      SuFra last edited by
      Hallo zusammen.
      Ich habe gerade auch mein System auf JS Controller 6.0.9 upgedatet und nun die gleiche Fehlermeldung beim Starten/Compilieren der Scripte.
      frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/dayjs
      -bash: cd: /opt/iobroker/node_modules/dayjs: No such file or directory
      frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
      frank@iobroker-SuFra:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs$ ls -la
      total 152
      drwxrwxr-x+ 5 iobroker iobroker  4096 Aug  7 17:50 .
      drwxrwxr-x+ 6 iobroker iobroker  4096 Aug  7 17:50 ..
      -rw-rw-r--+ 1 iobroker iobroker 79810 Aug  7 17:50 CHANGELOG.md
      -rw-rw-r--+ 1 iobroker iobroker  7160 Aug  7 17:50 dayjs.min.js
      -rw-rw-r--+ 1 iobroker iobroker    94 Aug  7 17:50 .editorconfig
      drwxrwxr-x+ 4 iobroker iobroker  4096 Aug  7 17:50 esm
      -rw-rw-r--+ 1 iobroker iobroker 13872 Aug  7 17:50 index.d.ts
      -rw-rw-r--+ 1 iobroker iobroker  1072 Aug  7 17:50 LICENSE
      drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 locale
      -rw-rw-r--+ 1 iobroker iobroker  5033 Aug  7 17:50 locale.json
      -rw-rw-r--+ 1 iobroker iobroker  2526 Aug  7 17:50 package.json
      drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 plugin
      -rw-rw-r--+ 1 iobroker iobroker  7411 Aug  7 17:50 README.md
      Gruß Frank
        iob diag:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
         Static hostname: iobroker-SuFra
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.4 LTS
                  Kernel: Linux 6.8.8-4-pve
            Architecture: x86-64
        model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Wed 2024-08-07 18:11:20 CEST
                   Universal time: Wed 2024-08-07 16:11:20 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        frank
        HOME=/home/frank
        GROUPS=frank sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        1.5G        6.4G        0.0K        347M        6.7G
        Swap:           4.1G          0B        4.1G
        Total:           12G        1.5G         10G
        Active iob-Instances:   20
                 8192 M total memory
                 1475 M used memory
                 1621 M active memory
                  120 M inactive memory
                 6368 M free memory
                    0 M buffer memory
                  347 M swap cache
                 4096 M total swap
                    0 M used swap
                 4096 M free swap
        top - 18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
        Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   8192.0 total,   6368.2 free,   1475.8 used,    347.9 buff/cache
        MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6716.0 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        /dev/rbd3      ext4       20G   12G  7.4G  61% /
        none           tmpfs     492K  4.0K  488K   1% /dev
        efivarfs       efivarfs  192K  110K   78K  59% /sys/firmware/efi/efivars
        tmpfs          tmpfs      16G     0   16G   0% /dev/shm
        tmpfs          tmpfs     6.3G  116K  6.3G   1% /run
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                                        SOURCE                         FSTYPE      OPTIONS
        /                                             /dev/rbd3                      ext4        rw,relatime,stripe=16
        |-/run                                        tmpfs                          tmpfs       rw,nosuid,nodev,size=6503388k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
        | |-/run/lock                                 tmpfs                          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        | `-/run/credentials/systemd-sysusers.service tmpfs                          tmpfs       ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
        |-/dev                                        none                           tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                                  tmpfs                          tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                               mqueue                         mqueue      rw,relatime
        | |-/dev/full                                 udev[/full]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/null                                 udev[/null]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/random                               udev[/random]                  devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/tty                                  udev[/tty]                     devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/urandom                              udev[/urandom]                 devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/zero                                 udev[/zero]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
        | |-/dev/pts                                  devpts                         devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                                 devpts[/ptmx]                  devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                              devpts[/0]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                                 devpts[/1]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                                 devpts[/2]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                                       proc                           proc        rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                                 proc[/sys]                     proc        ro,relatime
        | | |-/proc/sys/net                           proc[/sys/net]                 proc        rw,nosuid,nodev,noexec,relatime
        | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]            tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]           proc        ro,relatime
        | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                           lxcfs[/proc/diskstats]         fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                             lxcfs[/proc/loadavg]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                             lxcfs[/proc/meminfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]          fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                                lxcfs[/proc/stat]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                               lxcfs[/proc/swaps]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                              lxcfs[/proc/uptime]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                        sysfs                          sysfs       ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections                  fusectl                        fusectl     rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]    sysfs       rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/debug                         debugfs                        debugfs     rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/security                      securityfs                     securityfs  rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/pstore                            pstore                         pstore      rw,nosuid,nodev,noexec,relatime
          |-/sys/firmware/efi/efivars                 efivarfs                       efivarfs    rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                            none                           cgroup2     rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu] fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        999M    /var/
        491M    /var/log
        488M    /var/log/journal
        337M    /var/log/journal/7ec90df983fc41e487e36202c16059a2
        320M    /var/lib
        Archived and active journals take up 24.5M in the file system.
