    4. [Adapter] cloudfreie Auslesung von Deye-Invertern
      A Former User @Rene55 last edited by
      @rene55
      Ok, mach ich morgen Abend… vielleicht hat ja noch einer den Fehler..
      • JB_Sullivan
        JB_Sullivan last edited by
        Habe heute auch die 0.15 aufgespielt und danach diese Meldung erhalten. Die DP`s scheinen aber sonst wie gehabt zu funktionieren.
        	12844	2024-07-30 18:01:49.461	error	TypeError: Cannot read properties of undefined (reading 'register') | TypeError: Cannot read properties of undefined (reading 'register') at Deyeidc.onData (C:\ioBroker\GLT\node_modules\iobroker.deyeidc\main.js:166:11) at Socket.<anonymous> (C:\ioBroker\GLT\node_modules\iobroker.deyeidc\main.js:152:10) at Socket.emit (node:events:519:28) at addChunk (node:internal/streams/readable:559:12) at readableAddChunkPushByteMode (node:internal/streams/readable:510:3) at Readable.push (node:internal/streams/readable:390:5) at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
        deyeidc.0
          A Former User @Rene55 last edited by A Former User
          @rene55
          Hab nochmal geupdated, hier das komplette log:
          2024-07-30 19:34:01.818  - info: deyeidc.0 (27892) Got terminate signal TERMINATE_YOURSELF
          2024-07-30 19:34:01.821  - info: deyeidc.0 (27892) terminating
          2024-07-30 19:34:01.822  - info: deyeidc.0 (27892) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-07-30 19:34:02.323  - info: deyeidc.0 (27892) terminating
          2024-07-30 19:34:02.364  - info: host.iobroker instance system.adapter.deyeidc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-07-30 19:34:03.616  - error: deyeidc.1 (27898) TypeError: Cannot read properties of undefined (reading 'register') | TypeError: Cannot read properties of undefined (reading 'register')
              at Deyeidc.onData (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:166:11)
              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:152:10)
              at Socket.emit (node:events:520:28)
          2024-07-30 19:34:05.743  - info: host.iobroker instance system.adapter.deyeidc.0 in version "0.0.15" started with pid 28018
          2024-07-30 19:34:06.049  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708,1044933,1522909","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736,41801,43259","Newprio_realtime_bps":"4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165,601,4247","Newprio_high_bps":"39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365,40277,37998","Newprio_default_bps":"1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206,923,1014","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-07-30 19:34:06.548  - debug: deyeidc.0 (28018) Redis Objects: Use Redis connection: 10.10.2.10:6379
          2024-07-30 19:34:06.575  - debug: deyeidc.0 (28018) Objects client ready ... initialize now
          2024-07-30 19:34:06.576  - debug: deyeidc.0 (28018) Objects create System PubSub Client
          2024-07-30 19:34:06.578  - debug: deyeidc.0 (28018) Objects create User PubSub Client
          2024-07-30 19:34:06.832  - debug: deyeidc.0 (28018) Objects client initialize lua scripts
          2024-07-30 19:34:06.840  - debug: deyeidc.0 (28018) Objects connected to redis: 10.10.2.10:6379
          2024-07-30 19:34:06.858  - debug: deyeidc.0 (28018) Redis States: Use Redis connection: 10.10.2.10:6379
          2024-07-30 19:34:06.864  - debug: deyeidc.0 (28018) States create System PubSub Client
          2024-07-30 19:34:06.865  - debug: deyeidc.0 (28018) States create User PubSub Client
          2024-07-30 19:34:06.871  - debug: deyeidc.0 (28018) States connected to redis: 10.10.2.10:6379
          2024-07-30 19:34:07.443  - info: deyeidc.0 (28018) starting. Version 0.0.15 in /opt/iobroker/node_modules/iobroker.deyeidc, node: v22.5.1, js-controller: 6.0.9
          2024-07-30 19:34:07.469  - debug: deyeidc.0 (28018) IP address [10.1.1.100] seems to be valid.
          2024-07-30 19:34:07.470  - info: deyeidc.0 (28018) Retrieving data from the inverter will be done every 60 seconds
          2024-07-30 19:34:07.470  - debug: deyeidc.0 (28018) checkUserData is ready
          2024-07-30 19:34:07.470  - debug: deyeidc.0 (28018) try to connect . . .
