    4. SONOFF NSPanel Lovelance UI Rückgängig machen
      TT-Tom @Armilar last edited by
      @armilar
      ich habe auch den Verdacht dass die npm-Module nicht eingetragen sind.
        Karlson 0 @TT-Tom last edited by
        @TT-Tom
        @Armilar
        Die npm-Module führen mich leider zu meinem nächsten Problem, sobald ich sie eintrage startet mein JS Adapter nicht mehr und ich bekomme folgende Meldung:
        2024-08-09 21:17:39.475 - info: javascript.0 (675) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.7.0, js-controller: 6.0.9
        2024-08-09 21:17:39.575 - error: javascript.0 (675) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-08-09 21:17:39.576 - error: javascript.0 (675) unhandled promise rejection: URL.canParse is not a function
        2024-08-09 21:17:39.576 - error: javascript.0 (675) TypeError: URL.canParse is not a function
        at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
        2024-08-09 21:17:39.576 - error: javascript.0 (675) URL.canParse is not a function
        2024-08-09 21:17:39.604 - info: javascript.0 (675) terminating
        2024-08-09 21:17:39.605 - warn: javascript.0 (675) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-08-09 21:17:40.103 - info: javascript.0 (675) terminating
        2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: TypeError: URL.canParse is not a function
        2024-08-09 21:17:40.151 - error: host.ioBroker Caught by controller[1]: at installLibraries (/opt/iobroker/node_modules/iobroker.javascript/main.js:1868:17)
        2024-08-09 21:17:40.151 - error: host.ioBroker instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-08-09 21:17:40.151 - info: host.ioBroker Restart adapter system.adapter.javascript.0 because enabled
        2024-08-09 21:17:40.151 - warn: host.ioBroker Do not restart adapter system.adapter.javascript.0 because restart loop detected
        Armilar T 2 Replies Last reply Reply Quote 0
        • Armilar
          Armilar Most Active Forum Testing @Karlson 0 last edited by
          @karlson-0
          Führe mal ein
          iob fix
          durch
          Dann mal
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
          danach nochmal versuchen
          T 1 Reply Last reply Reply Quote 2
            TT-Tom @Karlson 0 last edited by
            @karlson-0
            Zeig mal was du da eingetragen hast.
              @armilar
              @Karlson-0
              Und gleich die nodejs Version anpassen auf 20.
              iob nodejs-update 20
                @tt-tom
                @Armilar
                Nach
                iob fix
                sudo apt update
                sudo reboot
                Hat es leider nicht funktioniert
                Jetzt das nächste Problem, und ich hoffe ihr habt starke nerven:
                Node V 20 bekomme ich bei mir irgendwie nicht drauf, war schon ein wunder dass ich 18 drauf bekommen habe.
                Muss dazu sagen, dass iobroker bei mir auf einem LXC Container über Proxmox läuft.
                Ich bekomme bei der Installation folgende Meldung:
                root@ioBroker:~# sudo -E bash nodesource_setup.sh
                2024-08-09 21:50:33 - Installing pre-requisites
                Ign:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
                Ign:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
                Ign:3 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
                Err:4 http://archive.ubuntu.com/ubuntu kinetic Release
                  404  Not Found [IP: 91.189.91.83 80]
                Err:5 http://archive.ubuntu.com/ubuntu kinetic-updates Release
                Err:6 http://archive.ubuntu.com/ubuntu kinetic-security Release
                Reading package lists... Done
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic Release' no longer has a Release file.
                N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-updates Release' no longer has a Release file.
                E: The repository 'http://archive.ubuntu.com/ubuntu kinetic-security Release' no longer has a Release file.
                2024-08-09 21:50:34 - Error: Failed to run 'apt-get update' (Exit Code: 0)
                Homoran T 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @Karlson 0 last edited by
                  @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
                  ubuntu kinetic
                  Ubuntu 22.10 Kinetic Kudu ist eine "Short Term Support" Version, die nur bis Juli 2023 mit Updates versorgt wird
                    TT-Tom @Karlson 0 last edited by TT-Tom
                    @karlson-0
                    Warum arbeitest du als Root????
