    • Rene55
      Rene55 @Armilar last edited by
      @armilar Ja. Alle in der Instanz eingetragenen Module sind in dem Ordner drin.
      Armilar 1 Reply Last reply Reply Quote 1
      • Armilar
        Armilar Most Active Forum Testing @Rene55 last edited by
        @rene55
        @haus-automatisierung jetzt weiß ich auch nicht mehr weiter 😕
        Das System und der ioBroker sollte nun auf dem aktuellsten Stand sein...
        @Rene55
        sende nochmal die Fehlermeldungen bitte...
        Rene55 1 Reply Last reply Reply Quote 1
        • Rene55
          @armilar Hier das Log vom Start:
          2024-08-07 23:31:01.945 - info: javascript.0 (398) Compiling TypeScript source script.js.common.NSPanel.NSPanelTS_44
          2024-08-07 23:31:09.877 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: TypeScript compilation successful
          2024-08-07 23:31:10.207 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.207 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.212 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.212 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.213 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.217 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.217 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.219 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.219 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.219 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.219 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.219 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.222 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.222 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.222 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.222 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.222 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.242 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.242 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.242 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.242 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.247 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.247 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.247 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.247 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.252 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.252 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.252 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.255 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.255 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.255 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.258 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.258 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.258 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.258 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.258 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.263 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.263 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.263 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.263 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.264 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
          2024-08-07 23:31:10.264 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.275 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.277 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.277 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.277 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.277 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.282 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.282 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.282 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.282 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.282 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.284 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.288 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.288 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.289 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.289 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.294 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.294 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.294 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.294 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.294 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.296 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.300 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.301 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.301 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.301 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.301 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.306 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.306 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.306 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.306 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.306 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.311 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.311 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.311 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.313 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.317 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.317 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.318 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.318 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.323 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.323 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.325 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.335 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.336 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.336 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.336 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.336 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
          2024-08-07 23:31:10.339 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: getDayjsLocale de
          2024-08-07 23:31:10.360 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: setObjects enabled - create Alias Channels possible
          2024-08-07 23:31:10.368 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: weather alias for accuweather.0. already exists
          2024-08-07 23:31:10.434 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          T 1 Reply Last reply Reply Quote 2
          • Nobody else
            Nobody else last edited by Nobody else
            Morgen zusammen,
            Habe das gleiche Problem mit den dayjs, ging bei mir los als ich den Javascript adapter geupdatet habe auf 8.7.6
            Habe den Javascript adapter wieder gedowngradet auf 8.3.1 und musste auch ein altes script 4.3.1.6 nehmen, das alles wieder halbwegs läuft, selbst das script 4.3.3.25 was ich voher hatte lief nicht mehr.
            Selbst ein Rückspielen von einen Backup hat nur Fehlermeldungen gebracht```
            Skript v.2024-05-22
            *** BASE SYSTEM ***
             Static hostname: debian
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.1.0-23-amd64
                Architecture: x86-64
             Hardware Vendor: FUJITSU
              Hardware Model: FUTRO S920
            Firmware Version: V4.6.5.4 R1.15.0 for D3313-A1x
            model name      : AMD GX-415GA SOC with Radeon(tm) HD Graphics
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             10:06:11 up 1 day, 23:49,  2 users,  load average: 0.43, 0.63, 0.84
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Fri 2024-08-09 10:06:11 CEST
                       Universal time: Fri 2024-08-09 08:06:11 UTC
                             RTC time: Fri 2024-08-09 08:06:10
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            root