          2024-07-30 19:34:07.477  - debug: deyeidc.0 (28018) Connected to server
          2024-07-30 19:34:07.650  - debug: deyeidc.0 (28018) Response: {"register":1,"modbus":{"type":"Buffer","data":[1,3,44,0,4,1,0,2,1,50,50,48,50,50,52,49,52,56,56,0,1,0,0,18,12,7,0,0,0,1,18,2,7,0,0,11,184,0,0,1,1,0,75,0,0,0,60,59]}}
          2024-07-30 19:34:08.243  - debug: deyeidc.0 (28018) Response: {"register":2,"modbus":{"type":"Buffer","data":[1,3,64,0,4,0,13,0,0,0,0,20,106,0,0,0,13,0,0,0,0,0,0,20,106,0,0,0,0,0,0,9,46,0,0,0,0,0,0,0,0,0,0,19,136,0,0,0,0,0,0,0,0,0,0,0,0,6,54,0,0,0,0,0,0,21,54,117]}}
          2024-07-30 19:34:08.469  - debug: deyeidc.0 (28018) Response: {"register":3,"modbus":{"type":"Buffer","data":[1,3,8,1,97,0,45,0,0,0,0,136]}}
          2024-07-30 19:34:08.564  - debug: deyeidc.0 (28018) Response: {"register":4,"modbus":{"type":"Buffer","data":[1,3,8,10,190,7,8,20,80,18,142,34]}}
          2024-07-30 19:34:08.579  - debug: deyeidc.0 (28018) Data reception for 4 registersets completed
          2024-07-30 19:34:08.580  - debug: deyeidc.0 (28018) [computeData]  {"value1":"DV1","value2":"DC1","key":"DP1","name":"DC Power PV1","unit":"W","factor":0,"values":"DV1*DC1"}
          2024-07-30 19:34:08.581  - debug: deyeidc.0 (28018) [computeData]  {"value1":"DV2","value2":"DC2","key":"DP2","name":"DC Power PV2","unit":"W","factor":0,"values":"DV2*DC2"}
          2024-07-30 19:34:08.581  - debug: deyeidc.0 (28018) [computeData] ResultJson: [{"key":"DP1","value":"158.85","unit":"W","name":"DC Power PV1"},{"key":"DP2","value":"0.00","unit":"W","name":"DC Power PV2"}]
          2024-07-30 19:34:08.600  - debug: deyeidc.0 (28018) [watchStates] set to Power_Set
          2024-07-30 19:34:09.059  - info: tuya.0 (10496) bf51aaad135aa1ced0dhmw: Error on Reconnect (5): connect EHOSTUNREACH 10.1.12.101:6668
          2024-07-30 19:34:10.353  - info: influxdb.0 (7447) Store 1001 buffered influxDB history points
          2024-07-30 19:34:12.050  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708,1044933","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736,41801","Newprio_realtime_bps":"10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165,601","Newprio_high_bps":"38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365,40277","Newprio_default_bps":"985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206,923","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-07-30 19:34:18.052  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223,1298708","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672,22736","Newprio_realtime_bps":"3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709,2165","Newprio_high_bps":"21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081,18365","Newprio_default_bps":"2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882,2206","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-07-30 19:34:19.827  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Error on Reconnect (7): connect EHOSTUNREACH 10.1.5.86:6668
          2024-07-30 19:34:21.228  - info: linux-control.0 (2133) getting data from Influxdb (10.1.1.4:22)
          2024-07-30 19:34:22.803  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Connect locally to device
          2024-07-30 19:34:22.803  - info: tuya.0 (10496) bf36cda59741f65a3evbfd Init with IP=10.1.5.86, Key=Y''bS^'ldE@_g'}d, Version=3.3
          2024-07-30 19:34:22.833  - info: tuya.0 (10496) bf36cda59741f65a3evbfd: Error on Reconnect (1): connect EHOSTUNREACH 10.1.5.86:6668
          2024-07-30 19:34:24.017  - info: host.iobroker instance system.adapter.oilfox.0 in version "4.3.0" started with pid 28087