                    Du musst immer als normal User im System unterwegs sein.
                    Lege die ein neuen Container an, als Vorlage würde ich dir Debian 12 empfehlen.
                    Dann baust du dir iobroker komplett neu auf und spielst das Backup deiner aktuellen Version ein.
                    Wenn ich zu Hause bin kann ich dir eine kleine Schritt für Schritt Anleitung noch posten.
                    K 1 Reply Last reply Reply Quote 2
                      @tt-tom
                      So weit meine Kenntnis reicht, gibt es in diesen LXC Containern nur den Root User, In einigen Foren wird noch der User Ubuntu beschrieben, mit pw ubuntu, funktioniert bei mir aber nicht.
                      Thomas Braun K 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Karlson 0 last edited by
                        Man legt sich immer einen user an.
                        Ist die erste (und einzige) Aktion als root in einem frischen LXC.
                        Undd dein kinetisches Kudo ist ausgestorben. Deswegen frisst das auch kein nodejs20 mehr.
                        Zimmer dir einen frischen Debian12-LXC hin.
                          Karlson 0 @Karlson 0 last edited by Karlson 0
                          Ich habe gerade das ioBroker Backup gemacht, werde morgen einen neuen Debian 12 Container für Iobroker erstellen, und danach sofort berichten
                            @karlson-0
                            hier wie versprochen meine kurze Schritt für Schritt Anleitung. Wenn der Container läuft sind die ersten Schritte bis zum Reboot als Root. Danach wird root nicht mehr angefasst, IMMER als Standard-User anmelden und ggf. mit sudo arbeiten.
                            apt update && apt full-upgrade -y
                            apt install -y curl sudo mc
                            dpkg-reconfigure tzdata
                            dpkg-reconfigure locales
                            //Standarduser erstellen
                            adduser "name"
                            usermod -aG sudo "name"
                            reboot
                            // login als Standarduser
                            // install ioBroker
                            curl -sLf https://iobroker.net/install.sh | bash -
                              Leider weiterhin nicht erfolgreich.
                              Mein iobroker läuft jetzt auf einem Debian 12 Container, node 20 ist drauf, npm Module sind jetzt auch eingetragen, und die Instanz javascript wird grün.
                              Bekomme beim Start von NSPanelTS.ts folgende Meldungen:
                              2024-08-12 21:45:15.043 - info: admin.0 (407) ==> Connected system.user.admin from ::ffff:192.168.178.240
                              2024-08-12 21:45:19.220 - info: javascript.0 (458) Compiling TypeScript source script.js.common.NSPanelTs_ts
                              2024-08-12 21:45:24.438 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                              2024-08-12 21:45:24.545 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.545 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.546 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.548 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.548 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.548 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.549 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.551 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.551 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.552 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.553 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.554 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.554 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.554 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.554 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.555 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.556 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.558 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.560 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                              2024-08-12 21:45:24.561 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                              2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.562 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.562 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.562 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.563 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.564 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.564 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.564 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.564 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.564 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                              2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                              2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.565 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.565 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.565 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.566 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.567 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.568 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.569 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.569 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.569 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.569 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.570 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.571 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.573 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.575 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.575 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.575 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.575 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.575 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                              2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                              2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.576 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.576 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.576 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.577 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.578 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.578 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.578 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.579 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.580 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.581 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.581 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.581 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.581 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.581 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                              