            HOME=/root
            GROUPS=root
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.0G        3.5G        3.1G        1.8M        1.7G        4.5G
            Swap:           1.1G          0B        1.1G
            Total:          9.1G        3.5G        4.2G
            Active iob-Instances:   25
                     7615 M total memory
                     3295 M used memory
                      614 M active memory
                     3663 M inactive memory
                     2972 M free memory
                      156 M buffer memory
                     1473 M swap cache
                     1022 M total swap
                        0 M used swap
                     1022 M free swap
            top - 10:06:11 up 1 day, 23:49,  2 users,  load average: 0.43, 0.63, 0.84
            Tasks: 169 total,   2 running, 167 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   7615.7 total,   2971.8 free,   3296.3 used,   1629.8 buff/cache
            MiB Swap:   1023.0 total,   1023.0 free,      0.0 used.   4319.4 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  3.7G     0  3.7G   0% /dev
            tmpfs          tmpfs     762M  1.3M  761M   1% /run
            /dev/sda1      ext4       58G   17G   38G  31% /
            tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
            tmpfs          tmpfs     762M   48K  762M   1% /run/user/1000
            [Wed Aug  7 10:17:03 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
            [Wed Aug  7 10:17:04 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET                                                  SOURCE      FSTYPE          OPTIONS
            /                                                       /dev/sda1   ext4            rw,relatime,errors=remount-ro
            |-/sys                                                  sysfs       sysfs           rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security                                securityfs  securityfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup                                      cgroup2     cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
            | |-/sys/fs/pstore                                      pstore      pstore          rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/bpf                                         bpf         bpf             rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug                                   debugfs     debugfs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/tracing                                 tracefs     tracefs         rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/config                                  configfs    configfs        rw,nosuid,nodev,noexec,relatime
            | `-/sys/fs/fuse/connections                            fusectl     fusectl         rw,nosuid,nodev,noexec,relatime
            |-/proc                                                 proc        proc            rw,nosuid,nodev,noexec,relatime
            | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=16509
            |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc     rw,nosuid,nodev,noexec,relatime
            |-/dev                                                  udev        devtmpfs        rw,nosuid,relatime,size=3863224k,nr_inodes=965806,mode=755,inode64
            | |-/dev/pts                                            devpts      devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | |-/dev/shm                                            tmpfs       tmpfs           rw,nosuid,nodev,inode64
            | |-/dev/mqueue                                         mqueue      mqueue          rw,nosuid,nodev,noexec,relatime
            | `-/dev/hugepages                                      hugetlbfs   hugetlbfs       rw,relatime,pagesize=2M
            `-/run                                                  tmpfs       tmpfs           rw,nosuid,nodev,noexec,relatime,size=779848k,mode=755,inode64
              |-/run/lock                                           tmpfs       tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
              |-/run/credentials/systemd-sysusers.service           ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              |-/run/credentials/systemd-sysctl.service             ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
              |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs      rw,relatime
              `-/run/user/1000                                      tmpfs       tmpfs           rw,nosuid,nodev,relatime,size=779844k,nr_inodes=194961,mode=700,uid=1000,gid=1000,inode64
                `-/run/user/1000/gvfs                               gvfsd-fuse  fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
            /var:
            4.3G    /var/
            3.1G    /var/log
            3.0G    /var/log/journal
            2.4G    /var/log/journal/f4c3246da5c8449e8998270413aa11c1
            956M    /var/cache
            Archived and active journals take up 2.3G in the file system.
            /opt/iobroker/backups:
            152M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            4.4G    /opt/iobroker/iobroker-data/
            4.0G    /opt/iobroker/iobroker-data/history
            357M    /opt/iobroker/iobroker-data/files
            138M    /opt/iobroker/iobroker-data/files/javascript.admin
            118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            21M     /opt/iobroker/iobroker-data/states.jsonl
            21M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /dev/serial/by-id/usb-Espressif_USB_JTAG_serial_debug_unit_DC:54:75:93:E1:64-if00
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDDF59A-if00
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyACM1
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.20.4
            /usr/bin/node           v18.20.4
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            /usr/bin/corepack       0.28.0
            nodejs:
              Installed: 18.20.4-1nodesource1
              Candidate: 18.20.4-1nodesource1
              Version table:
             *** 18.20.4-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.20.3-1nodesource1 500
                 18.20.2-1nodesource1 500
                 18.20.1-1nodesource1 500
                 18.20.0-1nodesource1 500
                 18.19.1-1nodesource1 500
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                 18.19.0-1nodesource1 500
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.9
            admin:          7.0.22
            javascript:     8.3.1
            nodejs modules from github:     0
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : debian                                   -  enabled
            + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.apcups.0                 : apcups                : debian                                   -  enabled
            + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
            + system.adapter.ble.0                    : ble                   : debian                                   -  enabled
              system.adapter.devices.0                : devices               : debian                                   -  enabled
            + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
            + system.adapter.ebus.0                   : ebus                  : debian                                   -  enabled
            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : debian                                   -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : debian                                   -  enabled
            + system.adapter.history.0                : history               : debian                                   -  enabled