        /opt/iobroker/backups:
        139M    /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        716M    /opt/iobroker/iobroker-data/
        424M    /opt/iobroker/iobroker-data/files
        198M    /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        45M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        tcp
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
          Installed: 20.16.0-1nodesource1
          Candidate: 20.16.0-1nodesource1
          Version table:
         *** 20.16.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3.6 500
                500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : iobroker-SuFra                           -  enabled
        + system.adapter.admin.0                  : admin                 : iobroker-SuFra                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.admin.1                  : admin                 : iobroker-SuFra                           - disabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker-SuFra                           -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker-SuFra                           -  enabled
        + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker-SuFra                           -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker-SuFra                           -  enabled
          system.adapter.devices.0                : devices               : iobroker-SuFra                           -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker-SuFra                           -  enabled
          system.adapter.echarts.0                : echarts               : iobroker-SuFra                           - disabled
          system.adapter.flot.0                   : flot                  : iobroker-SuFra                           -  enabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-SuFra                           -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker-SuFra                           -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker-SuFra                           -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker-SuFra                           -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker-SuFra                           -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.proxmox.0                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
          system.adapter.proxmox.1                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
          system.adapter.puppeteer.0              : puppeteer             : iobroker-SuFra                           - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker-SuFra                           -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : iobroker-SuFra                           -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sql.0                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
        + system.adapter.sql.1                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
        + system.adapter.sql.2                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
        + system.adapter.statistics.0             : statistics            : iobroker-SuFra                           -  enabled
        + system.adapter.tahoma.0                 : tahoma                : iobroker-SuFra                           -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker-SuFra                           - disabled
          system.adapter.vis.0                    : vis                   : iobroker-SuFra                           -  enabled
        + system.adapter.web.0                    : web                   : iobroker-SuFra                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : iobroker-SuFra                           -  enabled, port: tcp://10.10.20.111:6638
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
        Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "puppeteer"    : 0.3.0    , installed 0.3.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        11193
        States:         9228
        Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://repo.zabbix.com/zabbix/6.4/ubuntu jammy InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        8828040    100/systemd-resolve
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8826131    1/init
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8832002    533/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8829055    503/io.sonoff.0
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8824769    488/io.mqtt.0
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       8824770    488/io.mqtt.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8828322    416/master
        tcp6       0      0 :::10050                :::*                    LISTEN      110        8827415    116/zabbix_agent2
        tcp6       0      0 :::22                   :::*                    LISTEN      0          8828000    1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          8826133    1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8828323    416/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8831226    652/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8824491    173/io.admin.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        8828039    100/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8826132    1/init
        udp6       0      0 :::111                  :::*                                0          8826134    1/init
        2024-08-07 18:02:59.701  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: registered 30 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2024-08-07 18:02:59.704  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: No Updates for NSPanel available