2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                              2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.582 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.582 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.582 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.583 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.584 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.585 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.586 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.586 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.586 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.587 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.588 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.588 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.588 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.589 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.590 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.590 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.591 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.594 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.594 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.594 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.595 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.595 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                              2024-08-12 21:45:24.595 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                              2024-08-12 21:45:24.595 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.598 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.598 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.598 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.599 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.599 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.599 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.599 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.599 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                              2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                              2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.600 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.600 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.600 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.601 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                              2024-08-12 21:45:24.602 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.603 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.603 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.603 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.604 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.605 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.606 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.606 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.606 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.606 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.607 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.608 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.609 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.610 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.611 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.612 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.612 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.613 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.614 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.615 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                              2024-08-12 21:45:24.615 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                              2024-08-12 21:45:24.615 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                              2024-08-12 21:45:24.616 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                              2024-08-12 21:45:24.623 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                              2024-08-12 21:45:24.624 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                              2024-08-12 21:45:24.630 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                              2024-08-12 21:45:24.689 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:24.694 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                              2024-08-12 21:45:24.694 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2994:1
                              2024-08-12 21:45:24.694 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                              2024-08-12 21:45:24.696 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at get_tasmota_status0 (script.js.common.NSPanelTs_ts:3495:42)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:2986:5
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Object._schedule (script.js.common.NSPanelTs_ts:11224:9)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3212:34)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at listOnTimeout (node:internal/timers:581:17)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) at processTimers (node:internal/timers:519:7)
                              2024-08-12 21:45:24.726 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:24.727 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                              2024-08-12 21:45:24.877 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                              at Function.AxiosError.from (/opt/iobroker/node_modules/axios/lib/core/AxiosError.js:89:14)
                              at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/axios/lib/adapters/http.js:620:25)
                              at RedirectableRequest.emit (node:events:519:28)
                              at RedirectableRequest.emit (node:domain:488:12)
                              at ClientRequest.eventHandlers. (/opt/iobroker/node_modules/follow-redirects/index.js:38:24)
                              at ClientRequest.emit (node:events:531:35)
                              at ClientRequest.emit (node:domain:488:12)
                              at Socket.socketErrorListener (node:_http_client:500:9)
                              at Socket.emit (node:events:519:28)
                              at Socket.emit (node:domain:488:12)
                              at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)
                              at processTicksAndRejections (node:internal/process/task_queues:95:5) {
                              hostname: 'undefined',
                              syscall: 'getaddrinfo',
                              code: 'ENOTFOUND',
                              errno: -3008,
                              config: {
                              transitional: {
                              silentJSONParsing: true,
                              forcedJSONParsing: true,
                              clarifyTimeoutError: false