            + system.adapter.hue.0                    : hue                   : debian                                   -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : debian                                   -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : debian                                   -  enabled
            + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
            + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : debian                                   -  enabled, port: 1884, bind: 0.0.0.0
              system.adapter.onvif.0                  : onvif                 : debian                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.sonoff.0                 : sonoff                : debian                                   -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sony-bravia.0            : sony-bravia           : debian                                   -  enabled
            + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
            + system.adapter.tuya.0                   : tuya                  : debian                                   -  enabled
            + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : debian                                   -  enabled, port: /dev/ttyACM1
            + instance is alive
            ioBroker-Repositories
            │ (index) │   name   │                           url                           │ auto upgrade │
            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
            Adapter    "admin"        : 7.0.22   , installed 7.0.22
            Adapter    "apcups"       : 4.0.0    , installed 4.0.0
            Adapter    "backitup"     : 3.0.16   , installed 3.0.16
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "ebus"         : 3.3.4    , installed 3.3.1  [Updatable]
            Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "hue"          : 3.11.0   , installed 3.11.0
            Adapter    "ical"         : 1.15.0   , installed 1.15.0
            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
            Adapter    "javascript"   : 8.7.6    , installed 8.3.1  [Updatable]
            Controller "js-controller": 6.0.9    , installed 6.0.9
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
            Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
            Adapter    "telegram"     : 3.3.2    , installed 3.3.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
            Objects and States
            Objects:        11957
            States:         11021
            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://linux.teamviewer.com/deb stable InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:6 https://repo.ebusd.eu/apt/default/bookworm bookworm InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16159      620/iobroker.js-con
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20833      620/iobroker.js-con
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1418002    109185/cupsd
            tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          18654      768/teamviewerd
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       1800529    140673/io.mqtt.0
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21069      1007/io.shelly.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21767      1033/io.sonoff.0
            tcp        0      0 127.0.0.1:3551          0.0.0.0:*               LISTEN      0          16079      757/apcupsd
            tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          20829      753/ebusd
            tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          20830      753/ebusd
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          725        1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20576      656/sshd: /usr/sbin
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22214      1325/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16193      802/io.admin.0
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1418001    109185/cupsd
            tcp6       0      0 :::111                  :::*                    LISTEN      0          15411      1/init
            tcp6       0      0 :::80                   :::*                    LISTEN      0          15999      658/apache2
            tcp6       0      0 :::22                   :::*                    LISTEN      0          20587      656/sshd: /usr/sbin
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1631       1/init
            udp        0      0 0.0.0.0:57892           0.0.0.0:*                           104        15869      515/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1420450    109188/cups-browsed
            udp        0      0 192.168.178.101:5353    0.0.0.0:*                           1001       21162      1063/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15867      515/avahi-daemon: r
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21159      1079/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21160      1079/io.tuya.0
            udp6       0      0 :::111                  :::*                                0          726        1/init
            udp6       0      0 fe80::921b:eff:fe9e:546 :::*                                0          1460247    559/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        15868      515/avahi-daemon: r
            udp6       0      0 :::40642                :::*                                104        15870      515/avahi-daemon: r
            2024-08-09 09:30:00.770  - info: host.debian Restart adapter system.adapter.mqtt.0 because enabled
            2024-08-09 09:30:02.485  - info: host.debian instance system.adapter.mqtt.0 in version "5.2.0" started with pid 138317
            2024-08-09 09:30:12.134  - info: host.debian instance system.adapter.ical.0 having pid 138304 terminated with code 0 (NO_ERROR)
            2024-08-09 09:49:44.351  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
            2024-08-09 09:49:44.409  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
            2024-08-09 09:49:44.493  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 14 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2024-08-09 09:51:33.557  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
            2024-08-09 09:51:33.662  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
            2024-08-09 09:51:33.738  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2024-08-09 09:53:32.593  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
            2024-08-09 09:53:32.697  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
            2024-08-09 09:53:32.742  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2024-08-09 09:54:55.962  - info: javascript.0 (117154) Stopping script script.js.Kamera_Steuerung
            2024-08-09 09:54:56.019  - info: javascript.0 (117154) Start JavaScript script.js.Kamera_Steuerung (Blockly)
            2024-08-09 09:54:56.067  - info: javascript.0 (117154) script.js.Kamera_Steuerung: registered 15 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2024-08-09 09:56:38.408  - info: host.debian instance "system.adapter.onvif.0" disabled via .alive
            2024-08-09 09:56:38.422  - info: host.debian "system.adapter.onvif.0" disabled
            2024-08-09 09:56:38.423  - info: host.debian stopInstance system.adapter.onvif.0 (force=false, process=true)
            2024-08-09 09:56:38.470  - info: host.debian stopInstance system.adapter.onvif.0 send kill signal
            2024-08-09 09:56:39.139  - info: host.debian instance system.adapter.onvif.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2024-08-09 10:00:00.059  - info: host.debian instance system.adapter.ical.0 in version "1.15.0" started with pid 140661
            2024-08-09 10:00:00.784  - info: host.debian instance system.adapter.mqtt.0 scheduled normal terminated and will be restarted on schedule.