        2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
        2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
        2024-08-07 18:02:59.768  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Debug mode disabled
        2024-08-07 18:03:00.206  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
        2024-08-07 18:03:00.207  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
        2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
        2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Start MQTT-Port-Check -------------------------------------
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- admin.0                   - 8081
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- mqtt.0                    - 1884
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- shelly.0                  - 1882
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sonoff.0                  - 1883
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.0                     - 3306
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.1                     - 3306
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.2                     - 3306
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- web.0                     - 8082
        2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- zigbee.0                  - tcp
        2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884
        2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: End MQTT-Port-Check ---------------------------------------
        2024-08-07 18:03:07.443  - info: sonoff.0 (503) Client [Shelly-Wz-Decke] connected with secret 1723046587442_9493
        2024-08-07 18:04:50.965  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
        2024-08-07 18:11:39.077  - info: admin.0 (173) <== Disconnect system.user.admin from ::ffff:10.10.20.229 admin
        2024-08-07 18:11:40.923  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
                                v.2024-05-22
                 Chassis: container
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CEST, +0200)
        User-ID:                1000
        Pending OS-Updates:     0
        Pending iob updates:    2
        Nodejs-Installation:
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        Recommended versions are nodejs 20.16.0 and npm 10.8.1
        MEMORY:
        Mem:            8.2G        1.6G        5.9G        0.0K        636M        6.6G
        Swap:           4.1G          0B        4.1G
        Total:           12G        1.6G         10G
        ioBroker Core:          js-controller           6.0.9
                                admin                   7.0.22
        Objects type: redis
        States  type: redis
        Objects:                11193
        States:                 9228
        Size of iob-Database:
        15M     /opt/iobroker/iobroker-data/objects.json.migrated
        15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        0       /opt/iobroker/iobroker-data/objects.json.broken
        17M     /opt/iobroker/iobroker-data/states.jsonl
        2.0M    /opt/iobroker/iobroker-data/states.json.migrated
        2.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        • Rene55
          Rene55 @TT-Tom last edited by
          @tt-tom Sorry für die späte Antwort. Ich habe in meiner Installation die Module dayjs, moment und moment-parseformat hier /opt/iobroker/node_modules/iobroker.javascript/node_modules/ gefunden.
          Ich hab hier noch nicht weiter upgedatet. Womit sollte ich anfangen?
          Armilar 2 Replies Last reply Reply Quote 1
          • Armilar
            Armilar Most Active Forum Testing @Rene55 last edited by
            @rene55
            gefunden
            das ist sehr interessant, denn die sollten eigentlich in:
            etc.
            liegen.
            • Armilar
              Armilar Most Active Forum Testing @Rene55 last edited by Armilar
              @rene55 sagte in SONOFF NSPanel mit Lovelace UI:
              Wenn das ein altes Backup ist, bringe erstmal das System auf den neuesten Stand
              sudo apt-get update
              sudo apt-get full-upgrade
              sudo reboot
              dann
              iob stop
              iob update
              iob upgrade self
              iob upgrade
              iob fix
              iob start
              falls nodeJS noch 18 ist, sollte es jetzt mit nochmaligem:
              sudo apt-get update
              sudo reboot
              aktualisiert werden...
              Falls das OS ein Debian Buster sein sollte, dann gibt es außer einer Neuinstallation mit anschließenden Backup-Einstellungen keine andere Wahl...
              • Rene55
                @armilar Ich habe gerade nochmals gesucht. In dieser Richtung hab eich nur Fundstelle_atIOB.png
                Ich habe auf dem System kein '@iobroker-javascript'
                • Rene55
                  Rene55 @Armilar last edited by
                  @armilar Wie gesagt: ich habe extra ein 'uralt' Backup rausgesucht. Ich wollte jetzt eigentlich Schritt für Schritt updaten um den Fehler -möglicherweise- einzugrenzen. Wenn ich das so mache, wird der Fehler wahrscheinlich wieder da sein. Oder?
                  • Armilar
                    @rene55
                    das Verzeichnis sollte sich nach der beschriebenen Update-Variante aber dann finden lassen.
                    Da wir nicht wissen, warum sich das so unterschiedlich darstellt, können wir auch nicht sagen, ob das Problem danach gelöst ist oder nicht... Lässt sich ja bei uns nicht reproduzieren...