                              adapter: [ 'xhr', 'http', 'fetch' ],
                              transformRequest: [ [Function: transformRequest] ],
                              transformResponse: [ [Function: transformResponse] ],
                              timeout: 0,
                              xsrfCookieName: 'XSRF-TOKEN',
                              xsrfHeaderName: 'X-XSRF-TOKEN',
                              maxContentLength: -1,
                              maxBodyLength: -1,
                              env: { FormData: [Function], Blob: [class Blob] },
                              validateStatus: [Function: validateStatus],
                              headers: Object [AxiosHeaders] {
                              Accept: 'application/json, text/plain, */*',
                              'Content-Type': undefined,
                              'User-Agent': 'ioBroker',
                              'Accept-Encoding': 'gzip, compress, deflate, br'
                              method: 'get',
                              url: 'http://undefined/cm?cmnd=Status0',
                              data: undefined
                              request: Writable {
                              _events: {
                              close: undefined,
                              error: [Function: handleRequestError],
                              prefinish: undefined,
                              finish: undefined,
                              drain: undefined,
                              response: [Function: handleResponse],
                              socket: [Function: handleRequestSocket]
                              _writableState: WritableState {
                              highWaterMark: 16384,
                              length: 0,
                              corked: 0,
                              onwrite: [Function: bound onwrite],
                              writelen: 0,
                              bufferedIndex: 0,
                              pendingcb: 0,
                              [Symbol(kState)]: 17580812,
                              [Symbol(kBufferedValue)]: null
                              _maxListeners: 100,
                              _options: {
                              maxRedirects: 21,
                              maxBodyLength: Infinity,
                              protocol: 'http:',
                              path: '/cm?cmnd=Status0',
                              method: 'GET',
                              headers: [Object: null prototype],
                              agents: [Object],
                              auth: undefined,
                              family: undefined,
                              beforeRedirect: [Function: dispatchBeforeRedirect],
                              beforeRedirects: [Object],
                              port: '',
                              agent: undefined,
                              nativeProtocols: [Object],
                              pathname: '/cm',
                              search: '?cmnd=Status0'
                              _ended: true,
                              _ending: true,
                              _redirectCount: 0,
                              _redirects: [],
                              _requestBodyLength: 0,
                              _requestBodyBuffers: [],
                              _eventsCount: 3,
                              _onNativeResponse: [Function (anonymous)],
                              _currentRequest: ClientRequest {
                              _events: [Object: null prototype],
                              _eventsCount: 7,
                              _maxListeners: 100,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              chunkedEncoding: false,
                              shouldKeepAlive: true,
                              maxRequestsOnConnectionReached: false,
                              _defaultKeepAlive: true,
                              useChunkedEncodingByDefault: false,
                              sendDate: false,
                              _removedConnection: false,
                              _removedContLen: false,
                              _removedTE: false,
                              strictContentLength: false,
                              _contentLength: 0,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                              socket: [Socket],
                              _header: 'GET /cm?cmnd=Status0 HTTP/1.1\r\n' +
                              'Accept: application/json, text/plain, */*\r\n' +
                              'User-Agent: ioBroker\r\n' +
                              'Accept-Encoding: gzip, compress, deflate, br\r\n' +
                              'sentry-trace: 49d0d7813b8c428eab3645c24d1a50f8-98b170a0ea551350\r\n' +
                              'baggage: sentry-environment=production,sentry-release=iobroker.javascript%408.7.6,sentry-public_key=f3b9740caaee4ee69eb68019d71526ff,sentry-trace_id=49d0d7813b8c428eab3645c24d1a50f8\r\n' +
                              'Host: undefined\r\n' +
                              'Connection: keep-alive\r\n' +
                              '\r\n',
                              _keepAliveTimeout: 0,
                              _onPendingData: [Function: nop],
                              agent: [Agent],
                              socketPath: undefined,
                              method: 'GET',
                              maxHeaderSize: undefined,
                              insecureHTTPParser: undefined,
                              joinDuplicateHeaders: undefined,
                              _ended: false,
                              res: null,
                              aborted: false,
                              timeoutCb: [Function: emitRequestTimeout],
                              upgradeOrConnect: false,
                              parser: null,
                              maxHeadersCount: null,
                              reusedSocket: false,
                              host: 'undefined',
                              protocol: 'http:',
                              _redirectable: [Circular *1],
                              [Symbol(shapeMode)]: false,
                              [Symbol(kCapture)]: false,
                              [Symbol(kBytesWritten)]: 0,
                              [Symbol(kNeedDrain)]: false,
                              [Symbol(corked)]: 0,
                              [Symbol(kOutHeaders)]: [Object: null prototype],
                              [Symbol(errored)]: null,
                              [Symbol(kHighWaterMark)]: 16384,
                              [Symbol(kRejectNonStandardBodyWrites)]: false,
                              [Symbol(kUniqueHeaders)]: null
                              _currentUrl: 'http://undefined/cm?cmnd=Status0',
                              [Symbol(shapeMode)]: true,
                              cause: Error: getaddrinfo ENOTFOUND undefined