          2024-07-30 19:34:24.432  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1817837,921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570,1705223","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"47909,27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254,48672","Newprio_realtime_bps":"1609,3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773,7709","Newprio_high_bps":"45132,21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064,40081","Newprio_default_bps":"1168,2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417,882","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-07-30 19:34:25.255  - info: linux-control.0 (2133) successful received data from Influxdb (10.1.1.4:22)
          2024-07-30 19:34:26.003  - info: oilfox.0 (28087) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.oilfox, node: v22.5.1, js-controller: 6.0.9
          2024-07-30 19:34:27.653  - info: oilfox.0 (28087) Terminated (NO_ERROR): Without reason
          2024-07-30 19:34:28.179  - info: host.iobroker instance system.adapter.oilfox.0 having pid 28087 terminated with code 0 (NO_ERROR)
          2024-07-30 19:34:30.046  - info: tr-064.0 (14051) {"NewTotalNumberSyncGroups":"2","NewSyncGroupName":"sync_dsl","NewSyncGroupMode":"VDSL","Newmax_ds":"13258125","Newmax_us":"5185625","Newds_current_bps":"1492501,1817837,921663,1523785,1601157,1750389,763912,1670101,1740643,1314488,1035425,1571816,1567295,1601588,1011045,1394843,1451758,1807280,531676,1771570","Newmc_current_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0","Newus_current_bps":"52177,47909,27837,49992,45351,53297,27920,41739,58945,27807,42143,39223,48087,54020,42618,33404,45628,58028,32142,51254","Newprio_realtime_bps":"14472,1609,3840,10254,4099,12227,2885,7778,18734,3522,1754,1541,7413,10505,4256,3176,5461,20468,3666,7773","Newprio_high_bps":"36303,45132,21802,38753,39288,39646,19089,33012,39310,20130,38469,36282,33646,29000,37725,29695,39099,36477,25972,43064","Newprio_default_bps":"1402,1168,2195,985,1964,1424,5946,949,901,4155,1920,1400,7028,14515,637,533,1068,1083,2504,417","Newprio_low_bps":"0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"}
          2024-07-30 19:34:33.132  - error: deyeidc.0 (28018) TypeError: Cannot read properties of undefined (reading 'register') | TypeError: Cannot read properties of undefined (reading 'register')
          ^C
          Auch die Instanzen geloescht, dann nur eine neu angelegt, die Konfig importiert, aber gleicher Fehler...
          Also wenn das Nachvollziehbar ist, dann sollte der Fehler doch zu finden sein.. ?
          • Rene55
            Rene55 @Guest last edited by
            @ilovegym Ich habe heute nochmal geforscht. Kannst du bitte mal den Adapter direkt von Github installieren?
              @rene55
              Siehe da, kaum macht man's richtig... :). die Github Version geht ohne Fehler!
              Danke!!
              • Rene55
                @ilovegym Super. Ich hab ja auch dran gearbeitet. 😊
                Wenn keine Fehler mehr auftreten mache ich morgen die 0.0.16
                  MPF last edited by MPF
                  Moin,
                  ich habe komischerweise jetzt die Adapterversion 0.1.0 drauf und diese Warnungen im Log :
                  • Rene55
                    @mpf Ist nicht komisch, 'is a feature'. Der Adapter prüft jetzt, ob der Datenpunkt - in dem Fall "DV1" auch vorhanden ist. Eventuell bei den Coils mal nachsehen oder bei den Berechnungen die Formel prüfen.
                      MPF @Rene55 last edited by
                      @rene55 und die Version 0.1.0 ist so korrekt ?
                      • Rene55
                        Rene55 @MPF last edited by
                        @mpf Ich denke ja.
                          MPF @Rene55 last edited by MPF
                          @rene55 sagte in [Adapter] cloudfreie Auslesung von Deye-Invertern:
                          @mpf Ich denke ja.
                          ist ja aktueller als 0.0.16.....
                          einwandfrei
                          Berechnung so korrekt ?
                          Wo finde ich den DP "DV1" ?
                          Oder einfach löschen, wenn ich den nicht benötige ?
                          • Rene55
                            @mpf Die Formel sieht doch gut aus. Der "DP1" wird bei der nächsten Datenabholung angelegt.