                    Rene55 2 Replies Last reply Reply Quote 1
                    • Rene55
                      @armilar OK. Dann arbeite ich mal eben die Updates durch.
                      • Rene55
                        @armilar So. Updates sind komplett durch. Habe jetzt das aktuellste Beta-System. Und der Fehler ist auch wieder da. Und nu??
                        • Armilar
                          @rene55
                          1. Jetzt poste mal ein iob diag
                          2. Stelle sicher, dass dayjs auch in der Javascript Instanz eingetragen ist
                          3. Überprüfe den Verzeichnispfad nochmal
                          • Rene55
                            Rene55 last edited by Rene55
                            @armilar Ich bin mir nicht sicher, ob wir hier das gleiche Ziel verfolgen. Diese Übung sollte nur dazu dienen, den Fehler einzugrenzen. Das von dir angegebene Verzeichnis existiert jetzt.Fundstelle_atIOBn.png
                            Und auch die Ausgabe von Diag:```
                                                    v.2024-05-22
                             Static hostname: iobroker-pmx
                                     Chassis: container ☐
                              Virtualization: lxc
                                      Kernel: Linux 6.2.16-3-pve
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1000
                            Boot Target:            graphical.target
                            Pending iob updates:    0
                            /usr/bin/npm            10.8.1
                            /usr/bin/npx            10.8.1
                            MEMORY:
                            Mem:            2.1G        1.5G        230M         98K        432M        663M
                            Swap:           536M         45K        536M
                            Total:          2.7G        1.5G        767M
                            Active iob-Instances:   11
                            ioBroker Core:          js-controller           6.0.10
                                                    admin                   7.0.23
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : iobroker-pmx                             -  enabled, port: 8081, bind: 192.168.69.109, run as: admin
                              system.adapter.web.0                    : web                   : iobroker-pmx                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                51100
                            States:                 38730
                            43M     /opt/iobroker/iobroker-data/objects.jsonl
                            11M     /opt/iobroker/iobroker-data/states.jsonl
                            • Armilar
                              @rene55
                              ist denn auch dayjs im Verzeichnis?
                              • Rene55
                                @armilar Ja. Alle in der Instanz eingetragenen Module sind in dem Ordner drin.
                                Armilar 1 Reply Last reply Reply Quote 1
                                • Armilar
                                  @rene55
                                  @haus-automatisierung jetzt weiß ich auch nicht mehr weiter 😕
                                  Das System und der ioBroker sollte nun auf dem aktuellsten Stand sein...
                                  @Rene55
                                  sende nochmal die Fehlermeldungen bitte...
                                  Rene55 1 Reply Last reply Reply Quote 1
                                  • Rene55
                                    @armilar Hier das Log vom Start:
                                    2024-08-07 23:31:01.945 - info: javascript.0 (398) Compiling TypeScript source script.js.common.NSPanel.NSPanelTS_44
                                    2024-08-07 23:31:09.877 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: TypeScript compilation successful
                                    2024-08-07 23:31:10.207 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.207 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.208 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.212 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.212 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.213 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.217 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.217 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.219 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.219 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.219 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.219 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.219 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                                    2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                                    2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.220 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.222 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.222 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.222 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.222 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.222 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                                    2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                                    2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.227 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.242 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.242 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.242 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.242 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.243 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.247 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.247 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.247 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.247 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.248 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.252 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.252 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.252 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.253 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.255 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.255 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.255 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.256 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.258 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.258 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.258 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.258 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.258 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                                    2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                                    2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.259 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.263 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.263 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.263 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.263 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.264 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                                    2024-08-07 23:31:10.264 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                                    2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.270 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.275 