                              at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) {
                              errno: -3008,
                              code: 'ENOTFOUND',
                              2024-08-12 21:45:24.879 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                              code: 'ENOTFOUND',
                              errno: -3008,
                              config: {
                              transitional: {
                              timeout: 0,
                              maxBodyLength: -1,
                              method: 'get',
                              data: undefined
                              request: Writable {
                              _events: {
                              close: undefined,
                              finish: undefined,
                              drain: undefined,
                              length: 0,
                              corked: 0,
                              writelen: 0,
                              bufferedIndex: 0,
                              pendingcb: 0,
                              _maxListeners: 100,
                              _options: {
                              maxRedirects: 21,
                              protocol: 'http:',
                              method: 'GET',
                              agents: [Object],
                              auth: undefined,
                              family: undefined,
                              port: '',
                              agent: undefined,
                              pathname: '/cm',
                              _ended: true,
                              _ending: true,
                              _redirectCount: 0,
                              _redirects: [],
                              _eventsCount: 3,
                              _eventsCount: 7,
                              _maxListeners: 100,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              sendDate: false,
                              _removedTE: false,
                              _contentLength: 0,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                              socket: [Socket],
                              '\r\n',
                              agent: [Agent],
                              method: 'GET',
                              _ended: false,
                              res: null,
                              aborted: false,
                              parser: null,
                              host: 'undefined',
                              protocol: 'http:',
                              errno: -3008,
                              code: 'ENOTFOUND',
                              2024-08-12 21:45:25.215 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                              2024-08-12 21:45:25.265 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                              2024-08-12 21:45:25.294 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:25.294 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:25.294 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                              2024-08-12 21:45:25.295 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                              2024-08-12 21:45:25.295 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                              2024-08-12 21:45:25.295 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                              2024-08-12 21:45:25.295 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:25.304 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                              2024-08-12 21:45:25.305 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                              2024-08-12 21:45:25.307 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3341:99
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                              2024-08-12 21:45:25.308 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                              2024-08-12 21:45:25.309 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                              2024-08-12 21:45:25.309 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:25.321 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has been written without ack-flag with value "[object Object]"
                              2024-08-12 21:45:25.321 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.NSPanel_ipAddress" has to be type "string" but received type "object"
                              2024-08-12 21:45:25.355 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:25.356 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                              2024-08-12 21:45:25.357 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:25.369 - warn: javascript.0 (458) getState "mqtt.0.SmartHome.NSPanel_1.stat.INFO2" not found (3)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_tasmota_ip_address (script.js.common.NSPanelTs_ts:3370:34)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at get_current_berry_driver_version (script.js.common.NSPanelTs_ts:3436:42)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at script.js.common.NSPanelTs_ts:3352:21
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at step (script.js.common.NSPanelTs_ts:33:23)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at Object.next (script.js.common.NSPanelTs_ts:14:53)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at fulfilled (script.js.common.NSPanelTs_ts:5:58)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at runNextTicks (node:internal/process/task_queues:60:5)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) at processImmediate (node:internal/timers:454:9)
                              2024-08-12 21:45:25.370 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: error at function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
                              2024-08-12 21:45:25.379 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                              code: 'ENOTFOUND',
                              errno: -3008,
                              config: {
                              transitional: {
                              timeout: 0,
                              maxBodyLength: -1,
                              method: 'get',
                              url: 'http://undefined/cm?cmnd=GetDriverVersion',
                              data: undefined
                              request: Writable {
                              _events: {
                              close: undefined,
                              finish: undefined,
                              drain: undefined,
                              length: 0,
                              corked: 0,
                              writelen: 0,
                              bufferedIndex: 0,
                              pendingcb: 0,
                              _maxListeners: 100,
                              _options: {
                              maxRedirects: 21,
                              protocol: 'http:',