            2024-08-09 10:00:00.785  - info: host.debian Restart adapter system.adapter.mqtt.0 because enabled
            2024-08-09 10:00:02.466  - info: host.debian instance system.adapter.mqtt.0 in version "5.2.0" started with pid 140673
            2024-08-09 10:00:12.269  - info: host.debian instance system.adapter.ical.0 having pid 140661 terminated with code 0 (NO_ERROR)
            iob diag has finished.
            Press any key for a summary
              TT-Tom @Nobody else last edited by TT-Tom
              @nobody-else
              Auf den ersten Blick passt deine JS-Controller Version nicht zur JavaScript Version. Diese müsste auch wieder auf die 5. Version.
              Ich kann dir nur empfehlen wieder auf die aktuellen Versionen umzusteigen und die Fehlermeldung beim Start vom Script ignorieren. Bis jetzt funktioniert alles einwandfrei, auch mit den Meldungen.
              Nobody else 1 Reply Last reply Reply Quote 1
              • Nobody else
                Nobody else @TT-Tom last edited by
                @tt-tom Leider funktioniert es nicht, das Skript wird gestoppt sobald die Fehlermeldungen kommen.
                Und das NS Panel reagiert nicht mehr.
                  lustig29 last edited by
                  Hat es denn mittlerweile schon mal jemand probiert, ein Ns Panel hinter einem Shelly Dimmer 2 laufen zu lassen?
                    @nobody-else
                    von welcher Fehlermeldung sprechen wir hier eigentlich? dayjs oder exitsObject
                    bei welcher Scriptversion ist die Fehlermeldung gekommen?
                    Nobody else 1 Reply Last reply Reply Quote 0
                    • Nobody else
                      @tt-tom ich werde es heute nochmal den Java-Adapter updaten und die Fehlermeldung loggen, vielleicht war es ja nur die dayjs.
                      Ich habe dann so viele verschiedene Skrips mit verschiedenen Java adapter versionen probiert, das ich die genaue Fehlermeldung nicht mehr weiß.
                      Aber wenn du sagst das trotz des dayjs Fehlers das Panel läuft muss ich das nochmal probieren, ich hatte dann zu den Zeitpunkt keine Lust mehr, weil immer rote Fehlermeldungen kamen und ich und meine Regierung ein funktionierendes Panel für die Haussteuerung brauchen.
                        @nobody-else
                        alles klar, sehe heute Abend nochmal vorbei, wie es läuft.
                        • Nobody else
                          Nobody else @TT-Tom last edited by Nobody else
                          @tt-tom ich habe jetzt alles aktualisiert und du hast recht gehabt, der dayjs Fehler läuft durch und das Panel funktioniert trotzdem. 👍 😊
                          2024-08-09 21:15:38.696 - info: javascript.0 (177494) Stopping script script.js.NS_Panels.NS_Panel_Update_3
                          2024-08-09 21:15:39.933 - info: javascript.0 (177494) Compiling TypeScript source script.js.NS_Panels.NS_Panel_Update_3
                          2024-08-09 21:15:41.722 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: source code did not change, using cached compilation result...