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.277 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.277 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.277 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.277 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.278 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.282 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.282 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.282 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.282 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.282 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                                    2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                                    2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.283 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.284 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.288 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.288 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.289 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.289 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.290 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.294 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.294 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.294 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.294 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.294 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                                    2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                                    2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.295 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.296 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.300 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.301 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.301 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.301 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.301 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.302 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.306 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.306 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.306 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.306 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.306 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                                    2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                                    2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.307 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                                    2024-08-07 23:31:10.311 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                                    2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.312 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.312 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.313 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.317 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.317 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.318 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.318 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.319 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.323 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.323 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                                    2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.334 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.334 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.334 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.335 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.336 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.336 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.336 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.336 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                                    2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                                    2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.337 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-07 23:31:10.339 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: getDayjsLocale de
                                    2024-08-07 23:31:10.360 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: setObjects enabled - create Alias Channels possible
                                    2024-08-07 23:31:10.368 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: weather alias for accuweather.0. already exists
                                    2024-08-07 23:31:10.434 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    T 1 Reply Last reply Reply Quote 2
                                    • Nobody else
                                      Nobody else last edited by Nobody else
                                      Morgen zusammen,
                                      Habe das gleiche Problem mit den dayjs, ging bei mir los als ich den Javascript adapter geupdatet habe auf 8.7.6
                                      Habe den Javascript adapter wieder gedowngradet auf 8.3.1 und musste auch ein altes script 4.3.1.6 nehmen, das alles wieder halbwegs läuft, selbst das script 4.3.3.25 was ich voher hatte lief nicht mehr.
                                      Selbst ein Rückspielen von einen Backup hat nur Fehlermeldungen gebracht```
                                      Skript v.2024-05-22
                                      *** BASE SYSTEM ***
                                       Static hostname: debian
                                             Icon name: computer-desktop
                                               Chassis: desktop 🖥️
                                                Kernel: Linux 6.1.0-23-amd64
                                          Architecture: x86-64
                                       Hardware Vendor: FUJITSU
                                        Hardware Model: FUTRO S920
                                      Firmware Version: V4.6.5.4 R1.15.0 for D3313-A1x
                                      model name      : AMD GX-415GA SOC with Radeon(tm) HD Graphics
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       10:06:11 up 1 day, 23:49,  2 users,  load average: 0.43, 0.63, 0.84
                                      CPU threads: 4
                                      *** Time and Time Zones ***
                                                     Local time: Fri 2024-08-09 10:06:11 CEST
                                                 Universal time: Fri 2024-08-09 08:06:11 UTC
                                                       RTC time: Fri 2024-08-09 08:06:10
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      root
                                      HOME=/root
                                      GROUPS=root
                                      iobroker
                                      HOME=/home/iobroker
                                      GROUPS=iobroker tty dialout audio video plugdev bluetooth
                                      *** Display-Server-Setup ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            8.0G        3.5G        3.1G        1.8M        1.7G        4.5G
                                      Swap:           1.1G          0B        1.1G
                                      Total:          9.1G        3.5G        4.2G
                                      Active iob-Instances:   25
                                               7615 M total memory
                                               3295 M used memory