                              path: '/cm?cmnd=GetDriverVersion',
                              method: 'GET',
                              agents: [Object],
                              auth: undefined,
                              family: undefined,
                              port: '',
                              agent: undefined,
                              pathname: '/cm',
                              search: '?cmnd=GetDriverVersion'
                              _ended: true,
                              _ending: true,
                              _redirectCount: 0,
                              _redirects: [],
                              _eventsCount: 3,
                              _eventsCount: 7,
                              _maxListeners: 100,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              sendDate: false,
                              _removedTE: false,
                              _contentLength: 0,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                              socket: [Socket],
                              _header: 'GET /cm?cmnd=GetDriverVersion HTTP/1.1\r\n' +
                              '\r\n',
                              agent: [Agent],
                              method: 'GET',
                              _ended: false,
                              res: null,
                              aborted: false,
                              parser: null,
                              host: 'undefined',
                              protocol: 'http:',
                              _currentUrl: 'http://undefined/cm?cmnd=GetDriverVersion',
                              errno: -3008,
                              code: 'ENOTFOUND',
                              2024-08-12 21:45:25.413 - warn: javascript.0 (458) script.js.common.NSPanelTs_ts: AxiosError: getaddrinfo ENOTFOUND undefined
                              code: 'ENOTFOUND',
                              errno: -3008,
                              config: {
                              transitional: {
                              timeout: 0,
                              maxBodyLength: -1,
                              method: 'get',
                              data: undefined
                              request: Writable {
                              _events: {
                              close: undefined,
                              finish: undefined,
                              drain: undefined,
                              length: 0,
                              corked: 0,
                              writelen: 0,
                              bufferedIndex: 0,
                              pendingcb: 0,
                              _maxListeners: 100,
                              _options: {
                              maxRedirects: 21,
                              protocol: 'http:',
                              method: 'GET',
                              agents: [Object],
                              auth: undefined,
                              family: undefined,
                              port: '',
                              agent: undefined,
                              pathname: '/cm',
                              _ended: true,
                              _ending: true,
                              _redirectCount: 0,
                              _redirects: [],
                              _eventsCount: 3,
                              _eventsCount: 7,
                              _maxListeners: 100,
                              outputData: [],
                              outputSize: 0,
                              writable: true,
                              destroyed: false,
                              _last: true,
                              sendDate: false,
                              _removedTE: false,
                              _contentLength: 0,
                              _hasBody: true,
                              _trailer: '',
                              finished: true,
                              _headerSent: true,
                              _closed: false,
                              socket: [Socket],
                              '\r\n',
                              agent: [Agent],
                              method: 'GET',
                              _ended: false,
                              res: null,
                              aborted: false,
                              parser: null,
                              host: 'undefined',
                              protocol: 'http:',
                              errno: -3008,
                              code: 'ENOTFOUND',
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                              2024-08-12 21:45:27.153 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------
                              2024-08-12 21:45:32.571 - info: admin.0 (407) <== Disconnect system.user.admin from ::ffff:192.168.178.240 javascript
                              2024-08-12 21:45:36.977 - info: mqtt.0 (509) Client [NSPanel_1] connected with secret 1723491936974_7775
                              2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
                              2024-08-12 21:45:37.084 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
                              2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
                              2024-08-12 21:45:37.085 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
                              2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^cmnd\.NSPanel_1_fb\..*/
                              2024-08-12 21:45:37.086 - info: mqtt.0 (509) Client [NSPanel_1] subscribes on "cmnd/NSPanel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NSPanel_1_fb\..*/
                              2024-08-12 21:45:37.285 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                              2024-08-12 21:45:37.286 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                              2024-08-12 21:45:37.287 - info: mqtt.0 (509) Client [NSPanel_1] publishOnSubscribe send all known states
                              • Armilar
                                Armilar Most Active Forum Testing @Karlson 0 last edited by Armilar
                                @karlson-0 sagte in SONOFF NSPanel Lovelance UI Rückgängig machen:
                                Das Problem liegt immer noch im falschen Script Parameter:
                                Im Result Connection String für MQTT (im NSPanelTs.ts Script) sollte:
                                mqtt.0.SmartHome.NSPanel_1.tele.RESULT
                                stehen...
                                Bitte erneut die:
                                • Einstellungen im Tasmota (MQTT)
                                • Objekte unter mqtt.0.SmartHome.NSPanel_1
                                • Einstellungen der mqtt.0. Instanz
                                senden.
                                Dein Problem liegt nach wie vor in der MQTT-Kommunikation...