                          2024-08-09 21:15:42.000 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.000 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.000 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.000 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.001 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.004 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.004 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.005 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.006 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.006 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.008 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                          2024-08-09 21:15:42.009 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.010 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.045 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.045 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.045 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.046 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.046 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                          2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                          2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.046 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.047 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.047 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.050 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.050 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.050 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.050 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.051 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.054 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.054 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.054 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.055 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.058 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                          2024-08-09 21:15:42.059 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.060 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.063 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.063 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.063 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.063 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.063 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                          2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                          2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.064 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.067 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.067 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.067 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.067 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.068 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.071 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.072 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.073 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.073 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.075 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                          2024-08-09 21:15:42.076 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.077 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.080 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.080 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.080 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.080 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.080 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                          2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                          2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.081 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.084 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.084 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.085 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.086 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.089 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.089 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.089 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.090 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.093 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.094 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.095 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.095 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                          2024-08-09 21:15:42.098 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                          2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.099 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.102 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.102 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.102 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.102 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.102 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                          2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                          2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.103 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.106 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                          2024-08-09 21:15:42.107 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.108 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.111 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.111 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.112 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.113 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.115 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                          2024-08-09 21:15:42.116 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.117 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.120 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.120 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.120 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.120 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.120 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                          2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                          2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.121 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.124 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.124 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.124 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.124 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.125 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.128 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.128 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.129 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.130 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.130 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.133 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.133 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.133 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.133 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.133 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                          2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                          2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.134 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.137 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                          2024-08-09 21:15:42.138 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.139 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.142 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.142 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.142 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.142 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.143 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.146 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.146 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.146 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.147 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.148 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                          2024-08-09 21:15:42.151 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.152 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                          2024-08-09 21:15:42.155 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                          2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.156 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.159 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.159 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.159 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.159 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.159 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                          2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                          2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.160 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.163 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.163 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.163 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.164 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.167 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.167 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.168 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.169 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.171 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.171 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.172 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.173 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.173 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.175 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.176 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.177 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.177 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                          2024-08-09 21:15:42.180 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                          2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.181 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                          2024-08-09 21:15:42.184 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                          2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.185 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.188 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.188 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.188 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.188 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.188 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                          2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                          2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.189 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.192 - error: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Error: Cannot find module 'dayjs'
                          2024-08-09 21:15:42.192 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:981:27)
                          2024-08-09 21:15:42.192 - error: javascript.0 (177494) at Module.require (node:internal/modules/cjs/loader:1231:19)
                          2024-08-09 21:15:42.192 - error: javascript.0 (177494) at require (node:internal/modules/helpers:177:18)
                          2024-08-09 21:15:42.192 - error: javascript.0 (177494) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                          2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                          2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Module.load (node:internal/modules/cjs/loader:1203:32)
                          2024-08-09 21:15:42.193 - error: javascript.0 (177494) at Function.Module._load (node:internal/modules/cjs/loader:1019:12)
                          2024-08-09 21:15:42.248 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: nodeJS must be at least v18.X.X. Currently: v16.20.2! Please Update your System! --> iob nodejs-update 18
                          2024-08-09 21:15:42.248 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: nodeJS must be at least v18.X.X. Currently: v16.19.0! Please Update your System! --> iob nodejs-update 18
                          2024-08-09 21:15:42.249 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: setObjects enabled - create Alias Channels possible
                          2024-08-09 21:15:42.265 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: weather alias for accuweather.0. already exists
                          2024-08-09 21:15:42.299 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: No Updates for NSPanel available
                          2024-08-09 21:15:42.300 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2024-08-09 21:15:42.312 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: No Updates for NSPanel available
                          2024-08-09 21:15:42.753 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:42.753 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:42.972 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Debug mode disabled
                          2024-08-09 21:15:43.608 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:43.609 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:43.837 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Desired TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:43.838 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Installed TFT Firmware: 53 / v4.4.0
                          2024-08-09 21:15:47.654 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: Start MQTT-Port-Check -------------------------------------
                          2024-08-09 21:15:47.655 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- admin.0 - 8081
                          2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- hue.0 - 443
                          2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- mqtt.0 - 1884
                          2024-08-09 21:15:47.656 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- shelly.0 - 1885
                          2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- sonoff.0 - 1883
                          2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- telegram.0 - 8443
                          2024-08-09 21:15:47.657 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- web.0 - 8082
                          2024-08-09 21:15:47.658 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: -- zigbee.0 - /dev
                          2024-08-09 21:15:47.659 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884
                          2024-08-09 21:15:47.659 - info: javascript.0 (177494) script.js.NS_Panels.NS_Panel_Update_3: End MQTT-Port-Check ---------------------------------------
                          • Nobody else
                            Hi Zusammen,
                            ich hab mal noch eine kleines Problem, wenn ich im Systemmenü des Panels die Helligkeit ändere wird dies erst geändert wenn ich das Skript neu starte, b.z.w. wenn ich das Panel mal stromlos gemacht habe sind auch wieder die Default werte eingestellt bis ich das Skript neu starte.
                            Das Problem hab ich eigentlich schon von Anfang an, seit verschiedenen Skript Versionen, stört jetzt nicht so, aber der innere Monk will halt das alles irgendwie rund läuft.😊
                              @nobody-else
                              Kannst du bitte dazu ein Issue auf Github machen, danke.
                                tobiasp @Rene55 last edited by
                                @rene55 said in SONOFF NSPanel mit Lovelace UI:
                                dules/cjs/loader:1358:14)
                                Geanu so sieht es bei mir aus.