                                                614 M active memory
                                               3663 M inactive memory
                                               2972 M free memory
                                                156 M buffer memory
                                               1473 M swap cache
                                               1022 M total swap
                                                  0 M used swap
                                               1022 M free swap
                                      top - 10:06:11 up 1 day, 23:49,  2 users,  load average: 0.43, 0.63, 0.84
                                      Tasks: 169 total,   2 running, 167 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   7615.7 total,   2971.8 free,   3296.3 used,   1629.8 buff/cache
                                      MiB Swap:   1023.0 total,   1023.0 free,      0.0 used.   4319.4 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.7G     0  3.7G   0% /dev
                                      tmpfs          tmpfs     762M  1.3M  761M   1% /run
                                      /dev/sda1      ext4       58G   17G   38G  31% /
                                      tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
                                      tmpfs          tmpfs     762M   48K  762M   1% /run/user/1000
                                      [Wed Aug  7 10:17:03 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Wed Aug  7 10:17:04 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET                                                  SOURCE      FSTYPE          OPTIONS
                                      /                                                       /dev/sda1   ext4            rw,relatime,errors=remount-ro
                                      |-/sys                                                  sysfs       sysfs           rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/security                                securityfs  securityfs      rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/cgroup                                      cgroup2     cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                      | |-/sys/fs/pstore                                      pstore      pstore          rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/fs/bpf                                         bpf         bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                                      | |-/sys/kernel/debug                                   debugfs     debugfs         rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/tracing                                 tracefs     tracefs         rw,nosuid,nodev,noexec,relatime
                                      | |-/sys/kernel/config                                  configfs    configfs        rw,nosuid,nodev,noexec,relatime
                                      | `-/sys/fs/fuse/connections                            fusectl     fusectl         rw,nosuid,nodev,noexec,relatime
                                      |-/proc                                                 proc        proc            rw,nosuid,nodev,noexec,relatime
                                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16509
                                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc     rw,nosuid,nodev,noexec,relatime
                                      |-/dev                                                  udev        devtmpfs        rw,nosuid,relatime,size=3863224k,nr_inodes=965806,mode=755,inode64
                                      | |-/dev/pts                                            devpts      devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                                      | |-/dev/shm                                            tmpfs       tmpfs           rw,nosuid,nodev,inode64
                                      | |-/dev/mqueue                                         mqueue      mqueue          rw,nosuid,nodev,noexec,relatime
                                      | `-/dev/hugepages                                      hugetlbfs   hugetlbfs       rw,relatime,pagesize=2M
                                      `-/run                                                  tmpfs       tmpfs           rw,nosuid,nodev,noexec,relatime,size=779848k,mode=755,inode64
                                        |-/run/lock                                           tmpfs       tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                                        |-/run/credentials/systemd-sysusers.service           ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                        |-/run/credentials/systemd-sysctl.service             ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                        |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                        |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
                                        |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs      rw,relatime
                                        `-/run/user/1000                                      tmpfs       tmpfs           rw,nosuid,nodev,relatime,size=779844k,nr_inodes=194961,mode=700,uid=1000,gid=1000,inode64
                                          `-/run/user/1000/gvfs                               gvfsd-fuse  fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                      /var:
                                      4.3G    /var/
                                      3.1G    /var/log
                                      3.0G    /var/log/journal
                                      2.4G    /var/log/journal/f4c3246da5c8449e8998270413aa11c1
                                      956M    /var/cache
                                      Archived and active journals take up 2.3G in the file system.
                                      /opt/iobroker/backups:
                                      152M    /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      4.4G    /opt/iobroker/iobroker-data/
                                      4.0G    /opt/iobroker/iobroker-data/history
                                      357M    /opt/iobroker/iobroker-data/files
                                      138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      21M     /opt/iobroker/iobroker-data/states.jsonl
                                      21M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_DC:54:75:93:E1:64-if00
                                      /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDDF59A-if00
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyACM1
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v18.20.4
                                      /usr/bin/node           v18.20.4
                                      /usr/bin/npm            10.7.0
                                      /usr/bin/npx            10.7.0
                                      /usr/bin/corepack       0.28.0
                                      nodejs:
                                        Installed: 18.20.4-1nodesource1
                                        Candidate: 18.20.4-1nodesource1
                                        Version table:
                                       *** 18.20.4-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                           18.20.3-1nodesource1 500
                                           18.20.2-1nodesource1 500
                                           18.20.1-1nodesource1 500
                                           18.20.0-1nodesource1 500