                                  Karlson 0 @Armilar last edited by
                                  @armilar
                                  Bitteschön:
                                    Karlson 0 @Karlson 0 last edited by
                                    @karlson-0
                                    Hier das Ergebnis mit der Änderung tele.result:
                                    2024-08-12 22:12:45.360 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: TypeScript compilation successful
                                    2024-08-12 22:12:45.462 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.463 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.464 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                                    2024-08-12 22:12:45.465 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                                    2024-08-12 22:12:45.466 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.467 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.468 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.469 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.470 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.471 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.472 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.473 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.474 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.475 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.476 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.477 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.478 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.479 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.480 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.481 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.482 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.483 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.484 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.485 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.486 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.487 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.488 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.489 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.490 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.491 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.492 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.493 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.494 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.495 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                                    2024-08-12 22:12:45.496 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.497 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.498 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Error: Cannot find module 'dayjs'
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at require (node:internal/modules/helpers:179:18)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                    2024-08-12 22:12:45.499 - error: javascript.0 (458) script.js.common.NSPanelTs_ts: Config-Parameter: << config.panelRecvTopic - mqtt.0.SmartHome.NSPanel_1.tele.RESULT >> is not reachable. Please Check Parameters!
                                    2024-08-12 22:12:45.512 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: nodeJS must be at least v18.X.X. Currently: v14.5.0! Please Update your System! --> iob nodejs-update 18
                                    2024-08-12 22:12:45.513 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: setObjects enabled - create Alias Channels possible
                                    2024-08-12 22:12:45.517 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: weather alias for accuweather.0. already exists
                                    2024-08-12 22:12:45.524 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                                    2024-08-12 22:12:45.525 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    2024-08-12 22:12:45.528 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: No Updates for NSPanel available
                                    2024-08-12 22:12:45.835 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Desired TFT Firmware: 53 / v4.4.0
                                    2024-08-12 22:12:45.891 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Debug mode disabled
                                    2024-08-12 22:12:46.199 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                                    2024-08-12 22:12:46.199 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                                    2024-08-12 22:12:46.240 - warn: javascript.0 (458) Read-only state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has been written without ack-flag with value "[object Object]"
                                    2024-08-12 22:12:46.240 - info: javascript.0 (458) State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "string" but received type "object"
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: Start MQTT-Port-Check -------------------------------------
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- admin.0 - 8081
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- mqtt.0 - 1888
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.0 - 8001
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- samsung_tizen.1 - 8000
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: -- shelly.0 - 1882
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1888
                                    2024-08-12 22:12:47.852 - info: javascript.0 (458) script.js.common.NSPanelTs_ts: End MQTT-Port-Check ---------------------------------------```
                                    • Armilar
                                      @karlson-0
                                      Okay... schon besser:
                                      Die oberen dayjs-Meldungen sind erstmal irrelevant. Haben andere auch, kommen aktuell nur zum Start und hindert den Start des NSPanels auch nicht. Kommt nicht bei allen Usern - ist aber ein Thema außerhalb des Scriptes zwischen JS-Adapter/JS-Controller... also erstmal ignorieren...
                                      "mqtt.0.SmartHome.NSPanel_1.tele.INFO2" ist vorhanden - dennoch kommt diese Nachricht:
                                      Kannst du mal den dritten Reiter aus der MQTT-Instanz posten
                                      EDIT:
                                      Wir müssen also nur noch dieses Problem lösen:
                                      Danach läuft das Panel...
                                      EDIT2: Auch hier würde @TT-Tom wieder anmerken, dass da der Datenpunkt "tele.RESULT" im MQTT bei dir nicht vorhanden ist.
                                      Sieht so aus, als würde der Berry-Driver im Tasmota nicht existieren...
                                      K 1 Reply Last reply Reply Quote 2
                                        @armilar
                                        Bitteschön:
                                        • Armilar
                                          @karlson-0
                                          Siehe Vorherige Nachricht... Bitte den Berry-Driver nochmal installieren...
                                          Danach auf jeden Fall Tasmota neu starten
                                            @armilar
                                            @Homoran
                                            @Samson71
                                            @Thomas-Braun
                                            @TT-Tom
                                            Es läuft endlich, vielen lieben Dank an euch.
                                            Armilar 1 Reply Last reply Reply Quote 1
                                            2380