                              JoeM last edited by
                              Hallo Rene, hallo Forum,
                              bei den Versuchen an gewisse Daten von meiner Solaranlage zu kommen, bin ich über diesen IOBroker Adapter gestolpert und habe ihn gleich installiert. Einrichten mit IP und Seriennummer war total einfach. Dafür also auf alle Fälle schonmal Danke Rene55.
                              Ich habe den SUN-5K-SG03LP1-EU und nachdem ich einige JSON Dateien von verschiedenen Geräten getestet habe, erhielt ich mit der SUN2000.json erste brauchbare Ergebnisse. Ich habe auch schon unnötige Datenpunkte aus dem Setting heraus gelöscht.
                              Jetzt stellt sich mir nur die Frage, wo finde ich Informationen welche Register welche (sinnvollen) Daten enthalten, damit ich evtl. das Setting erweitern kann?
                              Ich danke Euch schon einmal für Eure Hilfe.
                              • Rene55
                                Rene55 @JoeM last edited by
                                @joem Hallo, ja freut mich, dass der Adapter bei dir läuft.
                                Bei den Registern für die "großen" Wechselrichter war ich auch auf Input von eifrigen Nutzern angewiesen.
                                Gibt denn das Handbuch oder eine technische Anleitung keine Hinweise auf die verwendeten Register?
                                  Fichte last edited by
                                  @Rene55
                                  Ich habe das selbe Problem wie MPF.
                                  Ich weiss aber nicht woran es liegt.
                                  HAbe schon alles gecheckt und auch neu Installiert.
                                  Evtl. Sehe ich den Wald vor Lauter bäumen nicht.
                                  Was ist das problem?
                                  @MPF Hast du schon eine Lösung?
                                  Liebe Grüße
                                  • Rene55
                                    @fichte Das bedeutet einfach, dass er zur Berechnung von Werten die Datenpunkte 'DV1' und 'DV2' haben möchte. Werden diese beiden Datenpunkte denn von den Coils erstellt/befüllt?
                                    Ansonsten mal schauen, was in den 'Berechnungen' drin steht und ob du die Berechnung überhaupt brauchst.
                                      Fichte @Rene55 last edited by Fichte
                                      @rene55
                                      Guten Morgen Rene
                                      Danke für deine Antwort.
                                      In meiner Berechnung steht dies ->
                                      Woran sehe ich das die Daten Erstellt/Befüllt werden?
                                      Die letze änderung war am 17.04.2024
                                      • Rene55
                                        Rene55 last edited by Rene55
                                        @fichte Schau mal in den Objektbaum, da wo alle Werte abgelegt werden. Da sollten sich (neben vielen anderen Werten ) auch 'DV1', 'DV2', DC1' und 'DC2' finden lassen. Wenn die nicht da sind, müssen wir weiter forschen.
                                        Sorry falsch gelesen:
                                        BTW: 17.04.2024 ist auch schon ein bissl her. Das heißt aber auch, dass keine neuen Werte abgeholt werden.
                                          Meintre 0 @Fichte last edited by
                                          @fichte
                                          Ich hatte auch diesen Fehler! Habe einfach die Berechnungen gelöscht und schon war der Fehler weg.
                                          Solltest Du die Berechnungen brauchen, mußt Du nachfolgendes kontrollieren:
                                          1. Gibt es unter Key im Objektbaum überhaupt alle Punkte "DV1" usw.
                                          2. Hast Du auch zwei Stränge am Deye angeschlossen? Bei mir fehlt der zweite Strang, dadurch ist wahrscheinlich der Fehler bei mir aufgetreten.
                                          Viel Spaß beim Überprüfen
                                          Gruß Meintre
                                            @Meintre-0
                                            Ich habe die Berechnung raus genommen und der Fehler ist Tatsächlich weg 👍
                                            @Rene55
                                            Das Stimmt, die Werte werden seid dem 17.04 nicht meh geholt 🙄
                                            Woran kann dies liegen? Fehler habe ich sonst keine.
                                            Das sind meine Register
                                            Und hier meine Spulen
                                            1.0k
                                            81.1k
                                            1158
                                            368138