                                           18.19.1-1nodesource1 500
                                           18.19.0+dfsg-6~deb12u2 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                           18.19.0-1nodesource1 500
                                           18.18.2-1nodesource1 500
                                           18.18.1-1nodesource1 500
                                           18.18.0-1nodesource1 500
                                           18.17.1-1nodesource1 500
                                           18.17.0-1nodesource1 500
                                           18.16.1-1nodesource1 500
                                           18.16.0-1nodesource1 500
                                           18.15.0-1nodesource1 500
                                           18.14.2-1nodesource1 500
                                           18.14.1-1nodesource1 500
                                           18.14.0-1nodesource1 500
                                           18.13.0-1nodesource1 500
                                           18.12.0-1nodesource1 500
                                           18.11.0-1nodesource1 500
                                           18.10.0-1nodesource1 500
                                           18.9.1-1nodesource1 500
                                           18.9.0-1nodesource1 500
                                           18.8.0-1nodesource1 500
                                           18.7.0-1nodesource1 500
                                           18.6.0-1nodesource1 500
                                           18.5.0-1nodesource1 500
                                           18.4.0-1nodesource1 500
                                           18.3.0-1nodesource1 500
                                           18.2.0-1nodesource1 500
                                           18.1.0-1nodesource1 500
                                           18.0.0-1nodesource1 500
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  6.0.9
                                      admin:          7.0.22
                                      javascript:     8.3.1
                                      nodejs modules from github:     0
                                      Adapter State
                                      + system.adapter.accuweather.0            : accuweather           : debian                                   -  enabled
                                      + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.apcups.0                 : apcups                : debian                                   -  enabled
                                      + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
                                      + system.adapter.ble.0                    : ble                   : debian                                   -  enabled
                                        system.adapter.devices.0                : devices               : debian                                   -  enabled
                                      + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
                                      + system.adapter.ebus.0                   : ebus                  : debian                                   -  enabled
                                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : debian                                   -  enabled
                                      + system.adapter.fritzdect.0              : fritzdect             : debian                                   -  enabled
                                      + system.adapter.history.0                : history               : debian                                   -  enabled
                                      + system.adapter.hue.0                    : hue                   : debian                                   -  enabled, port: 443
                                        system.adapter.ical.0                   : ical                  : debian                                   -  enabled
                                      + system.adapter.iqontrol.0               : iqontrol              : debian                                   -  enabled
                                      + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
                                      + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : debian                                   -  enabled, port: 1884, bind: 0.0.0.0
                                        system.adapter.onvif.0                  : onvif                 : debian                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                      + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1885, bind: 0.0.0.0
                                      + system.adapter.sonoff.0                 : sonoff                : debian                                   -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.sony-bravia.0            : sony-bravia           : debian                                   -  enabled
                                      + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
                                      + system.adapter.tuya.0                   : tuya                  : debian                                   -  enabled
                                      + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.zigbee.0                 : zigbee                : debian                                   -  enabled, port: /dev/ttyACM1
                                      + instance is alive
                                      ioBroker-Repositories
                                      │ (index) │   name   │                           url                           │ auto upgrade │
                                      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                      Active repo(s): stable
                                      Upgrade policy: none
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                                      Adapter    "admin"        : 7.0.22   , installed 7.0.22
                                      Adapter    "apcups"       : 4.0.0    , installed 4.0.0
                                      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                                      Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                      Adapter    "ebus"         : 3.3.4    , installed 3.3.1  [Updatable]
                                      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                      Adapter    "hue"          : 3.11.0   , installed 3.11.0
                                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                      Adapter    "javascript"   : 8.7.6    , installed 8.3.1  [Updatable]
                                      Controller "js-controller": 6.0.9    , installed 6.0.9
                                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                      Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
                                      Adapter    "telegram"     : 3.3.2    , installed 3.3.2
                                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                      Objects and States
                                      Objects:        11957
                                      States:         11021
                                      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:4 https://linux.teamviewer.com/deb stable InRelease
