                                    3. Überprüfe den Verzeichnispfad nochmal
                                    • Rene55
                                      Rene55 last edited by Rene55
                                      @armilar Ich bin mir nicht sicher, ob wir hier das gleiche Ziel verfolgen. Diese Übung sollte nur dazu dienen, den Fehler einzugrenzen. Das von dir angegebene Verzeichnis existiert jetzt.Fundstelle_atIOBn.png
                                      Und auch die Ausgabe von Diag:```
                                                              v.2024-05-22
                                       Static hostname: iobroker-pmx
                                               Chassis: container ☐
                                        Virtualization: lxc
                                                Kernel: Linux 6.2.16-3-pve
                                      Installation:           lxc
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      Boot Target:            graphical.target
                                      Pending iob updates:    0
                                      /usr/bin/npm            10.8.1
                                      /usr/bin/npx            10.8.1
                                      MEMORY:
                                      Mem:            2.1G        1.5G        230M         98K        432M        663M
                                      Swap:           536M         45K        536M
                                      Total:          2.7G        1.5G        767M
                                      Active iob-Instances:   11
                                      ioBroker Core:          js-controller           6.0.10
                                                              admin                   7.0.23
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : iobroker-pmx                             -  enabled, port: 8081, bind: 192.168.69.109, run as: admin
                                        system.adapter.web.0                    : web                   : iobroker-pmx                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                51100
                                      States:                 38730
                                      43M     /opt/iobroker/iobroker-data/objects.jsonl
                                      11M     /opt/iobroker/iobroker-data/states.jsonl
                                      • Armilar
                                        @rene55
                                        ist denn auch dayjs im Verzeichnis?
                                        • Rene55
                                          @armilar Ja. Alle in der Instanz eingetragenen Module sind in dem Ordner drin.
                                          Armilar 1 Reply Last reply Reply Quote 1
                                          • Armilar
                                            @rene55
                                            @haus-automatisierung jetzt weiß ich auch nicht mehr weiter 😕
                                            Das System und der ioBroker sollte nun auf dem aktuellsten Stand sein...
                                            @Rene55
                                            sende nochmal die Fehlermeldungen bitte...
                                            Rene55 1 Reply Last reply Reply Quote 1
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6624137