                                Er findet nicht das Modul Dayjs
                                  tobiasp @tobiasp last edited by
                                  @tobiasp
                                  Mein Ordner ist da. Komisch auch die Datei zh-cn.js
                                  javascript.0
                                  	2024-08-11 07:45:52.295	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.295	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.294	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.293	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.290	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.289	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.289	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.285	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.284	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.284	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.280	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.279	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.279	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.276	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.275	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.274	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.272	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.271	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.270	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.267	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.267	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.266	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.265	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.262	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.262	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.261	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.258	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.257	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.257	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.254	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.253	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.253	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.253	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.253	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.249	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.248	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.248	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.248	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.245	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.244	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.244	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.241	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.241	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.241	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.241	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.241	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.240	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.240	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.240	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.240	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.240	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.236	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.236	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.236	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.235	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.235	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.235	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.234	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.234	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.234	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.234	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.231	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.231	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.230	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.227	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.226	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.225	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.225	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.223	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.222	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.221	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.219	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.218	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                  javascript.0
                                  	2024-08-11 07:45:52.217	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.217	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at Module.load (node:internal/modules/cjs/loader:1208:32)
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                  javascript.0
                                  	2024-08-11 07:45:52.214	error	at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                  javascript.0
                                  	2024-08-11 07:45:52.213	error	at require (node:internal/modules/helpers:179:18)
                                  javascript.0
                                  	2024-08-11 07:45:52.213	error	at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                  javascript.0
                                  	2024-08-11 07:45:52.213	error	script.js.NsPanel_EG.NS_Panel: Error: Cannot find module 'dayjs'
                                  javascript.0
                                  	2024-08-11 07:45:52.213	error	at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    Wuschl last edited by
                                    Servus, ich habe das Problem daß in letzter Zeit das NS-Panel öfter hängen bleibt. Ich habe vor einer Woche mal alles auf den neuesten Stand gebracht, aber das hat nichts geändert. Heute morgen wieder ohne Funktion, Uhrzeit steht auf 11:17, Tasmota ist nicht mehr erreichbar, hilft nur noch Sicherung raus und wieder rein. Kennt jemand das Problem?
                                      eMd @Wuschl last edited by
                                      @wuschl
                                      Bei mir hing es am Skript. Ich hatte so eine popup Script laufen was nicht funktionierte aber das panel immer hängen ließ.
                                        @emd Das ist bei mir leider nicht der Fall. Ich habe im Script noch nichts eingefügt außer die mqtt Verbindung. Wollte es erstmal so testen um eben das auszuschließen.
                                        • Armilar
                                          Armilar Most Active Forum Testing last edited by Armilar
                                          @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
                                          Könntest du das etwas detaillierter beschreiben? Ist so etwa wie mein Vogelhaus kippt ständig um und ich sage meiner Frau, sie soll den Herd an und ausmachen 😊
                                          Wie ist Tasmota nicht erreichbar?
                                          • per MQTT oder per Web-GUI?
                                          Wovon wird ne Sicherung gemacht und wieder eingespielt?
                                          • etwa vom ioBroker? falls ja, warum sollte es das Problem zu einem komplett entkoppeltem System ändern?
                                          • Oder Sicherung für die Stromversorgung aus/an?
                                          Für mich deutet im Moment mehr auf eine schlechte WLAN-Kommunikation hin...
                                          • Check das mal, ggfs. Pings aufzeichnen, um zu sehen, ob es Abrisse gibt
                                          • WLAN Channel prüfen, um auszuschließen, dass es permanente Kanalwechsel gibt
                                          • RSSI checken um sicherzustellen, dass da außer Rauschen überhaupt etwas ankommen kann
                                          • etc.
                                          Kann tausende Gründe dafür geben... Etwas mehr Input...
                                            Wuschl @Armilar last edited by Wuschl
                                            @armilar das Panel ist weder per mqtt noch über die Web-Gui erreichbar. Kein Neustart mehr möglich. Heißt, die STROM-Sicherung raus und wieder rein, dann läuft es wieder ein paar Tage, manchmal länger manchmal kürzer. Schlechte Wlan Verbindung ist auszuschließen. Es reagieren nicht mal mehr die Taster-Relais an denen ein ganz normales Licht angeschlossen ist.
                                            Dies trat vor ein paar Monaten plötzlich auf, es wurde aber nichts verändert außer Tasmota Auto-Update.
                                            lovelace ui nspanel sonoff
                                            271
                                            7720
                                            6622351