                                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Hit:6 https://repo.ebusd.eu/apt/default/bookworm bookworm InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16159      620/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20833      620/iobroker.js-con
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1418002    109185/cupsd
                                      tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          18654      768/teamviewerd
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1800529    140673/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21069      1007/io.shelly.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21767      1033/io.sonoff.0
                                      tcp        0      0 127.0.0.1:3551          0.0.0.0:*               LISTEN      0          16079      757/apcupsd
                                      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          20829      753/ebusd
                                      tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          20830      753/ebusd
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          725        1/init
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20576      656/sshd: /usr/sbin
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22214      1325/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16193      802/io.admin.0
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1418001    109185/cupsd
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          15411      1/init
                                      tcp6       0      0 :::80                   :::*                    LISTEN      0          15999      658/apache2
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          20587      656/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1631       1/init
                                      udp        0      0 0.0.0.0:57892           0.0.0.0:*                           104        15869      515/avahi-daemon: r
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1420450    109188/cups-browsed
                                      udp        0      0 192.168.178.101:5353    0.0.0.0:*                           1001       21162      1063/io.tr-064.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15867      515/avahi-daemon: r
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21159      1079/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21160      1079/io.tuya.0
                                      udp6       0      0 :::111                  :::*                                0          726        1/init
                                      udp6       0      0 fe80::921b:eff:fe9e:546 :::*                                0          1460247    559/NetworkManager
                                      udp6       0      0 :::5353                 :::*                                104        15868      515/avahi-daemon: r
                                      udp6       0      0 :::40642                :::*                                104        15870      515/avahi-daemon: r
                                      2024-08-09 09:30:00.770  - info: host.debian Restart adapter system.adapter.mqtt.0 because enabled
                                      2024-08-09 09:30:02.485  - info: host.debian instance system.adapter.mqtt.0 in version "5.2.0" started with pid 138317
                                      2024-08-09 09:30:12.134  - info: host.debian instance system.adapter.ical.0 having pid 138304 terminated with code 0 (NO_ERROR)
                                      2024-08-09 09:49:44.351  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
                                      2024-08-09 09:49:44.409  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
                                      2024-08-09 09:49:44.493  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 14 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-08-09 09:51:33.557  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
                                      2024-08-09 09:51:33.662  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
                                      2024-08-09 09:51:33.738  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-08-09 09:53:32.593  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
                                      2024-08-09 09:53:32.697  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
                                      2024-08-09 09:53:32.742  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-08-09 09:54:55.962  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
                                      2024-08-09 09:54:56.019  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
                                      2024-08-09 09:54:56.067  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2024-08-09 09:56:38.408  - info: host.debian instance "system.adapter.onvif.0" disabled via .alive
                                      2024-08-09 09:56:38.422  - info: host.debian "system.adapter.onvif.0" disabled
                                      2024-08-09 09:56:38.423  - info: host.debian stopInstance system.adapter.onvif.0 (force=false, process=true)
                                      2024-08-09 09:56:38.470  - info: host.debian stopInstance system.adapter.onvif.0 send kill signal
                                      2024-08-09 09:56:39.139  - info: host.debian instance system.adapter.onvif.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2024-08-09 10:00:00.059  - info: host.debian instance system.adapter.ical.0 in version "1.15.0" started with pid 140661
                                      2024-08-09 10:00:00.784  - info: host.debian instance system.adapter.mqtt.0 scheduled normal terminated and will be restarted on schedule.
                                      2024-08-09 10:00:00.785  - info: host.debian Restart adapter system.adapter.mqtt.0 because enabled
                                      2024-08-09 10:00:02.466  - info: host.debian instance system.adapter.mqtt.0 in version "5.2.0" started with pid 140673
                                      2024-08-09 10:00:12.269  - info: host.debian instance system.adapter.ical.0 having pid 140661 terminated with code 0 (NO_ERROR)
                                      iob diag has finished.
                                      Press any key for a summary
                                        TT-Tom @Nobody else last edited by TT-Tom
                                        @nobody-else
                                        Auf den ersten Blick passt deine JS-Controller Version nicht zur JavaScript Version. Diese müsste auch wieder auf die 5. Version.
                                        Ich kann dir nur empfehlen wieder auf die aktuellen Versionen umzusteigen und die Fehlermeldung beim Start vom Script ignorieren. Bis jetzt funktioniert alles einwandfrei, auch mit den Meldungen.
                                        Nobody else 1 Reply Last reply Reply Quote 1
                                        • Nobody else
                                          Nobody else @TT-Tom last edited by
                                          @tt-tom Leider funktioniert es nicht, das Skript wird gestoppt sobald die Fehlermeldungen kommen.
                                          Und das NS Panel reagiert nicht mehr.
                                            lustig29 last edited by
                                            Hat es denn mittlerweile schon mal jemand probiert, ein Ns Panel hinter einem Shelly Dimmer 2 laufen zu lassen?
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6623654
